zorg
andrei.toledo
Multumesc de ajutor.
Dupa stergerea erorilor dispar cele de la modulul 46 si cel de la Airbag.Is curios ce semnifica
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
respectiv
01314 - Engine Control Module
79-00 - Please Check Fault Codes
Aceste 2 coduri le-am intalnit la majoritatea Golf-urilor 4 ALH sau SDI.
Aprinderea martorului de ESP la prima apasare a pedalei de frana poate fi datorata acelui switch de la pedala de frana?Becurile de pe frana functioneaza toate.
Pe ce modul apar cele doua erori ?
Cat despre ESP, nu apare din cauza switchului de la pedala de frana. In acel caz apare martorul de bujii (spirala galbena).
01314 - Engine Control Module: No Communications
Possible Causes
* CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
* Fault(s) stored in Engine Control Module
Possible Solutions
* Check CAN-Databus Wiring/Connectors from/to Engine Control Module
* Check Measuring Value Blocks (MVB)
o Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Possible Solutions
* Check Engine Control Module for Fault Codes
Special Notes
* Engine Control Module stored a Code which influences other Control Modules Functionality.
* To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
La fel ca andrei.toledo, am si eu o eroare la MAP:
17563 - Manifold Pressure Sensor (G71): Short to B+
P1155 - 35-00 - -
Intrebarea mea este ce inseamna, daca trebuie sa schimb MAP-ul sau nu, sa stiu sa nu dau bani degeaba.
Mersi.
17563/P1155/004437 - Manifold Abs.Pressure Sensor (G71): Circ. Short to B+
Possible Symptoms
Limp mode
Possible Causes
Connection(s) to/from Manifold Abs.Pressure Sensor faulty
Manifold Abs.Pressure Sensor (G71) faulty
Pipes/hoses not/wrongly attached
Possible Solutions
Check wiring and connections
Check / Replace Manifold Abs.Pressure Sensor (G71)
Check pipes and hoses
Special Notes
Someone with this dtc replaced the Boost Pressure Controle Valve (N75) and the dtc disappeared
respectiv
Da martorul de ESP/ABS fupa apasarea pe pedala de frana este din cauza senzorului de la pedala de frana.
Se regleaza foarte usor, dar ai grija ca are 2 pozitii (pregatire franre si franare)
Sal all,
Am si eu o eroare de care nu reusesc sa scap:
Are cineva idee unde se afla senzorul?
Monday,06,April,2009,15:22:36:21461
VCDS Version: Release 805.1
Address 17: Instruments
Control Module Part Number: 3B0 920 846 A
Component and/or Version: KOMBI+WEGFAHRSP VDO V01
Software Coding: 23115
1 Fault Found
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Modificat de psycho_mishu
andrei.toledo
@kostas
P1654 - 35-10 - - - Intermittent apare pe modulul Motor
Iar 01314 - Engine Control Module
79-00 - Please Check Fault Codes apare la ABS , Instruments si 19 (CAN-Gateway)
Din ce am citit , faptul ca masina nu depaseste 120 km/h poate fi datorat debimetrului care oricum la masurari indica o valoare mai mare decat cele normale.
@psycho_mishu : Aceasta operatiune se face mecanic sau se poate face si din Vag-Com?
Voi da search poate voi gasi mai multe legate de aceasta operatiune.
Multumesc de ajutor
Legat de senzorul G2 vei gasi o discutie interesanta aici
cine ma ajuta si pe mine ...mi se pare ca este cam mare valoare la debimetru....:) este un passat b6...se intampla dupa ce sta la relanti 1 2 min...se inregistreaza valoarea aia mare....
hai ca asta e tare !!! :))) in mers ce zice?
ma asteptam ca la relanti dupa ce egr se dezactiveaza sa sara la 450mg....dar 1300 :)))))))
are cumva eroare stocata?
