zorg
Buna si La Multi Ani tuturor,
tocmai mi-am scanat masina si am gasit urmatoarea problema:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 DP HW: 028 101 274 2
Component: R4 1,9L EDC G000SG 7870
Revision: --H02--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 66565 257 00032
1 Fault Found
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 96324 km
Time Indication: 0
Date: 2000.00.00
Time: 10:18:54
Freeze Frame:
RPM: 903 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00001011
Temperature: 8.1
Bujia incandescenta de pe cilindrul 3 !
Multumesc,
In cazul asta ar fi bine sa le schimb pe toate 4 sau doar pe cea in cauza? Ce tip (cod?) ar trebui sa cumpar?
Vezi ce ai pe masina si ia dupa codul piesei demontate (cilindrul 3 ) .
Ce rost are sa cumperi toate 4 ?
Totusi fa-i o verificare bujiei inainte sa cumperi alta .(demontare si alimentare la 12V)
Succes.
Va rog, are cineva un sfat pentru postul #2339? Din pacate, un nou scan - aceleasi erori:(
01426 - Controls in Steering Wheel (E221): No Signal/Communication
Possible Symptoms
* Multi-Function-Display (MFD) can not be operated
Possible Causes
* Steering Column Control Module Supply Voltage insufficient
* Fuse(s) faulty
* Wiring/Connectors from/to Steering Wheel Controls faulty
Possible Solutions
* Check Steering Column Control Module Supply Voltage
* Check Fuse(s)
* Check Wiring/Connectors from/to Steering Wheel Controls
Special Notes
* When found in VW Golf/Jetta (1K): Steering Column Control Module
o Check Fuse(s) SB2 (E-Box Low) or SB16 (E-Box High) in the Engine Compartment Fuse Box.
o Check Connector T5k on the Steering Wheel Controls
00888 - Wiper Switch for Intermittent Operation (E22): Defective
Possible Causes
* Fuse(s) faulty
* Wiring/Connector(s) from/to Wiper Switch for Intermittent Operation (E22) faulty
* Check Wiper Switch for Intermittent Operation (E22) faulty
Possible Solutions
* Check Fuse(s)
* Check Wiring/Connector(s) from/to Wiper Switch for Intermittent Operation (E22)
o See Measuring Value Blocks (MVB)
Special Notes
* When found in VW Golf/Jetta/Bora (1K/5M) (and similar): Steering Wheel, Check Measuring Value Blocks (MVB) 001.4 & 002.1.
* This fault does NOT mean the Wiper Switch/Lever itself, it means the small Switch for the Interval on top of it!
Terminal 15 e un "+" dupa contact.
Modificat de cuiuda
Si-a luat tata un polo bluemotion2 din 2008 insa ma deranjeaza un lucru: cand pun contactul se aprind farurile automat. Se poate anula aceasta functie cu vag-com (704)? Daca da, v-as fi recunoscator daca mi-ati explica si mie procedura.
Salutare si La Multi Ani !
Am facut o scanare unui prieten cu un Passat B5.5 , 1.9 TDI, 74KW care are urmatoarea problema: cand o accelereaza dupa 2500 - 3000 ture masina are ca niste zvacniri scurte. Face asa tot timpul cat e accelerata. O zvacnire de asta la 2 -3 secunde. Masina se accelereaza deci nu se observa cum scade demarajul. Pe motor nu are nici o eroare, am facut un log in mers poate cineva vede ceva suspect.
Va multumesc mult.
LOG_01_010_011_013_passat.zip
"suspecte" mi se par valorile la cele doua injectoare... ;)
Va prezint si eu o eroare gasita in seara asta in calculatorul masinii mele (masina din profil) :
VAG-COM Version: Release 303.1
Control Module Part Number: 038 906 019 KC
Component and/or Version: G200SG 4896
Software Coding: 00002
Work Shop Code: WSC 05314
Additional Info: WVWZZZ3BZ4E036921 VWZ7Z0C7811955
18263 - Powertrain Data Bus: Software Version Monitoring
P1855 - 35-10 - - - Intermittent
Am incercat sa intru pe pa Ross Tech, dar nu reusesc (nu prea mere bine netu).
