zorg
Un senzor temperatura combustibil, un motoras la clima, o sa ai probleme cu modulul de blocare a coloanei de volan.
pe spate sigur ai boxe?
Modificat de Al Bundy
Ambrus Zsolt
Am si pe spate boxe si functioneaza ok.
Am sters erorile si au mai ramas erorile de la boxe. Celelalte nu mai apar la o scanare noua.
Mare problema mare!
Revin cu un alt log, pe modulul de CAN-Gateway:
Address 19: CAN Gateway       Labels: 1K0-907-530.lbl
Control Module Part Number: 1K0 907 530 C    HW: 1K0 907 951
  Component and/or Version: Gateway         H08 0080
           Software Coding: 3D0F0B40070000
            Work Shop Code: WSC 00028 028 00001
                      VCID: 27578A3896F60B6
4 Faults Found:
00470 - Combination comfort Databus in Single Wire
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 45
                    Reset counter: 51
                    Mileage: 104388 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:28:42
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 29
                    Reset counter: 51
                    Mileage: 104388 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:28:31
01336 - Data Bus for Comfort System
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 51
                    Mileage: 104389 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:29:19
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 104393 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:20:37
Problema este ca nu mai functioneaza AC; nu primeste comanda de pornire; intre timp am verificat functionarea sistemului de AC legand compresorul direct la tensiune si a functionat fara probleme, raceste in cateva secunde.
Eu banuiesc ca modulul de CAN-Gateway este defect, deoarece am prea multe erori si la alte module care se leaga de el (Central elect, Door driver, Door passg. si Aux. Heat), toate pe aceleasi coduri:  01336; 00470
Se confirma, sau poate fi altceva?
Si mai este ceva care ma "baga in ceata" de tot:
Address 01: Engine       Labels: 03G-906-016-BKC.lbl
Control Module Part Number: 03G 906 016 B    HW: 028 101 147 8
  Component and/or Version: R4 1,9L EDC 0000SG  5645
           Software Coding: 0000071
                      VCID: 22419B2CFDD4EEE
18043 - Powertrain Data Bus
            P1635 - 000 - Missing Message from A/C Controller - Intermittent
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 34.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 11000000
                    Bin. Bits: 00000000
                    (no units): 0.0
Help!?
Undeva ai probleme cu firele de can confort(portocaliu/verde si portocaliu/maro), ori la ceva usa(intra usa si stalp) ori la unu din module(eu tind sa cred cimatic/climatronic).
In  measuring block grupurile 130,131,132 ai comunicarea pe can confort in timp real, urmareste sa vezi care sare pe 0 sau care ramane pe 0. De acolo incepi. Can gateway nu cred sa aibe ceva. Eroarea pe motor iti apae deoarece nu raspunde ac la un moment dat(are el ceva sau cum ai probleme la firele de can).
Salut, o intrebare, la o Fabia 1.9 TDI din 2004, am o problema cu servodirectia (cand vrea merge cand nu nu, daca opresc si pornesc motorul funcitoneaza iarasi si se stinge si becul). Credeti ca poate fi de la eroarea de alternator ? sa imi taie servodirectia ? am verifica toate sigurantele si conexiunile si sunt bune, dar am vazut si eroarea aceea de la J501 si J285 si se poate sa fie defecte si sa fie si de acolo ? erorile le-am sters si reapar, masina funcitonanad normal (are servo) ce sfaturi imi dati sa mai verific ? multumesc
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25626
   Shop #: WSC 13765
   VCID: 3C7330C304AB
3 Faults Found:
01309 - Power Steering Control Module (J500)
01117 - Generator Terminal DF Load Signal
01598 - Drive Battery Voltage
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
   Part No: 6Y0 920 880 D
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 00101
   Shop #: WSC 13765
   VCID: 3E773ACB12B7
   TMBJS16Y944142444     SKZ7Z0D2548105
2 Faults Found:
01322 - Control Module for Multi-Function Unit (MFA) (J501)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 003A GATEWAY CAN    1S34
   Coding: 00012
   Shop #: WSC 13765
   VCID: F0EB54F39863
Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
   Part No: 6Q0 423 156 AA
   Component: LenkhilfeKYO        V957
   Coding: 10110
   Shop #: WSC 13765
   VCID: 6ED7CA8B0257
4 Faults Found:
01321 - Control Module for Airbags (J234)
01317 - Control Module in Instrument Cluster (J285)
01314 - Engine Control Module
01312 - Powertrain Data Bus
            37-10 - Faulty - Intermittent
Modificat de ghitaSTT
Alexandru P
Verifica fulia alternatorului sa nu fie blocata, am vazut tot la o skoda dar octavia acelasi tip de eroare cu battery voltage
Functioneaza fulia...mersi
Verifica firele dintre cutie si lonjeron, ai acces la ele pe sub masina, ai 2 fire rupte aolo de la alternator.
Multumesc, pe marti o sa verific si revib cu rezultatul, si de acolo imi vin si problemele cu servidirectia?
