zorg
F l o r i n
On 5/5/2018 at 3:34 PM, filiphimself said:
In schimb când las on rămâne aceeași stare fa pe off (not oper.
da jos maneta si verifica/repara cablajul din interiorul acesteia.
cu un spray de contacte, curata si switch-urile
buna, ma ajuta si pe mine cineva cu ceva erori
1
Adresa 01: Motor (J623-CFGB)       Eticheta: ROJ\03L-906-018-CFF.clb
   Numar VAG SW: 03L 906 018 LH    HW: 03L 907 309 AD
   Componenta: R4 2,0l EDC   H25 2076
   Revizie: 42H25---    Numar serial: 00000000000000
   Codare: 00190012043600080000
   Atelier: WSC 01324 020 00200
   Pachet ASAM: EV_ECM20TDI01103L906018LH 003006
   ROD: EV_ECM20TDI01103L906018LH_VW36.rod
   VCID: 7BFF9C19F200B4F93A9-802E
1 cod a gasit:
10065 - Debitmetru aer-G70-  lipsa semnal
          P0104 00 [032] - -
          intermitent - Neconfirmat - Testat deLa otergere de memorie
             împrejurari cod:
Gata de func?ie: 0 0 0 0 0
 2
Adresa 08: Clima automata (J255)       Eticheta: ROJ\5K0-907-044.clb
   Numar VAG SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Componenta: Climatronic   H18 1112
   Revizie: 00001004
   Codare: 0000004002
   Pachet ASAM: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 0005EBF59BE6D7216FB-8055
1 cod a gasit:
13701520 - Limitare de functii -  cauza
          U1111 00 [009] - lipsa mesaj
          Confirmat - Testat deLa otergere de memorie
             împrejurari cod:
                    Stare defect: 00000001
                    Priorit.defect: 6
                    Frecv. defect: 8
                    Resetare contor: 158
                    rulaj: 61544 km
                    Data: 2018.05.13
                    timp: 01:43:28
3
Adresa 09: Electr. centrala (J519)       Eticheta: ROJ\1K0-937-08x-09.clb
   Numar VAG SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Componenta: BCM PQ35 M    011 0048
   Revizie: BC011001
   Codare: 40180A3BE8251AC0400800C0340009E44B750008736D8560E48400000040
   VCID: 3B7F5C19BA8074F97A9-806E
   Subsistem 1 - Numar VAG SW: 5N1 955 119     HW:              Eticheta: ROJ\1KX-955-119.CLB
   Componenta: Wischer 06101  013 0203
   Codare: 009795
   Subsistem 2 - Numar VAG: 1K0 955 559 AH  Eticheta: ROJ\1K0-955-559-AG.CLB
   Componenta: RLS 111011 05  54  0403
   Codare: 06304D
1 cod a gasit:
01333 - Modul comanda usa: stânga spate-J388-
            004 - lipsa semnal / nu comunica
             împrejurari cod:
                    Stare defect: 01100100
                    Priorit.defect: 6
                    Frecv. defect: 1
                    Resetare contor: 157
                    rulaj: 61544 km
                    Indicator de timp: 0
                    Data: 2012.10.03
                    timp: 01:43:30
             împrejurari cod:
                        Cl.15 Con.
                    tensiune: 12.00 V
                        Con.
                        Con.
                        Dec.
                        Dec.
                        Dec.
