zorg
nu are treaba, verifica intai ce ti-am zis si vedem dupa aia.
NU are treaba cu ce ai zis tu pana acum legat de ralanti, singura explicatie este ca in centrala electrica ai bifata optiunea de xenon cu shutter (bixenon), posibil sa le fi activat cand ai montat csenoanele.
Oraş:Bucureşti
Maşina:Volkswagen
Model:Passat
Motorizarea:2.0 tdi 143cp
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72 77
VIN: WVWZZZ3CZAE113054
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 EN HW: 03L 907 309 A
Component: R4 2,0L EDC G000SG 7373
Revision: 21H22--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 61891 133 81716
VCID: 75EBF9941C3FF7B6B75-8020
008863 - NOx Sensor 2 Bank 1
P229F - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 194170 km
Time Indication: 0
Date: 2053.14.00
Time: 13:16:52
Freeze Frame:
RPM: 1495 /min
Speed: 40.0 km/h
Voltage: 13.83 V
Lambda: 99.4 %
(no units): 255.0
188 ppm
(no units): 0.00
Readiness: 0 1 0 0 0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000104059191
Coding: 0002323
Shop #: WSC 05311 000 00000
VCID: 62C1B2C8BDB1700EE27-8037
01314 - Engine Control Module
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 78
Mileage: 193956 km
Time Indication: 0
Date: 2052.14.24
Time: 12:15:28
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011111
Count: 154
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 CC HW: 5K0 907 044 CC
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 6ED9D6F8B169C46E76F-803B
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 78
Mileage: 193956 km
Date: 2052.14.24
Time: 12:15:31
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 F HW: 3C8 937 049 F
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000003687748
Coding: E9888F0700041A00470A00000F000000000D5D435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 346D049057C5AEBE40B-8061
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 120210 006 0208
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 170210 054 0403
Coding: 00208936
Shop #: WSC 05124
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 78
Mileage: 193956 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08741004602214
Coding: 100002
Shop #: WSC 05314 000 00000
VCID: 326102886DD1A08E527-8067
No fault code found.
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__00H VW10 HI 1916
Revision: 20013000 Serial number: 003E2P2ZSTEN
Coding: 0012360
VCID: 448D545007651E3EF0B-8011
Subsystem 1 - Serial number: 6332MTS610450270
Subsystem 2 - Serial number: 6342MTS606910270
Subsystem 3 - Serial number: 6351HTS62GR986KJ
Subsystem 4 - Serial number: 6361HTS63DL986KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BP HW: 5K0 953 569 AA
Component: LENKS.MODUL 009 0122
Revision: FF010035 Serial number: 20100206200511
Coding: 5180270002
ASAM Dataset: EV_VW360SteerWheelUDS A03002
ROD: EV_VW360SteerWheelUDS.rod
VCID: 78F5F0A0C32D8ADEAC3-802D
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P10219083C
Coding: F9A07F06000602002002
VCID: 2F670BFCBEE38D663D9-807A
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 78
Mileage: 193956 km
Time Indication: 0
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0305
Revision: 13101005 Serial number: 0000466375
Coding: 0000B5
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: E5CB29D4E49F8736875-80B0
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001289717
Coding: 000090
66562 - Heated Exterior Mirror
B11F8 14 [008] - Open or Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 82
Mileage: 191740 km
Date: 2051.14.02
Time: 15:02:06
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.148 0703
Revision: 1AH03726 Serial number: 00093390155802
Coding: 0000258
VCID: 3A712AA875A158CE9A7-806F
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 78
Mileage: 193956 km
Time Indication: 0
Date: 2052.14.24
Time: 12:15:30
Freeze Frame:
Term 15 On
RPM: 1500 /min
Speed: 0.0 km/h
(no units): 7.0
Voltage: 12.10 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: KSG PQ46 ELV 043 0612
Revision: 00043000 Serial number: VWZCZ000000000
Coding: 0091020051030E763004941570084F0E707C01
VCID: 7AF1EAA8352198CEDA7-802F
Subsystem 1 - Part No: 1K8 951 605
Component: LIN BACKUP HORN H09 9002
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 HW: 3C0 959 792
Component: TUER-SG BT 002 0305
Revision: 15101005 Serial number: 0000455445
Coding: 0000B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: E6C92ED819998C2E8EF-80B3
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001296525
Coding: 000090
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000172628
Coding: 0000056
VCID: 2C5D1CF08FF5F67E18B-8079
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 78
Mileage: 193956 km
Time Indication: 0
Date: 2052.14.24
Time: 12:15:28
Freeze Frame:
Voltage: 12.10 V
Count: 73
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 040 0166
Revision: 00000001 Serial number: VWZ1Z3K6358575
Coding: 0500040004
VCID: E5CB29D4EC9F8736875-80B0
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000330057045
Coding: 012120
VCID: 2A511AE84501E84EEA7-807F
End ---------------------------------------------------------------------
daca puteti va rog sa mi explicati ce inseamna fiecare eroare in parte.
