suzu
Salut, am facut o scanare cu Vag azi si am gasit asa:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
Ma poate ajuta cineva ?
Multumesc !
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Possible Causes
  • Air Intake System leaking
  • Fuel Supply faulty
  • Injector(s) faulty
  • Ignition Cable(s) and/or Spark Plug(s) faulty
  • Ignition Coil(s) faulty
  • Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
  • Camshaft Position Sensor (G40) faulty
Possible Solutions
  • Check Misfire Recognition
  • Check Air Intake System
  • Check Fuel Supply
  • Check Injector(s) and Injector Sealing
  • Check Ignition Cable(s) and Spark Plug(s)
  • Check Ignition Coil(s)
  • Check Exhaust Gas Recirculation (EGR) Valve (N18)
  • Check Camshaft Position Sensor (G40)
Special Notes
This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cy
16685/P0301/000769 - Cylinder 1 Misfire Detected
Possible Causes
  • Ignition system
  • Fuel injectors
  • Fuel pressure
  • Running out of fuel
  • EVAP canister purge valve
  • Evaporative emission system
  • Low compression
  • Base engine problems
  • Controle Module damaged
Special Notes
This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
Multumesc liviuplaton din cate vad eu aici e cam nasol. Ce ma sfatuiti sa verific prima data ?
Bujii si fise :)
Daca sint de pe vremea lui Decebal ar fi bine sa le schimbi...
Aer fals pe admisie si furtune de vacum...
Eventual compresie proasta...
Cred ca scapi dupa primul pas...
fa rocada intre bobina cil 1 si oricare alta din celelalte si daca eroarea se muta....e clar
Bujiile sunt schimbate de curand, nu cred ca e de la ele.
O sa incerc prima data sa schimb bobinele intre ele, poate e de la bobina.
Multumesc !
Am avut parte de bujie proasta de noua...misfire si s-a lasat cu schimbare...
protection1988
salutare tuturor
am un vw passat din 2008.zilele trecute am montat pe masina o navigatie rns 510 de la witcon, de pe o skoda rs.cand am intrat in computerul de bord la sectiunea audio, mi-au aparut toate dotarile navigatiei, navi, tv, dvd..etc. cand am vrut sa ies din sectiunea audio nu am mai putut. a trebuit sa scot cablurile de alimentare de la baterie sa resetez totul. acum nu imi merg geamurile electrice sa le cobor sau urc de la a doua treapta.ma poate ajuta cineva cu un sfat?
de asemenea vreau sa va intreb cum pot sa schimb sigla navigatiei care apare cand se aprinde,din skoda in vw?dar lunimile navigatiei de la butoane din verde in rosu?
va multumesc!
unde as putea sa gasese un soft de navigatie rns 510 witcon pe card?
Incearca sa cauti aici un topic care trateaza problema ta.
La ultima intrebare iti raspund eu: trebuie schimbate ledurile verzi cu unele rosii.
E o replica dupa RNS510....
