zorg
@lucian_90tud:
01176 - Key: Signal too Low
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Immobilizer
Wiring and/or Connector(s) from/to Immobilizer Reader Coil faulty
Immobilizer Transponder in Key faulty OR incorrect Transponder in Key
Remote Control
Remote Control Battery low
Remote Control faulty OR incorrect Remote Control used
Possible Solutions
Immobilizer
Check Wiring and/or Connector(s) from/to Immobilizer Reader Coil
Check Key Immobilizer Transponder Status
See Measuring Value Blocks (MVB)
Check/Renew Immobilizer Key Matching
Check/Replace Key
Remote Control
Check/Replace Remote Control Battery
Special Notes
This Fault Code can be stored in due to Remote Control or Immobilizer Problems. On most Models these systems are separate and should therefor also be diagnosed separately.
In case of Engine Starting Issues please make sure that you are really experiencing an Immobilizer related Problem! On most models using conventional keys, the Engine will still start but cut out after 1-3 Seconds if an Immobilizer related Problem is the cause. On models using Kessy Systems and Electronic Keys, most systems in the car won't power up at all if if an Immobilizer related Problem is the cause. If you are NOT experiencing this behavior (e.g. Instrument Cluster powers up, and engine cranks but doesn't fire at all or engine won't crank) this is likely NOT Immobilizer related.
When found in Audi A3 (8L), Audi A4 (8D), Audi A6 (4B) or Audi A8 (4D), check Wiring from Immobilizer Control Module to Immobilizer Reader Coil. A known issue would be the Length of the Wiring, an optimized Replacement Part may be available (8D0-972-275).
poate sa imi spuna si mie ceva ce inseamna asta ?
Modificat de OviDU
@ovidu:
Possible Symptoms
Smoke
Possible Causes
Air in Fuel Supply
Possibly due to "dynamic driving style" while tank on reserve.
Fuel Supply leaking
Possible Solutions
Check Fuel Supply for Leaks
Perform Function Test until all Air is out of the Fuel Supply System
Perform Basic Setting (see Special Notes for further Instructions)
Special Notes
This fault may occur due to the auxiliary heating start up, while all related components and functions are free of faults.
When found in VW Touran (1T): Auxiliary Heating (or similar), perform Basic Setting.
Modificat de pronet
coincidenta sau nu pe data de 12 am facut plinul ... poate asta este o explicatie...
Modificat de OviDU
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to Plus
Le-am sters, au reaparut, iar acum arata doar numarul de eroare si zice can`t decode.
Am schimbat senzorul de temperatura si tot indica temperatura cand vrea, in momentul cand merg si cade acul de la temperatura apare becul check engine si da in nas. Posibil sa fie termostatul ? Solutii? Multumesc!
am inteles ca mai exista un alt senzor in afara de cel de jos undeva sus in spatele motorului ? multumesc.
Cand spui ca l-ai schimbat pe cel de jos te referi la cel de temperatura exterioara banuiesc. G2 (senzor temperatura agent racire) e in spatele motorului.
Modificat de pronet
Salut acum 3 saptamani am scanat masina cu vag 409 si mi-a dat : 01274 Air Flow Flap Motor - V71 ... am sters eroare ... si am scapat de tancanitul ala(de langa torpedou) cand porneam masina ... astazi a reaparut zgomotul acela .... si nu se lasa pana ce nu pornesc climatronicul si dau pe recirculare aer ...) am pus din nou vag comul pe masina ... si surpriza nu a mai aparut eroarea .... ce e de facut sa scap de problema ... de zgomot ...
PS masina e un golf 4 2006 cu climatronic
Modificat de WNT89
da temperatura la minim si il opresti....asa dispare... nu prea ai ce sa faci... decat sa-l schimbi.
Salut.Tocmai am achizitionat un tester si am dat si eu un autoscan si au aparut erorile astea.Cred ca e ceva de contact electric.Spuneti-mi si mie va rog ce inseamna mai exact astea?
2 Faults Found
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 108.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00000100
Temperature: 7.2
CRED ca s-ar putea sa trebuiasca sa schimbi bujiile. eu asta inteleg din " Glow plug - intermitent"
Modificat de AndreiVL
Ideea e urmatoarea:Acum cateva zile am bagat-o pe tester si mi-a aratat ca trebuie bujiile schimbate.Am schimbat bujiile si azi am bagat-o iar pe tester si eroarea era acolo.Am sters eroarea si acum nu mai apare nimic.Cred ca a ramas memorata de la primul tester si acum, remediind problema, eroarea a disparut prin stergere.Multam
@db06zun inainte de a le schimba, le-ai verificat daca sunt intradevar arse? mai fa o scanare mai incolo si daca nu mai apare nimic de glow plug ai scapat, dar de obicei se mai duce si modulul care comnada bujiile :icon_thumright: si iti da diferite bujii ca fiind arse, de aceea zic inainte de a le schimba trebuie verificate daca sunt intradevar arse sau nu.
