zorg
si v 157?nici asta nu merge....nici din output test nu vrea.
Au alimentare ambele ?
nu stiu pinii din mufa....habar nu am care e plusul,in elsa nu gasesc
Salutare.
Am schimbat de curant egr-ul dar problema persista. Dupa scanarea vcds am urmatoarele erori.
Address 01: Engine       Labels: 03G-906-021-BLS.clb
Control Module Part Number: 03G 906 021 TG    HW: 03G 906 021 AB
  Component and/or Version: R4 1,9l EDC G000SG  2051
           Software Coding: 0000071
            Work Shop Code: WSC 73430 000 00000
                      VCID: 77FD8DF9051CD7F9FE-5140
3 Faults Found:
001032 - EGR Sensor 2
               P0408 - 000 - Signal too High - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 70
                    Reset counter: 255
                    Mileage: 180131 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:56:38
             Freeze Frame:
                    RPM: 1659 /min
                    Speed: 27.0 km/h
                    Load: 17.3 %
                    Lambda: -2.7 %
                    Mass Air / Rev.: 360.0 mg/str
                    Mass Air / Rev.: 180.0 mg/str
                    Bin. Bits: 00000000
005269 - Switch-Over Valve for EGR Cooler (N345)
               P1495 - 000 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00101111
                    Mass Air / Rev.: 630.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
001139 - Exhaust Pressure Sensor 1 (G450)
               P0473 - 000 - Signal too High - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
ma poate ajuta cineva cu erorile astea ?
Modificat de caesarb5
Verifica valva by pass n345
Schimba senzorul de presiune diferentiala ptr dpf,fara el nu face regenerarea.
Modificat de vlahdacoroman
Verifica in mufa respectiva n 345 daca vine curent
Am facut masuratorile. Sper ca am masurat bine.
La pinul din stanga da valoare 4,9 V iar la cel din dreapta 5,5V. Multumesc pentru timpul acordat.
am sters erorile, am rulat cu masina si mi-a reaparut senzorul   P0473  Exhaust Pressure Sensor 1 (G450)  made usa si P0408 - 000 - Signal too High - Intermittent
Trebuie schimbat.
l-am comandat. poate luni sau marti il primesc.
Scuze de insistenta. La problema mea de mai sus aveti vreo idee?
te anunt eu daca am avut rezultat cu schimbarea senzorului in cateva zile.
fratele meu @aresR20 are o problema:
Spoiler
aresR20
Oraş: Bocşa
Maşina: vw golf 6
Model: vw golf 6 2011
Motorizarea: 2.0 TDI 140 CP
Posted 8 hours ago (edited) · Report post
salut,
sper sa nu am aceeasi problema...dar ieri,in bord ,s-a aprins acel semn de spirala ,mi s-a taiat acceleratia :(,am ajuns la destinatie,am mers cam 20 de min asa...cum am ajuns am oprit motorul si l-am repornit din nou si  a disparut,masina este un golf 6,2011,motorul CFF 2.0 tdi
filtrul de motorina a fost schimbat cam de 1 luna,la schimb nu am vazut pilitura sau impuritati ,a fost curat,masina o am de 3 luni, o sa mai schimb inca o data filtrul de ulei,ma gandeam  sa ii anexez cumva un magnet de HDD,sunt foarte puternice,ce ziceti?
Edited 8 hours ago by aresR20
Multumesc colegilor @vlahdacoroman    si @DiLivio  pentru promptitudine, avem doua log-uri, unul realizat in data de 20 martie 2017 si un altul astazi 23 aprilie.
Multumim anticipat pentru sfaturile voastre!
Log-20.03.2017-79450km.txt
Log-23.04.2017-81490km.txt
Modificat de alynro
Verifica sigurantele,daca in mufa egr ai curent...verifica cablaj,daca e ok schimba egr.
Verifica siguranta ptr alarma,firele...nu comunica cu goarna si cu senzorul.
Farurile adaptive nu merg..siguranta,fire...masa sasiu.
Nu merge un bec de zi si unul de faza lunga,sunt arse sau sigurante  fire,mufa.