4
Adresa 19: Poarta CAN  (J533)       Eticheta: ROJ\7N0-907-530-V2.clb
   Numar VAG SW: 7N0 907 530 K    HW: 1K0 907 951
   Componenta: J533  Gateway H40 1620
   Revizie:   H40       Numar serial: 011011F2001663
   Codare: 356002
   VCID: 387543158BB65FE197B-806D
1 cod a gasit:
             împrejurari cod:
                    Priorit.defect: 2
                    Frecv. defect: 1
                    rulaj: 61544 km
                    Data: 2012.10.03
                    timp: 01:43:29
5
Adresa 37: Naviga?ie (J0506)       Eticheta: ROJ\1T0-035-680.clb
   Numar VAG SW: 1T0 035 680 F    HW: 1T0 035 680 F
   Componenta: RNS-MID       H61 3970
   Revizie: AB001001    Numar serial: VWZ6Z7L2287112
   Codare: 0405000201000080000C
   VCID: 31637E3168CC8EA9D05-8064
1 cod a gasit:
00862 - Antena pentru navigatie -GPS- -R50/R52-
            007 - scurt la masa - intermitent
             împrejurari cod:
                    Stare defect: 00100111
                    Priorit.defect: 5
                    Frecv. defect: 6
                    Resetare contor: 198
                    rulaj: 42632 km
                    Data: 2016.04.24
                    timp: 14:06:33
6
Adresa 52: Uoa electr.pasager        Eticheta: ROJ\1K0-959-702-MAX3.lbl
   Numar VAG SW: 5N0 959 702 E    HW: 5N0 959 702 E
   Componenta: Tuer-SG         009 2111
   Codare: 0004542
   VCID: 387543154BB65FE197B-806D
1 cod a gasit:
Adresa 56: Radio (J0506)       Eticheta: ROJ\1T0-035-680.clb
1 cod a gasit:
             împrejurari cod:
                    Priorit.defect: 5
                    Frecv. defect: 6
                    rulaj: 42632 km
                    Data: 2016.04.24
                    timp: 14:06:33
8
Adresa 62: Uoa SS
Nu poate fi accesat
sper ca sunt enumerate corect . din cate am vazut unele sunt similare poate acelasi lucru. nu ma pricep asa ca va intreb pe voi.
am mai patit acum un an ceva de genu pe partea dreapta si a fost o siguranta , si am avut ceva probleme la sistemul audio nu se auzea in boxele masinii. toate au fost rezolvat la reprezentanta . dar observ acum ca nici eu nu cred ca stiu ce a avut.
un ajutor va rog
Debitmetru defect sau probleme cablaj
Usa stinga spate -modul defect sau cel mai probabil fire rupte in manson
Antena Gps defecta-se inlocuieste.
Sterge erorile si verifica ce mai ramine..posibil ca unele sa dispara.
juniorcelmic
Buna ziua,
am un golf 6 ca in semnatura si de la o vreme imi da anumite semne ca ceva nu e bine.
spre exemplu, atunci cand opresc motorul, fara sa scot cheia din contact, se opreste rns-ul.
portierele nu se deblocheaza dupa ce scot cheia din contact; daca opresc  masina la semafor, se deblocheaza portierele cateodata. imi aparea si o problema cu microfonul, dar am citit pe forum si am debifat la navigatie. nu mai arata acum eroare. a functionat totul bine pana acum o luna.
Va rog sa ma ajutati si pe mine sa repar erorile. Multumesc!
am facut o scanare cu vcds la masina si mi-au aparut urmatoarele erori:
logvw.txt
schimba partea electrica a contactului de pornire.
Ms. Am rezolvat defspt imi erau dezactivate majoritatea modulelor de pe masina. Cred ca la service sau jucat baietii cand au resetat pt schimbul de ulei. Un laptop, un tip meserias sa apucat de codat cam jumătate de ora si 250lei. Scurt si la obiect acum totul merge.
Vin si eu cu o problema la G6 2.0Tdi CDBC .
S-a oprit in mers cu spirala si n-a mai pornit.  Am incercat la automat dar s-a facut pom de craciun.
La scanare imi zice ca nu poate accesa Engine , deci ECU nu raspunde. Mentionez ca am resoftare facuta la TCM Turbo aproape 1 an.
Bateria are 1 an vechime.
Orice sfat e binevenit.  Un electrician/electronist in Cluj Napoca care sa ma ajute?
