zorg
Verifica firele care duc la calculatorul de usa stanga spate. CAt despre radio cred ca nu merge boxa din aceeasi usa.
Am o eroare care nu-mi da pace. Am tot cautat explicatii despre ea dar nu gasesc nimic elocvent pentru a depista cauza acesteia.
Eroarea este urmatoarea:
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 M HW: 3C0 614 095 M
Component: ESP 440 C2 H015 0001
Revision: H015 Serial number: 0657456912
Coding: 0029986
Shop #: WSC 02350 995 16874
02840 - Wake-Up Line from Central Convenience Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 6
Reset counter: 252
Time Indication: 0
Precizez ca nu se simte nici un comportament ciudat la masina. ABS-ul functioneaza normal. Chiar daca sterg eroarea, ea apare in mod aleator si nu-mi dau seama care este cauza care o produce. Ce ma ingrijoreaza este "fault priority" (6) "The fault has a long term influence on drivability".
Astept sfaturi din partea celor care s-au confruntat cu eroarea respectiva.
Modificat de pronet
Address 17 ------------------------------------------------------
Controller: 1J0 920 806 G
Component: KOMBI+WEGFAHRS. RB8 V24
Coding: 01112
Shop #: WSC 32549
WVWZZZ1JZ3W427757 VWZ6Z0B0369690
3 Faults Found:
01176 - Key
07-00 - Signal to Low
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01176 - Key
65-10 - Unauthorized - Intermittent
Address 46 -------------------------------------------------------
Controller: 1C0 959 799
Component: 1F Komfortger
Uite ce am gasit despre 01176 - Key Faulty: Signal too Low
Possible Causes
Low voltage in key-battery
Bad connections between immo reader coil and immo control module
Possible Solutions
Replace key-battery
If more than one key acts like this, check / clean the connector between immo reader coil and immo control module, the contacts tend to oxidize
There is also another known issue with the wiring between reader coil and immo module, they are known to be too short so there is a 'longer' wiring (8D0-972-275) available
si
00933 - Electric Window Motor; Passenger Side (V148): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Window Automatic Run not working
Pinch Protection limited
Possible Causes
Automatic Run & Pinch Protection not adapted
Possible Solutions
Adapt Automatic Run & Pinch Protection (see Special Notes)
Special Notes
Pinch Protection Adaptation
Make sure the window in question is completely closed.
Use the driver door window buttons to operate the window(s).
Roll down the window and keep holding the button down for 2 additional seconds after the window is already fully opened.
Roll up the window and keep holding the button up for 2 additional seconds after the window is already fully closed.
Now test the window automatic.
Modificat de pronet
Multumesc pt promptitudine,o sa incerc faza cu geamul maine. Cat despre cealalta eroare se poate sa fie de cand mi-am pus modul cu chei briceag si sa se fi setat ceva gresit la immo? O sa ma mai interesez,oricum multumesc pt raspuns.
Am facut si eu o scanare si am urmatoarele erori:
"Address 09: Cent. Elect.
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent"
verifica mufa si firele dintre usa si stalp,
18263 - Powertrain Data Bus: Software Version Monitoring
P1855 - 35-10 - - - Intermittent
sa fie oare o eroare fara rezolvare? scriu asta dupa ce am cautat si pe alte forumuri si dupa cateva telefoane la care au aceasta eroare
@dox99
citeste aici: http://www.passatworld.com/forums/archive/...p/t-220220.html
Ai schimbat/ inlocuit / reprogramat vreun modul la masina?
"The Bentley Manual's general recommendation for can-bus (data-bus) errors is to:
(1) check all of the computer modules for error codes: engine, transmission, instruments, convenience, radio, immobilizer, etc., and fix them, and
(2) check the can-bus wiring for damage or loose connections
More specifically, this error may be related to the radio/navigation swap. The instrument cluster module (ICM), convenience control module (CCM), or immobilizer (typically part of the CCM), may need to be "adapted" to the new navigation system -- it is expecting to "see" the old radio & is complaining that the radio is not there. The error message is forwarded to everything else on the can-bus network, so the ECM logs the error even though it isn't an engine-specific problem."
am activat functia de ridicare/coborare a geamurilor din cheie si s-a umblat prin ea pana am activat si interval service
Sfatul meu e sa verifici modulul care a fost reprogramat - sa nu dea vreo eroare.