Am verificat pe canalele indicate si totul pare Ok. Comunicarea se face pe ambele fire, iar toate componentele sunt pe 1 și așa rămân, inclusiv hvac pe care și eu îl bănui sa aibă probleme.
In rest nu sunt alte probleme, decat că nu pot porni ac.
Alte sugestii?
Mersi.
carceacristian
Salut baieti,
La masina din semnatura,la motoru 1.9SDI,am urmatoarele erori care ma depasesc.
Poate ma puteti ajuta va rog, sa stiu si eu exact cam ce ar fi:
-Prima problema ar fi ca masina nu porneste uneori(bineinteles e legata de eroarea de imobilizer).Ar trebui sa schimb bobina de la cheie nu?sau cam asa ceva.
-A doua problema e cu "Engine control module".Aici dupa cum am citit e vorba de releul 109,nu?.Dar e sigur asta problema?.Daca da cum il verific exact,daca functioneaza sau nu?.O sa ii refac si lipiturile.
Masina mergea bine,dar cum s-au intamplat toate:
Intr-o zi mergeam cu masina si eram in viteza.Deodata,mi-a dat timp de 1-2 secunde in nas si mi s-a aprins martorul de la bujii incandescente.Pe urma masina a functionat normal.In alta zi am mers cu vreo 60km/h in a4a si deodata,turatia a scazut, pana aproape de 1000x rot/min,aprinzandu-se ba becu de la baterie(care a ramas aprins),ba becul de la ulei.Am tras pe dreapta si am oprit motorul.L-am pornit si mergea ceas motoru,fara nici un martor aprins.
Am verifcat ulei si era ok.Sunt sigur ca nu e problema la motor,insa e la electronica asta,care pentru mine e ca si chineza.
Sincer in Constanta nu as stii unde sa ma duc sa imi rezolve probleme asta(la cineva super priceput).Daca stiti pe cineva cu adevarat priceput,va rog sa imi spuneti
Faza e ca as vrea as plec la bucuresti cu masina la Depeche Mode si mi-e sa nu ma lase in pana.
Uita-ti si scanarea facuta:
VAG-COM Version:
Release  311.2-N
Chassis Type: 1M -
Seat Leon
Scan:
01,02,03,08,15,17,19,22,35,46,56
Address 01
   Controller: 038 906 012 R
   Component:
1,9l R4 EDC 0000SG  2837
   Coding: 00002
   Shop #: WSC 06441
17978 - Engine Start
Blocked by Immobilizer
            P1570 - 35-00 - -
Readiness: N/A
Address 03
   Controller: 1J0 907 379  P
   Component: ABS     20 IE CAN
0001
   Coding: 03304
   Shop #: WSC 00000
01314 - Engine
Control Module
Intermittent
Skipping Address
15-Airbags
Address 17
   Controller: 1M0 920 801 B
   Component: S5-KOMBIINSTR. VDO V02
   Coding: 04106
   Shop #: WSC 02000
   IMMO-IDENTNR: SEZ7Z0Y0605231
2 Faults Found:
00771 - Fuel Level
Sensor (G)
            30-10 - Open or Short to B+ -
Intermittent
01314 - Engine
Control Module
Intermittent
Address 19
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 06441
01314 - Engine
Control Module
Intermittent
Address 46
   Controller: 1J0 959 799 S
   Component: 41 Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 06441
2 Faults Found:
00953 - Interior
Light Time limit
          25-00 - Unknown Switch Condition
358 - Internal
Central Locking Switch: Driver Side (E150)
Intermittent
End
Multumesc frumos!
Modificat de carceacristian
F l o r i n
Daca alimentarea (sa speram ca de la ea este) ECU iti face figuri, automat masina nu porneste si se aprinde imobilizatorul. Sa speram ca nu ECU este cel cu probleme....
Altfel, problema poate sa fie din ceasuri..... bobina cititoare - rar sunt probleme la ea.
carceacristian
Al Bundy,si eu sper ca de la ea este.Am sa refac lipiturile la releu 109.Faza e ca la mine mereu ,cand am vrut sa pornesc masina,s-a aprins becu de la bujiile incandescente.Din ce am citit la alti baieti,la ei nu se aprindea becu,si asta era simptom de releu 109.
Din ceasuri ce probleme sa fie?...daca nu sunt prea enervant cu intrebarile...
Daca scot mufa de la ecu si o dau cu putin spray de contacte banuiesc ca nu se poate intampla ceva rau nu?Bineinteles daca scot bornele.
Mersi frumos,
F l o r i n
Corecteaza-ti postul...... :lol:
Da, spirala este unul dintre martorii care iti confirma sau nu acest aspect.
In sistemul de imobilizare, ai mai multe componente - ceasurile, ECU, bobina cititoare si cipurile din chei - daca nu se verifica si potrivesc toate, nu se autorizeaza pornirea...
carceacristian
Uite l-am corectat :).