Atasez un autoscan:
Spoiler
Tuesday,15,May,2018,17:46:30:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W566905
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 113B200D09280000881404E4901E00423000
   Shop #: WSC 01357 011 00200
   VCID: 74EDC209D7A00E9
2 Faults Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 192713 km
                    Time Indication: 0
                    Date: 2102.14.18
                    Time: 16:42:30
             Freeze Frame:
                    Count: 0
                    Count: 0
                    Count: 4096
                    Count: 8196
                    Count: 40965
                    Count: 65535
                    Count: 0
                    Count: 0
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 192713 km
                    Time Indication: 0
                    Date: 2102.14.18
                    Time: 16:42:40
             Freeze Frame:
                    Count: 0
                    Count: 0
                    Count: 4608
                    Count: 8194
                    Count: 36617
                    Count: 256
                    Count: 0
                    Count: 0
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3AA 907 044 F    HW: 3AA 907 044 F
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0010004803
   Shop #: WSC 00015 115 12345
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_VW46.rod
   VCID: 336F01159A2E491
2 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 254
                    Reset counter: 184
                    Mileage: 187952 km
                    Date: 2099.14.14
                    Time: 11:39:01
9479442 - Control Circuit for Front Right Seat Heater
          B10A5 12 [009] - Short to Plus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 78
                    Mileage: 189939 km
                    Date: 2101.14.00
                    Time: 15:50:31
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 084     HW: 1K0 937 084
   Component: BCM PQ35  B   020 0360
   Revision: 00020000
   Coding: 00180A3F98211AC000080000000000E045010488525D8920468000000000
   Shop #: WSC 12345 123 12345
   VCID: EBDF59750A9E511
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 20040  21  0501
   Coding: 009F95
4 Faults Found:
01504 - Bulb for License-Plate Light (X)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Reset counter: 224
                    Mileage: 186621 km
                    Time Indication: 0
                    Date: 2098.14.05
                    Time: 17:56:13
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 184
                    Mileage: 192713 km
                    Time Indication: 0
                    Date: 2102.14.18
                    Time: 16:42:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 10.30 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01519 - Bulb for Back-Up Lights; Right (M17)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Reset counter: 184
                    Mileage: 186621 km
                    Time Indication: 0
                    Date: 2098.14.05
                    Time: 17:58:35
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.55 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01502 - Bulb for Rear Fog; Left (L46)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 192713 km
                    Time Indication: 0
                    Date: 2102.14.18
                    Time: 00:50:56
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475     HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0002
   Revision: --------    Serial number: 60640910601950
   Coding: 100001
   VCID: F3EF411552AE891
No fault code found.
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2R66299X
   Coding: 00003135
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: F7F775054ED6E51
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 6E4A1248ZZZZZZZZZZZZ
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 67044247ZZZZZZZZZZZZ
   Crash sensor for side airbag; rear driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 004A1D7BZZZZZZZZZZZZ
   Crash sensor for side airbag; rear passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 121A1E6DZZZZZZZZZZZZ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0020532
   Shop #: WSC 35110 377 09999
   VCID: 76E9F80101DC1C9
   Subsystem 1 - Part No: 3C8 959 537 D
   Component: E221__MFL-TK6   H07 0022
   Coding: 00000227
   Shop #: WSC 00000
2 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
00380 - Special Vehicle Control Module (J608)
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 870 C    HW: 5K0 920 870 C
   Component: KOMBI         H21 0030
   Serial number: 00000000000000
   Coding: 170B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 2D5B176D7C0A1F1
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 184
                    Mileage: 192713 km
                    Date: 2102.14.18
                    Time: 16:42:38
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 130409F2000603
   Coding: E9A07F06000202000002
   VCID: 377735054656A51
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 192713 km
                    Time Indication: 0
                    Date: 2102.14.18
                    Time: 00:50:17
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H21 0030
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2123
   Coding: 0000180
   VCID: 336F0115522E491
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 69     2501
   Revision: 00H15000
   VCID: 2C5D1A698F10169
3 Faults Found:
00778 - Steering Angle Sensor (G85)
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Time Indication: 0
             Freeze Frame:
                    Battery Volts: 12.4 V
                        PD
                    Temperature: 23.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 0
                        SteerAng n.Init
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 192713 km
                    Time Indication: 0
                    Date: 2102.14.18
                    Time: 00:01:09
             Freeze Frame:
                    Voltage: 12.13 V
                        DU
                    Temperature: 23.0°C
                    RPM: 1498 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
00750 - Warning Lamp
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 192713 km
                    Time Indication: 0
                    Date: 2102.14.18
                    Time: 00:01:15
             Freeze Frame:
                    Voltage: 12.13 V
                        DU
                    Temperature: 23.0°C
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Coding: 0000436
   VCID: 356B3F0D5C5A571
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 04105GD0023523
   Coding: 0000040004000A
   Shop #: WSC 00081 790 00126
   VCID: 458B4FCDCCBAC71
00856 - Radio Antenna
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 32
                    Reset counter: 131
                    Mileage: 173891 km
                    Time Indication: 0
                    Date: 2024.14.24
                    Time: 21:01:01
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 7AF1EC3135C4789
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
   VCID: 7BFFE9353AFE411
End   ---------------------------------------------------------------------
Modificat de Xtremu
Verifica intai sigurantele..
