suzu
Revin cu eroarea de care nu scap: 18056
Sigurantele sunt ok ce mai trebuie verificat si cum?
error code : 18056 P1648
com Control Data bus fault
and Data Bus Powertrain Malfunction
Additional info on the error codes. Intermittent
Possible symptoms:
Disturbances in behavior (switching shock, jerky rotation)
No ESP
No ASR
No MSR
Possible causes:
Fault in the data cables to the controller or automatic gearbox. ABS control unit
Fault in system: Automatic transmission, respectively. ABS
Possible solutions:
Check the terminating resistor in the engine control module (VAG special tools required)
Terminating resistor gives incorrect value: replace engine control module
Terminating resistor gives good value: Check flowcharts
Additional info:
The ECU talks to all control modules via the CAN databusaansluiting. All these control modules with two twisted inelkaar databuskabels (High and Low) are linked together and exchange information. If that databuskabels information is missing (fails) is shown on each line module as fault appears. A terminating resistor in the motor control unit ensures that the data bus can operate error-free.
Mersi, o sa merg la reprezentanta ca ma depaseste...
Salut.
Ce inseamna aceasta eroare?
008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
P2293 - 002 - Lower Limit Exceeded - Intermittent
Alta eroare: 16845 - fuel level sensor circuit implausible signal intermittent
Ce inseamna? mersi
Senzor nivel combustibil
Ok, nu ar trebui sa nu mai indice bine si in bord? unde il gasesc pozitionat?
In rezervor , pe pompa de combustibil.
Buna ziua, sunt un coleg de forum mai vechi dar nu am mai intrat de mult pe aici, am si eu o problema cu radio-ul masini si nu stiu sa-i dau de cap!
Mai exact am avut pe masina pus un pioneer cu mufa adaptoare pentru el, mufele originale erau intacte, asa ca mi-am luat un Blaupunkt Freiburg CD34 si l-am montat pe masina fara probleme, mufele originale fiind exact pentru el....a functionat vreo 2-3 zile ok, pana ieri cand m-a mancat palma si i-am dat sonorul din scala lui mai mare si a murit totul ....am suspectat sigurantele....le-am verificat si surpriza la pozitia 20 este lipsa siguranta...nici macar contacte nu are unde sa bagi siguranta(parca doar unul :shock: )...restul sunt bune...totul functioneaza corect pe partea electrica a masinii!!
Am luat cass-ul vechi sa-l montez, am suspectat ca s-a defectat radio cd-ul ....... caruia i-am verificat si lui siguranta si, era in regula!
Cand am facut conexiunile vechi sa pun pioneer-ul .....surpriza nu functioneaza nici el ...... nimic zero!
Azi dimineata am luat Blaupunkt-ul si l-am montat pe alta masina si functioneaza perfect !
Asa ca m-am blocat si nu stiu ce poate avea...am mai citi pe undeva ca radio-ul trece prin ECU sau asa ceva....dar nu prea am inteles ce este de facut!
Asa ca va cer ajutorul poate va pricepe-ti mai bine, sau cunoaste-ti pe cineva care stie mai bine!
Cu stima.
Florin A.
0729980207
Modificat de nmbcatega
F l o r i n
Florin, in primul rand despre ce masina vorbim, ce an, ce motorizare ?
Salut ... ma puteti ajuta si pe mine la un golf V 1.6 FSI ... da urmatoarele erori:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - MIL ON
motorul merge trepidat ...
multumesc mult!
schimba bobina de la cil 4 cu cea de la 3 si daca iti da erori pe cil.3 schimbi bobina
cu alta noua
Sigur e bobina de pe 4
s-a schimbat bobina 4 ... s-a pus un Beru ... si s-a rezolvat problema ... Multumesc de raspuns Turbocip si DragosR
va rog sa imi spunetisi mie inseamna erorile de mai jos si cum le pot remedia
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
Lipituri reci pe broastele de la usile spate stg si dr.
Modificat de Al Bundy
multumesc Al Bundy si revin cu o alta scanare la un passat b5 din 2002 pe care va rog sa ma ajutati sa o interpretez si sa o rezolv
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 EK
Component: 1,9l R4 EDC 0000SG 1367
Coding: 00002
Shop #: WSC 00028
VCID: 64C3A8A3DECB
WVWZZZ3BZ2P037085 VWZ7Z0A3723158
5 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
18027 - Glow Plug Relay (J52): Open or Short to Ground
P1619 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1328
Coding: 04255
Shop #: WSC 00028
VCID: 2545F5A79571
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0004
Coding: 17000
Shop #: WSC 00028
VCID: 2647F2ABE877
3 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
01273 - Fresh Air Blower (V2)
00792 - A/C Pressure Switch (F129)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 01
Coding: 12353
Shop #: WSC 00028
VCID: 2341EBBF9B45
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 806 A
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05115
Shop #: WSC 00012
VCID: 1F49E74FB72D
3 Faults Found:
01316 - ABS Control Module
01336 - Data Bus for Comfort System
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0EB54F39A33
4 Faults Found:
01331 - Door Control Module; Driver Side (J386)
End ---------------------------------------------------------------------
eu am sters erorile dar tot a ramas :
49-00 - No Communications
cum o pot remedia?unde sa verific?unde este acest modul?
si sa mi spuneti daca am procedat corect daca le am sters multumesc anticipat
Modificat de bor@
Fire intrerupte sau Centrala defecta ,
Verifici jos la picioare , partea soferului.
Sub mocheta.
am verificat jos la picioare si este uscat, firele sunt ok. acum o sa dau fata de prtiera jos la sofer sa vad daca gasesc ceva in neregula acolo.dar problema e ca nu pot sa dau fata de tabla jos pt ca nu imi functioneaza geamurile. astept pareri
Modificat de bor@
Daca firele sunt ok si ai toate tensiuniule de alimentare necesare, atunci pune un alt modul de confort.
Ai tras de ele ?
Poate doar la ochi par bine .
De obicei acolo este problema sau apa in CCM.
le am verificat pe toate amanuntit si au si tensiune; singura solutie e sa incerc cum a zis Al Bundy sa schimb un alt modul pt proba.multumesc mult si o sa revin sa va zic ce am facut.
Arata bine. Deci sa inteleg ca se acceseaza prin browserul smartphone-ului prin conexiunea wifi ? Fara interfata si alte cele ?... eu nu am inteles exact cum va functiona...
Modificat de MariusAP
  • Aerofan pinned this topic
    • R Z F