legat de geamuri - coboara geamul si tine apasat cateva secunde pe buton - in jos, Repeta operatiunea, in sus. Dupa aia o sa iti mearga functia de confort,
Salut.ma poate ajuta cineva cu urmatoarele erori?tin s aprecizez ca am facut modificarea la frana pentru cerc complet.multumesc anticipat
Sunday,01,July,2012,14:03:37:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7P038920 Mileage: 81580km/50691miles
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 03C 906 024 AH HW: 03C 906 024 K
Component: MARELLI 4HV G 0883
Revision: --H06--- Serial number: VWZ7Z0G8017062
Coding: 0004071
Shop #: WSC 00028 028 00001
VCID: 64CDDD34A740A0E
28793 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 7
Mileage: 80833 km
Time Indication: 0
Date: 2000.01.01
Time: 16:47:36
Freeze Frame:
Bin. Bits: 00000000
Load: 0.0 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 45.0°C
Absolute Pres.: 999.6 mbar
RPM: 0 /min
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
VCID: 3F8732586E66A36
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6ED9BF1C798C1AE
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006568603
Coding: A08D0F2700041519471400141400000000097B0F5C0001
VCID: 6BDFB6084A9EEF6
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 211206 020 0501
Coding: 00038805
Shop #: WSC 00028
5 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 248
Mileage: 81569 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
00987 - Lamp for Brake Light; Left (M9)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 248
Mileage: 81569 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 248
Mileage: 81569 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 13
Reset counter: 249
Mileage: 81569 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 249
Mileage: 81569 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0ZJXFM
Coding: 0013111
VCID: 3D7B4850646AB16
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
VCID: 74EDAD7417A030E
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 863 HW: 1K0 920 863
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8017062
Coding: 0003103
Shop #: WSC 10169 599 96651
VCID: E8D54904DB6844E
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 150107F1001188
Coding: 3D3F034007000002
VCID: 2F676218BE06536
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0987
Coding: 0000180
VCID: 387559444B4894E
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
VCID: 346D6D74572070E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 98900A005103487F2D04840560084F03E0FCA0
VCID: 830F7EA8C20E876
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000180
VCID: 39735C4070428D6
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 T
Component: Radio GR0 020 0023
Revision: 0002006S Serial number: VWZ2Z2G2077711
Coding: 0040400
VCID: 37775A7846569B6
01044 - Control Module Incorrectly Coded
000 - -
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0913
Coding: 0000144
Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End ---------------------------------------------------------------------
Si eroarea de pe centrala care e ?
Maximum speed, avoid waranty si un ":)"?
post-14028-0-22075400-1341154069_thumb.j
Am si eu niste erori care mi-au aparut in ultimele saptamani si poate are cineva cu mai multa experienta niste timp sa-mi explice posibilele cauze (am cautat si eu putin pe net, dar sunt o gramada si nu stiu de unde sa incep).
Povestea pe scurt: am un 1.6 16v cod motor AZD si in urma cu 2 saptamani mi-a aparut un "EMISSIONS WORKSHOP" (viteza a 4a, ~100km/h intr-o accelerare putin mai nervoasa) si martor de check engine aprins. In momentul respectiv aveam cam jumate de rezervor de Petrom 95. Mi-a spus un prieten ca desi pe capacul de la rezervor scrie 95/98 ar fi bine sa-i dau 98 pentru ca benzina de la noi nu e tocmai chiar asa de buna.
La scanare aveam missfire pe cilindrul 2 si 4 parca. Am sters erorile, am alimentat cu Petrom 99 si in urmatoarele 2 saptamani de mers pe la RAR, inmatriculari si in general prin Bucuresti lejer nu a mai aparut problema si am zis clar ca era de la benzina.
In weekend am fost pana la mare si undeva pe autostrada, la mers relativ lejer (viteza a 5a, 110-120km/h) a aparut iar "EMISSIONS WORKSHOP" si martor check engine (pana in acest moment consumasem cam tot Petrom-ul de 95 inainte sa umplu iar cu 99) am scanat erorile de pe engine si am ce vedeti mai jos. Am inteles de pe net ca s-ar putea sa fiu nevoit sa schimb sonda/ele lambda; eu ma gandeam deja sa schimb bujiile pentru ca nu stiu cand au fost schimbate ultima data (posibil si de aici sa fi avut missfire pentru ca am vazut pe forum ca sunt multi posesori de AZD care merg cu benzina de 95)
Control Module Part Number: 036 906 034 CN
Component and/or Version: MARELLI 4MV G 3957
Software Coding: 00031
Work Shop Code: WSC 00329
Additional Info: WVWZZZ1JZ2D009821 VWZ6Z0A3439024
VCID: 60C5D124CF67
3 Faults Found:
16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
P0133 - 35-10 - - - Intermittent
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-10 - - - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
Readiness: 0000 0001
Sterge-le si vezi ce mai apare...dar baga numai benzina buna sa te lamuresti...vezi ca e un topic numai cu AZD :)
Stiu ca e un topic numai cu AZD (l-am si citit :) ), de-asta am intrebat aici la erori pentru ca am pus benzina buna (si intr-adevar, n-am mai avut missfire) dar acum au aparut astea intr-o veselie (am primit EMISSIONS WORKSHOP de vreo 4 ori pe Constanta - Bucuresti la viteze mai mari (120, 130), la plecare de pe loc din parcare si asa mai departe). In ceea ce priveste masina, nu da vreun semn ciudat - adica sta ok la ralanti, nu tuseste, nu se ineaca, doar apar erorile astea.
