zorg
Am o scanare de acum vreo luna de zile, facuta de un prieten dupa ce am schimbat vechiul RCD 310 cu un RCD 510 cu intrare de camera (pe care nu se afla cuplat nimic) si uitandu-ma prin log, am gasit eraoarea asta:
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 190 C HW: 3C8 035 190 C
Component: Radio RCD510 051 0207
Revision: 00000001 Serial number: VWZ1Z3M2017948
Coding: 05000440040005
Shop #: WSC 01357 011 00200
VCID: 2345090722202306A91-8076
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 226
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
00821 - Antenna 2 for Radio (R93)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 226
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Sa imi fac vreo grija? Sa verific ceva?
7 hours ago, laurentiun said:
de ce este interzis pe forum? l-am regasit pe site-ul ross tech deci este original
 Boost Pressure Regulation - asa o sa fac, multumesc.
17054 - Glow Plug Module 1 - cablajul a fost verificat, ramane sa schimb releul. se poate verifica releul ca sa nu il schimb degeaba?
Pentru ca nu este original. daca era original cerea si ii faceai update la ultima versiune.
Salutare!
Apelez cu o problema la voi, am un Golf5 1.9 tdi din 2008 (BLS), iar de curand am achizitionat o interfata cu VCDS.
Dupa o scanare am gasit aceleasi erori care au aparut in momentul cand am fost in service cu masina si am schimbat senzorul de temperatura combustibil.
2 Faults Found:
005785 - Powertrain Data Bus
               P1699 - 000 - Missing Message from Steering Wheel Electronics
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 39
                    Reset counter: 255
                    Mileage: 238943 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:58:06
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.46 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
000387 - Fuel Temp. Sensor A (G81)
               P0183 - 000 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 238954 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:04:26
             Freeze Frame:
                    RPM: 2520 /min
                    Speed: 41.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Temperature: 30.6°C
                    Temperature: 88.2°C
                    Temperature: 61.2°C
Le-am sters, se stinge martorul check engine dar dupa o vreme iar se aprinde si apar aceleasi erori.
Am cautat in forum ce au mai scris colegii despre cele doua erori.. credeti ca e nevoie sa schimb alt senzor de temperatura? pentru prima eroare e activat CS? sau de ce apare?
Modificat de bogzi
daca nu pui autoscan de unde sa stim de ce apare.
schimba si senzorul de temperatura dupa ce verifici firele de la el.
Quote
crezi gresit. imi cere update dar l-am ignorat pentru ca nu am vrut sa stric un program functional. Incerc ultima versiune pe alt computer
NU ai ce sa strici cu un update testat de producator.
 Scanare Vcds VW jetta 2008
erori aparute
VIN: WVWZZZ1KZ8M081759   Mileage: 212260km/131892miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Malfunction 1010
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 79F90B6F302C89D6D3D-802C
00402 - Auxiliary Air Heater Element (Z35)
            004 - No Signal/Communication
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000000589962
   Coding: A1038E2700041502470A00000F00000000295D035C00010C000000000000
   Shop #: WSC 00066 123 12345
   VCID: 71E9334F685CC1966BD-8024
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 061107 020  0501
   Coding: 00038805
   Shop #: WSC 00066
3 Faults Found:
01333 - Door Control Module; Rear Left (J388)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 211868 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.80 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 207
                    Mileage: 211532 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.95 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00483 - Control Module for Auxiliary Air Heater
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Reset counter: 190
                    Mileage: 209133 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.30 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002021
   Shop #: WSC 00066 000 00000
   VCID: 8109E38FD8FC51161BD-80D4
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
00883 - Ignition Switch (D) Terminal S
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000017679014
   Coding: 0000180
   VCID: 3B75D1677A907BC6811-806E
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00111000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 0 km
                    Time Indication: 0
00943 - Heated Exterior Mirror; Driver Side (Z4)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 211
                    Mileage: 212042 km
                    Time Indication: 0
ddress 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1K0 035 186 AD    HW: 1K0 035 186 AD
   Component: Radio BVX       035 0047
   Revision: 00035000    Serial number: VWZ1Z2G6258260
   Coding: 0040401
   VCID: 68DF5E2B5B86005E3C3-803D
2 Faults Found:
00857 - CD Changer Unit (R41)
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000002328579
   Coding: 0000144
   VCID: 3D71DF7F648475F6BF5-8068
No fault code found.
