zorg
buna ziua mi-am achizitionat un pasat, i-am facut o scanare si mi-au aparut urmatoarele
Saturday,27,February,2016,12:14:38:55062
VCDS Version: Beta 12.10.3
Data version: 20130228
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
   Mileage: 230710km/143356miles
Address 01: Engine        Labels: 038-906-019-AJM.lbl
   Part No: 038 906 019 AJ
   Component: 1,9l R4 EDC G000SG  1060
   Coding: 00002
   Shop #: WSC 05311
   VCID: 5FC61416DDEA8AE6D6F
4 Faults Found
19464 - Camshaft Position Sensor (G40)
            P3008 - 35-00 - Signal Out of Range
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
17664 - Engine Coolant Temp Sensor (G62)
            P1256 - 35-10 - Open or Short to Plus - Intermittent
17552 - Mass Air Flow Sensor (G70)
            P1144 - 35-00 - Open or Short to Ground
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 8D0 907 389 D
   Component: ABS/ESP front       D36
   Coding: 04255
   Shop #: WSC 48208
   VCID: 346CABBA04EC79BE5BD
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 D
   Component: CLIMATRONIC        D2.1
   Coding: 05000
   Shop #: WSC 05311
   VCID: 22405DE2AE18E70EB91
3 Faults Found
01206 - Signal for Duration of Ignition Off Time
            35-10 - - - Intermittent
00792 - A/C Pressure Switch (F129)
00281 - Vehicle Speed Sensor (G68)
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 B
   Component: 0E AIRBAG VW5       0004
   Coding: 12357
   Shop #: WSC 48330
   VCID: 366891B212906BAE659
Address 17: Instruments        Labels: 3B0-920-xx2-17.lbl
   Part No: 3B0 920 822 A
   Component: KOMBI+WEGFAHRS. BOO V20
   Coding: 05145
   Shop #: WSC 48208
   VCID: 1D3A6E1E9766D8F6843
   Subsystem 1 - Part No: Ident
   Component: Nr. WEGFAHRS.:VWZ6Z0Y1542765
   Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1542765
2 Faults Found
01039 - Coolant Temperature Sensor (G2)
            64-10 - Not Currently Testable - Intermittent
01314 - Engine Control Module
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00004
   Shop #: WSC 48330
   VCID: F0E4E7AAB074859EFF5
3 Faults Found
00778 - Steering Angle Sensor (G85)
01044 - Control Module Incorrectly Coded
            35-00 - -
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 3C Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 05311
   VCID: 840CBB7A94CC893E2BD
   Subsystem 1 - Part No: 1J1959801D
   Component: 3C Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802E
   Component: 3C Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811D
   Component: 3C Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812D
   Component: 3C Tõrsteuerger. HR0002r
4 Faults Found
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 - -
End   ---------------------------------------------------------------------
Log-230710km-143356mi.txt
Sterge-le si refa scanarea si vino din nou cu erorile .
Si vezi codarea de pe can gateway , ca e incorecta.
Salutare tuturor,
Dupa lovitura incasata la inceputul lunii, am scos masina din service, evident ca sunt chestii de care sunt nemultumit desi a fost inlocuita bara si intercooler-ul.
Am facut si o scanare azi si am urmatoarele erori. Ma lamureste si pe mine un baiat priceput de la ce sunt si cum le pot remedia?
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6J0 820 043 A HW: 6J0 820 043 A
Component: Climatronic H07 0404
Revision: S0000000
VCID: 224B0C033D3A2A0EA27-8077
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 078101119
Coding: 3C882BE888610100003000007E0B1CC80080400F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 3E73D873A9826EEEA6F-806B
Subsystem 1 - Part No SW: 6R0 959 801 N HW: 6R0 959 801 N Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 3110
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 Q HW: 6R0 959 802 Q Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 3110
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3110
Coding: 000000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3110
Coding: 000000
2 Faults Found:
03428 - Activation of Left Adaptive Light
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 25
Time Indication: 0
03429 - Activation of Right Adaptive Light
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 25
Time Indication: 0
Multumesc,
Senzor presiune freon. Posibil sa fi umblat la el cand au demontat prin fata sau in urma impactului sa fi fost afectat. Vezi daca iti merge clima pe rece, nu pe econ.
A doua - se refera la luminile adaptative stg/dr - cand au demontat bara au decuplat poate si mufele corespondente.
Sterge-le si vezi ce mai ramane.
LE: poate era o fata priceputa, nu un baiat :))
Am facut zilele trecute o scanare si am gasit urmatoarele:
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 871 T    HW: 3C0 920 871 T
   Component: KOMBI         H05 0110
   Serial number: 00000000000000
   Coding: 160F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3561C75F94B4ADB6775-8060
1416448 - Oil Level Thermal Sensor
          B1041 29 [008] - Signal Implausible
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 180
                    Mileage: 191635 km
                    Date: 2077.14.08
                    Time: 16:13:15
E grav?
senzorul din baia de ulei faca figuri.
Vezi si conectica daca e cu probleme.
Daca e ok , senzor cu probleme - cum spune si Bundy
buna baieti am revenit cu o noua scanare si am gasit mai multe bube
E grav?