Verificat, par in regula în ambele panouri de sigurante.
Trebuie scos Ecu,vazut daca are alimentari,masa,can-uri...
Mda. Multumesc .
Imi recomanda cineva unde as putea sa o duc in Cluj Napoca?
Modificat de Xtremu
Revin cu un update la problema mea : ECU Defect .
03l906022LF este codul lui.  Exista vreun echivalent, sau pot pune doar codul acesta?
F l o r i n
pune o poza cu eticheta de pe el
Xtremu-resoftarea s-a facut by Obd  sau pe banc?
@spido Pe banc, ca nu se poate prin OBD.
Banuiesc si eu ca ceva s-a intamplat acolo.
@F l o r i n O sa revin cu poza cand mi-o trimite electricianul.
LE:
Am gasit pana la urma un ECu cu codul de mai sus la un pret convenabil.
LE2:
Banuiesc ca dupa ECU swap trebuie recodate cheile ?
E destul sa duc doar o cheie sau trebuie ambele?
Modificat de Xtremu
Ma poate ajuta si pe mine cineva cu un cod la piesa N345? Am acesta eroare: 005269 - Switch-Over Valve for EGR Cooler (N345). Multumesc
juniorcelmic
On 14.05.2018 at 20:46, Al Bundy a scris:
multumesc mult pentru sfat!  Am schimbat partea electrica la contactul de pornire si au disparut o parte din erori.
A ramas doar asta:
   Part No SW: 5K0 920 870 G    HW: 5K0 920 870 G
   Component: KOMBI         H13 0112
   Revision: X0013004    Serial number:
   Coding: 170F00
   Shop #: WSC 00066 000 00149
   ASAM Dataset: EV_KombiUDSMM9RM10 A04102
   ROD: EV_KombiUDSMM9RM10_VW36.rod
   VCID: 31697FA260E870CA1F-8064
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [008] - Internal electronic failure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 20993 km
                    Date: 2010.12.06
                    Time: 06:43:16
de la ce ar putea fi?
Va salut
Am in intentie sa cumpar o skoda cu dsg, 2013 de 2000 diesel, si  am facut un log si am cautat in cutie.
