zorg
Ma ajuta si pe mine cineva cu interpretarea erorilor....
Address 01 -------------------------------------------------------
Controller: 038 906 019 CR
Component: 1,9l R4 EDC 0000SG 1437
Coding: 00002
Shop #: WSC 00046
WVWZZZ1JZ2B039494 VWZ6Z0A3723053
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 35-10 - - - Intermittent
Readiness: N/A
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1C Komfortger
Si eu am aceeasi problema:
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Controller: 038 906 012 M
Component: 1,9l R4 EDC 0000SG 2813
Coding: 00002
Shop #: WSC 01317
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379
Component: ESP 20 CAN V002
Coding: 18945
Shop #: WSC 01317
00812 - Brake Pressure Release Solenoid (F84)
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 802 E
Component: KOMBI+WEGFAHRS. BOO V25
Coding: 01142
Shop #: WSC 00000
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1367106
00534 - Engine Oil Temperature Sensor (G8)
Controller: 1J0 959 799 Q
Component: 2H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
Mersi mult!
1.posibil ca turbina sa aibe geometria gripata...se mai fac niste teste2.posibil sa fac figuri intrepatorul de pe pedala de frana3.senzorul de temperatura ulei care face corp comun cu sonda de nivel ulei4. si oglinda incazita care nu mai merge incazirea....ori e arsa o e pe traseu intrerupt firupt primele 3 as da reset la erori ca sa vezi daca mai apar..la ultima degeaba
Ma ajuta si pe mine cineva cu interpretarea erorilor....VAG-COM Version: Release 311.2-NChassis Type: 1J - VW G/J/B Mk4Scan: 01,02,03,08,15,17,19,22,35,46,56 Multumesc anticipat Paul
1. motorasu de la EGR care inchide motoru....vezi firele sau sa fi fost odata scoasa mufa2. intrerupatorul de la use ....sau traseul electric Modificat de Swat Cat
Trece cineva prin Barlad si poate sa ma ajute si pe mine cu o scanare vag-com?
Am 2 erori la scanarea cu Vag-Com. Mi-a dat un Limp mode pe la 3200 rpm. Turbina a fost curatata (geometria) la 130.000km si acum am 142.000... am mers destul de turat cu masina, nu cred ca trebuie curatata iar... Sa trebuiasca schimbat MAF-ul?
A doua eroare banuiesc ca e vre-un contact sau de la vreo pornire greoaie... Ieri mi-a pornit abia la a doua cheie, dar noaptea au fost spre -20 grade. Sa incerc sa o sterg, sa vad daca mai apare?
Address 01: Engine
Part No: 038 906 019 DF
Component: 1,9l R4 EDC 0000SG 1237
Coding: 00002
Shop #: WSC 01317
Readiness: 0 0 X X X
Address 03: ABS Brakes
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0019458
Shop #: WSC 01317
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Pentru primul defect: actuatorul geometriei variabile a turbinei. Pentru MAF log in merg 3, 10, 11 pe engine.
Pentru 2: s-ar putea sa ai dreptate. Sterge si vezi daca mai apare.
Modificat de al bundy
pentru inceput LA MULTI ANI la toata lumea si un an nou asa cum isi doreste fiecare.
Azi dimineata am avut neplacuta surpriza de a merge cu taxi la servici pt ca nu mi-a pornit masina (GolfIV 1.9 TDI AXR). Bateria invartea motorul dar se pare ca nu destul ca sa porneasca. La prima ora afara au fost -10 grade. Cand am venit de la munca i-am dat curent de la alta masina si a pornit, vorba aia, "la sfert de cheie", asta avand in vedere ca dimineata i-am dat vreo 4-5 chei pana murit bateria.... Dupa asta i-am dat un autoscan cu Vag-com si aveam erorile astea:
Controller: 038 906 019 AT
Component: 1,9l R4 EDC G000SG 1513
Coding: 00002
Shop #: WSC 01391
WVWZZZ1JZ2W628316 VWZ6Z0B0052551
3 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
Readiness: N/A
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 01391
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Component: 1A Komfortger
Probleme aparute azi:
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
Controller: 038 906 019 DF
Component: 1,9l R4 EDC 0000SG 1260
Coding: 00002
Shop #: WSC 01317
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: N/A
Controller: 1C0 907 379 E
Coding: 0019458
Shop #: WSC 01317
2 Faults Found:
01435 - Shareware Version. To Decode all DTCs
008 - Please Register/Activate - Intermittent
Pe prima am inteles-o perfect, iar dupa cateva miscari bruscate a pedalului si-a revenit, am sa-l dau cu niste spray de contacte. A doua nu stiu ce poate fi, martorul in bord nu se aprinde nici la ABS si nici la ESP, iar ABS-ul functioneaza normal.
p.s. 1. La radio imi da "excessive comunication errors", asta de la ce poate fi, or fi ceva fire legate invers la radio?
