zorg
Overboost condition in loc de: 2229mbar iti baga 2568mbar si asta cam inseamna geometrie ancrasata.un bs011 cu turbina incinsa bn,ar dezvalui mai multe despre turbo.(sau mai bine postezi in aria "loguri si interpretarea lor".
geometrie imbacsita, in majoritatea cazurilor.
Multumesc baieti! Referitor la conoana volan ce ar trebuii sa fac?
Va salut daca un coleg stie sa mi spuna la ce se refera eroarea aceasta
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 A    HW: 4E0 035 729
   Component: Interfacebox    H43 4220
   Revision: 00000000    Serial number: 392EI057530304
   Coding: 0001005
   Shop #: WSC 02335 785 00200
   VCID: 2149030FF83C3116BBD-8074
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000155733
   Subsystem 3 - Serial number: 0109.05.050000000100010381ÿ
   Subsystem 4 - Serial number: 010381ÿ
02244 - Button in Control Head is Stuck
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 78
                    Mileage: 315995 km
                    Time Indication: 0
                    Date: 2015.04.15
                    Time: 09:42:33
             Freeze Frame:
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      010
                    Va multumesc anticipat.
Modificat de cmarius53
hai ma fratilor ca daca nici engleza + o eroare mai mult decat explicita nu stim sa interpretam...
Audi A6 C6...  unul din butoanele MMI de langa schimbator a ramas blocat apasat....
Modificat de andrei_221
Deci cum zic multumesc frumos Andrei_221.Ma bagase in ceata "control head".O zi buna.
asa se numeste consola centrala la A6 - respectiv adresa 07 pe VCDS.
Multumesc florin.am rezolvat,un buton peste care se varsase cafea.va doresc numai bine.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 46180A3E803308C0428800809500810442519DA8427D81605C8040000040
   Shop #: WSC 04941 000 00000
   VCID: 3B7133DF01A5
   Subsystem 1 - Part No: 1P0 955 119 C
   Component: Wischer 09021  22  0611
   Coding: 00DB90
   Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A
   Component: REGENLICHTSEN  H04 0003
   Coding: 02542E
03396 - Supply voltage terminal 30 for central locking
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 253
                    Mileage: 74794 km
                    Time Indication: 0
                    Date: 2109.14.02
                    Time: 12:14:37
             Freeze Frame:
                        Term 15 Off
                    Voltage: 11.95 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Pareri despre aceasta eroare? Seat Leon Facelift 2011
Numai ce am luat-o si e prima data cand o scanez. Cam da cu minus, raman dator pentru o mana de ajutor. Multam!
Saturday,18,April,2015,19:10:11:10074
VCDS Version: Beta 11.2.0 (x64)
Data version: 20110207
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 7D
VIN: WVWZZZ1KZ6W095530   Mileage: 147550km/91683miles
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC 0000SG  6176
   Revision: 12345678    Serial number: VWZ7Z0E3016659
   Coding: 0000072
   Shop #: WSC 01279 785 00200
   VCID: 65C5B5A7D7A1
4 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
            P0671 - 000 -  -
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 60.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
            P0672 - 000 -  -
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 60.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
            P0673 - 000 -  -
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 60.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
            P0674 - 000 -  -
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 60.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BD
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
   VCID: 6ADFC69B3EBF
01809 - Actuating Motor for Temperature Flap; Left (V158)
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005181507
   Coding: 038B0F2700041800001400001400000000097F075C
   Shop #: WSC 01287 785 00200
   VCID: 2B51039FF1C5
   Subsystem 1 - Part No: 1K1 955 119 C
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 01287
7 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 165
                    Mileage: 146798 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00987 - Lamp for Brake Light; Left (M9)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 165
                    Mileage: 144933 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.60 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00984 - Left Tail Light (M4)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 166
                    Mileage: 146798 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 154
                    Mileage: 146414 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
02071 - Local Databus
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 154
                    Mileage: 146414 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.30 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00153 - Windshield Wiper Motor;  Driver Side (V216)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 154
                    Mileage: 146414 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.30 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00927 - Terminal 30 (Right)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 154
                    Mileage: 146414 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 37 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD037R96
   Coding: 0013111
   Shop #: WSC 01269 785 00200
   VCID: 3B7133DF01A5
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 809002085103087F2D04840560084F01E0A440
   VCID: 800B0433A8C3
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
00930 - Locking Module for Central Locking; Rear Left (F222)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 134
                    Mileage: 145144 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:37:28
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2387
   Coding: 0000180
   VCID: 37792FEF3D8D
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
End   ---------------------------------------------------------------------
Ia sterge-le si vezi care mai reapar.Dupa mine miroase a interventie la motor si nu s-au sters erorile generate,plus ce mai apare p-acolo,sterge si revino.
