zorg
Bine ca s-a rezolvat, vezi sa incarci bateria - sa fie ok, chiar daca e noua.
1 hour ago, GABIVVX said:
Din ciclu ,,volkswagen ejaculeaza pe clienti'',pentru un teu de plastic de maxim 30 lei....trebuie sa cumperi jumatate de instalatie de alimentare.;)
Si senzorul in sine este piesa consumabila care este schimbata frecvent.
din pacate.....
Am schimbat EGR datorita racitorului crapat si apoi pompa suplimentara de racire EGR. De doua ori in cca 200 km de la schimbarea pieselor mi s-a aprins spira de bujie, motorul nu tragea, de fiecare data problema s-a rezolvat cu o repornire. Am facut o scanare astazi si nu inteleg sintaxa  "Intermittent - Not Confirmed" cu atit mai mult cu cit e vorba de piese noi:
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H26 7852
   Revision: 41H26---    Serial number: VWZCZ000000000
   Coding: 00190012042401080000
   Shop #: WSC 00028 028 00032
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003005
   ROD: EV_ECM20TDI01103L906018BE.rod
   VCID: 6FEDB4BDB65C314697-803A
3 Faults Found:
4875 - Coolant Pump 2
          P261A 00 [096] - Open circuit
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 121520 km
                    Date: 2016.04.01
                    Time: 07:53:55
4891 - EGR Valve (N18)
          P0403 00 [096] - Malfunction
             Freeze Frame:
4892 - EGR Valve (N18)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Mileage: 121638 km
                    Date: 2016.04.10
                    Time: 13:15:53
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V40C 0022
   Revision: --H07---    Serial number: 00000004560563
   Coding: 0002480
   Shop #: WSC 00028 028 00001
   VCID: 6DD1AEB57450C356A5-8038
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0004004803
   Shop #: WSC 00028 028 00022
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW36.rod
   VCID: 000FE7019BC23E3E7E-8054
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 E    HW: 3AA 937 087 E
   Component: BCM PQ47 H+   413 0455
   Revision: BC413001
   Coding: 000800000000000000180080540029F423D50088606C8560E480C7240041
   VCID: 3C7753F1BFAA9ADE62-8068
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 25061  10  0603
   Coding: 00B795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 290711 05  54  0403
   Coding: 06302A
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631120306755
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 7CF793F1F72A5ADE22-8028
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PE2KZ4.
   Coding: 0012337
   VCID: 4C9703312F0A2A5ED2-8018
   Subsystem 1 - Serial number: 6332MTS658642061
   Subsystem 2 - Serial number: 6342MTS675722081
   Subsystem 3 - Serial number: 6351HTS6G0HE8AKJ
   Subsystem 4 - Serial number: 6361HTS6BU0D8AKJ
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110721100262
   Coding: 018A250000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 72EBBDC9A56E1CAE78-8026
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H06 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 870 D    HW: 3AA 920 870 D
   Component: KOMBI         H03 0607
   Coding: 160F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 336578CD9AF455A6B3-8066
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 020811F2003472
   Coding: 461006
   VCID: 39794AE5B098AFF679-806C
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 76E381D90106008E54-8022
   Subsystem 1 - Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279 C    HW: 3C0 035 279 C
   Component: RNS315-EU   H33 0263
   Serial number: VWZAZ2L3399044
   Coding: 000004110400100000011301
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2345888D2A14C52643-8076
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_0031  0031
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003312135
   Coding: 0200B7
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356146D594804B969D-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002351336
   Coding: 000090
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 1002
   Revision: 1AH03733    Serial number: 00112160198801
   Coding: 0000258
   VCID: 3C7753F17FAA9ADE62-8068
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0634
   Coding: 08910A0002860E76300494157C084F0B607C01
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FEDB4BDBE5C314697-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003319563
   Coding: 0200B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 366341D98986408E94-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002355358
   Coding: 000090
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000122513
   Coding: 0022167
   VCID: 356146D55C804B969D-8060
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0105
   Revision: --------    Serial number: --------------
   Coding: 029200000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_SK46.rod
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H41 1620
   Coding: 030B185A
   VCID: 71E9B2C5A86827B681-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
piesele au fost noi? eroarea a fost stearsa dupa ce ai schimbat piesele ?
are eroare egr de ieri...piesele originale? montajul?