Nu imi apare grupul de valori 08, acolo unde stiam eu ca apar kilometri in cutie automata, asa ca am intrat la valori selectate si am bagat in filtru "km"
masina are in bord 161533, iar aici imi apare ceva cu 290000. Sa fie aia kilometri reali? Masina este prea legata pentru atâția kilometri
                Adresa 02: Cutie automatã  (0D9 300 040 K)
17:12:04
  IDE03189-ENG110508   Numãrul prevenirilor de oprire proces(statisticã)-km-Stand des letzten Stoppverbots 290944.0 km
  IDE05987-ENG110508   Prohibiþii stop motor-km-Stand des letzten Stoppverbots 290944.0 km
  ENG120969   Km-parcurºi dupã ultimul eveniment pe K1 60 km
  ENG120971   Km-parcurºi dupã ultimul eveniment pe K2 60 km
Am mai gasit si urmatoarele erori:
Adresa 01: Motor (J623-CKFC)       Eticheta: ROJ\04L-907-309-V1.clb
   Numãr VAG SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5520
   Revizie: 83H22---
   Codare: 111D0012043401090000
   Atelier: WSC 73430 031 00140
   Pachet ASAM: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AF19DD1FD786491A7-802E
2  coduri de defecte:
7144 - Cititi memoria de defecte la
          U1008 00 [047] - poarta CAN -J533- [Gateway] (adr.19)
          Confirmat - Testat deLa ºtergere de memorie
             împrejurãri cod:
                    Priorit.defect: 2
                    Frecv. defect: 8
                    rulaj: 161027 km
                    Data: 2018.04.27
                    timp: 23:18:12
                    Turaþie motor: 768.00 /min
                    Valoare de sarcinã normatã: 27.5 %
                    Viteza vehicul: 0 km/h
                    Temperatura antigel: 42 °C
                    Temperatura aer admisie: 30 °C
                    Presiune aer ambiental: 1010 mbar
                    Tensiune terminal 30: 13.880 V
                    Numãrãtor procese de adaptare nereuºite conform OBD: 40
                    Drive_train_coordinator_ACC_failure_state-Monitor_status_additional_onboard_diagnosis_camshaft_knock_sensors_bit0: 0
                    Drive_train_coordinator_ACC_failure_state-Monitor_status_additional_onboard_diagnosis_bit8: 0
                    Drive_train_coordinator_brake_failure_state-Monitor_status_additional_onboard_diagnosis_camshaft_knock_sensors_bit0: 0
                    Drive_train_coordinator_brake_function_state-Monitor_status_additional_onboard_diagnosis_camshaft_knock_sensors_bit0: 0
                    Drive_train_coordinator_brake_function_state-Monitor_status_additional_onboard_diagnosis_bit8: 0
                    Accelerare: 0.000 m/s2
7158 - Cititi memoria de defecte la
             împrejurãri cod:
                    Priorit.defect: 2
                    Frecv. defect: 1
                    rulaj: 161027 km
                    Data: 2018.04.27
                    timp: 23:17:13
                    Turaþie motor: 1636.00 /min
                    Valoare de sarcinã normatã: 38.0 %
                    Temperatura antigel: 36 °C
                    Tensiune terminal 30: 14.000 V
                    Stare resetare ECU motor-Monitor_status_additional_onboard_diagnosis_camshaft_knock_sensors_bit0: 0
                    Stare resetare ECU motor-Monitor_status_additional_onboard_diagnosis_bit8: 0
                    Limitare:cuplu: 134.9 Nm
                    Limitare:pedala de acceleraþie: 50.7 Nm
                    Sistem menþiere vitezã: stare-Monitor_status_additional_onboard_diagnosis_camshaft_knock_sensors_bit0: 0
                    Accelerator_pedal_position_raw_value: 19.78 %
                    Cuplu motor: 50.8 Nm
                    Generator:semnal sarcinã: 30.00 %
Gata de funcþie: 0 0 0 0 0
Adresa 02: Cutie automatã (J743)       Eticheta: 0D9-927-770.clb
   Numãr VAG SW: 0D9 300 040 K    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4028
   Revizie: 05652104    Numãr serial: TFK01307291290
   Codare: 0014
   Pachet ASAM: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1F478C45061AE1B9F0-804A
5  coduri de defecte:
21153 - Treapta 1. -nu este setabilã
          P072C 00 [002] - -
          intermitent - Neconfirmat - Testat deLa ºtergere de memorie
21159 - Treapta R
          P072B 00 [002] - -nu este setabilã
10731 - Ventil 3 în cutie parþialã 1
          P174A 00 [002] - defect lelectric
10906 - Ventil ulei rãcire;defect electric
          P179D 00 [002] - -
10763 - Autorizare pornire de la senzorii selector treaptã
          P1734 00 [002] - -
Orice parere imi poate fi de folos. Va multumesc.
