zorg
Salut, am facut o diagnoza cu autocom si a dat "eroarea" asta:
65535 - System OK (If fault still evident, check control unit and associated wiring)
Stie cineva ce inseamna?
Mersi.
nu este o eroare. asa citeste delphi / autocom starea de " bine" a motorului, adica nicio eroare. La alte marci sau la alte module, scrie simplu, No fault found.
Buna ziua.sunt nou pe aici si nu stiu cum funcționează. Ma poate ajuta si pe mine cineva cu problema asta?  -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 Mileage: 185370km-115183mi Repair Order: Chassis Type: 1K (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D VIN: WVWZZZ1KZ7W007558 Mileage: 185370km/115183miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 1010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 021 KH HW: 03G 906 021 KH Component: R4 1,9L EDC G000SG 8984 Revision: --H02--- Serial number: VWZ7Z0F3927531 Coding: 0000072 Shop #: WSC 01392 785 00200 VCID: 6FED35377E68D7667D9-803A 1 Fault Found: 005785 - Powertrain Data Bus P1699 - 000 - Missing Message from Steering Wheel Electronics Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl Part No: 1K0 907 379 P Component: ASR FRONT MK70 0105 Coding: 0017025 Shop #: WSC 01392 785 00200 VCID: 3F8DA5776E8867E6AD9-806A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1K0 907 044 BD Component: ClimatronicPQ35 090 0808 Shop #: WSC 00000 000 00000 VCID: 6ADB2423458A324E2A7-803F No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl Part No SW: 3C0 937 049 D HW: 3C0 937 049 D Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000005648648 Coding: A0890F2700041500001400001400000000097B075C Shop #: WSC 01287 785 00200 VCID: 2A5BE423850AF24EEA7-807F Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB Component: Wischer 120506 020 0501 Coding: 00038805 Shop #: WSC 01287 1 Fault Found: 02401 - Terminal 75x 006 - Short to Plus - Intermittent
Sterge erorile si vezi care ramin.S-au facut modificari/setari cu vcds-ul?
superb post, usor de citit - urmarit....:eek:
Am facut niste setari cu vcds-ul.comming home si inchiderea usilor dupa 15 km/h.azi nu mai am timp o sa fac maine alta scanare sa vedem ce rămâne.
Buna seara tuturor,
Am achiztionat recent un VW Golf 6, 2.0 TDI, iar astazi mi-am facut curaj sa-i verific DTC-urile, in urma scanarii au reiesit urmatoarele probleme:
Wednesday,02,November,2016,12:39:18:62939
VCDS -- Windows Based VAG/VAS Emulator
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 69 72 77
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 143B400D092300FB281302E7901B0042350000
   Shop #: WSC 01357 011 00200
   VCID: 7BF51167FA10BBC6C11-802E
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010                    Fault Priority: 2                    Fault Frequency: 2                    Reset counter: 169                    Mileage: 171929 km                    Time Indication: 0                    Date: 2060.14.23                    Time: 18:18:21
             Freeze Frame:
                    Count: 0,                    Count: 3276              Count: 12800                    Count: 397                    Count: 51456                    Count: 0                    Count: 253
                    Count: 0
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00001003
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 6ED32833B162DE6E76F-803B
2 Faults Found:
9472881 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [008] - Actuator stuck
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001                    Fault Priority: 2                    Fault Frequency: 7                    Reset counter: 158                    Mileage: 171744 km                    Date: 2052.14.28                    Time: 13:55:33
9481200 - Coolant Pressure
          B10AB F0 [009] - Too Low
             Freeze Frame:
                    Fault Status: 00000001                    Fault Priority: 2                    Fault Frequency: 1                    Reset counter: 118                    Mileage: 171762 km                    Date: 2056.14.00                    Time: 15:16:33
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 507 BB    HW: 5K0 953 549 D
   Component: Lenks.Modul   008 0080
   Revision: --------    Serial number:  90422KEK001ID
   Coding: 1082040000
   ASAM Dataset: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS.rod
   VCID: 71E9334FA05CC1966BD-8024
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Serial number: 70000000000000254241
   Coding: E20000
365080 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
             Freeze Frame:                    Fault Status: 00000001                    Fault Priority: 6                    Fault Frequency: 1                    Reset counter: 157                    Mileage: 171744 km                    Date: 2052.14.28
                    Time: 13:54:46
Multe concluzii nu prea stiu sa trag din logul asta dar asa la prima vedere ce am inteles eu ca ar fi:
1. Abs-ul a semnalizat ca am avut candva presiunea scazuta in pneuri
2. Am probleme (sau am avut) cu o clapita  din sistemul de clima
3. Presiunea lichidului de racire folosit de AC (porbabil freon) scazuta
4. Ceva probleme cu comenzile de pe volan... ciudat imi merg toate comenzile de pe volan...o fi altceva, poate problema s-a pasivizat.
