zorg
Salutare!
Imi spune si mie de ce apar aceste erori?
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 69 72 77
VIN: WVWZZZ3CZAE202877
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 EN    HW: 03L 907 309 A
   Component: R4 2,0L EDC G000SG  7373
   Revision: 21H27---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00020 000 00000
   VCID: 75E1075F1C34EDB6B75-8020
008863 - NOx Sensor 2 Bank 1
               P229F - 000 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 196686 km
                    Time Indication: 0
                    Date: 2051.14.27
                    Time: 15:47:17
             Freeze Frame:
                    RPM: 1518 /min
                    Speed: 89.0 km/h
                    Voltage: 13.98 V
                    Lambda: 99.4 %
                    (no units): 255.0
                        128 ppm
                    (no units): 0.00
Readiness: 0 1 0 0 0
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 7AFB1463352A82CEDA7-802F
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
2 Faults Found:
02823 - Requirements for Locking the Steering Column Lock not met
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 196703 km
                    Time Indication: 0
                    Date: 2051.14.27
                    Time: 19:32:30
02827 - Wake-Up request via ESP
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 196703 km
                    Time Indication: 0
                    Date: 2051.14.27
                    Time: 19:32:31
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 0802
   Revision: 1AH03729    Serial number: 00102500591201
   Coding: 0000258
   Shop #: WSC 05311 000 00000
   VCID: 3B75D1677A907BC6811-806E
4 Faults Found:
01316 - ABS Control Module
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 196703 km
                    Time Indication: 0
                    Date: 2051.14.27
                    Time: 19:32:21
             Freeze Frame:
                        Term 15 Off
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 11.0
                    Voltage: 13.20 V
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 196703 km
                    Time Indication: 0
                    Date: 2051.14.27
                    Time: 19:32:21
             Freeze Frame:
                        Term 15 Off
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 11.0
                    Voltage: 13.20 V
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Time Indication: 0
             Freeze Frame:
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Time Indication: 0
             Freeze Frame:
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
ai probleme cu sonda de N0x ( sau calculatorul acesteia), blocatorul de volan si ceva comunciatii defectuoase in sistem - probabil datorate unor intarzieri in alimentarea unora dintre unitati.
Modificat de andrei_221
Le-am sters si acum vreau sa vad daca mai apar. Ar putea fin din cauza ca a ramas fara baterie si a schimbat-o?
Stefan Eusebiu
redemperor ce adblue folosesti ?
E mașina nasului meu. Nu știu ce adblue folosește. De ce?
Stefan Eusebiu
eroare de la nox sensor poate aparea si din cauza lichidului adblue de proasta calitate(cel de la omw care este 80 lei, 10 litri), daca vrei iti trimit maine un cod pentru lichid adblue pentru grupul vag, in cazul in care are adblue de la omw, ar fi bine sa l scoata pe tot si sa il in locuiasca.
Am să-i spun. Dacă vrei să-mi dai codul...
Stefan Eusebiu
 codul acela il gasesti si pe rezervorul de adblue, o sa-ti trimit maine un mesaj pe privat pt ca am bidonul acela in garaj;
Astazi am revenit la softul original deoarece cu cel modificat am investit cam multi bani in masina intr-o perioada relativ scurta(4 luni). Am scanat masina inainte si dupa rescriere, inainte nu am gasit nici o eroare, dupa n-am mai fost asa norocos:
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J5 920 825 C
   Component: A4-KOMBIINSTR. VDO V04
   Coding: 06112
   Shop #: WSC 54321
   VCID: 2D51EF36E7B133760F5-5198
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0Y2571176
   IMMO-IDENTNR: VWZ7Z0Y2571176
2 Faults Found:
00771 - Fuel Level Sensor (G)
            30-00 - Open or Short to Plus
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EFB642B0039E9EE43-517A
Cea legata de senzorul de nivel combustibil este oarecum rezolvata, cand am motorina in rezervor peste jumate apare eroarea si indicatorul din bord o ia razna, o voi rezolva cand se incalzeste afara sa pot scoate sorbul afara.
Legat de celelalte(sau cealalta) ce ar putea fi? Am observat ca uneori pe Engine, grupul 019 imi arata in ambele casute 0 V desi ar trebui sa arate in prima o casuta o valoare intre 0.5-0.97V iar in a doua casuta 4.1-4.75V. Sa nu ajunga curent la pompa astfel ajustorul de combustibil sa nu miste?
Nu era facut de vreo firma anume, un cunoscut mi l-a facut "mocca" de acolo probabil si calitatea sa...
Si ce legatura au erorile astea cu resoftarea? In ce ai investit in 4 luni?
Nu are rost sa fac lista, saptamana trecuta doar kit de ambreiaj+volant si o planetara...
Bineinteles, nu toate piesele au fost schimbate din cauza softului dar nu am fost multumit deloc de masina in aceste 4 luni asa ca softul original mi s-a parut cea mai buna alegere.
Modificat de Rdn
Păi uite ce zice aici despre ultima oroare:
"Engine Control Module recently flashed or re-mapped" :D
omul a asociat problemele cu softul facut,dar unele chiar din vina softului au fost.
Foarte interesant, nu stiam. Si cu softul modificat nu iti apareau erorile? Nu neaparat astea, de exemplu la o autoscanare iti apare ceva sau daca remaparea ii rau facut ascunde si aceste erori stocate?