Da, piesele sunt noi, schimbate in service, erorile mentionate sunt aparute dupa inlocuiri. Dupa stergerea de ieri nu au reaparut. De aceea am intrebat ce inseamna "intermitent not confirmed" ,ca si traducere mi se pare mai degraba o eroare de conjunctura, gen avertizare de bec ars desi becul e ok si arde, dar din diverse motive poate consuma mai putin decit  valoarea stiuta de BSI. Nu stiu daca evenimentele sunt legate intre ele dar ce ma deranjeaza in afara de erori, citeodata pornirea mi se pare lunga, parca prea multe rotatii facute pe electromotor si am mai observat o usoara poticnire imediat dupa pornire parca nu ar lucra toate injectoarele cum trebuie timp de una doua secunde . Nu am descoperit o anumita situatie favorizanta gen temperatura scazuta cind se produc fenomenele, poate la pornirea mai lunga cred ca poate contribui starea bateriei de moment pentru ca circul pe distante scurte zilnic.
Modificat de alin_irimia
buna ziua tuturor. dupa o scanare a masinii unui prieten, stergerea erorilor si o rescanare la cateva zile, mi-au aparut erorile atasate mai jos. va rog, daca se poate sa ma ajutati cu cateva sfaturi pentru remedieri. mentionez faptul ca pe langa clasica problema cu motorasul v158 si suplimentar presiune mica pe instalatia de racire (posibil pierderi de freon pe instalate, care momentan nimeni nu vrea sa ii schimbe motivand ca temperaturile sunt scazute), din log si prin consultarea ross-tech, am vazut ca este o codare gresita pe modulul ABS, si are activat modul tractare remorca pe care nu il pot accesa.
erori cristi.txt
Salutari, am facut un log la bora mea cu vcds-ul achizitionat si am primit urmatoarele erori :
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 264930km/164619miles
Address 01: Engine        Labels: 038-906-012-AGR.lbl
   Part No: 038 906 012 M
   Component:  1,9l R4 EDC 0000SG  2813
   Coding: 00002
   Shop #: WSC 01317
   VCID: 1A3B34E3866A62CE7A7-4A3A
17965 - Charge Pressure Control
            P1557 - 35-10 - Positive Deviation - Intermittent
Readiness: N/A
si a doua eroare :
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 2K Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 01317
   VCID: 8407EA9B94EE443E30B-49D8
   Subsystem 1 - Part No: 1J1959801C
   Component: 2K Tőrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 2K Tőrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 2K Tőrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 2K Tőrsteuerger. HR0002r
3 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 - -
Aici stiu ca nu-mi functioneaza incalzirea in oglinzi, dar prima eroare ce e? Interior light time limit
Modificat de Biziday
In urma instalarii Auto Hold pe Passat am urmatoarea eroare
1 cod a gasit:
Versiune VCDS: ROJ 14.10.0
Marius
                Adresa 53: Frâna de parcare       Eticheta: ROJ\5N0-907-801.clb
                    Numar VAG: 3C8 907 801 E    HW: 3C8 907 801 E
   Componenta si/sau versiune: J540 EPB3  VW-15417 0007
                  Codare soft: 0000057
                Numar atelier: WSC 11444 111 99999
                      VCID: 2C5D6F458FEEE341E33-8079
1 cod a gasit:
02844 - Lampa pentru functiile de parcare automata
            006 - Scurt la plus - intermitent
             împrejurari cod:
                    Stare defect: 00100110
                    Priorit.defect: 3
                    Frecv. defect: 2
                    Resetare contor: 238
                    rulaj: 175953 km
                    Indicator de timp: 0
                    Data: 2016.04.15
                    timp: 02:11:45
             împrejurari cod:
                    tensiune: 13.50 V
                    contor: 82
                    viteza: 0.0 km/h
                    valoare Hex: 0x1268
                    valoare Hex: 0x8001
                    valoare Hex: 0x0101
Va rog sa ma ajutati cu un sfat
          76
   Coding: 00002
   Shop #: WSC 01317
Readiness: N/A
si a doua eroare :
   Coding: 04097
   Shop #: WSC 01317
3 Faults Found:
            35-00 - -
            35-00 - -
Posibil probleme valva N75 sau aer fals.Verifica furtune.
