zorg
A aparut aceasta eroare pe modulul de carlig ,ce parere aveti ( carligul este demontabil si nu a fost montat deci nu sa utilizata remorca) ?
log golf manole.txt
Modificat de manolovw
Am si eu o eroare pe motor, 2.0 tdi cr, cod motor CBAB
  Address 01: Engine       Labels: None
Control Module Part Number: 03L ABT 022 QC    HW: 03L 907 309
  Component and/or Version: R4 2,0L EDC G000SG  A732
           Software Coding: 0000072
            Work Shop Code: WSC 84224 418 411689
                      VCID: 2E59654DB9F29151CD7-807B
000304 - Oxygen (Lambda) Sensor B1 S1
               P0130 - 000 - Malfunction in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 213096 km
                    Time Indication: 0
                    Date: 2021.14.16
                    Time: 14:05:46
             Freeze Frame:
                    RPM: 897 /min
                    Speed: 48.0 km/h
                    Lambda: 1.6 %
                    Mass Air / Rev.: 235.0 mg/str
                    Voltage: 0.000 V
                    (no units): 0.0
                    Voltage: 3.300 V
Readiness: 0 0 0 0 0
Daca imi poate spune cineva de la ce e?
Pot sa merg cu masina asa sau trebuie schimbat urgent?
Unde se gaseste acest senzor pe masina?
E mult de desfacut?
Modificat de duduratoy
Schimba sonda lambda ,se afla deasupra catalizatorului ,cea cu 5 fire
 la o verificare a bateriei pe subsistem " Adress 61 Battery regulation " ca urmare a consumului marit
in ralanti, m urmatoarele valori:
10.60 V   Generator Voltage (spec.)
  0.000 A   Exciter Current
  6.00 s   Load Response Time
  Not OK   Electrical Generator Status
  Not OK   Mechanical Generator Status
  OK   Thermal Generator Status
  5   Generator Size
  11.776 V   Battery Voltage
  -8.4 A   Battery Current
  7.0°C   Battery Temperature
  1   Phase Degradation
  25.0 A   Current Consumpt. during Engine Stop
68   Battery Size
  No   Battery Seperation
  10.0°C   Battery Ambient Temp.
  59.0 %   Battery Level
  61.0 %   Battery Aging (Power)
  70.0 %   Battery Aging (Charge)
  12.20 V   Battery Quiescent Current
  StatCurStg 0   Quiescent Current Shutoff Stage
credeti ca am o problema cu bateria ? datele sunt obtinute la rece ( nepornita de 2 zile ) si pe contact ( cu motorul oprit ).
ma intereseaza semnificatia celor 2 valori cu " Not OK " si starea per ansamblu a acumulatorului ....
daca ea ar putea fi cauza consumului marit in ralanti si daca ar putea fi/este o problema de incarcare a alternatorului. - nu sunt nici un fel de erori stocate, la scanarea generala a masinii.
multumesc
testele se fac cu motorul pornit. Cu el oprit cum ai vrea sa ai generator ok daca el nu baga curent ?
ai mare dreptate.
eu vroiam sa stiu starea bateriei la rece gandindu-ma ca in functie de asta ar fi obligat alternatorul sa bage mai mult curent in
ralanti pentru a optimiza incarcarea si de aici consumul mai mare in ralanti - de asta am verificat in conditiile acestea.
o sa fac o scanare si cu motorul cald, si pornit sa vad ce si cum.
multumesc ptr opinie
tensiunea bateriei in conditiile astea ti se pare ok ?
Astea nu se modifica mai deloc, atat cu motorul stins, cat si cu el pornit.. Parerea mea este ca bateria este terminata. Adica eu am acolo valori de 52% resp 37% si mi s-a recomandat sa o schimb, iar tu ai cu mult mai mult.
cine ti-a recomandat ?
este f interesant ce.mi spui.
de pornit, imi porneste destul de bine
atat iarna cat si vara dar, poate ca nu e suficient.
Salutare, de la ce pot fi aceste erori ? La partea electrica, poate fi din cauza bateriei ? nu am schimbat-o niciodata de cand am cumparat masina.
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9248
   Revision: --H08---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 00028 028 00001
   VCID: 7AE2E3ABACDFACD251A494D-802E
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 137976 km
                    Time Indication: 0
                    Date: 2016.10.15
                    Time: 14:43:09
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 00101100
                    Idle Stabilization: 8.8°KW
                    (no units): 48.0
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   008       Serial number: 00000000031309
   Coding: 0000056
   VCID: 2846E9E302F3EE4277F06E5-807C
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 156
                    Mileage: 138018 km
                    Time Indication: 0
                    Date: 2016.10.15
                    Time: 21:10:17
             Freeze Frame:
                    Voltage: 11.70 V
                    Count: 52
                    Speed: 0.0 km/h
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x0404
Baterie slaba si posibil dat mult la automat sa porneasca-de acolo eroarea cu g40. La fel de bine posibil pb si la g40.
daca si porneste greu, schimba G40
Verifica si firele de la G40 la ecu.