S-au dus toate in afara de cele de pe address 09: Cent. Elect. Exceptand local databus si terminal 30 care nu stiu ce sunt pot sa-ti spun ca restul elementelor cu eroare functioneaza in regula.
Le-am pus pe pastebin ca sa nu umplu pagina fara rost.
http://pastebin.com/NspBuFx7
Edit: Multumesc andrei_221, dimineata o sa schimb siguranta sa vad care e treaba.
Modificat de smokeybandit
bun.... e cam usoara treaba asta.
Langa baterie este o cutie de sigurante, tragi spre fata masinii 2 zavoare si scoti capacul in sus.
In coltul dreapta sus o sa observi o siguranta verde de 30A topita...  demotezi babeste si refaci circuitul acela
post-17228-0-94273900-1429383861_thumb.j
dupa ce repari, o sa iti dispara si erorile intermitente la becurile de pe partea dreapta.
am schimbat bujiile incandescente insa tot primesc eroarea.plus ca a mai aparut inca una.
2 Faults Found:
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 294 /min
                    Torque: 162.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 9.80 V
                    Bin. Bits: 11000111
                    Temperature: 8.1°C
                    Bin. Bits: 01110000
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
            P2185 - 000 - Signal too High - Intermittent
             Freeze Frame:
                    RPM: 1533 /min
                    Torque: 46.0 Nm
                    Speed: 68.0 km/h
                    Load: 15.3 %
                    Voltage: 14.21 V
                    Bin. Bits: 11000000
                    Temperature: 91.8°C
                    Temperature: 81.9°C
verifica cablajul la bujie.
senzorul - posibil sa necesite inlocuire.
nu gasesc niciunde o schema cu amplasarea senzorului G83 la touran.el raspunde si de termocupla?
Modificat de iuliu1984
jos la radiator, in partea stanga, pe flansa de plastic, daca imi aduc bine aminte.
Salut cu respect pe toata lumea. E primul meu post aici,motiv pentru care multumesc tuturor pentru munca si amabilitatea de a ampartasii din experienta Dvs.Am gasit aici rezovare la multe probleme dar la ultima m-am cam anpotmolit. Cam de o luna de zile am constatat o problema comuna,cam pe la 120km h cineva sau ceva imi taie gazu ! OK,am scos maf-ul,l-am curatat cu un spray pt carburatoare,uscat,montat si talpa. De data asta a accelerat pana la 165 km h cand sa terminat drumul drept. E drept ca merge ceva mai bine insa accelereaza foarte lent si nu prea pot sa ma angajez in depasiri. Va rog sa ma ajutati cu interpretarea acestui log.  Sunt un mandru proprietar de Passat 3BG 1,9 tdi ,100 Hp,2002
log.csv.txt.txt
Multumesc mult.
Modificat de Bobiwar
Log-ul este ceva care se face cu un vag-com sub forma unor parametrii transcrisi de la anumite piese mecanice.Din ce spui tu acolo masina iti intra in Limp Mode (de la turbo)
Log-ul,normal ca l-am facut cu vag com doar ca nu ma pricep la interpretarea lui.De curand am schimbat trusa de scule din Dacie cu laptop-ul din Passat... :icon_confused:
Posteaza logul in aria "loguri si interpretarea lor" ne vedem acolo.
Fa si un bs 003 si 011(asta cu tirbo incins bn de tot)
Buna ziua stimati colegi. Rog si eu pe cineva sa-mi traduca erorile gasite la un audi b6/2002. Si sa-mi spuna cineva daca eroarea de la airbag pot sa o sterg fara a cauza deschiderea airbagurilor....stiu ca sunt anumite coduri care nu tb sterse din acest motiv. Va multumesc...
Log-WAUZZZ8E02A145504-234800km-145897mi.txt
salutare. revin cu oarecum aceeasi problema, insa cu alt tip de eroare. d-abia ce am montat un motoras reconditionat de STANGA, am putut sterge eroarea tipica "....resistance to movement" si m-am pricopsit cu alta pe dreapta:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11111100
                    Fault Priority: 1
                    Fault Frequency: 7
                    Reset counter: 0
                    Mileage: 185184 km
                    Time Indication: 0
                    Date: 2015.04.19
                    Time: 18:33:48
             Freeze Frame:
                    Voltage: 12.73 V
                    Count: 87
Treaba e ca piuie intr-una + clipoceste butonul+martor p taiat+martor frana, si NU POT STERGE aceasta eroare cu clona mea de vag.....intrebarea mea este: se poate sterge cu o interfata originala sau trebuie sa-i dau foc la masina?????
PS: nici cand aveam dacie acum 100 de ani nu aveam atatea probleme.........
scuzati tonul agresiz insa cred ca ma lasa nervii....
  • Aerofan pinned this topic
    • andrei_221
