zorg
F l o r i n
exista si varianta asta, dar mai rar.....
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J5 920 806 B
   Component: KOMBI+WEGFAHRSP VDO V11
   Coding: 01113
   Shop #: WSC 00000
   VCID: 2B5EB0C6D9D22640A47
   WVWZZZ1JZ2W468909     VWZ7Z0A4541356
1 Fault Found
01330 - Can't Decode, CODE File Not Loaded!
            49-10 - Can't Decode, CODE File Not Loaded! - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01391
   VCID: F0E4E7AAB0748598515
1 Fault Found
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799
   Component: 1F Komfortgerát HLO 0001
   Coding: 00259
   Shop #: WSC 01391
   VCID: F4ECEBBAC46CB9B8B5D
   Subsystem 1 - Part No: 1C1959801A
   Component: 1F Tőrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1C1959802A
   Component: 1F Tőrsteuer.BF KLO 0004
   Subsystem 3 - Part No: 1C0959811A
   Component: 1F Tőrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812A
   Component: 1F Tőrsteuer.HR KLO 0004
1 Fault Found
00929 - Can't Decode, CODE File Not Loaded!
            27-10 - Can't Decode, CODE File Not Loaded! - Intermittent
puteti sa-mi spuneti va rog si mie ce probleme sunt......multumesc anticipat
Nu e buna interfata sau nu ai instalat-o corect.
MAcar foloseste si tu o interfata activata.
mersi am sa incerc alceva apoi revin...cred ca doar saptamana viitoare
nici macar nu e greu de cautat pe Google... chiar si cu atat de putine informatii...  dar e grele...
01330 - Central Control Module for Central Convenience (J393)
49-00 - No Communications
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
http://lmgtfy.com/?q=vcds+01330
Modificat de andrei_221
 imi poti spune si mie unde trebui sa intru cu vag com sa fac un output test la n239 ?
19560/P3104/012548 - Valve for Intake Manifold Flap (N239)
Possible Symptoms
* Engines shakes at shutdown
Possible Causes
* Wiring Short to Plus
* Valve for Intake Manifold Flap (N239) faulty
Possible Solutions
* Check Wiring for Short to Plus
* Check Valve for Intake Manifold Flap (N239) > Output Test
se refera la sistemul de actionare a clapetei (valva N239, tubulatura de vacuum sau chiar clapeta cut off situata in corpul EGR) care limiteaza admisia aerului in admisie. Simptomele sunt oprirea cu trepidatii a motorului sau chiar uneori pornirea grea. Se poate efectua si un test cu Vagcomul pentru a vedea cum actioneaza aceasta clapeta.
Modificat de Corsar
intrii la 01 Engine  > Output test e a 3a sau a 4a activare din secventa
Nici nu e nevoie de VCDS. Pui pe cineva sa opreasca masina in timp ce te uiti la clapeta de shut-off si vezi  daca se misca pe inchis, revenind pe deschis dupa cateva secunde.
F l o r i n
da - asa ce cel mai simplu.
la B5 clapeta este actionata de o capsula vacumatica - daca nu inchide clapeta, verifica daca aceasta nu este spart.... de cele mai multe ori, este sparta - scoate-i furtunasul, baga altul si trage - daca nu actioneaza, atunci e sparta.
daca e buna, verifica furtunasul pana in n239.,.... si daca vine vacuum.
pornirea greoaie nu e de la clapeta de shut off
REspectivului ii da eroare pe electrovalva care comanda capsula, deci ori e dusa electrovalva ori are firele pana la ea roase.
CE treaba are eroarea lui cu vacuumul ?