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000002369395
   Coding: 0000144
   VCID: 3E73D87369826EEEA6F-806B
00099 - Rear Right Central Locking (Safe) Motor (V164)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 230
                    Mileage: 212166 km
                    Time Indication: 0
Address 7D: Aux. Heat
Cannot be reached
End   ---------------------------------------------------------------------
Salutare domnilor, vin si eu cu doua probleme. Prima problema e ca de vreo 4-5 zile dupa ce opresc masina si scot cheia din contact nu se aprinde plafoniera,asa ceva nu face totimpul,doar cand o apuca :( si a doua problema este ca de cand am luat masina am doua erori pe adresele 17 si 19 si nu stiu ce sa-i fac sa scap de ele. Mai jos atasez si rezultatul scanarii. Multumesc
VCDS Version: Release 12.12.3 (x64)
Data version: 20140822
Wednesday,07,September,2016,13:07:47:33490
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ2P282459 Mileage: 198410km/123286miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 ER
Component: 1,9l R4 EDC G000SG 1466
Coding: 00005
Shop #: WSC 00028
VCID: 6BD3B1F7190722465EF-4A3A
WVWZZZ3BZ2P282459 VWZ7Z0A4401181
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 04255
Shop #: WSC 00028
VCID: 254787CFBF63D436C8B-5000
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0008
Coding: 17000
Shop #: WSC 00028
VCID: 264580C3C265DF2EC11-5072
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 0004
Coding: 12353
Shop #: WSC 00028
VCID: 234399D7B1572A06A6F-5000
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 847 A
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 21115
Shop #: WSC 00000
VCID: 24419ACBB4592D3EDF5-5072
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0E9269BB021419EEBD-5000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 A
Component: 0X Komfortgerát HLO 0001
Coding: 00067
Shop #: WSC 00028
VCID: 3567578F0FC3A4B678B-4A3A
Subsystem 1 - Part No: 1C1959801
Component: 0X TĂľrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802
Component: 0X TĂľrsteuer.BF KLO 0002
27-00 - Implausible Signal
repara modulul de la usa soferului, sterge toate erorile si vezi daca mai ramane ceva dupa.
Modificat de bob7
Cum se rezolva eroarea de mai jos?
Este problema de fire?
Citat:
Address 46: Central Conv. (J393)
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H80 0145
2 Faults Found
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
02616 - Fuel Tank Cap; Unlock
AuDi B8.... inlocuieste motorasul de deschidere clapeta rezervor.
Este vorba de 8K0862153F?
Daca se lasa asa exista pericolul sa nu se mai poata alimenta?
Exista work-around intr-o situatie de asta?
Ma puteti ajuta va rog cu erorile de mai jos, ce e de schimbat ?
....mentionez ca ultima eroare nu a putut fi stearsa.
Control Module Part Number: 3C8 937 049 E    HW: 3C8 937 049 E
  Component and/or Version: Bordnetz-SG     H54 2602
           Software Coding: E78A8F0700041A00470A00000F000000000B5D435C000120000000000000
            Work Shop Code: WSC 05124 000 00000
           Additional Info: 3C1955419A  Wischer 171008 004  0206   1K0955559AH RLS     100209 054  0402
                      VCID: 3363690B52FA5EB9A29-8066
2 Faults Found:
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 78
                    Mileage: 225607 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 1
                    Fault Frequency: 10
                    Reset counter: 78
                    Mileage: 227791 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.70 V
                        ON
                        ON
                        OFF
                        OFF
Verifica becul de pozitie dreapta fata si becul de halogen ceata fata stanga...si cablajele cu mufele lor, eventual curata bine pinii cu un spray de contact.
am inteles, dar..... interesant este ca becul de la farul stanga pe faza scurta se aprinde "cam roz/violet" si cand/cum vrea el.
....am crezut ca eroarea de acolo este.
Stiti ce bec xenon trebuie ? ....ce marca/model recomandati ?
eroarea nu este de la xenon, daca ai xenon aftermarket nu vei vedea eroarea, poti schimba becul xenon e clar ca e pe duca , dar mai bn verifica sa nu fie cumva balastul de vina,le poti schimba intre ele sau schimbi becul pe cealalta parte, si practic vezi daca tot asa face.
daca ai instalatie originala, trebuia sa ai o eroare dar verifica tot asa ca mai sus, eventual vezi daca le poti da un out put test....cu vcds
Nu stiu exact ce instalatie xenon ai dar va trebui sa iei 2 becuri la fel ...cu acceasi temperstura in grade kelvin,si sa mearga la ce tensiune scot balasturile tale...ai grija sa nu te curentezi fiindca ele merg la tensiuni f mari.
are xenon din fabrica...... si nu stiu ce becuri sa-i spun sa-si cumpere, doar daca scot unul afara.
...insa e becul sau balastul ?
nu putem stii decat daca schimbam becul dintr-o parte in alta ...sa vedem care e buba, bec sau balast.
Poti sa faci si un output test.....apoi.scoti becul si vezi de care este...
Am fost sa verific si nu se pot schimba becurile intre ele.... trebuie date farurile jos.
Stie cineva ce becuri trebuie ? ....daca tot voi da bara jos ca sa am acces la faruri, sa le si schimb imediat.
Acum spune și de care model.....vad ca sunt mai multe variante....d1s ,  d2s, d2r  dar. ..presupun ca sunt pentru stânga și dreapta,  dar 1, 2 sau 3 ?
La o comanda pe Autohut.ro dupa VIN, reiese ca trebuie D1S....este correct ?
Q3, 2.0TDI CR, 8U0, CFFB, manuala.
Cum se procedeaza de obicei in acest caz?
Address 22: AWD
   Part No SW: 0BS 907 554 D    HW: 0BS 907 554 D
   Component: Haldex 4Motion      4017
  1 Fault Found
01155 - Clutch
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 70038 km
  • Aerofan pinned this topic
