zorg
01218 - Side Airbag Igniter; Front Passenger Side (N200): Resistance too High Possible Symptoms
  • Malfunction Indicator Lamp (MIL) active
Possible Causes
  • Wiring/Connectors from/to Side Airbag Igniter, Front Passenger Side (N200) faulty
  • Side Airbag Igniter, Front Passenger Side (N200) faulty
Possible Solutions
  • Check Wiring/Connectors from/to Side Airbag Igniter, Front Passenger Side (N200)
  • Check Side Airbag Igniter, Front Passenger Side (N200) faulty
    • Check Measuring Value Blocks (MVB)
Sintomele astea le am si eu.
Acum ca si rezolvare daca se poate un pic mai explicat. Ma refer unde gasesc mufele sau cum masor.
Multumesc anticipat!
Mufa e una galbena sub scaunul soferului.
Buna, la un Golf 4 ALH din 2002, am uramtoarele probleme : nu se mai deschid usile, sub bord se aude un tacanit de releu, care cu usa deschisa daca stau imi intrerupe iluminatul interior, un flash scurt. Din ce vad poate fi din codare ? si daca da cum pot face asta ? sau cu ce pot incepe....va multumesc frumos.
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 806 E
   Component: KOMBI+WEGFAHRS. BPV V05
   Coding: 01112
   Shop #: WSC 00000
   VCID: 295DF997FB39
   WVWZZZ1JZ2W028448     VWZ6Z0A3439537
01336 - Data Bus for Comfort System
            37-10 - Faulty - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EB54F39863
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
   Part No: 1C0 962 258 AA
   Component: 0K Zentr.Verriegel. 0001
   Coding: 00019
   Shop #: WSC 04938
   VCID: 66C7B2AB2AA7
6 Faults Found:
            37-00 - Faulty
00950 - Central Locking Motor - tailgate (V53); UNLOCK
            25-00 - Unknown Switch Condition
01299 - Diagnostic Interface for Data Bus (J533)
            49-00 - No Communications
00953 - Interior Light Time limit
01044 - Control Module Incorrectly Coded
            35-00 -  -
65535 - Internal Control Module Memory Error
            00-00 -  -
nu e din codare.... ci din inchiderea centralizata. Din cate vad, se pare ca si-a cam dat duhul.....
In consecinta alt modul de confort ? ca pe acela e si inchiderea nu ? adevarul e ca daca ii scoteam siguranta si o puneam la loc mai mergea de cateva ori apoi la fel facea, dar acuma nici vorba de asa ceva. multmesc @florin
Modificat de ghitaSTT
am gasit mufa si pare a fi in regula. Vreo idee unde pot sa masor valorile?
sau
ce ar mai rebui sa verific?
sau
Am o problema cu un passat 3c , nu vrea sa decupleze frana de mana si nici nu merge servodirectia, tin sa mentionez ca initial nu pornea nici masina, scria pe bord steering lock, am desfacut blocatorul de volan si l-am
invartit manual sa cupleze switch-ul sa pornesc masina, am erori
00926 - Terminal 30
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 179769 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 04:03:00
             Freeze Frame:
                     : ON
                    Voltage: 5.00 V
                     : ON
                     : ON
                     : OFF
                     : OFF
                     : OFF
   Part No SW: 3C0 920 870 G    HW: 3C0 920 870 G
   Component: KOMBIINSTRUMENT VD1 3938
   Coding: 0007105
   Shop #: WSC 00011
01309 - Power Steering Control Module (J500)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 179769 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 06:00:01
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Coding: 3DFD2C04C61002
   Shop #: WSC 05311
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 116
                    Mileage: 179769 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 03:21:14
Address 25: Immobilizer
   Part No SW: 3C0 959 433 H    HW: 3C0 959 433 H
   Component:    IMMO         038 0364
   Part No: 3C0 905 861 C
   Component:    ELV          023 0350
   3C0905861C     ELV          023 0350
02825 - Supply Voltage for Electronic Steering Column Lock Motor
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00110111
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 156
                    Mileage: 179769 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 04:13:00
Address 53: Parking Brake
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Coding: 0000011
   Shop #: WSC 05311
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 156
                    Mileage: 179768 km
                    Time Indication: 0
                    Date: 2012.11.09
                    Time: 02:59:42
             Freeze Frame:
                    Voltage: 7.56 V
                    Count: 202
02433 - Supply Voltage for Right Parking Brake Motor (V283)
            011 - Open Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11111011
                    Fault Priority: 1
                    Fault Frequency: 14
                    Reset counter: 116
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.21 V
                    Count: 117
02432 - Supply Voltage for Left Parking Brake Motor (V282)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 14
                    Reset counter: 116
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.21 V
                    Count: 116
02443 - Control Head
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11101100
                    Fault Priority: 2
                    Fault Frequency: 41
                    Reset counter: 116
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.21 V
                    Count: 40
Va rog sa imi spune-ti si mie ce inseamna eroarea urmatoare, se refera la debitmetru dar ce e de facut?
