suzu
Salut, as vrea sa stiu cate ceva despre codurile urmatoare de eroare. in speciale cele de pe engine si CAN Gateway .Este o masina de care sunt interesat si ma intereseaza cum si cat de grave sunt problemele de mai jos.
VAG-COM Version: Release 607.3-UD
Thursday,10,March,2011,18:24:04
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN Number: WVWZZZ1JZ2P046723
Address 01: Engine
Part No: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 00028
WVWZZZ1JZ2P046723 VWZ7Z0A4253079
13 Faults Found:
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 00028
No fault code found.
Address 08: Auto HVAC
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 00028
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-10 - Faulty - Intermittent
Address 15: Airbags
Part No: 6Q0 909 605 F
Component: 02 AIRBAG VW6 0101 0004
Coding: 12338
Shop #: WSC 00028
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 19: CAN Gateway
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 46: Central Conv.
Part No: 1C0 959 799 B
Component: 1D Komfortger
Engine:
Probleme turbo(presiune mare, N75,Diverter Valve)
Missfire pe toti cilindrii (posibil sa fie remediata odata ce ai auzit-o pornita si mergea rotund)
Relanti peste specificatii.
Comunicatia cu ABS intrerupta
CAN:
Nu comunica ABS
vad ca pe abs nu exista eroare , deci este posibil ca erorile de pe engine si can sa fie mai vechi.
sterge-le si vezi ce reapare ....
verifica furtune/tubulatura/turbo
Modificat de Turbocip
Da , asta mi se pare ciudat si mie motorul merge rotund si nu are fluctuati la turatie suna bine nu tacane nu se simpte ca tremura. Posibil sa fie dv-ul spart si care o sa il inlocuiesc. erorile le-am sters am dat o tura cu masina si dupa acea le-am copiat. Oricum mai multe o sa vb in aria de 1.8 t deoarece masina o sa o cumpar fiind la un pret foarte bun.
Multumesc pentru raspuns!
am verificat din nou senzorul l-am miscat dar degeaba tot imi apare eroarea ,pe cealalta parta am gasit o mufa care nu stiu de unde e ,am atasat si o poza cu el ,
post-7411-0-31841300-1299930798_thumb.jp
Salutare . am facut si eu o scanare in urma cu vreo saptamana cu Vag-Com-ul si am descoperit urmatoarele erori :
01262 - Solenoid Valve for Boost Pressure Control (N75)
26-10 - Output Open - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: N/A
Ce-a de-a doua am rezolvat-o cu schimbarea termostatului si a sondei de temperatura (G62) -ul .
Prima am inteles ca tine ori valva aia (n75) ori de tubulatura. Vorbesc si eu din ce am mai citit pe forum pana acum . Ma poate ajuta si pe mine cineva cu o informatie , mai exact cum as putea remedia problema . Multumesc anticipat !
As vrea sa va intreb cum se poate activa functia de inchidere automata usi la un golf4 din vagcom?ms
  • Administrator
Probabil ai vrut sa spui "incuiere automata"...
Control module coding (> MY 2001)
Select 46 (Comfort System)
Coding -> Function 07
Central locking (2-power windows):
00256 - Selective unlocking
00257 - Unlocking of all doors
Central locking (2-power windows and memory):
00258 - Selective unlocking
00259 - Unlocking of all doors
Central locking (4-power windows):
04096 - Selective unlocking
04097 - Unlocking of all doors
Central locking (4-power windows and memory):
04098 - Selective unlocking
04099 - Unlocking of all doors
Control module coding (MY 2002 >)
Central locking (2 doors / 2-power windows):
00064 - Selective unlocking
00065 - Unlocking of all doors
Central locking (4 doors / 2-power windows):
00066 - Selective unlocking
00067 - Unlocking of all doors
Control module adaptation (> MY 1998)
Select 35 (Comfort System w/o power windows)
or
Select 46 (Comfort System with power windows)
Adaptation -> Function 10
-> Channel 03 (Auto-Lock)
The doors will lock automatically when the vehicle reaches a speed of 15 km/h or 10 mph (0 = off/1 = on).
