zorg
Address 01: Engine Labels: 038-906-019-130.LBL
Part No: 038 906 019 DS
Component: 1,9l R4 EDC 0000SG 1266
Coding: 00002
Shop #: WSC 05311
WVWZZZ3BZ1E117502 VWZ7Z0Y3013734
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Salut...daca stie cineva ce inseamna aceasta eroare...mi-o aparut dupa ce am luat limp mode...spuneti-mi si mie ce inseamna eroarea asta....multumesc
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
* Reduced power output
* Limp mode
Possible Causes
* Boost Pressure too High
* Hoses/Pipes incorrect connected, disconnected, blocked or leaking
* Charger Pressure Control defective
o VNT (variable nozzle turbo): nozzles stuck
* Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
* Check Hoses/Pipes to/between Components
* Check Solenoid Valve for Boost Pressure Control (N75)
* Check / Clean / Replace Charge Pressure Control
o Check / Clean mechanism for variable nozzles
Rezultat obtinut cu http://www.bitnet.ro/vw/vagalizer/index.php.
Cam asta inseamna:
Possible Symptoms
Limp mode
Possible Causes
Possible Solutions
Am avut-o si eu; Rezolvarea a fost curatarea turbinei. Imbacsita de fum, dar asa cum scrie mai sus trebuie verificate si toate vacumurile
am urmatoarea problema:
Seat Cordoba fabricatie 2004, motor 1,9tdi pd.
La scanarea cu vag com au aparut urmatoarele erori:
Address 09: Cent. Elect.
Control Module Part Number: 6Q1 937 049 C
Component and/or Version: 00 BN-SG. 1S33
Software Coding: 00140
Work Shop Code: WSC 06441
Fault Codes have been Erased
3 Faults Found:
1 - Selector Lever (E313)
49-00 - No Communications
8 - Steering Angle Sensor (G85)
4 - Control Module for All Wheel Drive (J492)
si
Address 19: CAN Gateway
Control Module Part Number: 6N0 909 901
Component and/or Version: 65 GATEWAY CAN 1S33
Software Coding: 00014
3 Faults Found:
00511 - Selector Lever (E313)
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
poate cineva, cumva, sa ma limpezeasca?
multumesc
Daca ne spui si ce echipari are masina ta....
Este 4x4?
Are cutie automata?
Ideea ar fi, daca nu cumva este codata gresit adresa 19.!?
nu are 4x4 (as vrea eu)
iar la codare m-am uitat da cred ca este corecta ??????????
Are cutie manuala in 5 trepte - si nici macar nu are control pe cutie !
Atunci, de unde eroarea "01324 - Control Module for All Wheel Drive (J492) "...?
sincer nu am nici cea mica idee
am postat erorile pentru ca eu nu mai stiu ce sa mai ziccc.
acum 2 luni era absulut curata.... nu avea nici o eroare.... iar acum are deja 4x4!
este perfect adevarat ca are un pic de joc in bucsele de la ritile din fata, si asta sa imi dea eroarea pe servodirectie, dar pana la 4x4.. e distanta
si ce e selector lever?
Coding: 00002
Shop #: WSC 05311
Daca verifici tot ce este legat de vacum si electrovalva n75 si este ok atunci este posibil sa ai nevoie de un compresor findca se agata pargia de la geometria variabila eu a-m curatat cateva dar la cererea clientului si fara garantia ca va merge timp andelungat din pacate astea trebuie schimbate mai ales daca ai kilometri multi 2-3sute de mii poti ancerca curatirea turbinei dar nu tine mult timp asta din experienta proprie :)
@lxl
Cred ca erau necesare niste semne de punctuatie. :)
rizeab; intra si la abs si la engine si scrie aici ce coding au fiecare
da, dar alea nu imi dau nici o eroare
si de altfel masina se comporta super ok
momentan nu pot intra pe masina, dar probabil ca luni o sa o fac
exact acolo trebuie sa umbli si sa pui codul corect.
