zorg
revin cu logul, am masurat circuitele, toate sunt ok. cred ca este vorba de acest senzor Steering Angle Sensor (G85)
VCDS Version: Beta 11.2.0
Data version: 20110305
Sunday,24,June,2012,20:49:13:10074
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75 76
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 AT
Component: 1,9l R4 EDC 0000SG 1513
Coding: 00002
Shop #: WSC 00046
VCID: 69DDB9973BB9
WVWZZZ1JZ3B040359 VWZ6Z0B0207839
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 00046 615 1234567
VCID: 346318E32CFB
2 Faults Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure
00003 - Control Module
014 - Defective
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 00046
VCID: 214DE1B78309
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 02 AIRBAG VW61 0101 0001
Coding: 12338
Shop #: WSC 00046
VCID: 2759FFAFED2D
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 826 C
Component: KOMBI+WEGFAHRS. RB8 V24
Coding: 05112
Shop #: WSC 00046
VCID: 295DF997FB39
01334 - Door Control Module; Rear Right (J389)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
VCID: F0EB54F39863
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 1C Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00046
VCID: 366722EB3A87
Subsystem 1 - Part No: 1C1959801A
Component: 1C Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 1C Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 1C Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 1C Tõrsteuer.HR KLO 0004
2 Faults Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
End ---------------------------------------------------------------------
Modificat de biggy
Verifica senzorul G85, adica ansamblul in care se afla spira de airbag de sub volan.
Dupa un drum mai lung (350km) in care masina(din semnatura) s-a comportat excelent, turometrul a luat-o razna, (se ducea pana la capat si revenea... fara ca motorul sa se tureze). Se aprindeau martorii in bord, iar motorul dadea sa se opreasca. Aveam cam 70-80/h. Am patit cam de 2-3 ori pana am putut opri pe dreapta. Am pus testerul pe ea si am gasit urmatoarea eroare:
00513 - Engine Speed Sensor (G28)
Am sters eroarea, am dat la cheie si am plecat mai departe. Dupa 2-3 km, simptomele au reaparut. Povestea s-a repetat inca de 2 ori, pana cand motorul nu a vrut sa mai porneasca deloc. Am fost tractat si ce e mai grav, e ca nu mai pot intra cu testerul pe modulul engine (pe celelalte module pot sa intru ABS, Instruments.. etc) pe engine imi da "no response" . Am schimbat si Baud rate, dar degeaba. Cand pun contact, nu se aude nici pompa de benzina nici clapeta de acceleratie nu face zgomot. Cand dau la cheie, invarte bendixul dar nu porneste motorul. Am pus un alt ECU (la fel) si are aceleasi simptome. Sigurantele le-am verificat, sunt ok (si alea de pe baterie)
Pare a fi un fir intrerupt, sau un scurt, puteti sa va dati cu parerea?
P.S. vad ca asta e topic de TDI, scuze pentru postarea gresita, rog un moderator sa ma directioneze in topicul corect. merci.
Modificat de Andrei369
catalinpaun1998
ma puteti ajuta golf 5 plus martoru motor aprins
001025 - Sistem recirculare gaze evacuare: flux prea mic
masina functioneaza in parametri normali sugestii!!!
Membrana sparta la EGR ?
Buna,poate sa-mi spuna si mie ceva legat de postu 4302
FA o diagnoza cu o interfata care stie sa-ti decodeze erorile.
01145 - Can't Decode, CODE File Not Loaded!
29-10 - Can't Decode, CODE File Not Loaded! - Intermittent
la ce sa ma uit sa descoper problema
01145 - Actuators for Central Locking rear doors open. Central Locking - Opening Motor.
Possible causes:
Fuse (s) make poor contact or broken
Wiring and / or connections faulty
Motor failure
Possible solutions:
Check / replace fuse (s)
remove the fuse (s) out
make the ends of the fuse (s) clean (very light sanding with fine sandpaper, then very little contact spray on it)
fuse (s) by measuring with a multimeter (the fuse (s) sometimes looks fine, but appearances can be deceiving)
fuse (s) back / Replacing
Check / repair wiring and connections
Check (measured value blocks) / replace engine
Modificat de cuiuda
Coding: 11000
Shop #: WSC 00046
VCID: 214DE1B78309
Am si eu o nelamurire, legata de aceasta eroare, climatonicul nu baga rece, am verificat instalatia de racire, freon am, compresorul porneste, am pus compresorul direct la baterie, porneste, ajunge racirea pana la termostatul din partea dreapta a masinii, dar ramane blocat acolo, nu trece racirea mai departe in masina, daca nu este pus pe direct la baterie, nu ajunge nici la termostat racirea, indiferent daca ajunge sau nu, aerul nu este rece. unii zic ca este dus compresoul, altii zic ca e bun, nu stiu ce sa mai cred. In masina in partea dreapta, sub torpedou, se aud niste motorase, putin deranjat sunetul pe care il fac , dar totusi cred ca sunt de la climatonic, sau nush ce rol au, si de ce se aud asa.