SAlut , ma puteti ajuta cu o posibila solutie pentru :
Address 01: Engine        Labels: 06A-906-032-AUM.lbl
   Part No: 06A 906 032 HJ
   Component: 1.8L R4/5VT     G   0002
   Coding: 11500
   Shop #: WSC 02629
   VCID: 6DD12F3F276425764F5-5072
   WVWZZZ1JZ2W630204     VWZ7Z0B5014983
16955 - Brake Switch (F)
            P0571 - 35-10 - Implausible Signal - Intermittent
Readiness: 0000 0000
aici banuiesc ca este vorba de switchul de la pedala de frana ( daca e asa sunt norocos pt ca am deja unul nou )
mai greu este cu urmatoarele simptome  nu merg geamurile si trapa cu tot cu switchul de lumini din trapa , nu merge inchiderea usilor din telecomanda pentru care am erorile :
   Part No: 1J5 920 826 A
   Component: KOMBI+WEGFAHRSP VDO V05
   Coding: 05112
   Shop #: WSC 00000
   VCID: 2C57E23BDCFEEC7E18B-5000
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EFB64BB056489EE43-5000
aici nu stiu ce sa verific
Nu gasesc nicaieri un raspuns la urmatoarea eroare : 9478421 - Diagnostic line for front air blower B10A1 15 (009) - open or short to plus - Confirmed Tested Since Memory Clear , e O2 facelift, 1.6 D din 2011 si nu mai functioneaza aeroterma. Are releu sau siguranta ? daca da unde e, daca nu ce pot sa verific inainte sa ma apuc sa o desfac. orice sfat e binevenit
@ Al Bundy - l-am pus pe direct si functioneaza, am verificat si nu ii vine curent, sigurantele sunt ok, are vreun releu pe undeva ? unde e sau ce sa ii mai verific. mersi
Salutare! Am făcut și eu azi o scanare de rutina și am găsit doua erori. Ma puteți ajuta?
Saturday,31,May,2014,14:10:18:57991
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
Dealer/Shop Name: Florirolf SRL, GIURGIU
VIN: WVWZZZ1JZ5W060643 License Plate: GR12RED
Mileage: 175090km-108795mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ5W060643 Mileage: 175090km/108795miles
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 01266 785 00200
VCID: 346CAF8B54D9E8BE4FF-5120
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 16 AIRBAG VW61 0108 0003
Coding: 12598
Shop #: WSC 01266
VCID: 275648C7C50F9326FAD-5102
Part No: 1J0 920 846 C
Component: KOMBI+WEGFAHRSP VDO V23
Coding: 17112
Shop #: WSC 02241
VCID: 2B5EB4F7D9E7B7461E5-5102
WVWZZZ1JZ5W060643 VWZ7Z0D1182881
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Coding: 00006
Shop #: WSC 01266
VCID: F0E4E39BB041149EEB7-5102
01336 - Data Bus for Comfortx System
Address 37: Navigation Labels: 3B0-919-887.lbl
Part No: 1J0 919 887 A
Component: Navigation BNO 0206
Coding: 00000
Shop #: WSC 01266
VCID: 3668958312A5FAAE71B-4ACE
Part No: 1C0 959 799 B
Component: 1A Komfortger醫 HLO 0004
Coding: 00259
Shop #: WSC 01266
VCID: 3668958312A5FAAE71B-4AE6
Component: 1A T鮮steuer.FS KLO 0202
Component: 1A T鮮steuer.BF KLO 0202
Component: 1A T鮮steuer.HL KLO 0202
Component: 1A T鮮steuer.HR KLO 0202
00935 - Electric Window Motor; Rear Right (V27)
35-10 - - - Intermittent
Address 56: Radio Labels: 3B0-035-186.lbl
Part No: 1J0 035 152 G
Component: Radio BNO 0206
Coding: 00205
Shop #: WSC 01266
VCID: 224059D3AE2D760EAD3-4ACE
End ---------------------------------------------------------------------
Buna ziua . După o perioada lunga am iesit cu masina la un drum mai lung si dupa aproximativ 200 km parcursi masina a inceput sa nu mai traga, cand acceleram trepida foarte urat de parca ziceai ca loveste cineva cu barosul in motor. Am oprit sa vad ceva semne de vreo defectiune vizibile ochiometric gen furtune sarite sau sparte si nu am observat nimic suspect. In timpul  ce rulam nu s-a aprins niciun bec la bord.  Am plecat si nu a mai avut nimic masina  accelerand pana la 130 cat sa nu ma ia vreun radar pe distante scurte si nu am ami avut nicio problema . La scanare la motoer au aparut urmatoarele erori.