Probleme cu unul din switch-urile din usi...trebuie vazut care.
@AAM- verifica daca conexiunile au fost facute conform schemei..
@marydy- modulul remorcare se dezactiveaza pe can in instalation list.Schimba debitmetrul cu unul nou,original,refa presiunea din instalatia de clima,probleme la blocatorul de volan,probleme lumini portiere,buton frina parcare defect.
Modificat de spido
Salut! Am dat și eu peste eroarea asta
P0234. Se aprinde arcul și îmi taie puterea. Dacă repornesc merge ok. Am făcut check ul în mers atunci când apare eroarea. Nu face la o anumita viteză dar am observa ca pe subturare de multe ori. Ce teste sa mai fac?
Nu poti posta eroarea asa cum apare pe tester ? Arunci 4 cifre si vrei sa cautam noi restul ?
P0234-Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
Simplu ai o problema cu turbina.
Raspunsul il ai in celalalt post unde nu isi avea locul.....asa ca nu trebuie sa postezi peste tot ca sa primesti un raspuns
Modificat de gctinvalentin
Alexu, nu este ce zici....
1. Trebuie curatata geometria turbinei - ii face suprapresiune.
2.  posibil probleme la plafoniera sau modul confort - nu la switch-urile din usi.
   Salut baieti. De aproximativ o luna a aparut o problema la masina din semnatura si anume din treapta a 4- a in sus, peste 3000 rpm nu mai trage deloc (si nu urca mai mult de 110-120 km); banuiesc un limp mode. Am tot cautat pe forum un raspuns la problema mea dar nu am gasit. Am facut si o scanare in vcds si am atasat rezultatele. Am facut si un engine check pe modulele 003, 010, 011 banuind ca e turbina infundata, dar nu imi dau seama ce reprezinta valorile. Sa fie vinovat senzorul de temperatura de la motorina sau turbina? Asa si acum 3 saptamani a trebuit sa schimb radiatorul de la turbo ca eram in a 6-a si am incerat sa trec de 3000 rpm (a bubuit pur si simplu). Cu ocazia asta am schimbat si toate furtunele ce tin de turbo.
Ms de ajutor.
fault codes.txt
LOG-01-010-011-003.CSV
În primul rând debitmetrul praf (nu a fost limp). Inlocuieste-l apoi vezi cum se comportă. Senzorul de temperatură nu cred că are treaba cu pierderea de putere, eventual consum crescut. Verifică în primul rând mufa și  rezistența interna a senzorului.
Salut.
Stie careva la ce se refera codul?...
17958 - Reglare presiune incarcare
            P1550 - 11-10 - deviatie - intermitent
Multumesc anticipat.
@lupo_bv
    Ok. Revin cu pareri dupa "operatie". Mersi.
6 hours ago, Adiftl said:
Salut.
http://wiki.ross-tech.com/wiki/index.php/17958/P1550/005456
16 hours ago, Adiftl said:
Salut.
verifica electrovalva N75, furtunasele de vacuum (vacuum-ul) si actuatorul.
In continuare dupa schimbarea bujiilor la colegul Al Bundy care erau bune, primesc eroare pe cilindrul 2.
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Bin. Bits: 00001000
                    Temperature: 4.5°C
                    Bin. Bits: 00110000
Modificat de hkdz0r
verifica cablajul/fisa.
Din ce-mi aduc aminte, cablajul e  verificat, e ok. MAi ramane releul cu probleme.
Cel mai probabil, dar unde este situat? pentru a-l verifica.
Revin cu informatii. Am mai fost la un mecanic si nu e debitmetrul ci EGR-ul s-a dus si a ramas intredeschis si de acolo citirea eronata de pe debitmetru. Pentru teste a anulat EGR-ul si tragea caruta excelent. Urmeaza sa comand unul nou si sa il inlocuiesc. Drumuri bune.
  • Aerofan pinned this topic
