zorg
F l o r i n
Da, nu motorasul e de vina. Problema poate sa fie din calculatorul de usa sau cablaj.
va rog un ajutor si pentru mine pentru interpretarea erorilor de mai jos:
Saturday,19,May,2012,20:56:01:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ2W127171 Mileage: 219540km/136415miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 FB
Component: 1,9l R4 EDC G000SG 3350
Coding: 00002
Shop #: WSC 01317
VCID: 55A585678591
WVWZZZ1JZ2W127171 VWZ7Z0A3739965
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 01317 785 00200
VCID: 2C530083F69B
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 01317
VCID: 214DE1B78159
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 01
Coding: 12855
Shop #: WSC 01317
VCID: 224FEEBB845F
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 01317
VCID: 306B14F3DAB3
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 846 B
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 21112
Shop #: WSC 00000
VCID: 2A5F069BFC6F
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
VCID: F0EB54F39A33
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 1A Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 01317
VCID: 366722EB38D7
Part No: 1C1959801A
Component: 1A Tőrsteuer.FS KLO 0003
Part No: 1C1959802A
Component: 1A Tőrsteuer.BF KLO 0002
Part No: 1C0959811A
Component: 1A Tőrsteuer.HL KLO 0002
Part No: 1C0959812A
Component: 1A Tőrsteuer.HR KLO 0002
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 D
Component: RADIO SON 0003
Coding: 03401
Shop #: WSC 01317
VCID: 2647F2ABE877
End ---------------------------------------------------------------------
Modificat de rcs66
F l o r i n
Debitmetrul. Verifica cablajul pana in ECU, vezi daca ii vine alimentare. Dac totul e ok, trebuie schimbat debitmetru.
Yala - spate dreapta - iti face figuri.... ori switch ori lipituri reci
Am si eu o eroare care apare mai mereu la masina din semnatura...
17656 - Injection Start Regulation: Control Deviation
P1248 - 35-10 - - - Intermittent
Verifica in primul rand avansul.
Uite aici explicatia erorii respective. Avansul sau valva N108 ar fi unele dintre raspunsuri.
Nu intotdeauna apar erori, mai ales daca problema este la releul de sub lonjeron.
merge sa fac rocada pentru testare daca eu am AC iar el Climatronic?
nu am mai facut nici o rocada ca fiecare a avut altceva mai bun de facut; in schimb s-a dus masina la shopul dedicat (care a si umblat acolo ultima oara) si s-a constatat ca era un fir deconectat la compresor.
mai mult au avut de munca a fost cu demontatul/montatul scutului metalic.
Modificat de DragosR
Am si eu erorile aste.. daca poate cineva sa imi spuna ce e de facut pt inlaturarea lor raman dator:
1.
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F0006850560084F86307880
Shop #: WSC 04941 785 00200
VCID: 83010B3FBE31
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 04941
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 34
Reset counter: 26
Time Indication: 0
2.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 827 E
Component: KOMBIINSTRUMENT VO3 0450
Coding: 0002101
Shop #: WSC 00011 888 96745
VCID: 326F1EFBD10B
01299 - Diagnostic Interface for Data Bus (J533)
008 - Implausible Signal - Intermittent
3.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D550D87C835
01317 - Control Module in Instrument Cluster (J285)
Va cer si eu ajutorul pentru o problema la masina mea: VW Jetta 2008 1595 cmc motor benzina BSE
De ceva vreme aveam senzorul "Airbag fault" aprins pe bord iar ieri dupa ce l-am dus pe cel mic la gradi surpriza masina nu a mai pornit, Va atasez erorile scanate cu vag-ul . Autoscanul nu merge deoarece da o problema de comunicatie. Daca sterg erorile masina da semne ca ar porni dar cedeaza imediat pt ca nu se accelereaza.
In bord sunt aprinsi acum martorul ABS , martorul servo si clipeste "!" urmat de trei beepuri sonore.
Log jetta 03mai 2012.txtLog jetta 21mai2012.txt
Buna, am un Audi A4, 130 CP, 1.9 TDI din 2002 si am facut o scanare cu vag com dupa ce la 120 km/h sa blocat si nu mai tragea deloc, si mi-a dat urmatoarele eroari...daca ma puteti ajuta sa imi spuneti ce este exact va multumesc (le-am sters odata, am dat o tura si am facut iara test si aceleasi erori)
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JL
Component: 1,9l R4 EDC 0000SG 1519
Coding: 00002
Shop #: WSC 63351
VCID: 6ADFC69B3EBF
WAUZZZ8E42A290285 AUZ6Z0B0063590
3 Faults Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-00 - -
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
Readiness: 0 0 X X X
F l o r i n
Verifica cablajele si conectorii senzorilor.
