zorg
      Salutare.
  Am testat cu VCDS Passatul lui fratele meu si au aparut niste erori si daca puteti sa-mi spuneti daca e vreo problema grava!
Thursday,05,February,2015,16:22:07:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3BZ1P050511   License Plate: AR 80TOT
Mileage: 226550km-140771mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ1P050511   Mileage: 226550km/140771miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 DS
   Component: 1,9l R4 EDC 0200SG  1348
   Coding: 00002
   Shop #: WSC 10134
   VCID: 6BD5212719702B46511-4A9C
   WVWZZZ3BZ1P050511     VWZ7Z0Y2764519
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 3B0 614 111
   Component: ABS/ASR 5.3 FRONT   D00
   Coding: 00012
   Shop #: WSC 00028
   VCID: D3A519C721001386F91-5072
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 H
   Component: CLIMATRONIC B5GP    0002
   Coding: 17000
   Shop #: WSC 00028
   VCID: 26431013C212D62ECEF-5000
Address 15: Airbags        Labels: None
   Part No: 6Q0 909 601 A
   Component: 0J AIRBAG VW5       0004
   Coding: 12362
   Shop #: WSC 00028
   VCID: 3169F34FFBDC81962BD-49D8
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 805 A
   Component: KOMBI+WEGFAHRSP VDO V09
   Coding: 01105
   Shop #: WSC 12345
   VCID: 1E3338F39A420EEE86F-5000
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0EFB64BB056489EE43-5000
01320 - Control Module for Climatronic (J255)
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 0Z Komfortgerát HLO 0001
   Coding: 00259
   Shop #: WSC 00028
   VCID: 3663C05312B2A6AE7EF-4A3A
   Subsystem 1 - Part No: 1C1959801
   Component: 0Z Tőrsteuer.FS     0001
   Subsystem 2 - Part No: 1C1959802
   Component: 0Z Tőrsteuer.BF     0001
   Subsystem 3 - Part No: 1C0959811
   Component: 0Z Tőrsteuer.HL     0001
   Subsystem 4 - Part No: 1C0959812
   Component: 0Z Tőrsteuer.HR     0001
3 Faults Found:
01336 - Data Bus for Comfort System
            80-00 - Single-Wire Operation
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
End   ---------------------------------------------------------------------
    Multumesc si imi cer scuze ca ieri nu am postat unde trebuia!
   Ceva lamuriri se poate! Mersi.
[adblue]salutari, am urmatoarele 2 erori, in timpul mersului imi apare(problema de care m am tot ferit) ca mai am 1050km dupa care trebuie sa completez adblue, si martorul cu motorul(sonda lambda), am pus vag'ul si am sters erorile, insa nu mi se reseteaza kilometri la adblue. (passat b6 bluetdi)
care este remediul acestei probleme, si codurile pieselor care trebuie schimbate daca se poate. multumesc
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 EN HW: 03L 907 309 A
Component: R4 2,0L EDC G000SG 7373
Revision: 21H22--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 61891 133 81716
VCID: 75E791961CB65CB6B8B-8020
2 Faults Found:
008863 - NOx Sensor 2 Bank 1
P229F - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 194170 km
Time Indication: 0
Date: 2053.14.00
Time: 13:16:52
Freeze Frame:
RPM: 1495 /min
Speed: 40.0 km/h
Voltage: 13.83 V
Lambda: 99.4 %
(no units): 255.0
188 ppm
(no units): 0.00
008430 - SCR NOx Catalyst Bank 1
P20EE - 000 - Efficiency too Low - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 195656 km
Time Indication: 0
Date: 2056.14.16
Time: 10:10:10
Freeze Frame:
RPM: 1495 /min
Speed: 73.0 km/h
(no units): 0.93
Temperature: 198.0°C
(no units): 0.00
(no units): 1.02
Readiness: 1 3 0 0 0
Modificat de Stefan Eusebiu
Salut.Se poate putin ajutor?