17552 Mass Air Flow Sensor(G70)
P1144-35-00-Open or Short to Ground
Possible Causes
Possible Solutions
sau
sau
Si totusi nu gasesc niciun sfat rezolvare la problema mea?
Mersi Florin, am inlocuit modulul de confort, acuma functioneaza si iluminatul interior, nu mai am eroarile acelea, doar cea de "codare incorecta" , care am tot citit pe forum si pe wiki dar chiar nu am inteles cum se face...masina e un golf 4 ALH din 2002, inchidere din cheie clasica, fara geamuri electrice, fara geamuri electrice...simpla si in plus acuma se deschide hayonul, inainte nu se deschidea, dar acuma se deschide cand pun contactul. Coding la cel vechi aparea 00019, iar la cel care l-am cumparat acuma e 00017 si l-am modificat, dar tot degeaba, sau trebuie long coding...din ce am citit pe wiki cam ceva de genu, iar acolo nu stiu valorile. Modulul montat are exact acelasi cod cu cel vechi, lunadul din dezmembrari.Va rog cine ma poate ajuta cu un diy la codare modul dau o bere :) o zi buna
va rog sa imi spuneti si mie cate ceva despre ......
Thursday,14,February,2013,17:13:15:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R012773   Mileage: 207710km/129065miles
Address 01: Engine        Labels: 038-906-019-ARL.lbl
   Part No: 038 906 019 FK
   Component: 1,9l R4 EDC G000SG  1429
   Coding: 00003
   Shop #: WSC 06441
   VCID: 65CBC030FF7AD96
   VSSZZZ1MZ2R012773     SEZ7Z0A1239738
5 Faults Found:
18080 - Coolant Fan Control 1
            P1672 - 35-10 - Open or Short to Ground - Intermittent
19464 - Camshaft Position Sensor (G40)
            P3008 - 00-00 - Signal Out of Range
16705 - Engine Speed Sensor (G28)
            P0321 - 35-10 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 F
   Component: ESP ALLRAD MK60     0104
   Coding: 0023046
   Shop #: WSC 00001 001 00001
   VCID: 2D5B7810B70A216
00003 - Control Module
            014 - Defective
Address 08: Auto HVAC        Labels: 1M0-820-043.lbl
   Part No: 1M0 820 043 D
   Component: 1M-CLIMATRONIC    X0605
   Coding: 00043
   Shop #: WSC 06441
   VCID: 234F9E28B1CEE76
No fault code found.
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 1J AIRBAG VW51 0A     01
   Coding: 12618
   Shop #: WSC 06441
   VCID: 22419B2CAED4EEE
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1M0-920-xx2-17.lbl
   Part No: 1M0 920 822 E
   Component: KOMBI+WEGFAHRSP VDO V01
   Coding: 05124
   Shop #: WSC 00000
   VCID: 2A51730CD6E436E
2 Faults Found:
01176 - Key
01316 - ABS Control Module
   Coding: 00006
   Shop #: WSC 06441
   VCID: F0E52164B0B88CE
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 1F4792D89DA6C36
2 Faults Found:
00526 - Brake Light Switch-F
            27-00 - Implausible Signal
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 F
   Component: 3B Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 00000
   VCID: 3A71434C264486E
   Subsystem 1 - Part No: 1C0959801B
   Component: 3K Tõrsteuer.FS KLO 0003
   Subsystem 2 - Part No: 1C0959802C
   Component: 3K Tõrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811A
   Component: 3K Tõrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812A
   Component: 3K Tõrsteuer.HR KLO 0002
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00914 - Window Regulator Switch; Rear Left; Driver (E53)
            29-10 - Short to Ground - Intermittent
End   ---------------------------------------------------------------------
Salutari ! sunt nou pe aici... de cateva zile mi-a aparut eroarea :
000665 - Boost Pressure Regulation
               P0299 -
000 - Control Range Not Reached - Intermittent
             Freeze Frame:
Fault Status: 00110000
Fault Priority: 1
Fault Frequency: 3
Mileage: 170381 km
Time Indication: 0
Date: 2013.02.07
Time: 09:26:10
             Freeze
Frame:
RPM: 2079 /min
Speed: 108.0 km/h
Load: 59.2 %
Voltage: 14.52 V
Bin. Bits: 00001000
                    Absolute Pres.: 1836.0 mbar
Absolute Pres.: 1397.4 mbar
Readiness: 0 0 0 0
dupa ce pornesc si merg cativa km, imi apare in consola mesajul " engine fault workshop !" se aprinde intermitent becul de la bujii si motorul intra in limp mode. A mai dat careva peste problema asta ? ?