Am o problema cu motorul la un Polo 1.4 75 CP din 2005. Nu imi dezvolta putere. Nu mi se aprinde martor in bord. Mi-a citit cineva erorile din computer si mi-a spus ca e senzorul de presiune galerie admisie. L-am schimbat degeaba, dand si ceva bani pe el. Ma poate ajuta cineva cu un tester? Stiti unul bun? In sensul sa se priceapa oamenii sa interpreteze rezultatele? Mersi mult...
Ar fi indicat sa completezi in profil si localitatea de unde esti...Ca sa te poata ajuta cineva
@kostas
Multumesc de ajutor
Sal andrei.toledo,
Operatiunea e mai mult mecanic:
1. se scoate intrerupatorul pt faruri (se apasa pe el si se pune in pozitia 1 -pozitie- atunci poate fi scos )
2. se da jos partea de plastic din fata pedalelor - ca sa ai acces la senzor, la passat sunt 4 daca nu ma insel din care 2 sunt ascunse langa sigurante
3. senzorul se afla chiar la mijlocul pedalei de frana si este prin pe niste dintisori
4. ideal ar fi sa ai si un vag-com ca sa verifici cand il reglezi
5. in primii 2-3mm ar trebui sa cupleze pozitia 1 - pregatire de franare - pt cei cu cutie automata e mult mai simplu aceasta pozitie e acceasi cu stingerea becului de pedala de pe bord si de laga schimbator
6. dupa cei 2-3 mm ar trebui sa cupleze becul de frana din spate
Grija mare ca daca va fi intotdeauna in pozitia 1 (pregatire de franare) s-ar putea sa ai acceasi problema.
Apropo ai scanat modulul de abs-esp de erori?
"Din ce am citit , faptul ca masina nu depaseste 120 km/h poate fi datorat debimetrului care oricum la masurari indica o valoare mai mare decat cele normale."
Faptul ca iti indica valori mai mari nu inseamna neaparat ca ai debitmetrul defec - poti sa ai o gaura - spartura pe traseul de aer (care e destul de lung).
"faptul ca masina nu depaseste 120 km/h poate fi" pana la 120km/h accelereaza repede sau greoi?
Am un prieten cu un Golf 4 1.9 TDI ALH din 2001 cu urmatoarele coduri de eroare.
Apropo de "signal too low" si "intermittent" daca iti spun eu cum am rezolvat problema asta o sa ma ia lumea la misto:
Am schimbat bateria la sfatul celor de la Porsche si adio "signal too low" si "intermittent".
Salutare
Azi am fost la o mica diagnoza cu masina mea si am obtinut urmatorul rezultat:
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 M
Component: 1,9l R4 EDC 0000SG 2813
Coding: 00002
Shop #: WSC 01317
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
P3105 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 01317
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 01000
Shop #: WSC 01317
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J5 920 825 C
Component: A4-KOMBIINSTR. VDO V09
Coding: 01112
Shop #: WSC 10127
IMMO-IDENTNR: VWZ7Z0A3566099
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 2K Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
2 Faults Found:
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 D
Component: RADIO SON 0003
Coding: 03403
Shop #: WSC 01317
End -------------------------------------------------------
Poate cineva sa ma lumineze despre ce este vb cu eroarea de mai sus? Nu ma intereseaza alea cu oglinzile pt ca eu nu am incalzire in oglinzi.
P3105 - 35-00 - -
Ma puteti ajuta cu niste indicii?
Va multumesc
motoru cand se opreste se misca puternic?
asta e valva care opreste motoru prin clapeta de pe egr
pe langa furtunele de vacum care vin spre egr mai e un cablu acoperit cu un furtun de plastic.... pe drum spre egr se prinde de conducta care duce spre turbo.... acolo e mancat firul si s-a intrerupt
Da Swat Cat sa stii ca am observat si eu ca atunci cand opresc motorul acesta se misca puternic.....insa nu intotdeauna...cateodata.
Sambata am sa ma duc la meserias si o sa va spun ce am rezolvat.
Merci mult pt ajutor
Swat Cat
Buna ziua. Am observat ca va pricepeti f.bine la scanarea cu vag-com-ul . Am o mare rugaminte daca ma puteti ajuta .