Citi km are "tigaia" ? :)
Daca are peste 120-130k stringe bani de o sonda 1
Asta daca nu ai avut bafta de benzina de 90 la pret de 98 :)
Benzina am pus de la vreo 3 Petrom diferite si dupa cum ziceam, missfire n-am mai avut. In schimb masina are 153k acum (cel putin pe bord, reali habar n-am, dar am o vaga senzatie ca trece de 200-250k). Chiar speram sa fie de la altceva problema, dar cand am vazut 3 erori si toate cu lambda cam asa ma asteptam si eu.
a aparut si mie eroarea ceasta , am incercat sa o sterg se sterge dar dupa cateva minute reapare
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Control Module Part Number: 3C0 959 799 H HW: 3C0 959 799 H
Component and/or Version: 02 KESSY PQ46 R 070
Software Coding:
Work Shop Code: WSC 05311 000 00000
Additional Info: 1K0951605D LIN BACKUP HORN H08 9001 NGS n.mounted
Additional Info: IRUE n.mounted
VCID: 3E773ACB176E
1 Fault Found
01134 - Alarm Horn (H12)
000 - - - Intermittent
Freeze Frame
Fault Priority: 4
Fault Frequency: 3
Reset counter: 210
Mileage: 124080 km
Time Indication: 0
Date: 2102.14.13
Time: 19:41:14
Verifica siguranta, conectori si fire si daca acestea sunt ok- atunci este de vina alarma in sine
Lipsa comunicare cu goarna, posibil acumulatori scursi si goarna defecta.
http://wiki.ross-tec...90/P0106/000262
Baieti,daca am fi eroarea asta sa inteleg ca as cam avea de verificat:
-cablajul la senzor (senzorul deja e verificat)
-pierdere de aer pe admisie sau pe evacuare
-si modulul acela (despre care este vorba,stie cineva un cod pentru el sau ce piesa reprezinta mai exact) ?
Masina da in nas in treptele 1-2-3 de la 70 km/h in sus nu mai am intreruperi
Am mai gasit urmatorul raspuns pe un site din afara :The 1.2 engine has a timing chain and the tensioners wear and make the chain loose. The chain can then jump a tooth or two and make the cam timing go out. If it jumps too much the valves will be damaged.
If this is the case fit new tensioners ( I think there are 2) and time up the chain, the chain should be good for the life of the engine - deci sa verific si lantul de distributie?
Modificat de Adrian_S
Seat Leon 2008 : sonda lambda S1 si S2 ..Short to Ground ..dupa ce a fost agata a 2 sonda si rupte firele a aparut eroarea.reparat firele mers cu ea destul de mult a aparut eraoarea ca ar da la masa ambele sonde! Are cineva schema electrica sa pot urmari firele / masura pana in ECU sondele,si ce valori ar trebui sa dea.mersi PS cumparat ambele sonde si la fel face!
Modificat de bigstar
Am o interfata 409.1 kkl chinezeasca :D = CLONA = INTERZISA
sal. vreau sa cumpar si eu o astfel de interfata. am un audi a6 din 2002 si un pasat din 2004. o fi compatibila cu cele doua masini? Multumesc.
  • Aerofan pinned this topic
    • Hayate