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 B    HW: 028 101 147 8
   Component: R4 1,9L EDC G000SG  5645
   Revision: 12345678    Serial number: VWZ7Z0C8741776
   Coding: 0000071
   Shop #: WSC 00000 028 00001
   VCID: 22419B2C860F
19558 - Motor for Intake Manifold Flap (V157): No Signal
            P3102 - 000 -  -
             Freeze Frame:
                    RPM: 966 /min
                    Torque: 34.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 00001000
                    Torque: 148.0 Nm
                    Torque: 0.0 Nm
Am pus clapeta  noua,sigurante nu am gasit arse! Unde sa mai caut?
Mufa de la clapeta are 4 pini,unul de masa si inca 3.
2 fire merg direct la ECU fara sigurante si sunt ok,am continuitate.Al 4-lea fir nu gasesc unde merge,cel verde cu rosu.
Am incercat in ETKA sa gasesc schema dar nu dau de ea...Are cineva mai multe informatii?Ms.
in ELSA gasesti schema
Firul verde-rosu este alimentarea cu 12V. Merge la o conexiune cu firul ce alimenteaza modulul de pe ventilatoarele de racire si primesc curent de la siguranta SB8 de 10A, din cutia de sigurante de langa baterie.
Imi poate da cineva niste coduri echivalente pt o unitate ABS de la un audi a6 c5 din 1998 2.5 tdi ake,tractiune fata.codul unitatii vechi(stricata) este hr8e0614111hhl
Ca nu gasesc nici de-al naibii codul asta la dezmembrari.
Modificat de mario20vest
Chiar si primele 2,  codul incepe cu 8 si se termina in 111.
Salutare. Puteti va rog sa imi spuneti ce reprezinta eroarea si daca doar dupa aceste coduri de eroare se poate apreci cam cit cost reparatia; inteleg ca e vorba de incalzirea auxiliara, care este destul de simplu gindita, dar pe http://wiki.ross-tech.com/ nu gasesc nimic. Multumesc.
VW Sharan 2006, motor 2.0tdi
Address 18: Aux. Heat Labels: None
Part No: 7M3 815 071 B
Component: HEIZG. B/D5W 0001
5 Faults Found:
01492 - Function Lock-Out
35-00 - -
01409 - Repeated Flame-Out
35-00 - -
01413 - Dosing/Metering Pump (V54)
29-00 - Short to Ground
35-00 - -
Modificat de cosmosin
posibil sa fie pompa de motorina pentru webasto stricata sau firele catre ea.
Buna ziua colegi ! P 0546 ( G235 ) imi poate spune cineva despre senzorul acesta ?! Unde se afla si daca este greu de schimbat ? Am avut mai multe probleme si vad ca mi-a ramas eroarea asta împreuna cu martorii de la motor si spirala aprinși in IC :( . Passat cod motor BMP . ms anticipat
Modificat de casper_bdc
Putin ajutor va rog. Am urmatoarea problema: bordul este mort, nici un martor aprins cand bag cheia, motorul porneste pentru o secuda, dupa care se opreste. In rest, inchiderea centralizata, alarma, faruri, proiectoare, radio, aer conditionat functioneaza normal. Care ar fi cauza? La un scan cu VAG-COM mi-au dat urmatoarele erori:
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
Modificat de rycco4u
Salutare tuturor!
Ma poate lamuri si pe mine cineva de ce imi apare eroarea asta pe navigatie? 00854 - Radio Display Output in dash Panel insert
De celelalte doua stiu. Nu am legate doua fire in spatele navigatiei deoarece am schimbat-o si nu se potriveste mufa.
Si mai am una pe difuzoarele spate, dar care merg amandoua.
Cele de pe Instruments si CAN Gateway tot reapar.