Am un passat b5 1,9 tdi 101cp motor avb . De 3 luni de cind il am nu a trecut de 3500 de turatii niciodata . Pe modulul motor nu am nici un cod de eroare in afara de check memory of instrument cluster care apare cred ca din cauza ca s-au dat km inapoi (nu de catre mine) dar pompe-duzele sunt cam obosite . Am facut un test in mers pe grupele 3.10.11 dar nu ma pricep sa-l interpretez . Mentionez ca turbina este recent schimbata cu una reconditionata . Atasez log-ul cu testul facut ... poate ma puteti ajuta . Va multumesc .
O zi buna .
LOG_2009_003_010_011.xls
iti lipsesc 100 mbari din presiunea reala....cred ca e din actuator (nu e reglat bine)
O zi buna .
I. Din punctul meu de vedere nu ai furnizat toate datele:
Pe vagcom exista o procedura pt testarea turbinei:
in treaptele 4 si 5 se logheaza grupul 11 (si daca vrei 3) si se acceleraza la maxim - valorile rezultate in urma acestui test sunt cele mai concludente.
Apropo va exista o diferenta intotdeauna de presiune - niciodata nu va fi exact ca cerintele.
Mai jos ai procedura de pe rosstech:
Air system part I: Turbo
* Go to Engine Measuring Block 011
* Start Logging the data
* In a high gear (4th/5th) give full throttle from 1500-2000 rpm to 3500-4000 rpm
* Find and Open the Log file in Windows Explorer
* In Excel graph actual/requested boost -vs- rpm
* On a stock vehicle, one should see a spike at 2.1 bar quickly regulated at 1.9 through the whole rpm range
Si link-ul pt mai multe proceduri: http://www.ross-tech.com/vag-com/cars/tdi.html
II. cum ai ajuns la concluzia ca "pompe-duzele sunt cam obosite"?
@kotzo, Cred ca ai o problema cu tampoanele de la motor. Si anume... trebuie schimbate.
Modificat de kostas
Solicit ajutor !!!
Posed un VW transporter T5, 1,9 din 2006
La scanarea cu VAG-COM imi apare o eroare care nu poate fi resetata, si este aprins si ledul de la check engine ...
Va rog cine se procepe sa-mi dea niste informatii. Acesta este mesajul:
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 038 906 016 T
Component and/or Version: R4 1,9L EDC 000SG 8949
Software Coding: 0101031
Work Shop Code: WSC 02756
001138 - Exhaust Pressure Sensor 1 (G450): Signal too Low
P0472 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 83312 km
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Mileage: 170 km
Temperature: 108.0
Salut, am si u o mare problema cu un Golf 5 de 1,4 FSI. Nu vreasa mai porneasca. Am facut scanarea cu VAG-COM-ul si zice urmatoarele:
Wednesday,08,April,2009,17:54:43
Chassis Type: 1K - VW G/J Mk5
Scan: 01 02 03 08 09 0F 15 16 17 18 19 1C 22 25 36 37 3D 42 44 46
47 52 55 56 57 62 65 69 72 76 77 7D
VIN Number: WVWZZZ1KZ6W530847
Address 01: Engine
Part No SW: 03C 906 056 K HW: Hardware No
Component: MED 9.5.10 00 7584
Coding: 0000071
Shop #: WSC 01392
Readiness: 1110 0101
Address 03: ABS Brakes
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 01392
Address 08: Auto HVAC
Part No: 1K0 907 044 AT
Component: ClimatronicPQ35 066 0606
Address 09: Cent. Elect.
