zorg
nu am erori pe motor chiar nici una
Salutare, dupa update Dieselgate nu mai pot accesa majoritatea campurilor de pe Engine si am eroarea asta :
Address 01: Engine (J623-CAYC)       Labels: None
   Part No SW: 03L 997 557 P    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9980
   Revision: --H43---    Serial number: 00000000000000
   Coding: 10114016032400080000
   Shop #: WSC 00066 000 00086
   ASAM Dataset: EV_ECM16TDI02103L997557P 003002
   ROD: N/A
   VCID: 4999BBA6E8190F5603D-801C
No ASAM data for: "EV_ECM16TDI02103L997557P" (VW36)
No fault code found.
Readiness: 0 0 0 0 0
Are cineva fisierul ROD pentru noul SW, sau este vreo solutie pentru a-l adauga ?
Nu e nici o eroare. Nu ai labelul ptr resp.
   ROD: N/A
Foloseste o interfata originala si o sa le poti accesa.
Am si eu urmatoarele erori pe un Seat Leon 1P 2006:
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0006786
   Shop #: WSC 06441 785 00200
   VCID: 71EE0E8668325AC916-8024
2 Faults Found:
01486 - System Function Test Activated
            000 -  -
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001062238366
   Coding: 3D3F0B40070202
   VCID: 2A5CD9EA8564691197-807E
01044 - Control Module Incorrectly Coded
            000 -  -
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   Shop #: WSC 00000 000 00000
   VCID: 3362C48E52AE28D924-8066
            000 -  -
Si mai am ceva cu Steering Limit Stop o eroare.
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D56D2F6B48A7E2972-8078
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
Raman in bord Aprinse ABS ESP Semnul de Volan si Semnul de la Presiune Roti. Si mai nou merge servo greu si nu mai revine volanul.
Toate au aparut si au ramas aprinse in bord dupa ce am schimbat etrierele de la rotile fata.
Modificat de Johnny
Ai umblat unde nu trebuia..
Ai system test activat.Trebuie terminat testul intr-o parcare libera unde poti face ,,cerculete"..apoi calibrat G85.
Can-ul e codat gresit.
filiphimself
Mi-a aparut aseara si nu mai functioneaza Cruise Control. La Steering Wheel nu imi apare nicio eroare. Am incercat sa o sterg si a revenit.
              Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 LF    HW: 03L 906 022 G
  Component and/or Version: R4 2,0L EDC G000SG  3691
           Software Coding: 0000071
            Work Shop Code: WSC 80093 222 71269
                      VCID: 74E6E44C17BB2EE69E-8020
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 185473 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 01000000
Readiness: 0 0 0 0 1
Scoate o borna 5 min,apoi imterogheaza 16 din nou si sterge erorile.Vezi in blocurile de masura daca merg switchurile din maneta.
Aceeasi problema o am si eu cu cruise controlul, insa nu apare nicio eroare pe tester.Martorul in bord se aprinde la actionarea butonului, insa la setarea cruise controlului nu se activeaza, nu se intampla nimic.
Sa fie problema din maneta, din buton?
Modificat de Irinel9
Verificati in blocurile de masura starea switchurilor.
Al Bundy, poti fi putin mai detaliat de rog?La ce grup trebuie verificat, ce camp casa zic asa.?
F l o r i n
1. ce an este masina ta ?
2. vezi in 006 si 022
006 si 066 cred ca ai vrut sa zici..
Sau in advanced measuring blocks...in functie de an..
Modificat de spido
Fabricatie 11.1999.
006 ai blocuri masura
Ok.Mersi, o sa verific.In mod normal ce ar trebui sa avem acolo?
O serie de biti 0000 care la apasare frina,ambreiaj,switchuri maneta..din 0 se fac 1
La frina sunt 2 de 0 care se fac 1.
Modificat de spido
Am inteles.La astea te referi.Asa imi apar mie.O sa incerc azi sa vad daca la apasarea franei/switch-uri maneta se schimba din 0 in 1.
Da,la alea.
F l o r i n
nu, 022 la diesel, cu ecu mai noi decat ce are el - 066 este la benzinare, deci nu are ce cauta acolo,
bbogdanmircea
Voi aveti pe interfata originala ROD pentru acest SW ? Am incercat cu interfata originala si tot nu il gaseste .
Buna ziua,
Am urmatoarele erori pe un Golf 4 TDI 2004:
Friday,04,May,2018,20:48:15:31824
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ1JZ4D022969   License Plate:
Mileage: 275740km-171336mi   Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ4D022969   Mileage: 275740km-171336miles
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31414
   VCID: 211F19A8C8DE2F0F5D6-51CE
            37-00 - Faulty
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 1C Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 31414
   VCID: 3635DAF47150B8B7984-4B1E
   Subsystem 1 - Part No: 1C1959801A
   Component: 1C Tőrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802A
   Component: 1C Tőrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811A
   Component: 1C Tőrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812A
   Component: 1C Tőrsteuer.HR KLO 0202
00928 - Locking Module for Central Locking; Front Driver Side (F220)
End----------(Elapsed Time: 04:59, VBatt start/end: 12.4V/12.4V)-----------
Va rog sa ma indrumati ce trebuie sa fac?
1. pentru prima eroare trebuie sa schimb motorasul? (care este part number care trebuie comandat?)
2. pentru a doua eroare precizez ca in butucul de la portiera soferului nu se potriveste cheia, deci butucul a fost schimbat... cum as putea schimba butucul sa se potriveasca cheia? sau trebuie schimbate toate butucurile de pe masina cu altele noi pentru o cheie diferita?
filiphimself
On 01.05.2018 at 17:18, spido a scris:
Apare când apăs pe + și - și dau pr cancel . In schimb când las on rămâne aceeași stare fa pe off (not oper.)
Ai fire rupte in maneta de semnalizare/pilot.
Modificat de spido
  • Aerofan pinned this topic