@WNT89 trebuie sa schimbi respectivul motoras, in mod normal doar potentiometrul din el face figuri dar nu cred ca gasesti separat.
da, eu l-am schimbat pe cel din prima poza. deci sa inteleg ca trebuie schimbat celalalt, observ ca are exact acelasi cod piesa. multumesc.
as dori sa verific mufele de la injectoare la un a4 2.0tdi insa am vazut ca trebuie scos capacul de la curbutori.
din cate am observat trebuie inlaturat foarte putin capacul de verificare la cureaua de distributie si scoase cele 12 suruburi parca apoi capacul iese.
Stie cineva operatiunea asta ma refer daca mai trebuie mentionat ceva sa nu apara vreo complicatie?
apoi capacul de la curbutori vine strans tare sau doar putin.
@bbi
si eu va trebui sa fac operatiunea asta, daca te apuci poti sa faci niste poze si sa le postezi ?
bujiile incandescente sunt tot acolo ?
mersi
[012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 006 - short to plus- Intermittent
imi spuneti si mie va rog ce inseamna aceasta eroare??? motorul este un tdi cr 170 cp, cod motor bmr
e f posibil sa fie actuatorul, supapa de vacuum. Masina trage normal? nu scoate fum mai mult ?
19594/P3138/012600 - Intake Manifold Runner Control: Regulation Deviation
Possible Causes
Intake Manifold Runner Control Basic Setting not performed
Wiring from/to Intake Manifold Runner Control faulty
Possible Solutions
Perform Intake Manifold Runner Control Basic Setting
Check/Repair Wiring from/to Intake Manifold Runner Control
Check/Replace Intake Manifold Runner Control
Special Notes
When found in Engine: 2.0l TFSI, perform Basic Setting.
18039 - Accelerator Position Sensor (G79): Signal too High
P1631 - 35-00 - -
ce inseamna asta si cum se manifesta ?
pe ross-tech wiki nu am gasit nimic.
Este senzorul din pedale de acceleratie...unul din cei 2...Masina nu se accelereaza? Poti incerca cu spray de contacte. Asa am reusit sa rezolv problema la o Octavia 1
masina functioneaza normal, nu mi-a facut nici o faza la accelerare.
daca era de la contactele senzorului nu trebuia sa zica "Intermitent"?
Buna!
Am un golf 5 1.9 TDI 105 cp.In urma unei recente diagnoze la un service am descoperit
"16785-Sistem recirculare gaze evacuare : flux prea mic
P0401 - 000 - -
imprejurari cod:
RPM:1638 /min
cuplu: 50.0 Nm
viteza: 42.0 km/h
sarcina : 16.5 %
raport : 14.7 %
masa aer /cursa :225.0 mg/cursa
masa aer /cursa : 535.0 mg/cursa
Baieti de la service nu au putut sa-mi zica nimic de aceasta eroare.Doar,citez "ti se va duce turbina pentru ca e prea zgomotoasa"
Ma puteti ajuta? Ce inseamna si la ce sa ma astept ?Mentionez ca mi s-a aprins si un bec galben in bord ,in forma de motor.
Va multumesc!
egr bulit... adica daca o sa verifici... sigur e membrana sparta
daca egr nu merge turbina e mai zgomotoasa la relanti.... dar nu insemana ca o sa se duca.
imi spune si mie cineva mai exact ce vor sa reprezinte cele doua erori?
Prima:
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
2 Faults Found
02823 - Requirements for Locking the Steering Column Lock not met
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 97
Mileage: 171667 km
Time Indication: 0
Date: 2009.10.23
Time: 18:44:24
02827 - Wake-Up request via ESP
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 171667 km
Time Indication: 0
Date: 2009.10.23
Time: 18:44:25
A doua:
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 R
Component: Radio GR0 019 0023
Revision: 0001905S Serial number: VWZ2Z2F1404876
Coding: 0020200
Shop #: WSC 00028 028 00001
2 Faults Found
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Acestea sunt de la masina din semnatura.
Am sters erorile si am dat din nou autoscan si nu imi mai arata cele doua erori de sus, insa imi arata asta:
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Boxe nu am pe usile din spate, probabil de aceea da a doua eroare, este posibil ca masina sa fi avut? eu sunt al doilea propietar.
Modificat de Alinushu2007
La o scanare cu VAG-ul am gasit urmatoarea eroare...Ce reprezinta?????
Control Module Part Number: 038 906 018 P
Component and/or Version: 1,9l R4 EDC G00SG 1629
Software Coding: 00002
Work Shop Code: WSC 05311
00626 - Glow Plug Indicator Light (K29)
31-10 - Open or Short to Ground - Intermittent
Am dat cautare si nu am gasit nimic pe forum. Cineva zicea in alta parte ca ar fi becul galben care indica incalzirea bujiilor"dupa parerea mea functioneaza corect se aprinde la contact si se stinge dupa un timp".
  • Aerofan pinned this topic