Deci e posibil sa fie din alea si sa scap de turbina, ca multi ziceau ca mai mult ca sigur e turbina. O sa verific cablajul si o sa le curat cu spray de contact. Dar e posibil ca vreun senzor din cei 2 sa fie bulit ? Cum pot afla ?
Tot ce am intalnit pana acum cu eroarea "Open or Short to Plus" a fost din cauza unui circuit/cablaj intrerupt. Mai ales ca si @FLORIN ti-a confirmat.
Multumesc, luni o sa verific si sper sa vad daca e din acest motiv, iar daca e vreun cablu intrerupt care nu este vizibil, cum pot detecta daca este sau nu asa ? un aparat de masurat sau ceva care imi poate confirma acest lucru ? si pe care dintre pinii din mufa sa pun aparatul...multumesc!
Salut, pe un Passat am si eu urmatoarea eroare, daca ma poate lamuri si pe mine cineva. Multumesc.
Controller: 1C0 959 799 B
Component: 7X Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 05311
Modulul de confort nu comunica cu cesurile de bord. Eroarea se poate sterge ?
Salut, la scanare pe un Passat 2006 2.0TDI PD apar urmatoarele:
Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
Control Module Part Number: 5M0 907 357 HW: 5M0 907 357
Component and/or Version: AFS-Steuergeraet X016
Software Coding: 0000001
Work Shop Code: WSC 10161 599 84649
Additional Info: 7L6941329 AFS-Lst.-Modul l X018 ID-R fehlt AFS-Lst.-Modul r ....
VCID: F1ED51F79369
5 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Time Indication: 0
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Time Indication: 0
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Time Indication: 0
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Time Indication: 0
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 184695 km
Time Indication: 0
Date: 2000.00.00
Time: 13:38:51
Am incercat sa codez dar nu reusesc sa modific nimic.. in bord clipeste becul galben (AFS inoperative), farurile stau aprinse dar sunt blocate in jos.
Raman dator daca stie cineva ce pot sa fac.
Nu poti sa faci nimic pana nu rezolvi problema cu calc de far din dreapta. scahimba-l cu cel din stanga si vezi daca se muta eroarea. daca se muta, schimba calc in cauza.
Salutare.
Problema mea e urmatoarea: se aprinde martorul "robinetul galben" cel de emisii de gaze si la scanarea cu VAS imi da eroarea V157. care ar fi problema? si cum se remediaza???? Multumesc
Mentionez ca aprinderea martorului nu e in mers ci la punerea contactului si ramane aprins. Masina trage perfect, se duce in turatii, ajung la 150-160km/h fara probleme.
Modificat de sorin_mon
Clapeta de shut-off. Verifica intai siguranta care o alimenteaza. Sau vezi daca merg ventilatoarele la cuplarea AC, daca merg , siguranta e buna. Daca nu e capsulata, desfa-o si vezi ce e inauntru. Tot la schimbarea ei o sa ajungi.
Salut. Unui coleg de serviciu cu un Audi A6, 2002, 2.5 TDI, nu-i mai porneste masina (banuim ca e pompa de motorina din rezervor- cu umplerea manuala a filtrului de motorina a pornit o data). Am incercat sa o scanez cu VCDS 11.3 si nu ma pot conecta pe Engine. Am incercat cu un Autoscan, dar vad ca tot lipseste Engine-ul din log, aveti idee de ce? Mutumesc.
Log-140220km-87128mi.txt
Probleme la cutia automata - verifica in prima faza nivelul lichidului. Mai multe ai aici si aici.
Nu de la cutie nu-i porneste masina. In scanare se vede ca ECU nu este alimentat sau e defect si nu raspunde. Verifica tensiun ile de alimentare ale ECU conform schemei electrice.
Problema este ca a pornit cand a pus motorina in filtru (greu, dar a pornit). O sa o duca la service azi si o sa vada mecanicii care este problema. Eu doar am vrut sa o scanez, sa vad daca are vreo eroare pe engine, dar nu s-a putut. Multumesc pentru sfaturi. Salutare.
F l o r i n
da, nu s-a putut, ca nu-l vede. Nu-l vede, ca nu primeste tensiune (banuiesc ca verificarea sigurantelor si a releului de alimentare a fost facuta - daca nu, faceti) sau e mort....
  • Aerofan pinned this topic
    • Gabi219