Ș
Pe ecu ai un senzor Nox dus, se schimba.
Pe celelalte ai eroare de comunicatie cu ECU, sterge si vezi daca mai apar.
LA usa de la sofer ai o problema cu incalzirea oglinzii, posibil oglinda cu probleme.
La oglinda am verificat acum si nu se incalzeste, presupun ca trebuie schimbată oglinda cu tot cu sistemul de încălzire, despre senzorul nox imi puteți da niște detalii mai amănuntite, unde se afla si am cat ar costa, mulțumesc pentru răspunsuri .
Rog o interpretare a logului de mai jos ,cu multumirile de rigoare.
Va multumesc
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
2E-Media Player 3 -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H24 7852
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 00190012041401080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003005
   ROD: EV_ECM20TDI01103L906018BE.rod
   VCID: 6FE7CBFCB663CD667D9-803A
4710 - No Communications with Airbag Control Module
          U0151 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Mileage: 208280 km
                    Date: 2043.14.02
                    Time: 09:32:37
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
   Component: J104   C2 450M V485 0005
   Revision: --H07---    Serial number: 00000003675072
   Coding: 0002480
   VCID: 3777339C46B345A6659-8062
01321 - Control Module for Airbags (J234)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 208280 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:32:37
             Freeze Frame:
                    Speed: 52.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 254
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000003
   ASAM Dataset: EV_Climatronic A01010
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 000000000000000000180080540081E443510088426D85606480C7200041
   VCID: 387530A08BAD4ADE6C3-806D
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 21121  10  0603
   Coding: 00B795
   Component: RLS 120111 05  54  0403
   Coding: 033028
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 171
                    Mileage: 208280 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:32:40
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.35 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631101504876
   Coding: 118002
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW4280000.rod
   VCID: FCFD6CB0771526FE48B-80A9
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P0FKEV%
   Coding: 0012337
   VCID: 4C9D7C702F35D67E38B-8019
   Subsystem 1 - Serial number: 6332MTS664223480
   Subsystem 2 - Serial number: 6342MTS627303500
   Subsystem 3 - Serial number: 6351HTS6L5KOL9KR
   Subsystem 4 - Serial number: 6361HTS64T51M9KJ
00003 - Control Module
            014 - Defective - MIL ON
             Freeze Frame:
                    Fault Status: 11101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 208279 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:32:26
   Part No SW: 3C9 953 501 BF    HW: 5K0 953 569 S
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20110113100658
   Coding: 118A050000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 870 A    HW: 3AA 920 870 A
   Component: KOMBI         H20 0420
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 306508806BDD929E243-8065
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 171
                    Mileage: 208280 km
                    Date: 2043.14.02
                    Time: 09:32:37
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 040111F2002435
   Coding: 462006
   VCID: 346D049097C5AEBE40B-8061
2 Faults Found:
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 171
                    Mileage: 208280 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:32:38
03927 - Function Restriction due to Driver Fatigue Recognition
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 208281 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:33:57
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Shop #: WSC 131071 1023 2097151
   VCID: F6E97E9881397CAE3EF-80A3
   Subsystem 1 - Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669241814
   Coding: 010000
   VCID: 2855E0E05B0DDA5EFC3-807D
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0002086115
   Coding: 0200B7
   Shop #: WSC 05311 115 08193
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356B399494BFB7B6775-8060
   Slave Driver:
   Component: J388__TSG-HL  004 0407
   Serial number: 00000001883108
   Coding: 000090
68107 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 171
                    Mileage: 208280 km
                    Date: 2043.14.02
                    Time: 09:32:39