Va rog sa ma lamuriti si pe mine daca se poate interpreta faptul ca  problemele respective sunt active si in prezent sau au fot prezente in istoricul masinii si nu au fost sterse DTC-urile.
Altceva ce mi se pare ciudat este modul in care e afisata data...2060. 14. 23, ceva nu se leaga, KM par a fi ok desi cam toate erorile au aparut cam in aceeasi perioada, inainte sa o cumpar eu din Germania.
Astept cu interes parerile si sfaturile voastre,
O seara frumoasa!
Modificat de Radudar91
NU incerca sa intelegi data din modulele masinii.
Va salut ! Nu am reusit sa citesc tot topicul, desi am vazut ca s-a mai discutat pe alocuri,despre erorile mele.
Am un Passat B4 din 1995, 1.9 TDI 1Z.
De cand l-am cumparat nu mi-a mers abs-ul si ceva descarca bateria de pe 1 zi pe alta.
Am fost cu ea la cineva cu interfata, si mi-a gasit urmatoarele erori:
1. La ABS = 00532 - Supply Voltage B+                        ( ABS TEVES)
                                 35-00 -
2. Iar la faza cu descarcarea bateriei de pe o zi pe alta : 01117- Generator Terminal DF Load Signal
        27-10 - Implausible Signal- Intermitent
Ma poate ajuta cineva cu o interpretare a lor? Omul nu a stiut sa imi zica despre ce ar fi vorba mai exact...
Modificat de cristian_98
Verifica tensiunea de incarcare a acumulatorului,alternatorul sau regulatorul de tensiune sunt de vina.
La ABS, ce ar putea fi? Am citit ca e legat de ceva conexiuni..
Prima eroare e generata de a doua.Verifica ce ti-am zis.
On 10/26/2016 at 1:28 PM, Al Bundy said:
senzor 3 de temperatura defect de pe evacuare.
NU vad ce can ai, dar daca nu e schimbat cu unul mai nou nu poti acccesa navigatia pentru diagnoza, fiind un rns310.
CAt despre tf, ciudat ca apare ca e necodat, el avand un coding acolo.
Multumesc....
senzorul l-am schimbat , acum este ok.
la adresa 19 arata asa :
Address 19: CAN Gateway        Labels: 3C0-907-530.lbl
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C0572102FB
   Coding: 7FFD3C44C61002
   Shop #: WSC 00028 028 00001
   VCID: 2143FB5DF8D2CB1
@anonim-trebuie sa schimbi can-ul ptr a putea accesa unitatea.Si vei ramine fara baterie in curind..
buna seara, ma ajutati si pe mine cu o parere/sfat la aceasta eroare. Masina e un passat 1.9 tdi, porneste dar cand accelerzi incepe sa tremura ca si cum nu s ar mai alimenta si scoate fum.Multumesc.
Log-Log.txt
Monday,07,November,2016,15:16:31:32264
VCDS Version: Release 11.11.3
Data version: 20120401
                Address 01: Engine       Labels: 038-906-019-AVB.lbl
Control Module Part Number: 038 906 019 GN
  Component and/or Version: 1,9l R4 EDC G000SG  1497
           Software Coding: 00005
            Work Shop Code: WSC 05314
           Additional Info: WVWZZZ3BZ2E277521     VWZ7Z0A4456039
                      VCID: 69D3A37D1362C31
18071 - Control Circuit for PD Injectors
            P1663 - 35-10 - Short to Plus - Intermittent
Readiness: 0 0 X X X
Modificat de cyti
Injector cu probleme....verifica tot cablajul si mufele de la fiecare injector,eventual curata bine si clemele din mufe dar si mufa rotunda.