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 HK    HW: 028 101 225 1
   Component: R4 2,0L EDC G000AG  7000
   Revision: 12345678    Serial number: VWZ7Z0D1243978
   Coding: 0000078
   Shop #: WSC 01324 785 00200
   VCID: 73E539471240F386991-8026
2 Faults Found:
16618 - Boost Pressure Regulation
            P0234 - 000 - Limit Exceeded (Overboost Condition)
             Freeze Frame:
                    RPM: 3234 /min
                    Torque: 326.0 Nm
                    Speed: 102.0 km/h
                    Load: 100.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 00001000
                    Absolute Pres.: 2233.8 mbar
                    Absolute Pres.: 2590.8 mbar
17674 - PD Unit Injector: Cylinder 3 (N242)
            P1266 - 000 - Implausible Signal
             Freeze Frame:
                    RPM: 2394 /min
                    Torque: 82.0 Nm
                    Speed: 117.0 km/h
                    Load: 29.8 %
                    Voltage: 14.21 V
                    Inj. Quantity: -0.52 mg/str
                    Temperature: 86.4°C
                    (no units): 16.0
Pe centrala electrica au aparut erorile de mai jos. Am verifivat cablajul din stalp pana in usa la continuitate si nu sunt problemedar totusi usa de pe partea dreapta nu se deschide intotdeauna din telecomanda ramane blocata si trebuie sa actionez clapeta din interior de 2 ori ca sa se deblocheze usa. proiectorul e spart deci nu il luam in seama trebuie schimbat dar nu gasesc SH modelul meu stiti pe undeva ? masina e touran 2005 si e fara lupa . Nu in
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001382762
   Coding: 038B8F020004100000120C000000000000087F075C
   Shop #: WSC 00000 000 00000
   VCID: 3A7BD46375AA42CE9A7-806F
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00065493
   Shop #: WSC 00000
3 Faults Found:
00526 - Brake Light Switch-F
            008 - Implausible Signal - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01500 - Bulb for Fog-Lamps; Right (L23)
            010 - Open or Short to Plus
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Component: Tuersteuergeraet 09 0157
   Coding: 0000116
   VCID: F5E1875F9C346DB6375-80A0
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
            012 - Electrical Fault in Circuit
Puteti sa ma ajutati cu o interpretare a problemelor si ce anume trebuie schimbat? Multumesc!
Verifica turbina , actuatorul si vacuumul.
Intareste contactele de la mufele de la injectoare.
Ai o problema cu broasca de la pasager, in general se schimba.
petro.ionut
Salut, ma puteti ajuta cu un sfat privind cele 2 erori de mai jos:
Prima:
Address 44: Steering Assist Labels: 5N1-909-144.clb
Control Module Part Number: 5N1 909 144 J HW: 5N1 909 148 F
Component and/or Version: J500__APA-BS KL.081 0502
Software Coding: 0000258
Work Shop Code: WSC 00028 028 00001
VCID: 3973333D7042B31
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 29
Mileage: 112920 km
Time Indication: 0
Date: 2123.14.04
Time: 12:41:22
Freeze Frame:
Voltage: 2.90 V
Voltage: 7.10 V
Voltage: 7.10 V
Not Occup.
Not Occup.
Iar cea de-a doua se manifesta destul de rar:
Address 53: Parking Brake Labels: 5N0-907-801.clb
Control Module Part Number: 3C8 907 801 A HW: 3C8 907 801 B
Component and/or Version: J540 EPB3 VW-10498 0003
Software Coding: 0000056
VCID: 2855E6799BE83A9
2 Faults Found:
03200 - Switch for Electric Parking Brake (E538)
Freeze Frame:
Fault Status: 00111100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 32
Mileage: 113007 km
Time Indication: 0
Date: 2123.14.09
Time: 20:05:00
Freeze Frame:
Voltage: 12.40 V
Count: 10
Speed: 0.0 km/h
Hex Value: 0x12F1
Hex Value: 0x0001
Hex Value: 0x1010
16352 - Control Module - Electrical Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 6
Reset counter: 32
Mileage: 112908 km
Time Indication: 0
Date: 2123.14.04
Time: 11:26:10
Freeze Frame:
Voltage: 11.60 V
Count: 42
Speed: 0.0 km/h
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Mentionez ca masina merge fara probleme vis-a-vis de prima problema!
Modificat de petro.ionut
1: ai ramas fara baterie?
2: cred ca o sa ajungi sa schimbi calc franei de mana, dar intai schimba butonul.
Fara baterie nu, sterg eroarea, dau scanare, nu mai apare, dar daca merg si fac din nou scanare, reapare!
