zorg
      Salutare.
  Am testat cu VCDS Passatul lui fratele meu si au aparut niste erori si daca puteti sa-mi spuneti daca e vreo problema grava!
Thursday,05,February,2015,16:22:07:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3BZ1P050511   License Plate: AR 80TOT
Mileage: 226550km-140771mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ1P050511   Mileage: 226550km/140771miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 DS
   Component: 1,9l R4 EDC 0200SG  1348
   Coding: 00002
   Shop #: WSC 10134
   VCID: 6BD5212719702B46511-4A9C
   WVWZZZ3BZ1P050511     VWZ7Z0Y2764519
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 3B0 614 111
   Component: ABS/ASR 5.3 FRONT   D00
   Coding: 00012
   Shop #: WSC 00028
   VCID: D3A519C721001386F91-5072
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 H
   Component: CLIMATRONIC B5GP    0002
   Coding: 17000
   Shop #: WSC 00028
   VCID: 26431013C212D62ECEF-5000
Address 15: Airbags        Labels: None
   Part No: 6Q0 909 601 A
   Component: 0J AIRBAG VW5       0004
   Coding: 12362
   Shop #: WSC 00028
   VCID: 3169F34FFBDC81962BD-49D8
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 805 A
   Component: KOMBI+WEGFAHRSP VDO V09
   Coding: 01105
   Shop #: WSC 12345
   VCID: 1E3338F39A420EEE86F-5000
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0EFB64BB056489EE43-5000
01320 - Control Module for Climatronic (J255)
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 0Z Komfortgerát HLO 0001
   Coding: 00259
   Shop #: WSC 00028
   VCID: 3663C05312B2A6AE7EF-4A3A
   Subsystem 1 - Part No: 1C1959801
   Component: 0Z Tőrsteuer.FS     0001
   Subsystem 2 - Part No: 1C1959802
   Component: 0Z Tőrsteuer.BF     0001
   Subsystem 3 - Part No: 1C0959811
   Component: 0Z Tőrsteuer.HL     0001
   Subsystem 4 - Part No: 1C0959812
   Component: 0Z Tőrsteuer.HR     0001
3 Faults Found:
01336 - Data Bus for Comfort System
            80-00 - Single-Wire Operation
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
End   ---------------------------------------------------------------------
    Multumesc si imi cer scuze ca ieri nu am postat unde trebuia!
Modificat de doki32
Salut. Nu cred ca am postat unde trebuia dar chiar nu gasesc un pot pe tema asta.
Am un golf 5 2.0 BKD. Dupa un drum mai lung am observat ca imi face probleme. L-am dus in service si dupa ce a intrat pe tester mi-a aparut clapeta de acceleratie.
Astazi am mers in service si am lasat masina acolo, neavand timp sa stau. Dupa cateva ore mecanicul mi-a spus ca este moarta de tot clapeta de acceleratie si ca trebuie schimbata.
Este posibil sa moara de tot ? Am auzit de la alte persoane ca se poate curata. Este vreo sansa sa crape de tot fara a mai putea fi salvata cu o curatare ?
Multumesc si scuze inca odata pentru post !
Am mutat aici postul în ideea că poate postezi codul erorii. Nu de alta, dar nu cred că maşina ta are clapetă de acceleraţie.
E vb ma gandesc la cea de cut off. Masina se scutura la oprire?
bkd are corp clapeta acceleraţie si da eroarea asa apare. deobicei clapetele de acceleraţie au prostul obicei sa se strice dintii de plastic de pe cramaliera clapetei sau de pe axul motorasului.
are rol si de shutoff
Modificat de kosmyn_aurel89
Va salut. Am golf 5 2.0 tdi. BKD. Am următoarea eroare a mai intalnit o cineva?
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Control Module Part Number: 03G 906 021 KK HW: 03G 906 021 KK
Component and/or Version: R4 2,0L EDC 000SG 9183
Software Coding: 0000072
Work Shop Code: WSC 00028 028 00001
VCID: 72EB3C436D5AFA8E927-8027
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 121444 km
Time Indication: 0
Date: 2000.00.00
Time: 19:03:07
Freeze Frame:
RPM: 2982 /min
Speed: 156.0 km/h
Load: 78.0 %
Voltage: 14.36 V
Bin. Bits: 11000000
Absolute Pres.: 2264.4 mbar
Absolute Pres.: 2590.8 mbar
DA, ai presiune prea mare in turbo, cauta dupa LIMP MODE>
Pentru Al Bundy ; Daca ai postat un sfat pt. mine te rog specifica , pentru ca nu prea inteleg daca este legat de problema mea ceea ce se posteaza. Vreau sa stiu problema aparuta si modul de rezolvare.....
