zorg
la ce se refera tulumba de frana cu tot? adica acea "boshca" rotunda de la servo frana cu tot cu pompa de frana?
pentru un senzor....uai...
inca o intrebare.daca circul asa,in momentul in care e aprins becul nu functioneaza ESP-ul su ABS-ul?
Daca nu merge ABS nu merge nici ESP.
Salut oameni buni, in dimineata ca urmeaza o sa fac un drum mai lung si de 10 min am facut o scanare si mi`a dat ceva erori. Rog pe cei amabili sa`mi explice cat de cat cu ce se mananca inainte sa ma duc la atelier. Va multumesc mult :
Wednesday,12,December,2012,18:20:47:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ5D065041 Mileage: 136600km/84879miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 7L0 907 401 HW: 8E0 907 401 AB
Component: 3.0L V6TDI G000AG 0060
Revision: --H01--- Serial number: VWZ3Z0E1314700
Coding: 0011779
Shop #: WSC 31414 000 00000
VCID: E8D52679D8687A9
2 Faults Found:
009301 - Diesel Particle Filter; Differential Pressure Sensor
P2455 - 000 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 132628 km
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 21 /min
Torque: 230.1 Nm
Speed: 0.0 km/h
Temperature: 545.2°C
Temperature: 11.8°C
(no units): 0.0
Absolute Pres.: 81.6 mbar
001137 - Exhaust Pressure Sensor 1 (G450)
P0471 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 132628 km
Time Indication: 0
Date: 2111.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Temperature: 35.4°C
(no units): 0.0
Absolute Pres.: 30.6 mbar
Readiness: 0 0 0 0 0
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0099492
VCID: 468948C132BCCC9
2 Faults Found:
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal
00907 - Intervention load Management
000 - -
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 7L6 815 071 C
Component: Standheizung E1MAC
Coding: 0000000
VCID: 32610411AE34409
01126 - Engine Speed Signal
008 - Implausible Signal - Intermittent
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2L HSG 0201
Coding: 0000065
VCID: 3E7920216A6C949
Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground - Intermittent
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0D Einparkhilfe 1107
Shop #: WSC 00000 000 00000
VCID: 3973333D7342B31
00434 - Left Front Inner Parking Aid Sensor (G332)
006 - Short to Plus
End ---------------------------------------------------------------------
Am pus doar cele la care au aparut erori. Hai ca la becul frana am inteles, faza e ca imi merg toate 3.
PM`uri sau aici va rog frumos. Numai bine !!!
Pe scurt: probleme la senzorul de presiune - ai grija ca iti va incarca repede DPF-ul, un senzor de pe mijloc stanga dus, al treile bec de frana ars, verifica bateria - de acolo se poate trage si treaba cu preincalzirea .
Bateria am schimbat`o recent, 3 luni !!! Probleme am si la pornire, dau cheie, invarte, se opreste foarte putin, invarte si porneste motorul. Altadata pleaca din prima, altadata invarte de 3,4 ori !! Idee ?? tot baterie ?
LE : Si chestia e ca stopurile merg
In legatura cu senzorul de presiune si ca imi incarca DPF`ul, e recomandat sa il schimb cat mai repede sau mai pot face km ?? Pana unde vreau sa ajung sunt vreo 800 de km, acolo o pot duce la un atelier. Merci mult pronet
Modificat de skibadee
Verifica daca iti incarca bine alternatorul si cat anume.
Bateria ramane pe 14 tot timpul, niciodata nu coboara. Oricum o sa verific bateria, ce e mai principal e senzorul ala de presiune.
Schimba senzorul, mai ales daca cel de pe masina este made in US.
postasem gresit scuze
Modificat de rusen
revin cu solicitarea unei pareri asupra #4790; cineva, ceva pareri?
salutare
De 2 zile ma confrunt si eu cu o problema.
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Unde pot gasi si eu mufa de la aceasta eroare?
Sau care ar fi rezolvarea ei?
Boca Gavril Ion
Buna ziua si va salut, astazi am dat o scanare la masina si mi-au aparut urmatoarele errori:
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 254880km/158375miles
Address 01: Engine Labels: 038-906-019-AJM.lbl
Part No: 038 906 019 AJ
Component: 1,9l R4 EDC G200SG 1305
Coding: 00002
Shop #: WSC 10148
VCID: 5FC9A74FF5FD
2 Faults Found:
17675 - PD Unit Injector: Cylinder 3 (N242): Regulation Range Exceeded
P1267 - 35-00 - -
17678 - PD Unit Injector: Cylinder 4 (N243): Regulation Range Exceeded
P1270 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front D36
Coding: 04255
Shop #: WSC 05311
VCID: 346318E32CFB
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 05 AIRBAG VW5 0004
Coding: 12341
Shop #: WSC 05311
VCID: 366722EB3A87
No fault code found.
Address 17: Instruments Labels: 3B0-920-xx2-17.lbl
Part No: 3B0 920 842 A
Component: B5-KOMBIINSTR. VDO V25
Coding: 21145
Shop #: WSC 00012
VCID: 1F49E74FB57D
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2516005
IMMO-IDENTNR: VWZ7Z0Y2516005
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 05314
VCID: F0EB54F39863
01044 - Control Module Incorrectly Coded
35-00 - -
Address 37: Navigation Labels: 3B0-919-887.lbl
Part No: 1J0 919 887
Component: Navigation BNO 0103
Coding: 00000
Shop #: WSC 05311
VCID: F5E565E7E701
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 S
Component: 98 Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 04926
VCID: 4E976A0BA217
Subsystem 1 - Part No: 1J1959801D
Component: 3B Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802E
Component: 3B Tõrsteuerger. BF0002r
00912 - Window Regulator Switch; Front Left (E40)
Address 56: Radio Labels: 1J0-035-15x-56.lbl
Part No: 1J0 035 152 D
Component: Radio BNO 0103
Coding: 00205
Shop #: WSC 05311
VCID: 1F49E74FB57D
Imi puteti spune cam ce are, am citit mai sus problema cu can gatewey, se poate rezolva si la mine?
se poate ca inainte de as cumpara masina sa fi fost sarite airbag-urile si sa fie inlocuite?