-> Channel 04 (Auto-Unlock)
The doors will unlock automatically when the key is removed from the ignition switch (0 = off/1 = on).
-> Channel 05 (Interior Monitoring)
Activation of interior monitoring system (0 = off/1 = on).
-> Channel 08 (Unlock Blink)
Blink when unlocking via remote control (0 = off/1 = on).
-> Channel 09 (Lock Blink)
Blink when locking via remote control (0 = off/1 = on).
-> Channel 10 (Country Setting)
Country setting for alarm horn.
1 - Rest of World (RoW)
2 - Germany
3 - Great Britain
Control module adaptation (MY 1999 >)
or
-> Channel 06 (Unlock Horn)
Horn beep when unlocking via remote control (0 = off/1 = on).
-> Channel 07 (Lock Horn)
Horn beep when locking via remote control (0 = off/1 = on).
2 - Germany
3 - Great Britain
Dada:)
Masina mea are inchoidere doar din cheie(centralizata) in acest caz se poat activa treaba aceasta?ms
Ceea ce ai intrebat tu, DA, de poate.
Pareri pentru Engine?
VCDS Version: Release 908.0
Data version: 20090911
Saturday,19,March,2011,18:35:31:13314
Chassis Type: 1J - VW Golf/Bora IV
76
Mileage: 149350km/92801miles
Address 01: Engine Labels: 06A-906-018-AGU.lbl
Part No: 06A 906 018 CG
Component: 1.8L R4/5VT MOTR HS D02
Coding: 04000
Shop #: WSC 00046
1 Fault Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 00046
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 00046
1 Fault Found:
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 02 AIRBAG VW5 0004
Coding: 12338
Shop #: WSC 00046
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 821 A
Component: KOMBI+WEGFAHRS. BOO V28
Coding: 07142
Shop #: WSC 44598
Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y1630319
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1630319
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Coding: 00006
Shop #: WSC 00000
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4R Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00046
Part No: 1J1959801C
Component: 4R Tõrsteuerger. FS0002r
Part No: 1J1959802D
Component: 4R Tõrsteuerger. BF0002r
1 Fault Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
End ---------------------------------------------------------------------
Simptome initiale: Nu pornea sau pornea si murea dupaia in 30 sec 1 minut.
Azi am incercat sa pornesc cu mufa la MAF scoasa. Porneste motorul perfect, nu moare, sta la relanti. Din nou cand am pus mufa sus si am pornit iara si la fel a murit.
E destul de scump un MAF Bosch nou si nu m-as ambala sa iau. Vineri mergea perfect masina si nu avea pe Engine nici o eroare, la ora 16 si la ora 22 PAC, nu a mai pornit. Se paote asa brusc ca se fi picat? Ce pot sa mai incerc sa fac?
Sa incerc cu un MAF to de pe un alt AGU sa vad cum se compornta. Daca tot la fel face sa vad conexiunile?
Modificat de volnick1986
16487/P0103/000259 - Mass Air Flow (MAF) (G70): Signal too High
Possible Symptoms
Probably no serious malfunctions
Loss of power
Possible Causes
Wiring and/or connections (short circuit?)
Mass Air Flow (MAF) (G70) defective
Possible Solutions
Check wiring and connections
Check / Replace Mass Air Flow (MAF) (G70)
Special Notes
In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
Astea le-am gasit si eu pe Ross Tech. Mersi mult oricum. :)
LE: 2000 scire si la semnatura.
Ce an e masina? VEzi mai multe aici.
Ai doua variante , conexiuni ori G70 defect . Daca spui ca masina merge bine cu mufa scoasa atunci as merge pe defectiune la G70 . Dupa cum scrie si pe site au o reputatie proasta , ai putea sa incerci o curatare desi se pare ca nu e usor de curatat . Ai verificat functionalitatea ? [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm).