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Coding: 018D0F2700041800000A00000F00000000085D035C
Shop #: WSC 01392
Part No: 5M0 955 119 A
Component: Wischer VW359 012 0403
Coding: 00065493
Shop #: WSC 01392
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 169
Mileage: 113226 km
Time Indication: 0
Freeze Frame:
: ON
Voltage: 7.80 V
: ON
: ON
: OFF
: OFF
: OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 169
Mileage: 113226 km
Time Indication: 0
Freeze Frame:
: OFF
Voltage: 8.60 V
: OFF
: ON
: OFF
: OFF
: OFF
Address 15: Airbags
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 1R AIRBAG VW8 015 2100
Coding: 0012626
Shop #: WSC 01373
Address 16: Steering wheel
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenks
:Driver:
Postez aici pentru ca totul se trage de la o eroare vag-com: IMMO
Asadar, ca sa intelegeti amarul: cu mare greutate ne-am cumparat si noi o masina, SH, pentru ca nu am avut bani de una noua, passat b5 din 98 (are 10 ani dar eu ma bucur de ea), pentru ca o vindea un prieten care pleca din romania. Nu merg cu ea la serviciu, nu o folosesc pentru a merge la cumparaturi in coltul blocului cu ea, o folosesc cand imi duc sotia la doctor sau cand chiar am nevoie de ea (mers acasa la parinti).
Pe scurt : nu mai porneste.
Am incercat asa:
1. cheia de rezerva
2. curatat baterie
3. milogit la benzinarie sa ma lase sa iau 5 l de benzina in butoi, pe care i-am bagat cu un furtun, cu ajutorul sotiei
4. verificat sigurante (era arsa una de 30A, pe primul rand din stanga, al doilea (patru in total) rand de sub primele doua randuri de sigurante mici
Nu am avut bani sa o tractez la service, si am reusit dupa multe telefoane sa gasesc pe cineva sa se uite la ea, la fatza locului (stau in Militari).
A venit si a scanat cu VAG-COM, mi-a spus ca are erori pe IMMO, le-a sters si nu au mai aparut, desi i-am spus sa le salveze (offf!). Mi-a luat banii, a zis ca nu are nu stiu ce soft sa ma ajute, a mai tras un pic de fire pe ici, pe colo, si a plecat!
Din cate imi aduc aminte, aratau cam asa (din memorie, deci nu sunt exacte)
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Alte indicii:
- intregul ansamblu de butuci si chei a fost schimbat in ianuarie (cu ce chin!) (dar am mers cu masina de atunci), in urma furtului cheilor de rezerva
- cand pun contactul, toate cele se aprind in bord, iar simbolul de masina cu cheie se aprinde si se stinge (normal, ca si inainte)
- am putut sa-mi resetez singur indicatorul de service (fusese uitat de mecanic dupa revizie), deci teoretic imi vede cheia (nu?)
- porneste electromotorul si atat (se ridica turatia la 3-4 sute de turatii si atat)
Nesimtitii de la reprezentanta unde am schimbat cheile (Midocar) au zis ca ei nu tracteaza masini, chiar daca sunt in garantie, pentru ca nu sunt siguri ca problema e de la piesele lor. Si mai sunt si la 19 km de unde stau eu (Militari versus iesirea spre autostrada Soarelui)
Va rog sa ma credeti ca nu stiu cum sa fac, pentru ca nu am bani sa o tractez pana la Midocar....ajutati-ma si pe mine macar cu un sfat:
1. credeti ca s-a incercat furtul masinii (alarma nu am schimbat-o, din nou, din lipsa de bani), si s-a blocat motorul cand s-a incercat pornirea cu cheile vechi?
2. se poate sa fie ars/stricat cipul de immo (nu trebuia sa-mi apara eroare pe vag-com)?
3. de ce nu porneste masina, daca nu apare intermitent semnul de masinutza cu cheie in bord?
4. are rost sa fac cold-reboot (adica sa scot si sa pun in scurt bornele de la baterie pentru 15 secunde)? ce se poate intampla rau in acest caz?
Multumesc mult de tot,
O seara buna,
Gabi
Modificat de Qntrix
:Driver:
Parerea mea ca s-au desincronizat cheile cu IMMO,.
Cauta pe cineva cu un VAG COM care te poate ajuta (sau macar zona), sau cumpara unul au ajuns destul de ieftine aprox 350 ron (nu stiu cat ai platit pe scanare dar cred ca daca faci 3 scanari pe bani te costa mai mult).
Aici gasesti o procedura pentru IMMO: http://www.ross-tech.com/vag-com/cars/immobilizer.html
Nu am inteles mare lucru in codurile de eroare de la adresa 09. Stie cineva sa-mi zica ce are???