Saturday,14,February,2015,16:52:39:62939
Dealer/Shop Name: redemperor
VIN: WVWZZZ1JZ5W060643   License Plate: GR12RED
Mileage: 188940km-117401mi   Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ5W060643   Mileage: 188940km/117401miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 KP
   Component: 1,9l R4 EDC G000SG  4902
   Coding: 00002
   Shop #: WSC 01266
   VCID: 6FED35372D68D7667D9-49D8
   WVWZZZ1JZ5W060643     VWZ7Z0D1182881
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Component: ESP FRONT MK60      0102
   Coding: 0019458
   Shop #: WSC 01266 785 00200
   VCID: 3467FA5B54CEB4BE40B-5072
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: 16 AIRBAG VW61 0108 0003
   Coding: 12598
   Shop #: WSC 01266
   VCID: 275D1D17C518CF26F59-5072
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 01317
   VCID: 306FF64BF0D6889E243-50E6
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 846 C
   Component: KOMBI+WEGFAHRSP VDO V23
   Coding: 17112
   Shop #: WSC 02241
   VCID: 2B55E127D9F0EB46111-5000
            80-10 - Single-Wire Operation - Intermittent
   Coding: 00006
   Shop #: WSC 01266
Address 37: Navigation        Labels: 3B0-919-887.lbl
   Part No: 3B0 919 887 E
   Component: Navigation     BNO 0304
   Coding: 00001
   Shop #: WSC 00000
   VCID: 3467FA5B04CEB4BE40B-4A3A
3 Faults Found:
00625 - Vehicle Speed Signal
            03-00 - No Signal
00867 - Connection to ABS Control Module
            03-00 - No Signal
   Component: 1A Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 01266
   Subsystem 1 - Part No: 1C1959801A
   Component: 1A Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802A
   Component: 1A Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811A
   Component: 1A Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812A
   Component: 1A Tõrsteuer.HR KLO 0202
Address 56: Radio        Labels: 3B0-035-186.lbl
   Part No: 3B0 035 186 D
   Component: Radio          BNO 0304
   Coding: 03407
   Shop #: WSC 01973
   VCID: 204F060BA036381EB43-4A3A
00853 - Loudspeaker(s); Rear
            36-00 - Open Circuit
Ptr. clapeta de cut-off si electroventilator poti incerca un self-test dar uitete si la cablaj...cand opresti motorul se opreste mai brutal sau normal,iar referitor la ultima eroare este un pic mai ciudata ptr. ca ar trebui sa mai ai o eroare pe un alt modul ex. gen abs,verifica pe canalul 125 daca ecu comunica cu toate modulele,poate ai un contact imperfect in mufa pe undeva tinand cont ca este o eroare intermitenta
salut mai am o eroare    01336-data bus for confort system     80-10-single-wire operation-intermittent.............si mai specifi faptul ca masina a stat parcata vreo 2 luni cu frana de mana trasa si când am revenit acasa când am pornit-o mi-a aparut in bord problema la ABS si la ESP....au facut putin zgomot la primele 3 frane si dupa aia si-a revenit.multumesc....ai putea sa detaliezi putin ce ai spus mai sus te rog....pentru a sti exact unde sa umblu....daca se poate si in pm.multumesc dragi colegi
Da bordul jos si verifica daca ai alimentarile necesare in mufa lui.
Îmi spune și mie cineva de ce am erorile alea? Pls!
sterge-le si nu le mai baga in seama.
ultima arata ca nu iti functioneaza un difuzor, pe spate.
Legam șters și au reparut. Difuzorul de pe spate inițial mergea, după nu a mai funcționat. Am desfăcut panoul de ușă și, ca prin minune, și-a revenit. Dar tot apare eroarea. Parca sa zic ca se și aude puțin mai încet decât celalalt de pe spate. În schimb nu știu de ce mi-a apărut eroarea aceea de display.
navigatia nu comunica cu displayul din ceasuri, deci ar trebui sa nu afiseze indicatiile pe display-ul din ceasuri...
Nu înțeleg care ar fi cauza. Asa dintr-o data sau mai comunice? Mi se pare ciudat.
fire intrerupte, contacte imperfecte.
  • Aerofan pinned this topic
    • Jony04