Ai avut ceva reparatii la compartimentul motor? Ori nu ai vacum , ori ai o pierdere mare de presiune. Verifica tubulatura de la turbo.
nu cred , cel putin de cand o am eu (1 an )... o sa ma uit si revin cu un raspuns.. mersi de informatie !
Am renuntat la ideea de a primi ajutor de aici, o sa ma duc la un service sa vedem ce imi zice. Oricum o sa revin cu o rezolvare in cazul in care o sa o si gasesc.
PS: pentru cei care posteaza erorile scanate cu vcds-ul, o rugaminte am la voi. Nu mai postati si acele parti unde nu aveti erori.
Exemplu:
"Address 08: Auto HVAC        Labels: 1M0-820-043.lbl
 Coding: 00043
Shop #: WSC 06441
No fault code found."
Multumesc pentru intelegere,
Sper sa nu va suparati! ;)
Modificat de alcsalx
un DIY cu codarea modului va rog cine poate sa ma ajute, legat de postul de mai sus cu modulul de confort.
Daca ai intarit contactele din mufa si tot la fel face, atunci taie firele si leaga-le pe direct.
modulul de confort vechi la scanare avea coding 00019, iar cel second care l-am montat si avea eroare de "incorect coding" avea 00017, am intrat la coding si am pus 00019 si nu mai apare eroarea de incorect coding, dar tot nu mi se deschis usile, doar hayonul, si acesta de fiecare data cand pun contactul...nu aia era codarea corecta sau mai are un secret de nu merg usile si hayonul se deschide aiurea.
De vreo cateva zile am avut probleme cu pornirea dimineata ( dupa ce ii dau sa porneasca abia dupa 5-10 secunde porneste ).
Dupa ce se incalzeste motorul simt ca nu mai trage masina si nu urca mai mult de vreo 3000 rpm in orice treapta. Cand este rece motorul nu am probleme.
Dupa ce am scanat cu Vag-Com-ul mi-au aparut urmatoarele erori:
Address 01: Engine        Labels: 038-906-018-AGR.lbl
   Part No: 038 906 018 AE
   Component: 1,9l R4 EDC 0000SG  2140
   Coding: 00002
   Shop #: WSC 01317
   VCID: 59B393BDC302531
3 Faults Found:
17971 - Quantity Adjuster (N146)
            P1563 - 35-00 - Lower Limit Reached
17969 - Quantity Adjuster (N146)
            P1561 - 35-10 - Control Deviation - Intermittent
17656 - Start of Injection Timing Regulation
            P1248 - 35-10 - Control Deviation - Intermittent
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 B
   Component: CLIMATRONIC     V 1.0.0
   Coding: 01000
   Shop #: WSC 01317
   VCID: 2045FE59A0D8C29
2 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
            35-10 -  -  - Intermittent
Astept orice sugestii. Multumesc anticipat
Modificat de amr
S-a oprit caruta! Am impins caruta in fata blocului, am dat scan cu vagul si mi-a dat urmatoarele erori :
Address 01
   Controller: 038 906
019 ET
   Component: 1,9l R4
EDC 0001SG  1268
   Coding: 00002
   Shop #: WSC 01317
5 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
            P1557 -
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
            P1144 -
35-00 - -
18077 - Valve for Pump-Jet: Cylinder 4 (N243): Electrical
Malfunction
            P1669 -
35-00 - -
18075 - Valve for Pump-Jet: Cylinder 2 (N241): Electrical
Malfunction
            P1667 -
35-00 - -
18072 - Control Circuit for PD Injectors: Electrical Malfunction
            P1664 -
Readiness: N/A
Ce naiba mai are ????
Ma poate ajuta si pe mine cineva cu un sfat , macar de unde sa pornesc?
Multe erori, important e daca toate au aparut deodata....
daca nu, se pare ca ai probleme cu injectoarele / circuitul electric - nr. 2 si 4. - din cauza asta s-a oprit.
desfa si verifica cablajele si conectorii acestora - strange conectorii,
Unde pot sa citesc numarul de regenerari DPF ale unei masini.
In Engine, dar mai exact ce canal?
Cred ca am idee unde insa nu cred valoarea citita, de aceea intreb, ca sa fiu sigur de informatie.
Am rezolvat pana la urma, era supapa de la turbo... mi-a zis mecanicul ca a mai schimbat una de curand la acelasi model de passat...
  • Aerofan pinned this topic