 Cer scuze pentru stangaciile mele prin forumul asta. Este de mare ajutor pentru novici ca subsemnatul.
 Multumesc anticipat pentru ofurile mele.
nu era pt tine raspunsul.
la tine trebuie sterse toate erorile si scanat dupa un timp si vazut care reapar.
in principiu e o problema la motorasul de recirculare de la climatronic.
restul nu sunt relevante cred
Am si eu o eroare care imi da batai de cap:
P0087 Fuel Rail/System Pressure - Too Low
Tin sa precizez ca aceasta eroare a aparut dupa ce m-am confruntat cu spanul :( schimbat toate injectoarele, pompa de inalta, curatat rezervor si conducte.
Inainte sa apara eroarea am auzit un zomot ciudat din fata , era parca nu motoras care se supra tura , dupa asta spirala aprinsa in bord si s-a oprit motorul.
Dupa ce am pus testul am dat la automat si masinia a pronit fara nici o problema.
Sincer mi-e frica sa o mai pornesc pana nu sunt convins care e problema.
multumesc pt ajutor
Am uitat sa precizez ca masina este un Golf VI 2010, 2.0 TDI 140 CP
ttrebuie facuta o verificare amanuntita. Eroarea poate sa fie de la pompa rezervor - pompa tranfer , pompa HP care nu face presiune, supapa dozatoare care nu deschide suficient, senzor presiune pe rampa care citeste aiurea, regulator care lucreaza greu ( gripat), injectoare care scapa pe retur.
http://wiki.ross-tech.com/wiki/index.php/16471/P0087/000135
Modificat de andrei_221
Eu am avut eroarea asta la un vw transporter din 2012,motor 2.0 cr tdi CCFC care nu mai pornea deloc.a scapat cu "output test" pe pompa de motorina din rezervoe,a balbotat putin si a pornit la prima cheie apoi.am vb cu proprietarul si zicea ca a mai bagat si "alta" motorina decat cea din peco.la recomandarea mea a demontat rezervorul,si surpriza,sorbul pompei era plin de mazga
ciao,
               Am scos pompa din rezervor si am testato iar, la fel si cu pompa de tandem. dupa ce l-am pus inapoi pe masina am dat din test amorsarea pompelor si masina a pornit din prima.
              Scanat iar si alta eroare : P0088 fuel rail/system pressure - too high. Am sters eroarea si totul ok nu au mai reaparut nici una.
              Mers 20 Km cu masina si se aprinde CHECK ENGINE  :(((  pun testul pe ea . Eroare pe EGR :tuktuk:  Nu mai tin minte exact codul dar era ceva cu scurt circuit la masa, Eroare permanenta care nu o pot sterge. Am mai mers vreo 10 Km asa cu becul aprins dar masina se comporta normal. Am sa vad Luni ce mai pot face.
 Daca aveti ceva sfaturi va sunt recunoscator.
Am urmatoarele erori aparute la Golful meu 6 .
Ma poate ajuta cineva cu o interpretare a lor ?
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 4F 52 55 56 61 62 72 77
VIN: WVWZZZ1KZBM601988
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 087 H    HW: 5K0 937 087 H
   Component: BCM PQ35 H    011 0035
   Revision: BE011001
   Coding: 00180E3F982D02C0C00800844500AF2C036D0088625D856264C087000041
   Shop #: WSC 71242 136 87103
   VCID: 3A712AA8B5A158CE9A7-806F
   Subsystem 1 - Part No: 1Q1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 21051  22  0512
   Coding: 009795
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 160
                    Time Indication: 0
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.70 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 163
                    Mileage: 202509 km
                    Time Indication: 0
                    Date: 2052.14.06
                    Time: 12:40:54
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JEF0006K
   Coding: 108A140000
   Shop #: WSC 00066 000 00184
   ASAM Dataset: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS.rod
   VCID: 72E1C288A551E08E927-8027
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0000034
   Coding: 820000
3 Faults Found:
332564 - Databus
          U1121 00 [008] - Missing Message
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 160
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
332580 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 160
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
332596 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 160
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H25 0602
   Revision:   H25       Serial number: 01071001201936
   Coding: 050B0500
   Shop #: WSC 48062 000 1048576
   VCID: EFE74BFC3E634D66FD9-80BA
   Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H01 0220
   Subsystem 2 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H01 0220
02071 - Local Databus
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 6
                    Reset counter: 151
                    Mileage: 200609 km
                    Time Indication: 0
                    Date: 2050.14.29
                    Time: 18:58:48
Salut.Se poate putin ajutor?
