zorg
Multumesc frumos terrabyt. O sa incerc si asa.
la mn s-a rezolvat intre timp .. era tot din pompa, spanul de la pistonul de avans a ajuns si pe solenoid (n108) pe care initial il verificase-m doar din pct de vedere electric
ms oricum pentru raspuns!
Modificat de nelco
La un audi a6 am gasit urmatoarele erori
                Address 46: Central Conv.       Labels: 1C0-959-799.lbl
Control Module Part Number: 1C0 959 799 B
  Component and/or Version: 1C Komfortgerát HLO 0003
           Software Coding: 00259
            Work Shop Code: WSC 01271
           Additional Info: 1C1959801A  1C Tõrsteuer.FS KLO 0004
           Additional Info: 1C1959802A  1C Tõrsteuer.BF KLO 0004
           Additional Info: 1C0959811A  1C Tõrsteuer.HL KLO 0004
           Additional Info: 1C0959812A  1C Tõrsteuer.HR KLO 0004
                      VCID: 366722EB3D63
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
        53-10 - Supply Voltage Too Low - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
        27-00 - Implausible Signal
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
18:10074
VCDS Version: Beta 11.3.0
Data version: 20110801
                Address 19: CAN Gateway       Labels: 4F0-910-468.lbl
Control Module Part Number: 4F0 910 468 A    HW: 4F0 907 468 B
  Component and/or Version: Gateway         H09 0030
           Software Coding: ECEE53C43B2104
            Work Shop Code: WSC 02325 785 00200
                      VCID: 2759FFAFEAC9
01327 - Control Module for Parking Aid (J446)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 56
                    Mileage: 224558 km
                    Time Indication: 0
                    Date: 2013.03.02
                    Time: 12:15:39
                Address 42: Door Elect, Driver       Labels: 4F0-910-793-42.lbl
Control Module Part Number: 4F0 910 793 B    HW: 4F0 959 793 B
  Component and/or Version: TSG FA          H11 0040
           Software Coding: 0000522
            Work Shop Code: WSC 02327 785 00200
                      VCID: 295DF997FCDD
02115 - Locking Unit for Central Locking
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 58
                    Mileage: 224558 km
                    Time Indication: 0
                    Date: 2013.02.23
                    Time: 12:19:45
                Address 01: Engine       Labels: 03G-906-016-BLB.lbl
Control Module Part Number: 03G 906 016 BF    HW: 028 101 185 0
  Component and/or Version: R4 2,0L EDC G000SG  9553
           Software Coding: 0000072
            Work Shop Code: WSC 05484 995 69932
                      VCID: 68DBBC932757
2 Faults Found:
19463 - Camshaft Position Sensor (G40): No Signal
            P3007 - 000 -  -
             Freeze Frame:
                    RPM: 966 /min
                    Torque: 34.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101000
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  -
             Freeze Frame:
                    RPM: 945 /min
                    Torque: 38.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.76 V
                    Bin. Bits: 00101000
                    Torque: 161.0 Nm
                    Bin. Bits: 00000100
Readiness: 0 0 1 1 1
                Address 09: Cent. Elect.       Labels: 4F0-910-279.lbl
Control Module Part Number: 4F0 910 279 B    HW: 4F0 907 279 B
  Component and/or Version: ILM Fahrer      H14 0080
           Software Coding: 0000101
            Work Shop Code: WSC 02335 785 00200
           Additional Info: 4F1910113   Wischer AudiC6  H05 0150   4E0910557   REGENLICHTSENSORH10 0050
                      VCID: 285BFC93E7D7
2 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 48
                    Mileage: 224408 km
                    Time Indication: 0
                    Date: 2013.02.19
                    Time: 19:03:00
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00111010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 43
                Address 05: Acc/Start Auth.       Labels: 4F0-910-852.lbl
Control Module Part Number: 4F0 910 852     HW: 4F0 905 852 B
  Component and/or Version: FBSAUDIC6 ELV   H30 0220
           Software Coding: 0000001
           Additional Info: 4F0910131D  FBSAUDIC6 EZS   H44 0070   4F0910220D  FBSAUDIC6 IDG   H38 0040
                      VCID: E3C12BBF5E71
3 Faults Found:
00956 - Key 2
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00110010
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 217721 km
                    Time Indication: 0
                    Date: 2012.10.19
                    Time: 14:35:34
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 56
                    Time Indication: 0
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 224357 km
                    Time Indication: 0
                    Date: 2013.02.18
                    Time: 14:41:44
                Address 08: Auto HVAC       Labels: 4F0-910-043.lbl
Control Module Part Number: 4F0 910 043     HW: 4F1 820 043 F
  Component and/or Version: KLIMABETAETIGUNGH04 0150
           Software Coding: 0000020
                      VCID: DBB1135F6601
01206 - Signal for Duration of Ignition Off Time
ma poate ajuta si pe mine cineva  cu o explicatie>?alea de la motor am senzorul de viteza care trebuie sal schimb  am scos mufa si masina merge bine,,dar nu mai porneste din prima ca inainte,,,se va remedia problema dupa inlocuirea senzorului?si o problema cu inchiderea din telecomanda   nu pot so descui cu telecomanda trebuie sa bag cheia so descui
                    Mileage: 22422
Salut. Am urmatoarea problema.Am facut un scan la un Passat din 2007 si am urmatoarele probleme.Tin sa precizez ca la problema cu frana mi se aprinde intermitent butonul de parcare electronica(frana de mana) si beculetul din bord(P - ul rosu).