Posteaza si valorile la injectoare.
Buna seara
Am 2 erori la ultima scanare facuta cu VCDS-ul la care as avea nevoie de ajutor. Mentionez ca am montat un Tempomat zilele trecute care a fost codat pe modulul Engine cu 11463 si pe Steering wheel cu 0000034 . Maneta functioneaza corect , a fost testata. Totusi persista o eroare 01044 - Control Module incorrectly coded , pe modulul 16 - Steering wheel . Mai jos si rezultatul scanarii .
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           853 0111
   Coding: 0000034
   VCID: 0305E56A42D4325ABD-8056
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
Si ptr cea de a doua eroare , de pe Radio :
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4211905
   Coding: 0500040004
   VCID: 65C1DBF26CA0EC6A33-8030
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 158326 km
                    Time Indication: 0
                    Date: 2011.04.03
                    Time: 02:25:53
Daca puteti sa imi sugerati care ar putea fi problema .
Multumesc,
Sterge eroarea pe 16 cu motorul porni si ai o problema cu difuzorul de bas pe stinga spate.Verifica firele din mansonul de cauciuc dintre usa si stilp si conectorul ce intra in stilp.
Multumesc , voi incerca probabil in weekend cele spuse de tine si revin daca va fi cazul.
buna din nou, am primit o sugestie de la un vechi  amic pe PM , cu privire la erorile de mai sus, sa le sterg ca multe erau din cauza ca schimbasem acumulatorul, si avuse dreptate o parte au disparut, o parte sau remediat cea cu becurile , erauu arse ceva becuri , iar unele au ramas, dar am o alta problema pe langa toate astea erori ,  nu vrea sa porneasca dimineata decat dupa a3 sau a 4 a cheie  si asa greuuu pana  o ia, nu am vrut sa postez aici ceva prostii, asa ca zilele astea am to citit  la posturi de mi sau facut ochii ca cepele:wacko: ( nevasta se sparie dimineta de mine:biggrin:)  nici nu stiu in care topic ar trebui sa scriu, caci am gasit si ca trepideaza motorul la relantiu, si am verificat si rtpm este undeva intre 780 si 840 oscileaza cam tare.
multumesc
Log-3-WVGZZZ1TZ6W040438-267250km-166061mi.txt
Log- (2).txt
Log-.txt
Buna seara, dupa multi ani in care socru-miu nu a bagat nici un ban in masina(VW SHARAN 2003 1.9TDI cod motor ASZ), azi (ca prin minune) a inceput sa spuna ca nu mai vede pe unde merge, ca lupele nu mai bat, ca bat jos ca etc. Am scanat cu VCDS si am primit codul urmator (pe langa alte coduri legate de HVAC, coolant Temp si etc):
Address 39: Right Light        Labels: 7M3-907-391-39.lbl
   Part No: 7M3 907 391
   Component: EVG GDL + AutoLWR   0003
   Coding: 00005
   Shop #: WSC 00000
   VCID: 74020C5FD7B42CB2D1B6A9-4BCA
00546 - Data wiring faulty
            27-00 - Implausible Signal
Dupa parerea mea de neavizat cred ca trebuie sa merg la electrician, dar daca ma poate ajuta cineva cu un sfat sau ceva sau sa imi recomande un electrician din bucuresti care ar rezolva problema. Mwntionez ca becurile se aprind dar bat FOARTE SLAB, si nici autoleveling-ul nu functioneaza.Ca si cum ar fi blocate pe pozitia jos. Becul de pe partea cu pricina (dreapta) este cel de fabrica , cu care a venit masina(ceva d2s-dar nu stiu firma).
Modificat de CosminOlanescu
cod gresit
  • Aerofan pinned this topic