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 B    HW: 028 101 147 8
   Component: R4 1,9L EDC G000SG  5645
   Revision: 12345678    Serial number: VWZ7Z0C8741776
   Coding: 0000071
   Shop #: WSC 00000 028 00001
   VCID: 22419B2C860F
19558 - Motor for Intake Manifold Flap (V157): No Signal
            P3102 - 000 -  -
             Freeze Frame:
                    RPM: 966 /min
                    Torque: 34.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 00001000
                    Torque: 148.0 Nm
                    Torque: 0.0 Nm
Am pus clapeta acceleratie noua,sigurante nu am gasit arse!Unde sa mai caut?
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K1 909 144 E
   Component: EPS_ZFLS Kl.0       1202
   Shop #: WSC 00000 000 00000
   VCID: 2D5B7810CFD1
00778 - Steering Angle Sensor (G85)
            000 -  -  - MIL ON
             Freeze Frame:
                    Mileage: 2480 km
                    Count: 1
                    Steering Angle: 0.00°
Am luat masina cu aceasta problema,a disparut dupa ce am condus putin,am deconectat bateria si a aparut din nou.
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio BVX       012 0022
   Coding: 0010400
   VCID: 2F676218C5DD
01042 - Control Module; Not Coded
            000 -  -
Radio functioneaza normal!
Coding: 0000071
VCID: 22419B2C860F
P3102 - 000 - -
Freeze Frame:
RPM: 966 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00001000
Torque: 148.0 Nm
Torque: 0.0 Nm
VCID: 2D5B7810CFD1
000 - - - MIL ON
Freeze Frame:
Mileage: 2480 km
Count: 1
Coding: 0010400
VCID: 2F676218C5DD
000 - -
Siguranta pt clapeta de shut off ar trebui sa fie cea de pe panoul de langa bateria masinii (F8) ,mai e pe ea si comanda electroventilatoarelor,etc.Verifica sa vezi daca nu cumva ai omis.
Incearca un output test pt ea (v157 o sa o gasesti la output test).
Verifica cablajul catre ecu daca tot nu zice nimik.
Si asa de cultura generala motoarele diesel NU AU CLAPETA DE ACCELERATIE.ele se accelereaza din injectie.dovada e ca la tine cu siguranta se accelereaza motorul.aia e o clapeta care obtureaza aerul la oprirea motorului(diesel=compresie mare),pt ca acesta sa se opreasca fara scuturare. Si mai are un rol pt fluxul de gaze Egr.
  Ai dreptate cu clapeta,greseala mea.Am uitat sa specific ca masina e un golf 5 din 2004.Stie cineva unde trebuie sa intru cu VCDS sa verific functionarea ventilatoarelor la radiator?Sau care e siguranta exact?Sunt multe sigurante care lipsesc,masina o am de o luna asa ca nu stiu ce sa lucrat la ea.
sigurantele nu lipsesc, atatea trebuie sa fie...
verifica firele ca sunt intrerupte.
Initial mi-a aparut martorul cu spirala. Acum martorul motor sta aprins si cel spirala sa aprinde daca stau mai mult de 2-3 minute cu motorul la relanti
 Ce este Turbocharger Boost Control Position Sensor Circuit si celelalte erori?
Saturday,07,February,2015,22:18:49:62939
VCDS Version: Release 12.12.0 (x64)
VIN: WVGZZZ5NZAW068851   License Plate:
Chassis Type: 5N (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 61 62 69 72
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CD    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H20 6102
   Revision: 41H20---    Serial number: 00000000000000
   Coding: 00190012042401080000
   Shop #: WSC 01324 020 00200
   ASAM Dataset: EV_ECM20TDI01103L906018CD 003008
   ROD: EV_ECM20TDI01103L906018CD.rod
   VCID: 6ED32833B162DE6E76F-803B
7934 - Turbocharger Boost Control Position Sensor Circuit
          P2563 00 [236] - Implausible Signal
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 11
                    Mileage: 189790 km
                    Date: 2057.14.16
                    Time: 17:01:42
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: None
   Part No SW: 5N0 614 109 L    HW: 5N0 614 109 L
   Component: J104    C4 450 V10B 0003
   Revision: --H28---    Serial number: 00000002461966
   Coding: 0067905
   VCID: 3467FA5B57CEB4BE40B-8061
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000003
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 7EF31873E102AEEEE6F-802B
   Part No SW: 5K0 937 086 C    HW: 5K0 937 086 C
   Component: BCM PQ35 M    011 0028
   Revision: BC011001
   Coding: 40180A3B98251AC0400800803400012443513088436D85605C8087000001
   VCID: 3467FA5B97CEB4BE40B-8061
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 15120  012 0203
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 040110 05  54  0402
   Coding: 03304D
2 Faults Found:
00447 - Function Limitation due to Over-Voltage
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 6
                    Fault Frequency: 22
                    Reset counter: 49
                    Mileage: 183198 km
                    Time Indication: 0