Incearca cu o interfata originala ,pare ca are 290.944km
Nu,nu trebuie recodate cheile.Se face doar adaptarea noului Ecu pe masina.
@juniorcelmic- eroarea apare datorita faptului ca ceasurile au fost accesate cu o imterfata clona/de slaba calitate si s-a umblat pe acolo....posibil km modificati.E vb de Eepromul ceasurilor care este alterat.
Pentru ECU swap, procedura e exact ca la pct 3 de aici: ?
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_ECU_Swapping#Engine_Control_Unit_.28ECU.29_Swapping_.28USED_ECU.29
Vreau sa stiu pt ca electricianul zicea ca e ceva de lucru desi mi se pare simplu si treaba de 5 minute.
LE: Si daca ECU vechi e prajit cum se face rost de PIN?
Modificat de Xtremu
Imi cer scuze pt dublu post dar mi se cer 150 de euro doar pt adaptarea pe masina a noului ecu (SH) . Eu atata am dat pe ECU.
Mi se pare foarte scump si mi se pare ca se incearca sa se profite de mine.
Cat costa o operatiune de genul?
Este cineva din Cj care ma poate ajuta?
Modificat de Xtremu
robert.alexandru
Imi cer scuze daca nu am postat unde trebuie, dar nu am gasit in alta parte un topic dedicat.
Astazi, pentru ca era ploaie afara, am descuiat usile la masina, am lasat ceva inauntru si am incuiat-o la loc. Am sters parbrizul de mizerie dupa care am descuiat-o si am sarit in ea.
Am pornit motorul si am incercat sa dau drumul la incalzirea in scaune .... surpriza, incalzirea in scaune nu mergea. M-am gandit in sinea mea ca o fi din cauza temperaturii mari de afara etc etc.
Dau sa plec, vreau sa aprind farurile, pauza ... se aprind doar pozitiile si atat. Semnalizarea mergea, faza lunga mergea daca dadeam de maneta ca si cand as da blitz-uri, luminile din interior mergeau, acele, butoanele se iluminau, totul mergea in afara de faza scurta, faza lunga, proiectoare de ceata si luminile din triplele pe spate.
Am oprit motorul, si l-am pornit din nou in interval de cateva secunde, la fel, acelasi scenariu ca si mai sus.
Pana la urma, am oprit motorul, am incuiat masina si am lasat-o asa vreo 5 min sa intre computerul in modul sleep. Am pornit iarasi masina iar luminile si incalzirea in scaune mergeau ... surprinzator dar mergeau.
Am ajuns acasa, am luat tableta, si am facut o diagnoza. Nu am gasit nici o eroare.
Masina in cauza este o Skoda Rapid, 1.6 TDI CAYC din 2013.
Ca idee, a mai intalnit cineva problema asta ? Imi e sa nu raman fara lumini noaptea pe undeva, pe vreun camp sau prin vreun loc uitat de lume.
Cu respect,
Robert
Modificat de robert.alexandru
Salut vreau sa fac o diagnoza la un Tiguan 2.0 tdi 4x4 tiptronic CBAB 2009 pentru niste simptome in mers nu mai trage aceleratia mai lenta la intrare pe un drum la vale daca iau picorul de pe acceleratie face frana de motor si la teminarea coborarii cand accelerez merge in suturi tacane motorul daca il opresc din cheie isi revine .Din ce am citit pe forum am gasit canalele care trebuie scanate dar la motor CR spunea cineva pe forum ca sunt alte BS in care trebuie sa ma uit si cum se realizeaza un log in mers la cutie automata ?Cum pot afla cate pompe am in rezervor ca practic este din doua bucati din cauza cardanului.  Multumesc celor care vor avea rabdare sa citeasca tot si ma pot ajuta.
F l o r i n
003, 010 si 011.
013 - injectoare.
  • Aerofan pinned this topic