2. Imi dadea eroare la switch-ul de la portbagaj, desi nu am avut niciodata probleme, adica se aprinde becul in portbagaj cand deschid si apare si pe BC portbagaj deschis/inchis daca acesta e deschis respectiv inchis.
Modificat de TitvsCaivs
Am avut si eu eroarea asta si cred ca e de la o pornire greoaie, la a doua cheie, baterie slabita... Am sters-o cu Vag-Com -ul si nu a mai aparut...
@ c0c0
01359 - Internal Central Locking Switch: Passenger Side (E198)
Verifica daca se mai aprinde becul din usa dreapta fata si plafoniera la deschidere. Cel mai probabil e switch-ul din broasca. Vezi aici http://vwforum.ro/index.php?showto...0&start=280
Modificat de Nick.sb
01435 - poate fi tot de la switch-ul de frana.
Bad post ! :)
Trebuia postat in alt topic ! :)
HELP?
Controller: 036 906 013 D
Component: MED7.5.11 G 4605
Coding: 00031
Shop #: WSC 47899
WVWZZZ1JZ2W581795 VWZ7Z0A4496855
5 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 - -
17912 - Intake Air System: Leak Detected
P1504 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
Readiness: 0000 0000
Controller: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0011266
Shop #: WSC 01271
3 Faults Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
003 - Mechanical Failure - Intermittent
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
00283 - Front Left ABS Wheel Speed Sensor (G47)
012 - Electrical Fault in Circuit
Si mai porneste sau cum se manifesta masina?
Porneste neajutata de acceleratie 2 secunde dupa care se opreste. Daca o ajut cu acceleratia ramane o perioada pornita. Sincer nu am vrut sa aflu cat poate sta pornita de frica sa nu se intample ceva rau
http://wiki.ross-tech.com/index.php/17748/P1340/004928
17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
Possible Causes
Timing Belt/Chain incorrectly installed
Timing Chain probably lengthened
Camshaft Position Sensor (G40) faulty
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Timing Belt/Chain installation
Use Measuring Value Blocks (MVB) to Check Timing Chain
Check/Replace Camshaft Position Sensor (G40)
Check/Replace Engine Speed Sensor (G28)
cum zice cred ca e distributia putin decalata......restu erorilor de la motor sa fie din aceasta cauza
la abs e f ciudat....zic sa resetezi toate erorile sa vezi daca mai apar
Erorile de la ABS cred ca sunt datorate faptului ca ai mers prin nametii din Bucuresti din ultimele zile .
Daca intre senzorii ABS si discuri intra zapada sau gheata apar astfel de erori .
Aceleasi erori le avea acum 2 zile un vecin cu un Polo . Dupa stergere reapareau .
Am incercat sa curatam noi zapada si gheata de la roti dar ... n-a mers .
A tinut masina o noapte in garaj si a doua zi dupa stergere erorile au disparut ! :)
Super, thanks guys.
Aveti idee daca putea fi montata distributia gresit si acum sa se fi inrautatit situatia ? Adica, eroarea aia o am de cand am luat masina din service, abia acum a inceput sa imi faca probleme.
Inainte imi spunea de cham shaft intermitent ... acum pare un mesaj mai rau.
Bad post ! :Driver:
Trebuia postat in alt topic ! :P
Ba nu...este doar cu intarziere - era un raspuns la 2 post-uri mai sus :( :lol:
Distributia nu poate fi montata gresit, adica, daca era sa fie montata gresit, decalat chiar si cu un singur "dinte" de curea, nu mai pornea masina deloc, si se spargeau cateva lucruri instantaneu, de exemplu valvele puteau sa deie in piston si din alea.
xxnelu
Postul meu era "bad post" , nu altul .
Voiam sa postez in alt topic si am ... gresit . :) :)
Salut ma ajuta cineva cu interpretarea erorilor?
Controller: 1J0 920 826 B
Component: KOMBI+WEGFAHRS. RB8 V15
Coding: 01112
Shop #: WSC 00000
WVWZZZ1JZ2W500441 VWZ6Z0A3829447
01176 - Key
Modificat de wertali
...decalat chiar si cu un singur "dinte" de curea, nu mai pornea masina deloc, si se spargeau cateva lucruri instantaneu, de exemplu valvele puteau sa deie in piston si din alea.
nu se intimpla grozaviile alea de care zici tu; merge prost daca e decalata si cu 3 4 dinti
01176 - Key
Nu exista(intermitent) comunicare intre cheie si IMMO - poate fi sin cauza bateriei din cheie
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
Cum spune chiar textul... tensiune de alimentare prea mica (intermitent)
Le-ai sters (erorile)? Bateria masinii da semne de oboseala?
  • Aerofan pinned this topic
    • flavius 22
