zorg
Salut ma poate ajuta si pe mine cineva cu eroarea asta cood eroare 180012 ce inseamna mai exact?
ar fi bine sa postezi un log cu eroarea facut cu VCDS. In caz ca e vorba de aceasta eroare:
Error Code: 18012 P1604
Possible symptoms:
  • Job Loss
Possible causes:
  • Control Module faulty
Possible solutions:
  • Check (measuring blocks) / Replacement Control Module
Va rog frumos, o parere, cat de mica...
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Control Module Part Number: 03G 906 021 LR HW: 03G 906 021 AN
Component and/or Version: R4 1,9L EDC 000SG 9248
Software Coding: 0000071
Work Shop Code: WSC 00028 028 00001
VCID: 7AF1834C35C446E
5 Faults Found:
005522 - Altitude Sensor / Boost Pressure Sensor
P1592 - 000 - Implausible Correlation - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 9
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Pressure: 254 mbar
Pressure: -114 mbar
Bin. Bits: 00011010
Absolute Pres.: 999.6 mbar
Absolute Pres.: 2295.0 mbar
005269 - Switch-Over Valve for EGR Cooler (N345)
P1495 - 000 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 11000100
Mass Air / Rev.: 775.0 mg/str
Mass Air / Rev.: 0.0 mg/str
005184 - EGR Valve (N18)
P1440 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 11000100
000579 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 11000100
Absolute Pres.: 142.8 mbar
Absolute Pres.: 1071.0 mbar
000275 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 124893 km
Time Indication: 0
Date: 2012.11.18
Time: 15:30:36
Freeze Frame:
RPM: 882 /min
Speed: 4.0 km/h
Load: 2.0 %
Voltage: 14.44 V
Temperature: -8.1°C
Temperature: 78.3°C
Temperature: 72.0°C
Readiness: 0 4 0 0 0
buna seara! Am un golf 6 motorizare 1,6 tdi.....va rog frumos puteti sa-mi spuneti o parere despre eroarea urmatoare: 17851-potentiometer for egr (g212) p1443-35-10 signal too low
precizez ca s-a curatat egr-ul si am schimbat si senzor g71 totusi masina nu se tureaza mai mult de 2500 de turatii (nici in mers si nici pe loc) si in bord am aprinse spirala si Check Engine Multumesc mult !!!!
17851 - P1443 - wiring short to earth / EGR valve position sensor (am patit la care nu a reusit opretiaunea cu curatarea, si a trebuit inlocuita) ... asta oricum poti sa o verifici si de pe diagnoza (parametrii)
17851/P1443/005187 - Potentiometer for Exhaust Gas Recirculation (G212): Signal too Low
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Wiring and/or Connector(s) from/to Potentiometer for Exhaust Gas Recirculation (G212) faulty
  • Potentiometer for Exhaust Gas Recirculation (G212) faulty
  • Exhaust Gas Recirculation (EGR) Valve (N18) stuck/faulty
Possible Solutions
  • Check Wiring and/or Connector(s) from/to Potentiometer for Exhaust Gas Recirculation (G212)
  • Check/Replace Exhaust Gas Recirculation (EGR) Valve (N18)
    • Perform Output Test
    [*]Check Exhaust Gas Recirculation (EGR) System
Modificat de ghitaSTT
azi am facut o diagnoza la un audi a4 2006 2.0 tdi in vederea cumpararii.la citirea km am 120000km,la auto testul cu vcds la radio la unele erori ale lui imi apare mileage-655300.sunt confuz,ce poate sa insemne acel mileage?km reali ai masini?
tu acolo ai ceva trecator,la motorasul de la geam pasager si incalzirea la oglinda.ele iti functioneaza acum ?citi km are acum masina?eu banuiesc ca eroarea a aparut la acei km,a fost demontata cred usa.apoi ai modulul de la telefon eroare la 167517 km.
Modificat de marianu
Am exact km precizati. Daca sterg eroarea, ea reapare. Nu e trecator.
Geamul si incalzirea functioneaza, insa eroarea aia ma streseaza sa o stiu acolo.
Modificat de Tibo78
poate fi din mufa dintre usa si caroserie,a oxidat un pic si e un contact imperfect.o poti desface si da cu wd40.
Insa ce ma fac cu erorile legate de navigatie si telefon? Si aici functioneaza toate, insa erorile ma dispera. Deja se face luna.