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.309 0802
   Revision: 1AH03729    Serial number: 00110040215901
   Coding: 0000258
   VCID: 3B7F2FAC7A9B61C6811-806E
   Component:    KSG PQ47 ELV 043 0631
   Coding: 0091020052830E76300494157C084F0B607C01
   Shop #: WSC 05311 000 08193
   Subsystem 1 - Component:   Sounder n.mounted
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 171
                    Mileage: 208280 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:32:39
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: EFE74BFC3E634D66FD9-80BA
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0002091939
   Coding: 0200B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 36693E9889B9BCAE7EF-8063
   Slave Passenger:
   Component: J389__TSG-HR  004 0407
   Serial number: 00000001865115
   Coding: 000090
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 171
                    Mileage: 208280 km
                    Date: 2043.14.02
                    Time: 09:32:39
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000126224
   Coding: 0022067
   VCID: 336F078C52CBA986591-8066
3 Faults Found:
03200 - Switch for Electric Parking Brake (E538)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 132
                    Mileage: 207825 km
                    Time Indication: 0
                    Date: 2042.14.29
                    Time: 15:05:32
             Freeze Frame:
                    Voltage: 13.30 V
                    Count: 10
                    Speed: 0.0 km/h
                    Hex Value: 0x1263
                    Hex Value: 0x0021
                    Hex Value: 0x1010
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 171
                    Mileage: 208280 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:32:37
             Freeze Frame:
                    Voltage: 14.20 V
                    Count: 74
                    Speed: 52.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 171
                    Mileage: 208280 km
                    Time Indication: 0
                    Date: 2043.14.02
                    Time: 09:32:37
             Freeze Frame:
                    Voltage: 14.20 V
                    Count: 161
                    Speed: 52.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: F1E34D8428575B96EBD-80A4
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000141216977
   Coding: 4106040000000000
   VCID: F3EF478C524B6986191-80A6
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 D    HW: 7P6 035 730 D
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007669095980
   Coding: 0A00000000000001
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 336F078C9ACBA986591-8066
Senzor Nox nou este vreo 2500 lei.
@DMG
Ai modulul de airbag cu probleme, trebuie schimbat si mai ai de schimbat butonul de la frana de mana.
Modificat de Al Bundy
Multumesc, Florin si Al Bundy da era bifata eroarea cu bixenon am debifato am sters eroarea si acum nu imi mai apar cele doua erori.....in legatura cu problema legata de relatiu ma puteti ajuta cu un sfat o sugestie Multumesc anticipat!
@DMG
Multumesc mult de raspuns.
Daca se sterge eroarea va aparea din nou???  Costurile acestui modul si daca exista vreun risc sa merg asa o perioada.
Mii de multumiri
O seara fain!
Mulțumesc de informații , cred ca voi caută totusi un senzor nox sh,imi puteți spune codul piesei sau unde il pot găsi, si daca nu mi a apărut nimic in bord, nicio avertizare sau vreun martor, as putea sa mai merg asa pana găsesc senzor sh? Eroarea am descoperit-o când am facut un test întâmplator cu vagcomul
Fault Frequency: 1
Reset counter: 255
Mileage: 194170 km
Ce kilometraj ai acum? Vad ca a aparut doar o data (frequency 1). Sterge eroarea si vezi daca reapare. Nu m-as ingrijora la o singura aparitie.
Erorile de tipul "No Signal/Communication" le-am vazut si eu dupa ce a murit bateria si s-a cerut schimbata.
@mihneasim- acum am in jur de 194.500, dupa cate vad din diagnoza eroarea a aparut la RPM: 1495 /min Speed: 40.0 km/h, bateria este cea originala (masina a fost fabricata in 04/10/2009 (z/l/a) si prima inmatriculare in 24/04/2010 )deci e posibil sa ceara schimbata insa nu imi face figuri. multumesc
@andrei_221- dupa cate vad pe google, pare ca senzorul acesta e fabricat de siemens(banuiesc ca sunt mai multi producatori, inca nu am cautat mai precis) deci ma astept sa fie destul de proaste dupa experienta cu injectoarele de pe bkp; deci eu trebuie sa caut piesa cu codul 03L907807D sau cel actual ? multumesc
@al bundy- multumesc pentru clarificari
Cel actual, ca la asta sunt samse mici de a se defecta.