Pai si in cazu asta cam n-ar fi de la releu,din ce ma duce capu.O sa ii refac lipiturile,dar daca nu e de la asta nu stiu ce sa fac mai mult,ca deja ma depaseste...
Iti multumesc frumos...
F l o r i n
ramane de verificat mai departe, sa vedem cine si de ce face asa.... poate sa fie ECU, poate sa fie probleme de conectica, etc
daca ai probleme cu releul 109, cand nu porneste, trebuie ca la scanare sa nu iti apara ECU, sa nu-l vada....
carceacristian
Al Bundy,am ramas cu masina in drum:).S-a oprit pur si simplu motoru si nu a mai vrut sa porneasca.Dupa 5min iar a pornit.
Dimineata cand am dat sa o pornesc nu mi s-a aprins becu de la bujii.Cand nu se aprinde becu de la bujii nu porneste.Cand se aprinde porneste fara probleme.Deci e cam 99% releu,uite abia acum am fost mai atent si am vazut ca becu de bujii nu se aprindea mereu(obisnuinta).
O sa ii repar lipiturile la releu 109,dar cel mai bine as da comanda de unu nou.O sa ii dau si o scanare.
Iti multumesc inca odata,imi pare rau ca nu stau in Bucuresti,ca te-as fi deranjat putin,nu numai cu problema asta.
F l o r i n
Cristi... tu vb cu noi... sau in loc de PM scrii pe topic ?
daca nu se aprinde spirala, ai cele mai mari sanse sa fie de la releul 109. Probeaza cu altul, verifica - refa lipiturile la cel vechi, curata-i platina.
Va salut. La o scanare la un audi q7 motor 3.0 Tdi mi-au dat urmatoarele scanari'
004203-Throttle Valve-Stuck or difficult to move
013128-Control Circuit for Controller for Turbocharcher 1(J724)-Electrical Malfunction
004120-Intake Manifold Runner(Bank 2)- Lower limit not reached
012597-intake Manifold Runner Control-Lower Stop not reached
009258-Exhaust Gas Temperaturre Sensor, B1, S3-Malfunction
Oricine ma poate ajuta cu cateva din aceste erori ii multumesc frumos. Precizez ca am sters erorile iar la accelerare apar inapoi. O zi buna
carceacristian
Scuza-ma F l o r i n ,gresisem numele :)).S-a dovedit sa fie,releu 109.I-am refacut lipiturile si acuma masina porneste fara probleme si NU se mai opreste.Preventiv am comandat si un releu 109.
Mii de multumiri.
F l o r i n
Nu e stres.... numai ca nu intelegeam daca e dedicata solicitarea sau vb cu mine..... :D . Ma bucur ca am putut sa te ajut.
Codrin - verifica clapeta, verifica sigurantele si conector/cablajul controller turbo.
Clapeta de acceleratie este curatata, data jos de pe masina cu tot cu galerie. Poate influenta senzorul de la dpf? Ala trebuie sa imi vina in cateva zile. Totusi cand pun contactul motorasele intake manifold runner, se misca.
Revin cu aceasi mare problema: nu functioneaza AC.
Am o singura eroare la scan:  00898 - Control Circuit A/C compressor       007 - Short to Ground
Parametrii cu AC pornit sunt urmatorii:
08:44:24 Group 001
  16.0  Compressor Shut-Off Code
  900 /min  Engine Speed
  0.0 km/h  Vehicle Speed
  04:00  Standing Time
08:44:24 Group 002
  0.830 A  Compressor Current (actual)
  0.820 A  Compressor Current (specified)
  1100 /min  Compressor Speed
  2.0 Nm  Compressor Load
08:44:24 Group 003
  6.0 bar  Coolant Pressure
  10.0 %  Radiator Fan Activation (actual)
  0.0 %  Radiator Fan Activation (spec.)
  OFF   Engine Speed Increase
Mentionez ca am verificat electrovalva, am incarcat sistemul cu agent de racire si am verificat alimentand pe direct cu tensiune, totul functioneaza OK, raceste in cateva secunde; dar cand vreau sa comand din masina, nu mai functioneaza.
Am verificat si calculatoarele, inclusiv cel de clima si par a fi in regula, comunicatia se face ok si toate sunt active.
Am verificat toate sigurantele si nu am gasit nicuna arsa.
Am verificat cablajul pana la primul conector si este OK; nu am verificat in schimb mai departe; din ce am vazut pe schema electrica, cablul se duce direct la modulul de clima pe pinul 16 al conectorului T20; vreau sa demontez modulul, sa verifica cablul, dar as vrea sa verific si daca pe acel pin am tensiunea care trebuie, dar nu stiu exact ce trebuie sa am.
Stie careva ce semnal trebuie sa am pe pinul 16 al T20?
Alte sugestii?
terminatoru
Fa o proba cu o alta unitate de climatronic,la mine ea a fost problema.
LA el vede in scurt firele cetre electrovalva. daca le lasi in aer pe al mufa internmediara, ce eroare genereaza?
  • Aerofan pinned this topic