@rizeab Nu te stresa, dai recodare cu codu actual(00014) si o sa-si revina, o mai ia din cand in cand bornetz (care are si gateway inauntru) razna. :P
multumesc mult
sper din tot sufletul sa mearga, ca am ramas fara idei
oricum va spun luni
multumesc mult
Bogdanys
multumesc mult pt raspuns :P
Daca verifici tot ce este legat de vacum si electrovalva n75 si este ok atunci este posibil sa ai nevoie de un compresor findca se agata pargia de la geometria variabila eu a-m curatat cateva dar la cererea clientului si fara garantia ca va merge timp andelungat din pacate astea trebuie schimbate mai ales daca ai kilometri multi 2-3sute de mii poti ancerca curatirea turbinei dar nu tine mult timp asta din experienta proprie :(
deci masina are 242 de mii de km si la turbina nu am umblat deloc de cand o am 155 de mii .
o sa ma interesez de curatat turbina .
sper sa nu se agraveze pb :D
Modificat de THE ROCK
Verifica intai actuatorul de la turbina sa nu fie blocat sau sa se miste greu.
Ai perfecta dreptate dar an ganeral la cate a-m desfacut turbina a-m gasit paletii de la geometrie ca se agatau an cei doi pereti ai turbinei si actuatorul care la modelul asta este comandat cu vacum nu dezvolta atata putere s-al poata misca pana an limitele max. si min.
Cel mai des al deschide la maxim dar se agata la coborare an jos unde a-l anpinge arcul din capsula de vacum care are o putere limitata si raman paletii antrun unghi an care turbina are turatie mult peste cerintele motorului an anumite momente de sarcina si apare suprapresiunea sesizata de ecu.
Urat defect... :coolpics: ceva pe la turbina,actuatorul blocat citeste de la inceput topicul asta si o sa vezi la mai multi si chiar si la mine am tot comentat pe acest cod de eroare
:nono: Nu actuatorul se blocheaza omule .La ala in cel mai rau caz se sparge membrana si nu mai tine vacuum.
In cazul asta calamina depusa coroborata cu uzura mecanica a vanelor si al inelului ce misca vanele si intreg ansamblul se gripeaza sau se misca defectuos .
:) cred ca s-ar rezolva daca l-ar unge cu putina vaselina :nono:
Ca sa revenim ontopic:
Pana sa demontati piese din masina puneti un VAG-com si dati un test pe actuatori de unde selectati N75 dupa care coborati din masina si mergeti frumos in fata masinii si uitati-va daca tija actuatorului face cursele complete pana la minim si maxim. Repetati aceasta chestie si cu motorul cald eventual sa nu banuiti un comportament diferit cu motorul cald.
Eu am patit sa imi dea limp-uri din cauza unui furtun de vacuum crapat care la cald se manifesta mai abitir decat la rece.
Modificat de dukku
Salutare.Am scanat un Vw Passat din 2003 1.9 TDI AVB
La prima scanare arata cam asa :
VCDS Version: Release 805.0
Data version: 20080529
Thursday,17,January,2008,13:50:14:21461
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ3E407832 Mileage: 170500km/105943miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 GL
Component: 1,9l R4 EDC 0000SG 1495
Coding: 00002
Shop #: WSC 05314
WVWZZZ3BZ3E407832 VWZ7Z0C7074909
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17571 - Fuel Temp Sensor (G81): Open or Short to Plus
P1163 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04255
Shop #: WSC 05311
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0009
Coding: 17000
Shop #: WSC 05311
2 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
Dupa stergerea erorilor logul arata cam asa :
Thursday,17,January,2008,15:04:00:21461
Coding: 00002
Shop #: WSC 05314
Coding: 04255
Shop #: WSC 05311
No fault code found.
Coding: 17000
Shop #: WSC 05311
Sunt mai mult interesat de eroarea aceea la modul ABS.Din cate mi-a spus propietarul se intampla sa i se aprinda martorul de la ESP cateodata in mers.
Astept opinii asupra logurilor.
Rezolva problemele de la engine, cele 2 defecte dau un consum mare si o pornire greoaie si performante scazute la motor si o sa vezi ca dupa inlocuirea senzorilor si stergerea erorilor nu mai apare nimic la ABS.
Trebuie inlocuite: senzorul temperatura lichid racire si senzorul de temperatura combustibil
Modificat de al bundy
salutare
am si eu om problema care mi-a aparut in ura unei scanari
aici pe forum nu am gasit nimic despre aceste orori
imi poate zice cineva ceva?
  • Aerofan pinned this topic
    • alinbum
