zorg
simptomul de la Adress 42, l-am gasit discutat dar nu si lamurit aici insa celelalte erori nu le-am gasit
...apropo, chiar pe acest topic, intreba cineva acum cativa ani daca este fisier .lbl pt motorul 2.0 tdi, bkp, 103 kw...a gasit careva?
Modificat de giga_3310
Buna ziua. Am un audi a4 b6 2001 1,9 tdi tip motor awx.si la vag com am gasit aceste erori
2 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: 0 0 X X X
00975 - Heated Rear Window (Z1)
31-10 - Open or Short to Ground - Intermittent
17994/P1586/005510 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
Possible Causes
* Wiring/Connectors from/to Engine Mount Solenoid Valves (N144/N145) faulty
* Engine Mount Solenoid Valves (N144/N145) faulty
Possible Solutions
* Check/Repair Wiring/Connectors from/to Engine Mount Solenoid Valves (N144/N145)
* Check/Repair Engine Mount Solenoid Valves (N144/N145)
Engine Mount Solenoid Valves (N144/N145) = Suportii de la motor (N144/N145).
Verifica-i si verifica si mufele/firele care intra in mufe.
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
* Reduced power output
* Limp mode
Possible Causes
* Boost Pressure too High
* Hoses/Pipes incorrect connected, disconnected, blocked or leaking
* Charger Pressure Control defective
o VNT (variable nozzle turbo): nozzles stuck
* Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
* Check Hoses/Pipes to/between Components
* Check Solenoid Valve for Boost Pressure Control (N75)
* Check / Clean / Replace Charge Pressure Control
o Check / Clean mechanism for variable nozzles
Cred ca e vorba de incalzirea lunetei. Vezi tensiuni de alimentare,contacte, fire, sigurante.
Modificat de cuiuda
Multumesc de raspuns La prima eroare cred ca e de la suportii motor ca sunt distrusi, dar o problema mai mare ar fi a doua eroare. As vrea sa curat turbina, iar la a treia eroare nu stiu ce as putea face in afara de verifict sigurante.Cu respect.
Buna seara,
va rog,daca se poate,sa imi spuneti si mie mai exact ce inseamna urmatoarele erori aparute la test:
X431 DIAG Report
SMARTBOX: 980640556400
DATA: 1/19/2011
01166 Engine Torgue Signal sporadic-Signal outside tolerance
01314 Engine Control Unit sporadic-No communication
01316 Brake Control Unit sporadic-No communication
00652 Gear Monitoring sporadic-Implausible signal
Mentionez ca masina(VW Sharan 2001,1.9 TDI Tiptronic) are ceva probleme la cutie:la rece,nu schimba;se tureaza motorul la maxim si nimic iar la cald e ceva mai bine,adica ajunge pana la viteza a4a dar cu acceleratia foarte incet calcata.
Va multumesc pentru ajutor si imi cer scuze daca nu se intelege din explicatia mea dar nu prea ma pricep la masini. :scratch:
01166 - Engine Torque Signal: Signal Outside Specifications
Possible Solutions
Check Engine Control Unit (ECU) for fault codes
01314 - Engine Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in Engine Control Module
Engine Control Module recently flashed or re-mapped
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Engine Control Module
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
00652 - Gear Monitoring
00652 - Gear Monitoring: Implausible Signal
Possible Causes
Automatic Transmission Fluid (ATF) Level not OK
Vehicle Speed Sensor (G68) dirty/faulty
Impulse Wheel dirty or Installation faulty
Gearbox Speed Sensor (G38) dirty/faulty
Multi-Function Switch (F125) faulty (but not detected)
Clutch or Valve Body faulty
Automatic Transmission Fluid (ATF) Pump faulty
Possible Solutions
Check Automatic Transmission Fluid (ATF) Level
Check/Clean/Replace Vehicle Speed Sensor (G68)
Check/Clean/Replace Gearbox Speed Sensor (G38)
Check/Replace Multi-Function Switch (F125)
Check/Replace Clutch and/or Valve Body
Special Notes
The ratio of engine speed to gearbox output speed in the currently engaged gear is implausible.
Slip rpm with torque converter lock-up clutch disengaged must be greater than stall speed.
Multumesc frumos @liviuplaton,specificatiile astea le-am gasit pe ross-tech dar,ma gandeam,daca as putea primi ceva informatii mai clare,cam care ar fi problema mai exact.
De zile intregi caut pe internet si sun mecanici de prin toata tara si nu am primit nici un raspuns mai exact de la nimeni.Doar preturi pentru reparatie-de la 1500 euro in sus.
De platit,reparatia trebuie platita oricum si oricat,ca asta este dar nu mi-a spus nimeni,mai exact:are asta,asta...
