zorg
Salutare!
Am gasit si eu cateva erori la scanare si sper sa ma ajutati si pe mine sa le descifrez sau poate chiar sa le rezolv. Una dintre ele este la "bulb for blinkers" care presupun ca se refera la becurile de semnalizare, dar acestea functioneaza perfect. Cealalta este mai importanta si anume: nu mai porneste incalzirea in scaune :biggrin: . Am atasat logul in caz ca ma puteti ajuta.
Multumesc anticipat!
Log__golf5_124900km_77609mi.txt
Modificat de Taf
02092 - Enabling Heated Seat: Open or Short to Ground
Possible Symptoms
Seat Heating not working
Possible Causes
Fuse(s) faulty
Wiring/Connector(s) from/to Central Electronics Control Module from/to Seat Heating Control Module faulty
Control Module incorrectly coded
Possible Solutions
Check Fuse(s)
Check Wiring/Connector(s) from/to Central Electronics Control Module from/to Seat Heating Control Module
Check Control Module Coding
When found in Central Electronics, see TSB/TPI 2010355.
If the Central Electronic Control Module has the Part Number 3C0-937-049-E and the Seat Heating Regulator has the Part Number is 1Z0-959-772-A while there are no Function Limitations, the Fault has to be ignored.
Cumva ai modificat codarile de pe centrala electrica?
As avea si eu nevoie de ajutor cu e eroare care nu se sterge:
18263 - Powertrain Data Bus: Software Version Monitoring
E o eroare care apare dupa diferite codari si adaptari pe masina, nu influenteaza functionarea masinii. Ai facut ceva pe motor sau confort ?
@ taf
00933 - Electric Window Motor; Passenger Side (V148): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Window Automatic Run not working
Pinch Protection limited
Possible Causes
Automatic Run & Pinch Protection not adapted
Possible Solutions
Adapt Automatic Run & Pinch Protection (see Special Notes)
Special Notes
Pinch Protection Adaptation
Make sure the window in question is completely closed.
Use the driver door window buttons to operate the window(s).
Roll down the window and keep holding the button down for 2 additional seconds after the window is already fully opened.
Roll up the window and keep holding the button up for 2 additional seconds after the window is already fully closed.
Now test the window automatic
Modificat de pronet
Singura modificare care am facut-o cu vag-com a fost sa schimb limba - din germana in engleza dar eroarea era deja prezenta. Sigurantele le-am verificat si nu sunt arse (cele aflate in stanga bordului si cele din dreapta bateriei-la motor). Presupun ca trebuie sa merg la reprezentanta sa-mi rezolv erorile astea nu? Aveti idee cam cat ar costa?
revin cu noi informatii/completari privind posturile mele de pe pagina anterioara (cele cu "turbo/supercharger overboost condition"):
dupa mai multe vizite la diversi mecanici, am auzi mai multe pareri, care mai de care in jurul "bubei". primul mi-a zis ca ar fi "o valva vacumatica pe la turbina" al doilea mi-a zis ca nu este acea valva (dupa ce a ridicat-o pe rampa si a verificat si geometria variabila - turbina functioneaza in parametrii) iar al treilea mi-a zis ca "ori e din debit-metru ori din blocul de valve". nu ma poate ajuta nimeni? nu vreau sa par insistent, solicit doar putin ajutor, sa nu ma apuc sa cumpar debit-metru (aprox 400 si/sau blocul de valve - aprox 600 Lei). daca aveti GOLF 2.0 TDI si ma puteti ajuta, va platesc, nu e problema. am nevoie doar de un debitmetru si/sau blocul de valve. am vazut cum se demonteaza, e vorba de 5 minute de munca.
va multumesc!
