zorg
e turbina sau actuatoru / electroventilul.... dar e ciudat ca in limp nu moare de tot
cred ca turbina a ramas pe intredeschis...dar ca sa mai elimini din posiblitati scoate vacumul de la turbo si vezi daca mai urca presiunea
Modificat de Swat Cat
VAG-COM Version: Release 311.2-N
Control Module Part Number: 038 906 019 EA
Component and/or Version: 1,9l R4 EDC 0000SG 1234
Software Coding: 00002
Work Shop Code: WSC 00028
Additional Info: WVWZZZ3BZ1P059481 VWZ7Z0Y2945177
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Control Module Part Number: 030 906 032 AP
Component and/or Version: ME7.5.10 3245
Software Coding: 00031
Work Shop Code: WSC 00788
Cauze si rezolvari?
Nu ti-a citit o data cipul de la cheie deci a fost blocata pornirea de imobilizator. Asa sa memorat eroarea.
sterge-o si nu mai apare
17978/P1570/005488 - Engine Start Blocked by Immobilizer
Possible Symptoms
* Engine starting but stalling immediately
Possible Causes
* Key(s) not matched
* Instrument Cluster not matched
* Engine Control Unit (ECU) not matched
* Engine Control Unit (ECU) Power Supply faulty
Possible Solutions
* Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
* Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
* Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
* Check Engine Control Unit (ECU) Power Supply (Relay)
Special Notes
* If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, in rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example)
http://wiki.ross-tech.com/index.php/17978/P1570/005488
PS: stie cineva daca site-ul www.bitnet.ro are alta adresa acum? Nu mai functioneaza de ceva vreme.
Reapare eroare, daca nu imediat, dupa ceve timp... Ma confrunt cu ea de ceva timp la masina unui coleg de forum. A incercat variantele mai simple, probabil s-a intamplat ceva cu un cablu de la imobilizator cand a fost montata alarma.
Cu aceeasi eroare, masina nu pornea, am pus Vag Comul, am sters-o, a pornit, nu a reaparut eroarea. A mers fara probleme 2 saptamani, dupa care din nou a reaparut problema.
Eroarea asta:
a fost insotita si de :
01176 - Key
07-10 - Signal too Low - Intermittent
Sper sa se rezolve, e destul de bine explicat pe wiki.ross-tech.
LE: Apropo, daca eroarea respectiva are aceleasi cauze ca cea despre care am vorbit mai sus, in cazul in care nu exista la indemana Vag Com pentru a sterge eroarea daca nu porneste motorul, la mine a pornit dupa ce am scos borna de la baterie, desi eroarea a existat si dupa aceasta procedura.
Modificat de WVWZZZ
01176 - Key
De zece minute le-am sters eu ca le aveam memorate dar fara sa scot borna bateriei,pur si simplu din VAG-COM. Erorile au aparut cand am facut eu o proba sa vad daca cipul din cheie citeste immo din orice pozitie,dar sa dovedit ca daca nu tii cheia briceag in pozitia corecta sa poata sa comunice cheia cu immo motorul nu mai porneste fiind blocat de imobilizator
Borna bateriei am scos-o cautand o alternativa pentru Vag Com cand nu porneste masina. Fiind masina cuiva care nu are Vag Com am vrut sa ii ofer o alta solutie daca cumva nu ii porneste masina si nu are de unde sa scoata Vag Com. Eroarea, evident, nu s-a sters si nici nu am crezut ca se va sterge cand scot borna. L-am rugat sa incerce cu ambele chei cand nu porneste masina si mi-a spus ca desi a facut asta, masina nu a pornit :vaidecapulmeu: Asta este motivul pentru care se poate ca problema sa fie in alta parte si nu neaparat la cheie...
Cred ca ar fi mai simplu sa ii dea IMMO OFF....daca nu stie cum sa rezolve problema...dar sunt sigur ca este de la alarma aftermarket. Este cumva cu pornire din telecomanda?
Nu, din cate stiu eu nu porneste din telecomanda, sper sa nu ma insel. Oricum am inteles ca eroarea exista de mult timp, doar ca mai nou a inceput sa nu mai porneasca ocazional. O sa ma uit in measuring blocks data viitoare, poate mai elimin astfel din posibilele cauze :)
Poate cineva sa-mi spuna cineva despre erorile pe care le am la masina mea?
