zorg
Stie cineva sa interpreteze eroarea de mai jos?
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 192
PS masina din semnatura nu mai are sistemul audio original ci navigatie AM - replica RNS, pe langa eroarea de mai sus mai am si
01304 - Radio
insa asta este normala!
Replica o am instalata de mai bine de 6 luni, pana de curand aveam doar eroarea 1304, acum a aparut si 1305 si chiar daca o sterg, apare imediat!
Pareri?
L.E. am citit ca eroarea are legatura cu schimbarea HU insa de ce a aparut dupa 6luni ...
Modificat de D@ny
No signal / no communication(No Signal / Communication No.).
defective(Defective)
Possible symptoms:
  • Unknown
Possible causes:
  • Faulty cables
  • Control Module faulty
Possible solutions:
  • Check / repair wiring and connections
  • All plugs and pull alternately reconnect, thereby measuring value block to monitor
  • Control Module Replace the data bus is blocked
Ce tare: symtoms: unknown :))
Hmm ... cu alte cuvinte, las-o asa!
PS: unde ai gasit informatia? Pe wiki-ros tech parca nu era postata ...
Modificat de D@ny
Salut, la un Passat B6 nu pot citi numarul real de kilometri. La aplications->EDC mileage-> read imi da eroare si imi zice ca ecu nu poate fi detectat sau nu contorizeaza km. Sunt km manariti cu un aparat(soft) care sa ascunda km? La golf am verificat km si nu a dat acea eroare. Care sa fie cauza?
Thursday,06,September,2012,01:08:20:46862
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8D0 907 401 F
Component: 22,5l/4VT EDC 0000AG D61
Coding: 02001
Shop #: WSC 06325
6 Faults Found:
18259 - Powertrain Data Bus: Missing Message from ABS Controller
P1851 - 35-10 - - - Intermittent
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-10 - - - Intermittent
01318 - Control Module for Injection Pump (J399)
01442 - Misfire due to Lack of Fuel
00546 - Data wiring faulty
00575 - Intake Manifold Pressure
11-10 - Control Limit Not Reached - Intermittent
Readiness: N/A
End ---------------------------------------------------------------------
este vorba de un audi a4 1999, 2,5TDI, AKE.
ce se poate face?
Sa postezi toate erorile. sa le stergi si sa vezi daca mai apar.
A fost umblat la KM.
Pai si doar la reprezentanta se pot afla km reali? Sau nu se poate?
Referitor la afirmatia "A fost umblat la km" eu am citit la mai multe masini nr de km reali care desigur difereau de ce era in bord, in schimb am intalnit si cazuri cand n-am putut sa-i citesc, sa fie de vina modul in care a fost umblat la km?
Da , are legatura cu felul cum s-a umblat.
SE poate doar daca masina are intrari in service-urile din reteaua VW.
Modificat de Al Bundy
Nu mai functioneaza asistenata la parcare(dupa ce bag in marsarier piuie cuntinuu cateva sec si apoi se opreste dar nu mai funcioneaza nici unul din senzori)Un senzor spate la un golf 4 dupa scanarea cu vag com imi spune :
01546 - Senzor asistenta parcare mijloc-stânga spate-G204-
28-10 - Scurt la plus
ce inseamna ? trebuie schimbat senzorul ?
precizez ca am scos senzorul de mai sus, l-am curata si am testat chiar si fara el si piuie la fel si nu funcioneaza la fel nici unul.Daca nu funcioneza unul nu funcioneza toti?
Va multumesc
Daca masina in cauza are EDC 17, adica are motor CR, nu vei putea citi km reali pentru ca VCDS-ul nu-i citeste (se poate sa nici nu fie scrisi, habar n-am)
Deci sunt umblati km sau nu? Pe mine asta ma intereseaza.
Din ce s-a spus pana acum, tu ce deduci ?
Va multumesc
daca unul sau amcar buzerul este defact, nu functioneaza intregul sistem. s schimba cu altul de alaturi, daca se muta eroarea atunci senzorukl este defect, daca nu se muta atunci sunt probleme cu firele.
Cine ma ajuta cu descifrarea erorilor
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
Shop #: WSC 00000 000 00000
VCID: 2D550D87C835
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 851 H
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0003103
Shop #: WSC 43664 143 59840
VCID: 2D550D87C835
00003 - Control Module
014 - Defective
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000961807
Coding: E5890F0600041800001400001400000000
VCID: 408B44336FA7
Subsystem 1 - Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Rezistenta suplimentara din climatronic - defecta -
cluster - de obicei apare cand sunt probleme - adica, modulul nu mai functioneaza. Am intalnit-o de mai multe ori, pe diverse componente, care functionau ok.... cel putin, in acel moment
switch frana - verifica si monitorizeaza in timp, daca iti merg lampile de frana.
Sterge erorile si vezi care reapar.
asa stiam si eu, la EDC17 nu citeste VCDS kilometri.....
Salutare. Este vorba de un VW Vento 1.9TDI, 1z, 90cp. 1994
Am facut o scanare cu vag com si mi-a dat urmatoarele erori:
2 Faults Found:
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
00575 - Shareware Version. To Decode all DTCs
17-10 - Please Register/Activate - Intermittent
Ma poate ajuta cineva sa le descifrez?
Masina trage foarte greu. Nu scoate fum deloc, Am facut si un log in mers si mi-au dat prost valorile debitmetrului. Am pus debitmetru de la un prieten de pe masina identic dupa cod si aceiasi masina si mi-a tot valori proaste. mai slabe decat cele date de ecu. am pus debitmetrul meu pe masina lui si i-a dat valorile exacte ca un debitmetru nou. Deci debitmetrul meu e bun...dar nu`l citeste.
Stie cineva de ce nu imi citeste debitmetrul aerul intrat?
pentru erori exista Google
17-10 - Control Difference - Intermittent
cat despre debitmetru, trebuie verificate firele de la el pana la calculator
Mersi pt raspuns
Atunci ce rol mai are topicul asta daca exista google? :icon_confused:
pai prin regulamente scrie sa folosesti functia search inainte sa postezi.... oare nu o mai fi avut nimeni problemele tale? :)
Si mai scrie sa nu postezi in mai multe locuri aceeasi problema. Ai primit raspuns dincolo.
Salut! La un motor AFN apare:
01237 - Fuel Shut-Off Valve (N109)
04-00 - Mechanical Malfunction
La pornire se tureaza pana la 2000 de ture timp de o secunda si dupa revine la relanti la turatia normala. Am incercat sa schimb supapa respectiva dar zici ca e sudata. Nu am reusit sa o dau jos. Filtrul de motorina este nou. In mers motorul nu mai are vlaga. Se tureaza destul de greu in sarcina.
A reusit cineva sa scoata valva N109?
Sa fie problema de la filtrul de motorina?
Am schimbat injectorul, senzorul de presiune, senzorul temperatura lichid racide dar acum nu imi indica temperatura la apa in bord, si cand pornesc motorul se tureaza pana la 1000 si apoi revinde la 800 si nici nu trage cum trebuie ...
  • Aerofan pinned this topic