Daca cineva s a mai lovit de acesta problema poate imi spune si mie cum a rezolvat o.
Multumesc frumos.
O zi buna tuturor ;)
@ Fane Babanu - ai facut de curand vreo adaptare/ codare a vreunui modul?
Eroarea respectiva ar putea rezulta si dintr-un firmware facut si care nu se "pupa" cu codarile unui modul.
@Pronet singurul lucru care l am modificat a fost turatia la relanti, dar asta a fost acum vreo 2 luni si ceva in urma. Pana in seara asta nu am mai vazut eroarea asta. Acum intreb si eu : dauneaza cumva masinii si care ar fi rezolvarea? In comportamentul masinii nu s a modificat nika (in afara de turatie pe care am modificat o eu).
Multumesc frumos.
O zi buna tuturor :icon_thumright:
"suspecte" mi se par valorile la cele doua injectoare... :icon_thumright:
Hmmm, vorbesti de Cyl3 si Cyl4? Eu vad acolo -2.8 to +2.8 dar nu stiu sa interpretez.
Ce inseamna valorile respective?
sterge-o si nu te mai gandi la ea :vaidecapulmeu:
...eu cred ca nu la cyl 3 si 4 sunt probleme.
Valorile injectoarelor trebuie sa fie intre -2,8 si +2,8...iar la tine pe cyl 1 si 2 sunt cam mari valorile.
mai precis cilindru 1 e cu probleme... dar refa logul cu turatie de relanti , turatie 1200
O sa dureze un pic pana fac alt log, masina e la suceava. O sa mai fac un log cum ajung acolo. Ar trebui sa mai adaug si alte grupuri sau e de ajuns un log pe relanti la 1200rpm?
Apropo, ce inseamna valorile astea de -1.91 si 1.55 ? Totusi se incadreaza in valorile specificate maxime...
nu dar este un inceput... si asta la relanti.... la turatii mai mari problemele se maresc...
OK dar ce anume reprezinta valorile astea? Vad mg/R. Ce inseamna si cum ar trebui sa se modifice valorile astea?
Merci.
salut
daca este cineva care sa-mi dea un sfat,am doua erori si nu stiu sa le interpretez..am tot cautat si nu am gasit nimic exact.
masina porneste greu dimineata (legat de problema asta am gasit rezolvari) dar mai are un uruit cateodata ca si cand motorul nu ar mai avea ulei,asta face pana in 2000 de rotatii ,nu face tot timpul ,face putin apoi isi revine iar mai face putin si tot asa, in momentul ala nici putere nu mai am ca si cand nu s-ar alimenta.
00546 - Data wiring faulty
49-00 - No Communications
00550 - Start of Injection Regulation
08-00 - Control Limit Surpassed
inseamna cat trebuie sa bage in plus sau in minus ( in mg) pe o rotatie a motorului
limitele maxime sunt +/- 2.99.... dar orice sta peste +/-1 este un semnal de alarma ca lucrurile se pot inrautatii
in primul lucru trebuie verificat avansul static la pompa de injectie pe basic setings 004
si vazut ca e in regula.... dupa un log pe grupul 004 cu treapta 3-a din 1500 ture blana pana in 4000....
multumesc mult,maine am sa i fac un log.
Am inteles. Si la 1200 rpm ce s-ar vedea in plus?
Ar putea fi un semn ca injectoarele sunt pe duca?
Merci.
compensarile pe tester sunt afisat pana in 1300 ture.... mai sus nu imi arata valorile
si crescand turatia vad cum evolueaza compensarea
Ma ajutati va rog cu un sfat, o idee cum as putea anula cu vag com sa nu se mai aprinda farurile(faza scurta si stopurile) cum pun contactul, desi eu nu pornesc farurile. Ele stau mereu aprinse fara sa le dau eu drumul iar in bord nu se aprinde nimic.
  • Aerofan pinned this topic