PS: sper sa nu fi incalcat vreo regula a forumului. daca aveti alte informatii sau un sfat, un mecanic bun care sa ma poata ajuta, un reply ar fi mai mult decat bine-venit :icon_thumleft:
Am inlocuit azi blocul de valve... problema persista....
sigur nu e geometria??? sau actuatoru??? cati km are masina.....
ti-am mai zis si inainte. 114 mii. am mai auzit o varianta: ramane geometria blocata. in mod normal presiunea trebuie sa fie in jur de 2200-2300. turbina mea urca la 2600 si acolo ramane. am pus VAG-u` pe ea si am dat forja. vreo idee? :icon_cool:
curata geometria ...altceva nu mai e... inafara de actuator...
ti-am mai zis si inainte. 114 mii. am mai auzit o varianta: ramane geometria blocata. in mod normal presiunea trebuie sa fie in jur de 2200-2300. turbina mea urca la 2600 si acolo ramane. am pus VAG-u` pe ea si am dat forja. vreo idee? :blah:
Pune aici logul facut sa-l vedem si noi.
e pus pe pagina 108 un prinscreen. log-ul nu-l am, din pacate. supapa aia vacumatica (actuatorul cred ca se numeste), e in regula. am schimbat blocul de valve = nimic. am schimbat supapa de presiune de pe intercooler = nimic. ultima versiune, "schimba dom-le turbina si gata" ;) ce sa fac?
dute la cineva care stie ce face si te costa de x mai putin decat o trubina noua...... daca vrei ajuto ma uit si eu la ea si poate gasim ceva
Postez si eu o eroare gasita in calculatorul masinii din profil:
VAG-COM Version: Release 303.1
Control Module Part Number: 1C0 959 799 B
Component and/or Version: 7X Komfortger
Posibil la tine sa fie doar lipituri reci in broasca.
am vorbit cu CIPOS in seara asta, posibil sa arunce un ochi sa vedem ce zice... revin :)
daca nu e geometria sa imi zici mie cutu :blink:)))
salut,
am vazut ca ati vb de codingul de la motor.
Nu prea inteleg cum il calculati voi.
Ca idee masina din semnatura + automatik + abs + esp are codingul 00001 si dupa datele de pe: http://www.ross-tech.com/vcds/tour/recode_screen.html reiese ca ar trebui 00003, corect?
Influenteaza cu ceva daca il schimb?
Modificat de psycho_mishu
Am facut o scanare si am urmatoarea eroare:
Control Module Part Number: 03G 906 016 CB
Component and/or Version: R4 1,9L EDC 0000SG 6176
Software Coding: 0000071
Work Shop Code: WSC 00028
16567 - Fuel Temp. Sensor A (G81): Open or Short to Plus
P0183 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Temperature: 30.6
Deoarece e intermitenta, sterge-o si vezi daca mai apare. Acel senzor are o mare importanta in calcularea cantitatii de motorina injectata.
Cei acre folosesc POWER-Box stiu, deoarece acolo se monteaza.
salut,
Depinde de motor si de an de fabricatie: teuerger
La ce se refera eroarea 17058 - cylinder glow plug circuit (Q13)? Cumva la o bujie incandescenta (arsa)? Multumesc.
DA, este vorba de o bujie (cilindrul nr.4)
17058/P0674/001652 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
Possible Symptoms
* No Pre-Glow Period
* Poor Cold Starting
Possible Causes
* Glow Plug Wiring faulty
* Glow Plug faulty
Possible Solutions
* Check Glow Plug Wiring
* Check Glow Plug
Multumesc de raspuns. Totusi am o nedumerire; La "possible solutions" am vazut ca problema "arderii" bujiei nu e mentionata. Ar trebui doar sa verific daca legatura la bujia nr 4 este neintrerupta, inteleg eu...
Un VAG-com pe masina ar spune mai multe.
Aia e la POSSIBLE CAUSES.
Verifica daca legatura IN bujia 4 nu e intrerupta.
am o problema
la masina din semnatra pana la un moment dat am resit sa scanez tot ce se putea
mai nou nu pot scana abs-ul cica nu comunica asa zice asta cu vag com 311-2
am incercat cu un vag mai bun si nu au fost probleme
dar nu inteleg de ce face figura daca mi-a mai mers si cu 311-le
  • Aerofan pinned this topic
    • mario75