                    Date: 2055.14.15
                    Time: 10:52:37
             Freeze Frame:
                        Term 15 Off
                    Voltage: 13.50 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00883 - Ignition Switch (D) Terminal S
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 4
                    Fault Frequency: 148
                    Reset counter: 6
                    Mileage: 179259 km
                    Time Indication: 0
                    Date: 2054.14.06
                    Time: 10:23:42
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.15 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PRNGRAI
   Coding: 0012336
   VCID: 4487AA9B076E043EF0B-8011
   Subsystem 1 - Serial number: 6332MTS602853379
   Subsystem 2 - Serial number: 6342MTS668243379
   Subsystem 3 - Serial number: 6351HTS67VJ539KJ
   Subsystem 4 - Serial number: 6361HTS65B3F76KR
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CN    HW: 1K0 953 549 CN
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 800FE68BD3F6581E143-80D5
5 Faults Found:
00576 - Terminal 15
            012 - Electrical Fault in Circuit
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5N0 920 871 C    HW: 5N0 920 871 C
   Component: KOMBI         H05 0305
   Coding: 110F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3169F34F60DC81962BD-8064
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
   Component: J533  Gateway   H20 0592
   Revision:   H20       Serial number: 141209F2000365
   Coding: F9807F46400202046002
   Shop #: WSC 01104 202 82029
   VCID: 6BD521274A702B46511-803E
00532 - Supply Voltage B+
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 43
                    Mileage: 183047 km
                    Time Indication: 0
                    Date: 2055.14.13
                    Time: 10:19:22
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0305
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA4230D8AB24EAA7-80BF
Address 37: Navigation (J794)       Labels: 3C0-035-270.clb
   Part No SW: 3C0 035 270     HW: 3C0 035 270
   Component: RNS310        H14 0227
   Revision: 10000000    Serial number: VWZ1Z2I8945423
   Coding: 000004010400000000000000
   ASAM Dataset: VW_RNS310 A02007
   ROD: EV_VWRNS310UDS.rod
   VCID: D7BDEDD7AEF83FA6059-8082
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
   Component: Tuer-SG         009 2101
   Coding: 0135358
   VCID: 377DCD5746B85FA6659-8062
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.162 0703
   Revision: 1AH03273    Serial number: 00092760014602
   Coding: 0000258
   VCID: 3A7BD46375AA42CE9A7-806F
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
   Coding: 0135614
   VCID: 387FCE6B4BA650DE6C3-806D
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 B    HW: 3AA 907 801 B
   Component: J540 EPB4  VW-49878 0004
   Revision:   H17       Serial number: 00000000002173
   Coding: 0023067
   VCID: 306FF64BA3D6889E243-8065
00457 - Control Module for Network (J519)
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 185080 km
                    Time Indication: 0
                    Date: 2056.14.01
                    Time: 10:38:55
             Freeze Frame:
                    Voltage: 9.60 V
                    Count: 141
                    Speed: 0.0 km/h
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 1K0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H20 0592
   Coding: 030B085A
   VCID: E8DFDE2B1B86805EBC3-80BD
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
Address 62: Door, Rear Left
Cannot be reached
Address 69: Trailer        Labels: RETROFIT69.lbl
   Part No SW: 5F0 05V 010 1    HW: 5F0 05V 010 1
   Component: TOWBA
   VCID: 285F1E2B9B06C05EFC3-807D
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
   Component: Tuer-SG         007 2102
   Coding: 0131216
   Shop #: WSC 01324 020 1012552
   VCID: 3979CB6F70AC49D693D-806C
trebuie sa schimbi actuatorul vacuumatic de la turbina si partea electrica de la contact.
03L198716B
1K0905849B
Multumesc mult! Ai ideie cam cat m-ar costa treaba asta in romania? Si poate dauna motorului daca merg asa? Precizez ca inafara de martorul aprins in bord nu simt nimic alceva in mersul masinii.
Modificat de radurdu
actuatorul costa undeva la 900 lei , switch-ul de la contact este cam 200 lei. manopera depinde de service... intre 200 si 400 lei
Dar atentie ca la actuatorul de la turbo trebuie facut reglaj... deci de preferat ar fi sa il faca cineva care are experienta.
Mersi mult!  Crezi ca pot sa merg cu ea asa 2000 km,dauneaza cu ceva sau e mai bine sa o rezolv pe aici prin Belgia?
poti sa mergi, in cel mai rau caz o sa ramai fara turbo, dar vei putea ajunge la destinatie mai incetisor.
  • Aerofan pinned this topic