Codeaza can cu 00006 posibil sa fi avut o problema cu airbagurile.
Interesete contectele din mufa de la injectoarele cu pricina.
salutare
Sunt 2 mufe sub scaunul soferului, una in podea si una mai sus, sub sezut.
Modificat de Al Bundy
Ma indoiesc......, la Passat avem asa....
0 - No available equipment
+1 - Automatic Transmission
+2 - ABS Brakes
+4 - Airbags
deci, codarea 00004 - reprezinta doar airbag-urile.... - nu are ce probleme sa aibe cu ele.
In schimb, nu e codata cu ABS.... si pentru ca masina este manuala, codam cu 00006
Vezi si cu injectoarele 3 si 4... ca nu arata bine.
buna baieti,
am eroarea asta:
00812 - Brake Pressure Release Solenoid (F84)
am citit pe undeva ca ar fi ceva senzor de la pompa de frana,altii au mai avut problema in momentul in care apasau pedala de frana se aprindea becu la ESP, la mine nu se aprinde becu de la ESP la calcarea franei si asa cand o apuca efectiv in mers.acum fiind iarna as dori sa rezolv cumva problema asta,daca stie careva ceva,mi-ar fi de mare ajutor,multumesc.
becurile pe frana imi merg
Possible Causes
  • Switch for Brake Recognition (F83) faulty
  • Wiring to Switch for Brake Recognition (F83) faulty
  • Brake Booster faulty
Possible Solutions
  • Check Switch for Brake Recognition (F83)
  • Check Wiring to Switch for Brake Recognition (F83)
  • Check Brake Booster
da asta am citit,dar nu e nimic concret,adica verific switchu sau cablaju,dar unii ziceau ceva de pompa de frana si cea de servo frana,toata tulumba,apoi senorul de presiune la mine e situat sub pompa de frana nicidecum in tulumva de servo.e foarte confuza treaba si neclara,nu stiu a avut care aceasta problema si sa o rezolve pana la capat?
switchu stiu ca e defect daca nu merg becurile la apasarea pedalei de frana,la mine merg si pedala e in regula
nedumerirea e mare...
@ Al Bundy Am 3 mufe sub scaun, 2 sub acel capac ( una neagra si una galbena) si alta mai in spate pe scaun
+2 - ABS Brakes
+4 - Airbags
Corect. le incurcasem intre ele.
buna baieti,
am eroarea asta:
CRezi ca daca scrii in mai multe topic-uri o sa primesti alte raspunsuri ?
NU e confuza deloc, pe pompa ai senzorul G201 pe servo ai F84.
DE alea galbene e vorba. Se taie si se leaga firele pe direct.
Salut. Am un Golf 5, mi-am cumparat un RCD 510 si am inlocuit Can Bus cu unul cu seria 7N0 907 530 M. Am facut print-screen inainte de a il inlocui, cu ce aveam instalat pe fostul si am bifat aceleasi lucruri si pe cel nou. Totusi la scanare imi apar urmatoarele erori:
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AE
Component: ClimatronicPQ35 066 0404
VCID: 6AD1B30C4564F6E
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001381321
Coding: A1898F060004180F0F1400001400000000087F075C
Shop #: WSC 12345 123 12345
VCID: 3A71434C754486E
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 12345
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 201211F2001046
Coding: 350000
VCID: 3A71434CB54486E
2 Faults Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Mileage: 144731 km
Time Indication: 0
Date: 2000.00.00
Time: 00:06:10
03272 - Control Module for Audio Interface
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 144731 km
Time Indication: 0
Date: 2000.00.00
Time: 00:06:14
M-am gandit ca ma puteti ajuta sa imi dau seama unde am gresit sau ce am uitat sa fac. Stima!
Address 01: Engine Labels: 03L-906-022-CAG.clb
Control Module Part Number: 03L 906 022 JM HW: 03L 906 022 B
Component and/or Version: R4 2,0L EDC H01 3173
Software Coding: 0104002C18072120
Work Shop Code: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TDI03L906022JM A01005 (AU48)
VCID: 79FDE9D74B19
3 Faults Found:
5231 - Fuel Rail/System Pressure: Too Low
P0087 00 [101] - Cannot Be Tested at this Time
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 96866 km
Date: 2012.12.27
Time: 22:17:16
5380 - Valve for Air Filter Bypass Flap (N275): Open Circuit
P1016 00 [100] - No Signal/Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 96395 km
Date: 2012.12.19
Time: 01:17:56
5253 - Diesel Particle Filter; Differential Pressure Sensor: Elect. Malfunction
P2452 00 [175] - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 46
Date: 2000.00.00
Time: 00:00:00
ultima eroaare ia aparut mai demult ...deci masina a intrat intr-un sleau de zapada si a atins foarte butin cu motorul si sa oprit si nu mai vrea sa porneasca .A fost stearsa eroarea si nimic.
Este un audi a4 din 2009 cred B8
Modificat de bigstar
este B8.
au fost verificate bine cablajele ?
posteaza erorile corect - lipsesc ceva cifre la ele. Oricum, atata timp cat nu are presiune in rampa, nu o sa porneasca.
acum, depinde si de ce a lovit si stricat la ea.....
  • Aerofan pinned this topic