Sunday,28,February,2016,18:04:31:55062
   Mileage: 230720km/143362miles
   Coding: 00002
   Shop #: WSC 05311
4 Faults Found
   Coding: 04255
   Shop #: WSC 48208
   Coding: 05000
   Shop #: WSC 05311
2 Faults Found
   Coding: 12357
   Shop #: WSC 48330
   Coding: 05145
   Shop #: WSC 48208
2 Faults Found
   Coding: 00004
   Shop #: WSC 48330
3 Faults Found
            35-00 - -
   Coding: 04097
   Shop #: WSC 05311
   Component: 3C Tõrsteuerger. FS0002F
   Component: 3C Tõrsteuerger. BF0002B
4 Faults Found
            35-00 - -
sterge erorile care le ai acum si scaneaza iar, sa vedem ce erori raman
Salut am si eu o problema cu brotacul meu :)
Si nu stiu care sonda este inainte sau dupa catalizator..sau ce trebuie schimbat
Chassis Type: 9C - VW New Beetle (1999 > 2010)
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
   Mileage: 157930km-98133miles
Address 01: Engine        Labels: None
   Part No: 06A 906 033 L
   Component: SIMOS33 1,6l 2V 00HS3466
   Coding: 00031
   Shop #: WSC 00066
   VCID: 2847E8A302F3EB7277F06E5-5140
2 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
            P1118 - 35-00 - Open Circuit
16522 - Oxygen (Lambda) Sensor B1 S2
            P0138 - 35-10 - Signal too High - Intermittent
Readiness: 0010 1001
4 Faults Found:
00943 - Heated Exterior Mirror Driver Side
00912 - Window Regulator Switch; Front Left (E40): Implausible Signal
            35-00 -  -
4 Faults Found:
            35-00 -  -
- problema la sonda lambda
- verifica luminile interioare, plafoniera, etc.
- incalzirile la oglinzile exterioare
problem..problema..dar care este? inainte de catalizator sau dupa? sa stiu sa o comand,la oglinzi stiu ce e..nu merge switch-ul.
http://www.autokarma.ro/sonda+lambda/bosch/vw/new-beetle/1-6/15112/10641/10148/30
Sistem de esapament : inainte de catalizator
Sonda lambda : Sonda reglaj
Interval de schimb recomandat [km] : 250000
Lungime totala (mm) : 1510
Nr. poli : 5
Adica ultima nu? Si o parere daca sunt bune pe bosch
Presupun ca asta e problem de imi consuma foarte multa benzina.,am mai schimbat la ea fisele si bujille..si am gasit pe bujiile 2-4 ulei si un miros intepator de benzina la schimbul de ulei,mecanicul mi-a recomandat segmentarea,eu cum nu prea am habar de mecanica,apelez la voi..e idiot mecanicul si este alta cauza? sau are dreptate?
Inainte de segmentare trebuie facut un test de compresie...apoi vezi ce si cum.Da,sonda lambda defecta modifica consumul...
ca sa vezi daca e din segmenti sau supape,faci test de compresie....iti iese un rezultat iar apoi bagi cu seringa ulei in capul fiecarui piston(sa etanseze mai bine segmentii).daca dupa injectarea uleiului se obs diferente in bine,inseamna ca sunt segmentii.daca nu se obs schimbari,inseamna probleme la supape.
ulei poate ajunge pe bujie ori de la segmenti ori de la simeringurile supapelor.
Modificat de mario20vest
15 hours ago, spido said:
Inainte de catalizator.
cea de dupa, ca e b1s2.
Modificat de Al Bundy
am gasit si eu aceasta eroare, rog pareri.
Km masinii sunt reali, daca are vreo importanta.
Cu o saptamana inainte de scanare mi s-a oprit motorul intr-o frana de motor la turatie mica. Am crezut ca de aceea s-a oprit, insa la scanare am gasit asta:
Mentionez ca ultima data cand am dat joc capacul de pe motor, am observat pompa uda, probabil motorina.
   Mileage: 188760km/117290miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 038 906 018 GA
   Component: 1,9l R4 EDC 0200SG  2605
   Coding: 00002
   Shop #: WSC 12345
   VCID: 5BBF89B5C93EA11
17969 - Quantity Adjuster (N146)
            P1561 - 35-10 - Control Deviation - Intermittent
Readiness: N/A
Nu prea are legătură cu faptul că are pierderi de motorină (doar dacă nu ia şi aer fals pe acolo, dar în situaţia asta cred că ai fi avut mai multe probleme, inclusiv pornire grea), pentru asta trebuie înlocuite garniturile.
Eroarea are legătură cu o eventuală oprire. Cauze posibile: contacte imperfecte la mufa pompei sau la mufa ECU (desfă-le şi curăţă-le cu spray de contacte), N146 cu probleme.
Curăţă contactele de care am pomenit, şterge eroarea şi vezi dacă mai apare.
Eroarea am sters-o. Curat contactele si monitorizez. Masina merge bine, porneste foarte bine, nu-s probleme nici in mers.