Magazia de cd nu e vazuta,nici antena gps....fire mufa.
Ai faruri xenon aftermarket cumva?
Navigatia e aftermarket?
La cate erori ai pe bcm suspectez ca e ceva in neregula cu el....
Sterge erorile si vezi ce mai apare dupa.
cel mai bine, stergere erori dupa care se posteaza numai ce ramane.
e foarte posibil sa fie erori capatate in timp, defecte/probleme care s-au rezolvat deja
Am si eu urmatoarele erori care au inceput sa apara din ce in ce mai des.
In bord mi se aprind pe rand martorii: P (parking), ESP, ABS si (!) frana de mana.
Cand apare si martorul pentru frana de mana (!), pedala de frana este moale si se aude un zgomot ca si cum ar intra ABS-ul.
Problema se rezolva cu oprirea si pornirea motorului de 2-3 ori, dar nu vad o rezolvare de durata astfel.
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 AN    HW: 028 101 208 5
   Component: R4 1,9L EDC G010SG  7004
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 01973 973 01973
   VCID: 6BD521274A702B46511-803E
005715 - Please check DTC Memory of ABS Controller
               P1653 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 1764 /min
                    Speed: 42.0 km/h
                    Load: 23.9 %
                    Voltage: 14.06 V
                    Bin. Bits: 11001010
                    Torque: 175.7 Nm
                    Bin. Bits:  0 00  0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 M    HW: 3C0 614 095 M
   Component: ESP 440 C2     H015 0001
   Revision:  H015       Serial number: 0657655365
   Coding: 0013569
   Shop #: WSC 00028 028 00001
   VCID: 2C57E23B8FFEEC7E18B-8079
3 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 190
                    Mileage: 192338 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:35:17
00810 - Sensor 1/2 for Brake Pressure
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 190
                    Mileage: 192339 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:38:39
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 192356 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:21:57
Verifica mufa si cablaj de la pompa abs la senzorii respectivi. Vezi in blocuri de masura presiunea  indicata la apasarea pedalei de frana
cam dubios cu erorile la cei doi senzori pe spate... plus cel de presiune.
ai umblat la ceva, pana acum, ai desfacut mufe, etc ?
Nu s-a umblat la nimic. Ultima data cand s-a umblat la roti a fost acum 2 luni cand le-am pus pe cele de vara, dar nu s-au umblat/atins mufele.
am inteles - doar ca e un pic dubios, cum ti-au aparut toate 3 erorile astea - poti verifica cablajul dintre cei doi senzori de roata spate si pompa, eventual inlocuiesti unul dintre senzori, daca este ok cablajul - si vezi daca se sterge eroarea
Cablajul se rezuma la mufa de langa disc pana la capacele de protectie de material plastic din interiorul compartimentelor rotilor spate?
de la senzor pana in pompa abs
Salutari tuturor, sunt nou in utilizarea vag-com-ului ma puteti ajuta cu aceste erori ?
Citat:
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CK    HW: 3C0 907 044 CK
   Component: ClimatronicPQ46 132 0809
   Revision: 00132022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6CD7A2954F5A642205-8038
01592 - Air Quality Sensor (G238)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00111110
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 225
                    Mileage: 231850 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:03:47
Unde gasesc acest senzor ? (G238)
Citat:
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P07B030130
   Coding: F9807F460002022002
   Shop #: WSC 00019 204 08739
   VCID: 234589A9E2046B5AF4-8076
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 228744 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:34:57
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 228744 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:35:01
Am rcd-300 si nu functionau cd-urile si m-am gandit sa il scot si sa curat lentila insa fara efect, ce e de facut ? la service la volkswagen in piatra mi-au spus domni ca nu e playerul masini si ca descarca masina , Ce e de facut sa imi cumpar alt player ? avand Can Gateway 3C0 907 530 E
Citat:
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 39794BC17088018ACE-806C
   Subsystem 1 - Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
01176 - Key
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 223585 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:34:00
Aceasta chiar nu stiu ce inseamna. Multumesc frumos pentru timpul acordat.
  • Aerofan pinned this topic
    • gigi.gigi