Address 01 -------------------------------------------------------
Controller: 038 906 018 AE
Component: 1,9l R4 EDC 0000SG 2140
Coding: 00002
Shop #: WSC 01317
3 Faults Found:
18025 - Glow Plug Pre-Heat Indicator (K29): Open or Short to Ground
P1617 - 35-10 - - - Intermittent
18027 - Glow Plug Relay (J52): Open or Short to Ground
P1619 - 35-00 - -
Readiness: N/A
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 B
Component: CLIMATRONIC V 1.0.0
Coding: 01000
Shop #: WSC 01317
01206 - Signal for Duration of Ignition: OFF
35-00 - -
Address 17 -------------------------------------------------------
Controller: 1J0 920 822 B
Component: KOMBI+WEGFAHRS. BOO V20
Coding: 07142
Shop #: WSC 00000
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1215653
2 Faults Found:
00534 - Engine Oil Temperature Sensor (G8)
30-00 - Open or Short to B+
01321 - Control Module for Airbags (J234)
49-00 - No Communications
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 2K Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
3 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
Am facut si eu o scanare aseara si mi-a dat urmatoarea eroare :
Controller: 038 906 019 EA
Component: 1,9l R4 EDC 0400SG 1263
Coding: 00002
Shop #: WSC 00028
WVWZZZ3BZ1P139363 VWZ7Z0Y3296102
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
Readiness: N/A
Am incercat sa o sterg si nu vrea, revine iar?
Ce trebui facut?
Si am si un log in mers se poate uita cineva si moate sa zica de ce intra in limp-mode pe la 3200 de rot/min???
LOG_01_003_010_011.zip
Din cate vad, cred ca s-a blocat actuatorul ...Verifica totusi si MAF
"Din cate vad, cred ca s-a blocat actuatorul ...Verifica totusi si MAF"
Te rog poti sa fii un pic mai explicit.
Pe partea electrica: "The steering angle sensor G85 supplies its information directly over the CAN databus to the control unit" adica el comunica direct cu controllerul ABS, prin magistrala masinii, si nu are "doua fire care duc de la el la controller" - asa cum ai afirmat tu.
Magistrala de CAN a masinii e formata din 2 fire torsadate intre modulele masinii si cu noduri de retea.
24_CAN_Databus.pdf
Actuatorul este tija de actionare a geometriei variabile a turbinei (vezi foto)
MAF = debitmetru de aer
Din cate vad tu ai pus un bord mai nou decat suporta masina, sterge erorile si scaneaza din nou 01, 15, 19, 17.
@RaduVoicu Al bundy are dreptate, in g85 ai o masa, un 12v de pe baterie un 12V de contact si 2 fire de can bus torsadate(daca ar face scurt ai avea si in restul calculatoareleor cod de eroare legat de magistrala can). Daca stergi eroarea reapare imediat sau dupa ce rulezi cu masina , daca mergi cu viteza mai mare apare mai repede?
ai climatronic sau ac?
legat de log, verifica turbina cum zicea si cuiuda.
MAF nu are nimic, e normala valoarea aceea la 2560 mbari.
01176 - Key
despre ce masina e vorba? strange pinii din mufa bordului si de pe bobina cititoare , readapteaza cheile si ar trebui sa fie ok.
(terrabyt ai climatronic sau ac? )
Am climatronic
Este vorba de Golful 4 de aici . Oricum, merci pentru raspuns, ma gandisem si la varianta asta...
Modificat de WVWZZZ
Probleme cu cruise control-ul la G5-ul unui prieten. De la ce vine problema, ce trebuie inlocuit/reparat? Multumesc
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 39
Mileage: 30550 km
Time Indication: 0
Date: 2000.00.00
Time: 20:34:30
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenks
Azi am facut iar o scanare si uite ce am gasit
Component and/or Version: 1,9l R4 EDC 0400SG 1263
Additional Info: WVWZZZ3BZ1P139363 VWZ7Z0Y3296102
2 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
Dupa o scanare la un Golf IV am gasit:
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 M
Component: 1,9l R4 EDC 0000SG 2813
Coding: 00002
Shop #: WSC 01317
2 Faults Found:
17656 - Start of Injection Timing Regulation: Control Deviation
P1248 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 18945
Shop #: WSC 01317
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 0F AIRBAG VW5 01 0004
Coding: 12358
Shop #: WSC 01317
2 Faults Found:
00589 - Airbag Igniter 1; Passenger Side (N131)
32-00 - Resistance too High
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 805 E
Component: KOMBI+WEGFAHRS. BOO V01
Coding: 01112
Shop #: WSC 00000
Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y1994637
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1994637
01176 - Key
Ne intereseaza mai mult eroerea 17656 si 01276
17656 Nu este reglat corect avansul la injectie,ai trei suruburi de 8 cu o cheie de 13 pe fulia p.inj. regleaza avansul prima data .
Ma poate ajuta cineva cu eroarea asta:
Controller: 1C0 959 799 E
Component: 2U Komfortger
E codat gresit modululd e confort. Codul 00067 are semnificatia de deschidere a tutoror usilor la masinile doatate cu numai doua geamuri electrice (fata).
Din ce an e masina si cate geamuri electrice si usi cu inchidere centralizata are?
Modificat de hiro
  • Aerofan pinned this topic