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000004434451
   Coding: E3828F0700041A00000A00000F000000000B5D435C0000
   Shop #: WSC 00028 028 00001
   Part No: 3C1 955 419
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 00028
   Part No: 1K0 955 559 AH
   Component: RLS     020709 054  0402
   Coding: 00209069
   Shop #: WSC 00028
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 158892 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 7.75 V
                        OFF
                        ON
                        ON
                        ON
                        ON
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1123
   Revision: 12007001    Serial number: 00000004368914
   Coding: 0000181
01034 - Electric Window Thermal Protection Active; Driver
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 7
                    Fault Frequency: 254
                    Reset counter: 172
                    Mileage: 158892 km
                    Time Indication: 0
                    Date: 2013.02.18
                    Time: 15:21:42
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1123
   Revision: 12007001    Serial number: 00000056868914
   Coding: 0000180
01035 - Electric Window Thermal Protection Active; Passenger
             Freeze Frame:
                    Fault Priority: 7
                    Reset counter: 172
                    Mileage: 158892 km
                    Time Indication: 0
                    Date: 2013.02.18
                    Time: 15:21:42
Address 53: Parking Brake        Labels: 3C0-907-801-53.lbl
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
   Shop #: WSC 131071 1023 2097151
2 Faults Found:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11111100
                    Fault Priority: 1
                    Fault Frequency: 6
                    Reset counter: 147
                    Mileage: 158936 km
                    Time Indication: 0
                    Date: 2013.03.03
                    Time: 13:03:06
             Freeze Frame:
                    Voltage: 13.15 V
                    Count: 87
02431 - Right Parking Brake Motor (V283) Resistance to Movement
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00110011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 187
                    Mileage: 158936 km
                    Time Indication: 0
                    Date: 2013.03.03
                    Time: 13:03:06
             Freeze Frame:
                    Voltage: 13.15 V
                    Count: 89
Address 55: Xenon Range        Labels: 5M0-907-357.lbl
   Part No SW: 5M0 907 357     HW: 5M0 907 357
   Component: AFS-Steuergeraet    0003
   Revision:   H09       Serial number:
   Coding: 0000001
   Part No: 7L6 941 329
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
02629 - Sensor for Swivel Module Position; Left
            014 - Defective - MIL ON
             Freeze Frame:
                    Fault Status: 11101110
                    Fault Priority: 3
                    Fault Frequency: 180
                    Reset counter: 148
                    Mileage: 153930 km
                    Time Indication: 0
                    Date: 2012.09.11
                    Time: 16:07:11
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1113
   Revision: 11005001    Serial number: 00000000605427
   Coding: 0000144
01036 - Electric Window Thermal Protection Active; Rear Left
             Freeze Frame:
                    Fault Priority: 7
                    Reset counter: 172
                    Mileage: 158892 km
                    Time Indication: 0
                    Date: 2013.02.18
                    Time: 15:31:58
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1113
   Revision: 11005001    Serial number: 00000000611108
   Coding: 0000144
01037 - Electric Window Thermal Protection Active; Rear Right
             Freeze Frame:
                    Fault Priority: 7
                    Reset counter: 172
                    Mileage: 158892 km
                    Time Indication: 0
                    Date: 2013.02.18
                    Time: 15:31:46
Etrier spate dreapta - blocat, far stanga - motoras swivel - probleme.
Sa inteleg ca la celelalte erori nu trebuie sa imi fac griji nu ?
daca stergatoarele si geamurile fata merg, nu ai treaba
Skoda Octavai 2 1.9tdi
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AB    HW: 1Z0 907 044 AB
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 76E9977C01DC22E
00716 - Air recirculation Flap Positioning Motor (V113)
Cat de grav este?
Nu e grav - e servomotorul de la recirculare - face figuri, se pare.
 Am scos furtunul de la filtrul de aer, a luat limp imediat si s-a aprins si martorul. De obicei se aprinde a doua, a treia oara. Gasesc oare actuatorul de la turbina separat?
Salut , am o intrebare : in ce camp se verifica EGR-ul la Vag Com ? Atunci cand apasand pedala de aceleratie sa imi dea valoare de 4,8  sau aprox . ?