Am mai cautat un pic pe net si am gasit pentru  : 01330 - Central Control Module for Central Convenience (J393)   49-00 - No Communications
de verificat siguranta 14 si releu 109. spre norocul meu cred ca s-a rezolvat cu siguranta 14
dar acum am urmatoarele :
3 Faults Found:
01038 - Central Locking Thermal Protection
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
00930 - Locking Module for Central Locking; Rear Left (F222)
ma puteti ajuta ?
Ai 2 broaste de reparat, cea de la sofer si cea de pe stanga spate.
Salutare! Recent mi-am achizitionat un Golf Plus 1.6 FSI cod BLF 2005 din Germania. Precizez ca sunt "praf" in mecanica/motoare. As vrea daca se poate sa ma lamuriti cu unele aspecte:
1. simt ca masina e foarte "lenesa"..inainte de asta am condus Golf 4 1.9 TDI si era racheta pe langa aceasta..chiar si daca merg turat, tot nu simt ca as avea putere nici macar la plecarea de pe loc (care se zice ca la benzina ar trebui sa fie mai puternica decat la diesel..si totusi 116cp>101cp de la 1.9 tdi..repet, macar pe primii 50-100m)
2.dupa ce am alimentat din tara la vreo cateva zile mi s-a aprins check-ul..pe calculator imi dadea eroare de EGR, stergeam eroarea la vreo 2-3 zile se aprindea iar, lucrul asta de vreo 5 ori..am reusit sa conving un mecanic sa-mi curete partea mecanica..becul nu s-a stins de la sine, l-a stins din diagnoza..au trecut cateva zile si nu s-a mai aprins, dar acum parca trage mai din greu decat inainte)
De asemenea, cand am venit mi-a consumat 5.6 pana acasa, acum am facut un drum de 300 km si mi-a luat undeva la 7.5 dus-intors (la dus am mers pana in 120-130, la intors am mers 120-160) nici o diferenta la consum..precizez ca la 170 km/h se opreste, nu mai urca (aici ma gandesc sa nu fie catalizatorul)
Per total cu drumul de 300km si in rest mers prin oras (nu foarte sportiv) cu un plin de 60 L am mers undeva intre 600-650 km.
3. mai da si eroare de presiune de frana (Brake pression ....)
4. acum mi-au mai aparut si niste zgomote ciudate..un clinchet cand accelerez sau iau piciorul de pe acceleratie (accelerare/decelerare) si de asemenea cand e in viteza si scade turatia pe la 1600 rpm scoate un vuiet (ma gandeam ca o fi volant, dar mi-a zis cineva ca nu are treaba??)
5. mi se pare ca intra greu in mansarier.."ultimul cm" sa zic asa cateodata intra greu, trebuie sa revin cu schimbatorul la pozitia initiala si sa incerc iar.
Concluzii: O fi EGR-ul? O fi catalizatorul? Un EGR e 560 RON..catalizatorul nici nu vreau sa ma gandesc cat o fi...
Astept sfaturile voastre. Multumesc anticipat!
Am avut o problema la o skoda cu ''check-ul '' mi-a dat eroare EGR. Cum am rezolvat: Am desfăcut EGR-ul și am curățat foarte bine clapeta de accelerație, după 10 km de mers cu mașina sa stins și nu sa mai aprins deloc.
e diferit EGR-ul asta la 1.6 FSI..asa arata http://www.ingaraj.ro/recirculare-gaz-esapament-rge-supapa-egr-vdo-vw-golf-plus-5m1-521-1-6-fsi/587/5379/18391/10891/1736727/ (imi cer scuze daca nu aveam voie sa postez acest link, nu intentionez sa fac nici un fel de reclama)
am fost la un service unde se curata EGR-uri cu ultrasunete (la indrumarea unui coleg) si dupa ce s-a uitat sub capota, omul a zis ca nu are ce sa-i faca. a zis ca modelul asta de EGR se "curata" cu "unul nou"..
cat despre clapeta de acceleratie stiu ca mi-a curatat-o primul mecanic la care am mers.
multumesc pentru raspuns..mai astept si alte pareri.
eu zic sa astepti pe aria Motoare pe benzina.  Ca aici e vorba de Diesel.
Adevarat..am aj aici cu google..pare rau:/
  • Aerofan pinned this topic