 Stie cineva daca vreunu din coduri imi fac sa porneasca greu masina si la rece si la cald? golf4 1.9 ajm. alte probleme nu am avut cu ea inafara de pornire.
Joi,10,Martie,2016,09:56:25:58836
VCDS -- Emulator VAG/VAS bazat pe Windows. Editie în Româna
Versiune VCDS: ROJ 14.10.0.0
Versiune date: 20141103
Tip sasiu: 1J - VW Golf/Bora IV (1998 > 2006)
Adrese de scanat: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   rulaj: 198380km
Adresa 01: Motor        Eticheta: ROJ\038-906-019-AJM.clb
   Numar VAG: 038 906 019 AM
   Componenta: 1,9l R4 EDC 0000SG  0813
   Codare: 00002
   Atelier: WSC 00028
   VCID: 62C1C17DEEAA653119F-4B18
Nu a gasit coduri.
Gata de functie: 0 0 X X X
Adresa 03: ABS frâne        Eticheta: ROJ\1J0-907-37x-ESP-F.lbl
   Numar VAG: 1C0 907 379
   Componenta: ESP     20    CAN  V002
   Codare: 18945
   Atelier: WSC 00028
   VCID: 67D7D06905880019CE1-4B18
1 cod a gasit:
00812 - Electromagnet pentru presiune frânã -F84-
            35-10 - - - intermitent
Adresa 08: Clima automata        Eticheta: ROJ\3Bx-907-044.clb
   Numar VAG: 3B1 907 044 C
   Componenta: CLIMATRONIC     C 0.5.0
   Codare: 01000
   Atelier: WSC 00028
   VCID: 21438E71AB2C3E29405-5266
Nu a gasit coduri.
Adresa 15: Airbaguri        Eticheta: ROJ\6Q0-909-605-VW5.clb
   Numar VAG: 6Q0 909 605 A
   Componenta: 02 AIRBAG VW5       0003
   Codare: 12338
   Atelier: WSC 00028
   VCID: 356B4A210FA4A2898CD-4B18
1 cod a gasit:
00532 - Tensiune alimentare B+
            07-10 - Semnal prea mic - intermitent
Adresa 17: Instrumente bord        Eticheta: ROJ\1J0-920-xx0-17.clb
   Numar VAG: 1J0 920 822 C
   Componenta: A4-KOMBIINSTR. VDO V20
   Codare: 05144
   Atelier: WSC 65463
   VCID: 254B9A61BF04D2093CD-515A
   Subsistem 1 - Numar VAG: IMMO
   Componenta: IDENTNR: VWZ7Z0X1894135
   IMMO-IDENTNR: VWZ7Z0X1894135
2  coduri de defecte:
01039 - Traductor pentru temperatura-G2-
            30-10 - Circ.deschis sau scurt la plus - intermitent
01314 - Modul de comandã motor
            49-10 - Nu este comunicare - intermitent
Adresa 19: Poarta CAN         Eticheta: ROJ\6N0-909-901-19.clb
   Numar VAG: 6N0 909 901
   Componenta: Gateway K<->CAN    0001
   Codare: 00006
   Atelier: WSC 00028
   VCID: 70E5BB353046C7A19FB-515A
1 cod a gasit:
Adresa 46: Confort        Eticheta: ROJ\1J0-959-799.clb
   Numar VAG: 1J0 959 799 AH
   Componenta: 4E Zentral-SG Komf. 0001
   Codare: 04097
   Atelier: WSC 00028
   VCID: 040DE7E514FECB014B3-4B18
   Subsistem 1 - Numar VAG: 1J1959801C
   Componenta: 4E Tõrsteuerger. FS0002r
   Subsistem 2 - Numar VAG: 1J1959802D
   Componenta: 4E Tõrsteuerger. BF0002r
   Subsistem 3 - Numar VAG: 1J4959811C
   Componenta: 4E Tõrsteuerger. HL0002r
   Subsistem 4 - Numar VAG: 1J4959812C
   Componenta: 4E Tõrsteuerger. HR0002r
4  coduri de defecte:
00945 - Senzor impact -G190-
            29-00 - scurt la masã
00953 - Temporizare lumina habitaclu
            25-10 - Pozitie comutator necun. - intermitent
00943 - Oglinda incalzita sofer -Z4-
            35-00 - -
00944 - Oglinda incalzita pasager-Z5-
            35-00 - -
Adresa 47: Sistem sonor        Eticheta: ROJ\1J0-035-456.lbl
   Numar VAG: 1J0 035 456
   Componenta: Soundprozessor 3   0004
   Codare: 00141
   Atelier: WSC 00028
   VCID: 62C1C17DEEAA653119F-4B00
Nu a gasit coduri.
Adresa 56: Radio        Eticheta: ROJ\1J0-035-18x-56.clb
   Numar VAG: 1J0 035 186 D
   Componenta:  Radio BNO         0004
   Codare: 00023
   Atelier: WSC 00028
   VCID: 26499D6DC202D911357-4B00
Nu a gasit coduri.
Sfârsit------------------------(Timp scurs: 04:59)-------------------------
  • Aerofan pinned this topic