Salut, cine ma poate ajuta cu erorile de mai jos? Multumesc frumos,
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J5 920 826 C
   Component: KOMBI+WEGFAHRSP VDO V05
   Coding: 05124
   Shop #: WSC 00000
   VCID: 2E597F1CEA0C5AE
   WVWZZZ1JZ2W245326     VWZ7Z0A4142851
01314 - Engine Control Module
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0E52164B0B88CE
Se aprinde spira de bujii cand pui contactul ?
Asa cum am promis am revenit cu rezolvarea projblemei de la postul cu nr. #4841.S-a inlocuit distributia,senzor ax came,verificat cablaj , absolut tot si dupa toate acestea masina facea la fel....s-au mai facut "sapaturi" si a reiesit ca de vina era pompa tandem,scapand ulei in motorina , s-a inlocuit si totul a revenit la normal.Interesant totusi ca eroarea era pe senzorul axei cu came si dupa inlocuire facand la fel masina,teoretic aceasta eroare neavand nicio legatura cu problema descrisa in postul cu nr.#4841.
Da, interesant.... si dupa aia, a disparut eroarea ?
Da,eroarea a disparut si masina merge perfect acum.
Nu mi se aprinde,
Parcă senzorul de la axa cu came este montat pe aceeași axa cu came pe care la extremitatea cealaltă este montata si pompa tandem. Astfel s-ar justifica eroarea.
Sper ca ai schimbat și garnitura aia de tabla dintre chiulasa și pompa tandem, altfel în scurt timp o sa înceapă sa se scurga motorina și pica pe furtunele care trec pe dedesubt.
Sent from my GT-I9300 using Tapatalk 2
da, este in capatul celalalt... ideea era de ce ii aparea eroare - ca nu are treaba, nu are cum sa simta ca are pompa uzura si iti baga ulei in motorina.... nu are nicio treaba una cu alta....
eu cred ca  de la distributie era.... ceva nu era ok.
O noua buba a aparut ....  a disparut dupa stergere si nu a mai reaparut dupa o ora de condus (voi mai verifica in zilele ce urmeaza).
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0101
   Coding: 0002042
   Shop #: WSC 73430 790 00000
   VCID: 78F599440BC854E
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
4 Faults Found:
00576 - Terminal 15
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
ceva extra informatii inafara de http://wiki.ross-tech.com/wiki/index.php/00576 ?
la ce pret se invarte  "contactul"? (nici nu stiu sub ce denumire se gaseste ca piesa de schimb)
Modificat de St3ff
e vb de partea electrica a contactului. Nu e scump.
Multumesc frumos.
salut....in urma unui auto - scan mia dat si mie urmatoarele eroari...puteti sa-mi zice-ti despre ce este vorba va rog?
salut...In urma unui auto - scan mi-a dar urmatoarele eroari pe vag com...Puteti va rog sa-mi ziceti despre ce este vorba?
Address 01: Engine        Labels: 038-906-019-AVB.lbl
   Part No: 038 906 019 KC
   Component: 1,9l R4 EDC G000SG  4896
   Coding: 00002
   Shop #: WSC 00028
   VCID: 62C1DB2CC68F
   WVWZZZ3BZ4P095879     VWZ7Z0C7975749
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 04255
   Shop #: WSC 00028
   VCID: 254B80309721
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 K
   Component: CLIMATRONIC B5GP    0010
   Coding: 17000
   Shop #: WSC 00028
   VCID: 29538C00FB39
2 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
            35-10 -  -  - Intermittent
            35-00 -  -
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 B
   Component: 0A AIRBAG VW51 04   0008
   Coding: 12353
   Shop #: WSC 00028
   VCID: 234F9E289915
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 826 A
   Component: KOMBI+WEGFAHRSP VDO V01
   Coding: 07115
   Shop #: WSC 00012
   VCID: 214394208309
01039 - Coolant Temperature Sensor (G2)
            30-10 - Open or Short to Plus - Intermittent
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0E521649863
00778 - Steering Angle Sensor (G85)
   Part No: 1C0 959 799 A
   Component: 0X Komfortgerát HLO 0003
   Coding: 00067
   Shop #: WSC 00028
   VCID: 356B50702781
   Subsystem 1 - Part No: 1C1959801
   Component: 0X Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 0X Tõrsteuer.BF KLO 0202
5 Faults Found:
01044 - Control Module Incorrectly Coded
            35-00 -  -
00912 - Window Regulator Switch; Front Left (E40)
00933 - Electric Window Motor; Passenger Side (V148)
            62-10 - No or Incorrect Adjustment - Intermittent
01332 - Door Control Module; Passenger Side (J387)
            37-00 - Faulty
End   ---------------------------------------------------------------------
cam multe.... sterge si scaneaza iar, sa vedem care revin
altfel, trebuie schimbat - curatata mufa - la G62, la clima - cele doua servomotoare fac figuri.
altfel, vezi ce ramane dupa stergerea erorilor.
  • Aerofan pinned this topic