O lamurire, ce as mai putea verifica, sa fiu sigur 100% ca e compresorul defect, sau o fi de la altceva.
micuzzu_marius
Buna seara, am si eu doua erori din care prima stiu de la ce e(am inlocuit radioul original cu o replica), dar a doua chiar nu am idee, poate ma puteti ajuta, multumesc mult
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 04081101270229
Coding: 351002
Shop #: WSC 00066 000 00000
VCID: 356A96BE9C5A57B
2 Faults Found
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 93
Mileage: 11631 km
Time Indication: 0
Date: 2005.14.23
Time: 13:34:08
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 4
Mileage: 15334 km
Time Indication: 0
Date: 2008.14.01
Time: 00:44:18
Te-ai mai jucat cumva pe CAN ? daca nu, da-i o recodare cu aceelasi cod.
micuzzu_marius
incerc azi o recodare cu acelasi cod, multumesc mult
Salutare
Ajutati-ma si pe mine sa deslusesc ce se intampla va rog! Am tot scanat si imi ramane eroarea. Ce as putea sa-i fac?
Part No: 1J5 920 826 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 05114
Shop #: WSC 00046
VCID: 2E570A8B4AB
WVWZZZ1JZ3B0 VWZ7Z0B58594
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-10 - Open or Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
Initial starea erorii era fara 29-10 - Short to Ground - Intermittent . Vad ca a aparut si asta. Masina merge ok, doar ca din cand in cand imi apare la pornire in bord Sensor for Oil Workshop.
Mersi!
Senzorul dus. Verifica totusi si cablajul de la el - pt short to ground.
Aveti idee de ce nu pot comuta in Basic Settings pe canalul 011? As vrea sa urmaresc miscarea actuatorului de la turbo.
Se pare ca am mai intampinat o problema. Puteti sa mai ma sfatuiti si pe mine inca odata?
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
RPM: 1974 /min
Torque: 43.9 Nm
Speed: 30.0 km/h
Load: 23.1 %
Duty Cycle: 14.7 %
Mass Air / Rev.: 230.0 mg/str
Mass Air / Rev.: 690.0 mg/str
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 000 - -
Freeze Frame:
RPM: 1449 /min
Torque: 0.0 Nm
Speed: 68.0 km/h
Temperature: 41.4°C
Absolute Pres.: 1030.2 mbar
(no units): 94.8
(no units): 0.73
Temperature: 86.4°C
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 51.2 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00001111
Temperature: 16.2°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 51.2 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00001111
Temperature: 16.2°C
Bin. Bits: 10110000
Tin sa precizez ca am curatat EGR.
Capsula de la egr are membrana intreaga? trage cu gura pe acel stut mic si vezi daca tine vid.
salutare! valorile astea la injectoare:
cyl 1: 0.00 mg/R
cyl 2: -0.45 mg/R
cyl 3: -0.49 mg/R
cyl 4: 0.87 mg/R
pot fi cauza faptului ca imi da in nas cand o tin la turatie constanta (in general se simte la peste 2000 rpm), dar si cand accelerez, manifestandu-se mai rar? Trepideaza si la relanti dar foarte putin si numai cand e motorul rece. Acul la turometru nu fluctueaza (fix 903 rpm). Pe engine nu am nicio eroare.
Merci! Numai bine
Modificat de jammin
Valorile sunt OK. fa-i un log in merss. Posibil MAF.
merci de raspuns pronet. am scos mufa de la MAF de tot si trepidatiile de la relanti nu au disparut. Merge rotund cateva secunde, dupa care are o balbaiala de 1-2 secunde. Ma gandesc ca pe partea de alimentare cu combustibil e ceva. Poate EGR-ul...?
Laurentiu Utiu
Eu as miza tot pe un injector. Egr-ul nu produce trepidatiile descrise de tine. Chiar si la relanti egr-ul lucreaza aprox 2 min dupa care se inchide.
Valorile bune ale injectoarelor nu e totdeauna un reper bun. Caci ele pot fi uzate uniform ,sa dea valori bune dar sa functioneze prost.
Verifica si filtrul de motorina.
Sau dai jos injectoarele, le trimiti la Sinaia sa ti le testeze, le faci un reglaj ca la carte si vei scapa de trepidatii. Asta in cazul in care injectoarele trec testul....
Sent from my E15i using Tapatalk
merci Laurentiu. O sa schimb filtrul, sa vad sa nu imi bage aer, apoi ma indrept spre injectoare. Numai bine!
Skoda octavia 2 din 2004
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H29 0704
Revision: 00029000 Serial number: 00000001253830
Coding: 01020E120004140000110D000000000000
Shop #: WSC 73430 790 00000
VCID: 408B44336843
Subsystem 1 - Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
2 Faults Found:
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
010 - Open or Short to Plus - Intermittent
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
Unde sa ma uit de relee? un ajutor ceva ?
  • Aerofan pinned this topic