Si care ar fi rezolvarea, avand in vedere ca acum ai softul original si erorile persista.
P.S Cu ce ti-a scris resoftarea?
Pe eBay sunt tot felu de programme de 15 -20 € (galetto, mps,k etc), si eu am si vream sa fac ceva pe un golf 4 care ii in familie da nu il prea ultilizam. Acum cred ca am sa las balta.
Nu ai un logo cu softul gresit sa vedem ce a facut defapt de s-a ajuns aici.
Lupo_bv, am vazut ca poate avea legatura cu rescrierea DAR la fel poate sa fie o problema electrica deoarece ajustorul de combustibil din pompa primeste curent doar uneori(grupul 019 arata valoarea 0 V), voi verifica astazi releul n109 si cablajele.
Cu softul modificat autoscanul nu mergea pe totate modulele, uneori ajungea doar pana la HVAC, cel mai probabil este o problema undeva..
Salutare!
Postez aici urmatoarea problema, in ideea ca e rezolvata problema pe jumatate, adica eroarea mecanica e reparata insa persista eroarea electronica.....
Dupa ce am schimbat motorasul stanga spate, de la frana de mana, nu pot "calibra" motorasele/etrierii din modulul parking brake/basic settings, spunandu-mi ca interfata nu e compatibila (ceva de genu'...). - ma gandesc ca trebuie interfata originala pentru acest tip de eroare, asa e?
Ideea este ca frana de mana functioneaza, cupleaza/decupleaza, insa persista eroarea in bord + clipoceli +sunete specifice de te scot din masina......am incercat sa sterg eroarea, nu merge, am scos borna, nu merge, am cuplat decuplat de 100 de ori, nu merge......ce i-as mai putea face???? e normal sa tiuie atata timp cat ea functioneaza? banuiesc ca din caua erorii stocate, fiind de rang1, pana nu se sterge tot asa va face, sau mai poate fi si altceva????Cam care ar fi algoritmul calculatorului???
Va multumesc mult pentru pareri si sper sa fi nimerit topicul...
02432 - Supply Voltage for Left Parking Brake Motor (V282)
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11111100
                    Fault Priority: 1
                    Fault Frequency: 24
                    Reset counter: 191
                    Mileage: 184408 km
                    Time Indication: 0
                    Date: 2015.03.29
                    Time: 08:54:10
             Freeze Frame:
                    Voltage: 13.46 V
                    Count: 86
02432 - Supply Voltage for Left Parking Brake Motor (V282): Electrical Fault in Circuit
02432 - Supply Voltage for Left Parking Brake Motor (V282): Open Circuit
Possible Symptoms
Parking Brake Warning Light active/flashing
Possible Causes
Wiring/Connectors from/to Left Parking Brake Motor (V282) faulty
Left Parking Brake Motor (V282) Power Supply faulty
Left Parking Brake Motor/Caliper (V282) faulty
Possible Solutions
Check Wiring/Connectors from/to Left Parking Brake Motor (V282)
Check Left Parking Brake Motor and (V282) Power Supply
Perform Terminal 30 Reset
Remove Fuse(s) for a short Time.
Special Notes
When found in VW Passat (3C): Parking Brake:
Clear Fault Codes with Engine running (to ensure proper Voltage Supply). When checking Voltage with this Fault Code stored, the Module may not output Power to the Motor. Try clearing Fault Codes and Operating the EPB as mentioned below before testing again.
Switch Ignition OFF for about 10 Seconds
Start the Engine and keep it running while trying to clear Fault Codes.
Press the Parking Brake Button (E538) in 5 Second Intervals.
Check TPI 2013530 (Rest of World) or TSB 2015075/01-07-47 (North American Region) for possible Control Module Software Update which corrects Low Voltage Sensitivity. This Update can be considered mandatory if you have these Fault Codes stored!
Sursa : http://www.google.ro/url?url=http://wiki.ross-tech.com/index.php/02432&rct=j&q=&esrc=s&sa=U&ei=nCckVZyvL4b_ygPj-oGYDw&ved=0CBMQFjAA&usg=AFQjCNGAUxg3CgH9Ky3VoP5dDAp6cvUgnw
Fault Priority: 1,trebuie stearsa,si facut basic settings.
Modificat de EEXCALADE
S-a rezolvat dupa ce am facut pasii descrisi mai sus. Miliarde de multumiri colegului Exxcalade pentru reparatia motorasului, pentru sfaturi si pentru profesionalismul desavarsit. Mai rar asa oameni. Recomand cu incredere!!!!
ai avut noroc, dar as suspecta si mufa de la etrier oxidata. La passat 3c si Audi A6 4F am intalnit cateva specimene de sertizare oxidata in papucii mufei.
Intr-adevar mufa era oxidata un pic. I-am dat cu spray de contacte si am curatat un pic cu suribelnita (cat s-a putut) insa chiar si inainte de operatiune facea contact bine.
Ma ajutati va rog cu:
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VD29 0005
   Revision: --H07---    Serial number: 00000003352708
   Coding: 0003504
   VCID: 387530A04BAD4ADE6C3-806D
01309 - Power Steering Control Module (J500)
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 20
                    Reset counter: 40
                    Mileage: 150533 km
                    Time Indication: 0
                    Date: 2050.14.03
                    Time: 19:32:15
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 278
                    Hex Value: 0x0000
  • Aerofan pinned this topic
    • andrei_221