Cat despre activarea SRI nu cred ca poate sa influenteze cu ceva/ sau sa determine aparitia erorii de mai sus.
Modificat de pronet
am erroarea asta
1 Faults Found:
00281 - Vehicle Speed Sensor (G68)
35-00 - -
si nu-mi merge viotezometrul si contorul de km. Am schimbat senzorul de viteza si exact la fel face.
Poate ma ajuta careva sa-mi dau seama de unde este problema.
merci anticipat!
prima data mi-a dat urmatoarea erroare
Address 01 -------------------------------------------------------
Controller: 06A 906 033 K
Component: SIMOS33 1,6l 2V 00HS3553
Coding: 00231
Shop #: WSC 31480
TMBBX41U522625241 SKZ7Z0A1317724
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-00 - -
Readiness: 0000 0000
Verifica contactele de la senzorul G68 (parca e situat pe cutia de viteze ;) )
00281 - Vehicle Speed Sensor (G68): No Signal
Possible Causes
* Wiring/Connectors faulty
* Vehicle Speed Sensor (G68) faulty
Possible Solutions
* Check Wiring/Connectors
* Check Vehicle Speed Sensor (G68)
o See Measuring Value Blocks (MVB)
Si la veche mea masina a aparut aceeasi eroare dupa ca m-am jucat la IC, si asa a ramas.
contactele sunt ok si senzorul nou. Firul pe traseul vizibil pare a fi ok, dupa ce intrea in manunchi Dumnezeu mai stie ce e cu el.
se poate ca ECU sa fie defect? ca si indicatorul de la benzina variaza aiuarea in timpul mersului si mai ales la accelerari.
dupa o scanare cu vag am gast unele erori
4 Faults Found:
16989 - Internal Control Module: ROM Error
P0605 - 35-00 - -
17970 - Quantity Adjuster (N146): Upper Limit Reached
P1562 - 35-00 - -
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-00 - -
Masina nu trage parca e SDI(nu mai porneste turbina cel putin asta simt eu) precizez ca e u 1.9 TDI ALH si la temperaturi mari exterioare nu se aprinde spirala si nu porneste iar daca pun vag pe ea nu recunoaste motorul.as fi recunoscator pentru posibile variante.la un mecanic la care am fost mia zis ca e busit calculatorul masinii ECU.
verifica daca functioneaza releul 109 in panoul de sub bord (info obtinuta de la al nostru moderator Al Bundy, intr-o alta imprejurare :icon_thumright: )
In prima faza releul 109. Dupa ce rezolvi asta , sterge erorile si vezi daca mai apar.
Salutare!
Masina mea se pare ca a avut o problema cu blocul de valve de la cutia tiptronic pe la 90.000KM, problema rezolvata la un service VW din Germania, prin schimbare blocului de valve si a cablajului.
In urma unor testari Vag Com, imi apar erorile de mai jos; Intrebarea mea este unde se stocheaza aceste erori? in calculatorul masinii sau in calculatorul cutiei? si de unde trebuie sterse?
Mentionez ca masina nu are nicio problema la cutie care sa ma duca cu gandul ca problema a reaparut.
Address 02: Auto Trans Labels: 09A-927-750.LBL
Part No: 09A 927 750 H
Component: AG5 Getriebe 09A 0138
2 Faults Found:
00264 - Solenoid Valve 4 (N91)
30-10 - Open or Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
Ciudata intrebare...in fine; erorile se stocheaza in calculatorul cutiei si tot de acolo se sterg. Cine ti-a facut diagnoza nu a stiut cum sa le stearga?