@pronet adica dat la automat?
O sa verific firele
Masina a pornit putin diferit fata de cum pornea de obicei :) de 2 ori am patit sa nu porneasca din prima cheie. Initial credeam ca porneste greu din cauza bujiilor, nici p'astea nu le-am schimbat niciodata
Modificat de stefz
Da. Eroarea resp poate apare si daca dai mult la automat-de ex ai o baterie slaba si tot o omori sa plece.
Nu,. Nu mi-a facut faze de genul.  S-a intamplat de 2 ori sa raman cu cheia apasata si motorul sa nu porneasca,. Dar dupa,  pornea fara probleme
Modificat de stefz
e posibil sa ai probleme la cablajul senzorului G40 - trebuie verificat pana in ECU
Daca cheia era apasata si nu pornea posibil pb la blocatorul de coloana.
in acets caz, ai erori legate de coloana, imobilizator, etc.... plus eroare de imobilizator/coloana, pe BC
eroarea aceasta este de la senzorul de temperatura filtru de particule....?!
4912 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E 00 [175] - Electrical Malfunction
MIL ON - Confirmed - Tested Since Memory Clear
Insa nu stiu care este fiindca sunt parca doi, unul inainte si unul dupa DPF...trebuie schimbat doar unul?
Banuiesc ca de aceea nu mai face regenerare filtru de particule....are si becul DPF aprins.
Modificat de vlahdacoroman
pozitia lui care este?
cum il deosebim de restul 3?
multumesc !
On 9/19/2016 at 20:44, Stefan.DFS a scris:
@Al Bundy curios este ca functioneaza fara nici o problema cu unul OE 03L129086. Am luat unul de pe un A4 B8, l-am montat...nici nu a trebuit sa mai dau adaptare.
sters erori, dat cheie si a plecat.
am sa caut unul SH si aia e.
nu stiu ce ai mai rezolvat ,dar nu ti mai bate capul cu cel nou nici la mama lu vw in Germania
NU se adapteaza motoras nou pe galerie veche nici cu tata lu rostech
mai stiu un caz identic care dupa ce a platit 200 lei degeaba la vw i au spus ca poate sa l arunce
vin si fac precizarea expressa pentru cei care au probleme cu motorasul 03L129086 v120 ,il au defect etc etc ..
NU ,repet NU cumparati motoras nou vdo continental ,NU vi l va mai adapta nimeni ,aruncati banii !!
acest motoras nou cu cod nou ,,sufera,, exclusiv de galerie noua .
ce ironie si ce bataie de joc la adresa clientului vw ,sa i vinzi piesa noua pe original STIIND ca nu o va putea adapta NICIODATA
si aici ma refer la galerie aluminiu 03L129711E si la cele de plastic e aceeasi treaba
rog a se muta pe sectiunea potrivita daca am gresit ,dar oricum e un sfat ce trebuia demult  sa fie regasit  aici pe vwforum !!
Modificat de vik71
@vik71 am rezolvat de 3 saptamani. Reconditionat pe cel vechi si gata. Totul a revenit la normal.
Corect ce ai spus si as completa cu mentiunea ca motorasul Continental este considerat "aftermarket". Are alt cod fata de cel VDO Siemens. Functioneaza la alti parametrii.
Lucru confirmat si de cel ce a reconditionat pe cel VDO. Se poate adapta, dar cu update de soft...samd.
Sper intamplarile noastre sa ajute si pe alti colegi.
numai bine,
ma bucur ca ai rezolvat o .
stiu tot asa pe cineva care a luat nou ,reprezentanta vw a zis ca nu poate adapta sub nici o forma ,i au adus motoras ei + curatat galerie 18 milioane !!!
vin si intreb ,de ce se mai fabrica si se mai vinde cel Continental daca NU il adapteaza nimeni pe masina ??
La un Passat B5.5 din 2004, dotat cu cradle pentru telefon, proprietarul a considerat ca nu mai are nevoie de el si a taiat firele si a constatat ca nu mai functioneaza radio.
A refacut legaturile insa radio tot nu functioneaza..... eroarea este aceasta...ce poate sa fie si cu o poate remedia ?
Address 56: Radio       Labels: 1J0-035-18x-56.lbl
Control Module Part Number: 1J0 035 186 E
  Component and/or Version:  Radio BNO         0006
           Software Coding: 04403
            Work Shop Code: WSC 00028
                      VCID: 275B8D5BC52222190E1-4A9C
00852 - Loudspeaker(s); Front
            36-00 - Open Circuit
Modificat de cridaia
eroare lipsa
  • Aerofan pinned this topic