Salutari..am un log facut..care mi-l explica si mie..am vazut ce si cum..dar vreau mai amanuntit..multumesc anticipat :)
Niste pareri ? :D Sunday,25,November,2012,14:47:46:37412
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Address 18: Aux. Heat Labels: None
Control Module Part Number: 1K0 815 071 H
Component and/or Version: Zuheizer 031 1312
Software Coding: 0000011
Work Shop Code: WSC 01324 785 00200
VCID: 2A51730C85E436E
5 Faults Found:
01410 - Heater Over-Temp
000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 92
Mileage: 130779 km
Time Indication: 0
Date: 2000.00.00
Time: 22:15:16
Freeze Frame:
Ctrl. Pause
Temperature: 148.0°C
Temperature: 61.0°C
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 248
Mileage: 222682 km
Time Indication: 0
Date: 2000.00.00
Time: 28:13:43
01444 - Under-Voltage Shut-Off (Automatic)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 248
Mileage: 222682 km
Time Indication: 0
Date: 2000.00.00
Time: 28:13:43
02251 - Heater Unit Locked
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 248
Mileage: 222682 km
Time Indication: 0
Date: 2000.00.00
Time: 28:13:43
01411 - Temperature Sensor (G18)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Reset counter: 248
Mileage: 222696 km
Time Indication: 0
Date: 2000.00.00
Time: 29:12:29
Freeze Frame:
Malfunction
Temperature: 205.0°C
Temperature: 68.0°C
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001434752
Coding: A18B8F020004100000120C000000000000087F075C
Shop #: WSC 12345 123 12345
VCID: 3A71434C754486E
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 12345
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0007103
Shop #: WSC 00999 444 64523
VCID: 30656164A3384CE
00003 - Control Module
014 - Defective
In primul rand verifica senzorul de temperatura, apoi va trebui sa deblochezi din VCDS unitatea de webasto. Verifica releul care tine de spalatoarele de faruri, inclusiv motorasul pompei. Pentru deblocarea webasto-ului salvei 1 in canalul 42 din Adaption, apoi stergi codul de eroare. Spor la treaba.
aha.multumesc..am vazut ca din centrala electrica..e nebifat aux heat.adica webasto-ul..
si la faza cu releul de la faruri..faza e ca bara mea nu are spalator de faruri..adica cand am luat masina,.ala mi-a zis ca are bara schimbata..dar nu a zis..ca are spalatori faruri :)
Modificat de CT91MOC
daca nu mai ai spalator de faruri, debifeaza din centrala electrica. SI nu trebuie sa fie bifat in centrala aux heating. aia e altceva, e cea suplimentara electrica nu cea stationara.
ok multumesc de raspuns..daca as pune bara cu spalator de faruri si motorase ar fi ceva..dar OEM m-ar costa cam multisor..o sa vad ce rezolv la webasto
Vezi daca mai ai si vasul spalator mare si motorasul de la spalatoarele din bara. Nu cumva e bifat aiurea si amsina nu a avut deloc spalatoare ?
Modificat de Al Bundy
La urmatorul schimb sau cand vine tata..verific tot.si daca e sa am ma gandesc daca le pun ..de la cel care am cumparat masina , a spus ca inlocuise bara..cu putin timp inainte sa ne-o vanda..vasul de la lichidul de parbriz e spart..si cand am schimbat distributia vroiam sa-l schimb..si nu am gasit ceva repede..in fine , daca stiam ma uitam atunci..la urmatoare intrare in service , ma uit la tot..acum cand am timp incerc sa fac webasto..daca nu ma duc la cineva , cu mai multa experienta..multumesc pt raspunsuri ! :santa:
Hello all,
AM facut o scanare cu vag com si am gasit urmatoarele:
Daca puteti sa ma ajutati cu descifrarea lor :
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00588 - Shareware Version. To Decode all DTCs
32-10 - Please Register/Activate - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
01176 - Key
Si restul modulelor nu le-am putut scana , imi zicea ca ''module not found'' ceva de genul.
Stie cineva vreo solutie sa ma pot conecta la toate modulele?
Ms mult !
Daca ne spui si pe ce module au aparut... De ce nu postezi intreg autoscanul masinii?
532 si 588 in "Airbag"
17965 in "Engine"
1176 in "Instruments"
...era bine de postat informatiile complete ale modulelor cu defecte.
Modificat de cuiuda
Salut, la o Skoda Roomster 1.4 TDI din 2007, se intampla uneori, pedala de frana se intareste la prima apasare, cum se face normal la ABS dupa 3 apasari de frana, dar in acest caz din prima, cel mai des se intampla in panta/rampa si in marsarier, la o scanare a masinii nici urma de defect. Din ce cauza poate fi ?
  • Aerofan pinned this topic
    • 42miticutza