Salut!azi dimineata masina din semnatura a pornit la a treia cheie fara sa ramana nimic aprins pe bord,a functionat foarte bine insa am gasit stocat cod 17428(nu pt. prima data,dovada ca problema persista)-stiu ca s-a mai discutat dar nu am inteles nimic din rezolvare si nici nu pot identifica F.P.control valve N276 siF.P.sensor G 247.Mentionez ca la 80%din porniri se aude pompa ca si un diesel dupa care tace.Multumesc.
G247 trebuie sa fie pe rampa de combustibil inainte de injectoare.Inainte de el trebuie sa fie si N276.
Modificat de divinewind
Salutare!
De curand am achizitionat si eu de pe Okazii o Interfata Vag. Pe ea scrie VAG106 Dual-K&CAN iar softul este VCDS 1062+. Recunosc ca ma cam depaseste engleza tehnica si m-am hotarit sa descarc varianta in romana, de pe www.diag.ro/products/vagcom.aspx .Problema este ca nu-mi merge varianta free de pe acest site. Stiti vreun alt site unde pot descarca o varianta in romana? Sau... ma poate ajuta cineva cu un soft in limba romana? Astept un mail la: g_florinel@yahoo.com
Dupa cite stiu functioneaza NUMAI cu softul cu care a fost livrata. Zi sarumina daca mai merge, parca se blocau daca incercai alta versiune.
Asa ca invata si "engleza" si "tehnica"...s-a inventat Goagal translate...
Traducerea nu prea te ajuta...e tradusa de un chinez :)
Ninutzu, eu zic sa cumperi versiunea oficiala a VCDS, altfel nu prea avem ce sfaturi sa iti dam aici avand in vedere ca discutam despre produse PIRAT.
Atentie mare, astfel de discutii nu sunt agreate de catre REGULAMENTUL VWFORUM.
Orice continuare a discutiei de mai sus o voi considera ca pe o incalcare cu buna stiinta a regulamentului si o voi sanctiona ca atare!
Modificat de BLiTZ
Ieri am schimbat placutele de frana, atat pe fata (cu senzor) cat si pe spate. Dupa ce am mers vreo 10 Km mi s-a aprins in bord martorul ESP. :blink:
Am oprit, am pus contactul iar si nu a mai aparut. Am facut vreo 200 de Km (timp in care NU s-a mai aprins martorul ESP) si am facut o scanare cand am ajuns acasa. Mi-a aparut urmatoarea eroare:
Address 03 -------------------------------------------------------
Controller: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 10753
Shop #: WSC 01317
1 Fault Found:
00812 - Brake Pressure Release Solenoid (F84)
Stiti cumva ce ar fi putut cauza aceasta eroare ? :huh: Multumesc. :(
Modificat de Deadly
Daca e sa te uiti pe ross tech ajungi aici.
Daca nu este switch-ul de la pedala de frana si nici la stopurile de frana nu e o pb e foarte posibil sa fie pompa de frana.
Hmmmm... M-ai cam pus pe ganduri. :blink:
N-am observat sa am probleme la switch-ul de la pedala de frana si nici la stopurile de frana. Nu raman aprinse, toate becurile merg etc...
Am sa mai fac maine un drum de vreo 100 de Km si am sa vad daca va mai aparea eroarea. Frana tine foarte bine deci nu inteleg care ar putea fi problema la pompa de frana. :vaidecapulmeu:
Mai exista si un switch in pompa de servo care poate sa faca probleme.
Ii spun asa "Brake pressure solenoid valve, in brake servo".
Bun, inainte de toate sa te asiguri ca nu ai aer in sistemul de frana si ca totul este aerisit ca la carte.
Bun. Am facut azi ~ 125 de Km, am ajuns acasa, am facut test si eroarea nu a mai aparut. :)
@divinewind, despre ce aerisire vorbesti ? :huh: Nu s-au schimbat decat placutele de frana, atat pe fata cat si pe spate. N-am schimbat lichidul de frana sau altceva. Nu s-a facut nici o aerisire, nimic. Multumesc. :icon_thumright:
  • WooZie changed the title to Octavia 2 2011 motor CGGA
  • Aerofan pinned this topic
    • S.Adrian