Oricum, problema este la valva care actioneaza "lock-up clutch". Cu alte cuvinte, la turatii mari ale motorului, acest "lock-up clutch" nu va fi actionat, avand ca efect, transmiterea cuplului motor catre cutie, in proportie de doar ~ 85% (atat poate transmite convertizorul la turatii mari). De aici, poate rezulta si un consum de conbustil mai mare.
tot imi apare si mie o eroare si nu stiu la ce se refera si daca e ceva grav:
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 J HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 10199 599 75590
1 Fault Found
005445 - Throttle Valve Controller: Malfunction
P1545 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 59
Mileage: 138739 km
Time Indication: 0
Date: 2009.08.11
Time: 15:35:00
Freeze Frame:
RPM: 756 /min
Torque: 78.0 Nm
Speed: 4.5 km/h
Voltage: 13.91 V
Duty Cycle: 22.1 %
Bin. Bits: 000
Mass Air / Rev.: 282.0 mg/str
Readiness: 0 1 0 0 0
MULTUMESC
Am mai facut un tester cu vag com si mi-a dat alte erori:
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 FA
Component: 1,9l EDC 0000SG 3349
Coding: 00002
Shop #: WSC 01317
WVWZZZ1JZ2W073595 VWZ7Z0A3689855
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: N/A
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 806 G
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 01112
Shop #: WSC 00000
00462 - Control Module for Seat Memory; Rear (J522)
49-00 - No Communications
Prima data adica acum 2 saptamani mi-a dar eroare ceva de genul cooler sensor temp.
Mi le explica si mie cineva ??
@ 86 BRB
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
Salut, am si eu niste erori , daca ma puteti ajuta sa detetectez unde sunt ,,bubele" :)
Saturday,12,September,2009,17:44:41:21461
VCDS Version: Release 805.1
Address 15: Airbags
Control Module Part Number: 8D0 959 655 J
Component and/or Version: Airbag Front+Seite 1001
Software Coding: 01104
Work Shop Code: WSC 06335
1 Fault Found
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
Saturday,12,September,2009,17:46:11:21461
Address 08: Auto HVAC
Control Module Part Number: 8D0 820 043 N
Component and/or Version: A4 KLIMAAUTOMAT D57
Software Coding: 00043
2 Faults Found
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01273 - Fresh Air Blower (V2)
17-00 - Control Difference
@osama: ai mai jos explicatiile DTC-urilor
01217 - Side Airbag Igniter; Front Driver Side (N199): Resistance too High
01217 - Side Airbag Igniter; Front Driver Side (N199): Upper Limit Exceeded
Possible Symptoms
Malfunction Indicator Lamp (MIL) active
Possible Causes
Wiring/Connectors from/to Side Airbag Igniter, Front Driver Side (N199) faulty
Possible Solutions
Check Wiring/Connectors from/to Side Airbag Igniter, Front Driver Side (N199)
Check Side Airbag Igniter, Front Driver Side (N199) faulty
Check Measuring Value Blocks (MVB)
00779 - Outside Air Temperature Sensor (G17): Open or Short to Plus
Possible Symptoms
In the Instrument Cluster you see dashes (---) instead of a temperature
Possible Causes
Wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster: Open or Short Circuit
Possible Solutions
Check wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster
Check Measuring Block Value
00779 - Outside Air Temperature Sensor (G17): Short to Ground
Possible Symptoms
Possible Causes
Outside Air Temperature Sensor (G17) damaged
Possible Solutions
Check / Replace Outside Air Temperature Sensor (G17)
Possible Causes
Fresh Air Blower (V2) defective
Control Module for Fresh Air Blower (J126) defective
Short of open circuit in wiring to Fresh Air Blower (V2)
Climatronic Control Module (J255) malfunctioning
Possible Solutions
Check Fresh Air Blower (V2)
Perform Output Test (Check Air Vents while Blower is active)
Check Meas. Blocks while Blower is active
Check Control Module for Fresh Air Blower (J126)
Check wiring and connectors
  • Aerofan pinned this topic