@al bundy - ok multumesc, am uitat sa precizez ca motorul este varianta de 105kw 143cp(adica varianta adblue) banuiesc ca nu are nicio importanta.
singura importanta pe care o are motorul CBAC, este ca are Adblue si din cauza asta are si acel senzor NOx.
Daca luai si tu CBAB, ca restul de 99% din romani, nu ai fi avut problema cu acest senzor, pentru ca nu ar fi existat pe masina.   :P
Modificat de andrei_221
am facut azi o scanare cu vag-ul pe passat si am urmatoarea eroare
Control Module Part Number: 3C0 907 530 Q    HW: 3C0 907 951
  Component and/or Version: J533  Gateway   H13 0172
           Software Coding: F9807F16000002001002
            Work Shop Code: WSC 12345 123 12345
                      VCID: 2F66A4D6BECA5A6626F
1 Fault Found
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame
                    Fault Priority: 1
                    Fault Frequency: 9
                    Reset counter: 150
                    Mileage: 174532 km
                    Time Indication: 0
@ andrei- acum stii cum e,daca nu era problema cu senzorul, era alta, la orice masina, indiferent de motorizare/marca/model apar probleme,ca doar sunt masini,fugi de una, dai de alta, la mine deocamdata a aparut doar o prima eroare, si asta la 194.000km, ceea ce cred ca e rezonabil, si nu stiu inca daca e dus senzorul, deoarece dupa cum am precizat mai sus, in calculatorul din bord nu mi-a aparut niciun martor .
geo - nu ai codat cu trebuie, can gateway-ul.... ceva nu corespunde, cu echipamentele de pe masina.
1 Fault Found
            000 - -
             Freeze Frame
                    Fault Priority: 1
                    Fault Frequency: 9
                    Reset counter: 150
                    Mileage: 174532 km
                    Time Indication: 0
Posteaza intreg autoscanul sa ne dam seama unde e greseala.
incearca sa postezi tot autoscan-ul si o sa vezi ca ai ceva in plus sau in minus fata de ce este echipata masina sau uitete in lista din can si vezi ce ai in plus sau in minus fata de ce module ai pe  masina....astaseintampla cand bifezi sau bineinteles debifezi unlele lucruri si dupa aceea te intrebi de ce imi apare eroarea asta...
Salutare, ce inseamna eroarea asta? Masina este un Seat leon 1P 2010 1,2 tsi 105cp.
 Address 01: Engine       Labels: 03F-906-070-CBZ.clb
Control Module Part Number: 03F 906 070 CE    HW: 03F 906 070 CE
  Component and/or Version: SIMOS10.10H03 9838
           Software Coding: 001900D6230400080000
            Work Shop Code: WSC 99999 1023 2097151
              ASAM Dataset: EV_ECM12TFS02103F 003004 (SE35)
                      VCID: 67D7A5459E76F51
No ASAM data for: "EV_ECM12TFS02103F" (SE35)
6322 - ROD - Unknown Error Code
          - B2 [040]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 8
                    Mileage: 35125 km
                    Date: 2046.14.18
                    Time: 10:54:02
Readiness: 0000 0100
demontata clapeta de acceleratie si curatita
@andrei_221
nu stiu de unde iti poti da seama tu andrei ca este vb de clapeta de acceleratie dar eroarea in sine ii zice ca nu exista date in protocolul asam ptr softul masini respective...adica cu alte cuvinte softul lui este mai vechi decat softul masini si bineinteles  interfata este o chinezerie de doi bani...asa ca eu nu stiu cum ai dedus tu ca este o eroare de clapeta....intrebarea vine din curiozitate.
Modificat de gctinvalentin
trebuie sa testez masina cu un Vcds mai nou? eu am 11.11.3... merci
Modificat de AlexandruC
  • Aerofan pinned this topic
    • Bachus20