Inainte de asta a s-a rupt cureaua de la alternator si am schimbat-o, dar am mers cam 30 km cu ea asa pentru ca nu eram in localitate. Dupa asta a dat o eroare de engine speed senzor intermitent, am anulat-o cu vag-comul si am mai mers aproximativ 10 km, dupa care s-a oprit si nu a vrut sa mai porneasca.
Bateria o am buna, electromotorul invarte bine motorul.
Ce ar putea fi?
Sal,
Eroarea de la grupul nou 09 iti spune ca ai avut bateria ta a fost super descarcata (~8 V).
Salveaza erorile si dupa sterge tot.
Cum ai verificat bateria ca dupa codurile de eroare arata ca e descarcata complet??
00446 - Function Limitation due to Under-Voltage = Functiile sunt limitate datorita subvoltajului.
002 - Lower Limit Exceeded - Intermittent = limita inferioara atinsa - intermitent
Freeze Frame:
Fault Priority: 4 = Priotitare : 4
Fault Frequency: 1 = Frecventa evenimentului (de cate ori sa repetat) 1
Reset counter: 169
Mileage: 113226 km = Km la care sa produs
Time Indication: 0
Link manual VAGCOM http://www.ross-tech.net/VCDS/download/man...-805-manual.pdf
EXTRAS DIN INTERPRETAREA ERORILOR:
The Display Freeze Frame Data checkbox adds Freeze Frame data for Fault Codes on
control modules using the KWP-2000 or CAN protocols. Note: Not all control modules fully
support this. As a rule of thumb, cars which were re-designed after 2003 will likely have
some control modules that support it, and older designs will not. There's no harm in leaving
this enabled in any case. However, un-checking it can make the results less cluttered in a
scan which contains many fault codes. In vehicles that do not support Freeze Frame, that
checkbox will not be present.
One component of Freeze Frame data is the Fault Priority number as described below:
Number Meaning
1 The fault has a strong influence on drivability, immediate stop is required.
2 The fault requires an immediate service appointment.
3 The fault doesn't require an immediate service appointment, but it should be
corrected with the next service appointment.
4 The fault recommends an action to be taken, otherwise drivability might be
affected.
5 The fault has no influence on drivability.
6 The fault has a long term influence on drivability.
7 The fault has an influence on the comfort functions, but doesn't influence the
car’s drivability.
8 General Note
Fault Frequency shows how many times the conditions that caused the fault have
recurred, during all driving cycles. So, if you have a fault with a Frequency of 11, then
conditions sufficient to trigger the fault have happened 11 times since the fault was stored.
The counter can have values from 0 to 254. It is incremented with each occurrence of the
fault (during all driving cycles).
The Reset counter is a number that has been pre-assigned to each fault, with the number
of problem-free driving cycles before the fault presumably clears itself. Each time a driving
cycle occurs, and the conditions sufficient to trigger the fault do NOT occur, then the reset
counter should go down by one. So if you have a fault with a Reset Counter of 40, if the
controller goes through a problem-free driving cycle then that number should go down to
39.
Merci @psycho_mishu pentru raspunsul prompt. Bateria am masurat-o cu un multimetru profesional si are 13.4V. Probabil ca a fost decarcata cand s-a rupt cureaua, dar dupa ce am schimbat-o a pornit si nu mi-a facut figuri. Am mai mers cu ea vreo 10 km si s-a oprit motorul chiar cand incercam sa o urc pe trotuar sa parchez(deci eram cu el putin mai turat) si nu a mai vrut sa porneasca. Am dat la cheie si degeaba. Inainte de asta, cand am schimbat cureaua am mai facut o scanare cu vag-com-ul si imi spunea ceva de senzorul de speed engine ca este intermitent , dar am ster eroarea fara sa o salvez, din pacate, si nu a mai aparut. Sa fie doar din cauza bateriei? sau este posibil sa fie si altceva?
Senzorul de turatie unde se afla amplasat?
  • Aerofan pinned this topic