O seara buna la toata lumea!
marcel_george2005
3 Faults Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - - - Intermittent
Freeze Frame:
RPM: 2478 /min
Torque: 160.0 Nm
Speed: 88.0 km/h
Load: 54.1 %
Voltage: 14.44 V
Bin. Bits: 11000000
Absolute Pres.: 1907.4 mbar
Absolute Pres.: 1499.4 mbar
18000 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
P1592 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 8.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00000100
Absolute Pres.: 938.4 mbar
Absolute Pres.: 714.0 mbar
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 000 - -
Freeze Frame:
RPM: 1764 /min
Torque: 0.0 Nm
Speed: 64.0 km/h
Load: 0.0 %
Duty Cycle: 96.8 %
Bin. Bits: 11000000
Mass Air / Rev.: 235.0 mg/str
Mass Air / Rev.: 380.0 mg/str
Readiness: 1 2 0 0 0
ma poate ajuta si pe mine cineva cu un sfat ce poate fi ... imi apare eroare o sterg cu vag-com`ul si reapare in 50 de km
masine e o skoda octavia 2 1.9 tdi-pd
masina trage la fel doar ca nu scap de eroarea din bord
Imi puteti spune si mie ce val trebuie sa aiba injectoarele la relanti si la turatie masurate cu vag com ul la masina din semnatura .
Va multumesc mult
@alinboblea - cat mai aproape de zero (compensarile la relanti trebuie safie intre -2,8/ +2,8)
La mine la relanti e 0 iar la acceleratie undeva la 1,8 inseamna ca e bine ?
Multumesc pt raspuns pronet
Modificat de alinboblea
Ajutati-ma va rog ca sunt disperat.Pe la ora 10 am scos siguranta de la pompa de motorina crezand ca e de la luneta care nu mai mergea si am pus-o mai jos in alt loc.Am plecat cu masina fara siguranta de la pompa si dupa aproximativ 2 km parca s-a terminat motorina si mi s-a oprit masina. Nu am mai reusit sa o pornesc si e ora 17.Intre timp am pus sigurnta la loc si am scos furtunul de la filtru sa vad daca atunci cand pun contactul mai vine motorina, si totusi motorina vine.Electromotorul se chinuie dar masina nu porneste si gata. Acum va intreb ce ar putea fi, ca eu am un tester si erori mi-a dat 2 la airbag si una - high pressure sensor open or short to plus intermittent. Cu respect va intreb ce ar putea fi dus, mai exista vreun releu la pompa de motorin sau ce.
am scos furtunul de la retur si a iesit mult aer dar masina tot nu porneste.La tester nu a iesit mai nimic
00819 - High pressure sensor G65
00779 - Outside Air Temp Sensor G17
Ce as mai putea face?
Am scanat masina unui coleg de forum si am gasit urmatoarele erori impreuna cu becul aprins in bord emision workshop:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 FS HW: 028 101 195 5
Component: R4 1,9L EDC 0000SG 6124
Revision: 12345678 Serial number: VWZ7Z0E1960458
Coding: 0000071
Shop #: WSC 66565 257 00032
3 Faults Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000000
Temperature: 13.5
cum as putea amorsa si sa scot tot aerul de pe instalatie la audi a4 2001 1.9 tdi .Va rog cu o informatie.
Am si eu o eroare la masina din semnatura :
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 M HW: 3C0 614 095 M
Component: ESP 440 C2 H015 0001
Revision: H015 Serial number: 0657571731
Coding: 0013569
Shop #: WSC 00028 028 00001
02840 - Wake-Up Line from Central Convenience Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 27
Time Indication: 0
Daca porneste se aeriseste singura, eu la golf 4 cand am ramas fara motrina am pus pe cineva sa de la automat si cu o siringa mare tragem pe retur inainte de filtru si porneste destul de usor,bafta.
02840
ro semnal de s
alex ia un spray de pornire scoate furtunu de la admisie si go (tii din spray pana se amorseaza)
Va multumesc tuturor, am rezolvat cu aerul din instalatie.Dupa ce am scos furtunul de retur de la filtru de motorina am dat la automat pana a iesit tot aerul.Dar am continuat sa dau cheie pana am terminat bateria si nu a pornit. A doua zi am venit cu bateria incarcata dar degeaba tot nu pornea , rezolvarea a venit de la cineva care mi-a spus ca trebuie apasata acceleratia sa se descchida o clapeta pentru a trece motorina ,dupa care miraculos a pornit.Am rezolvat fara nici un ban. Multumesc ca m-ati ascultat.-pentru motor pompe duse
MAi intreaba-l ce clapeta se deschide cand apesi acceleratia sa treaca motorina ..... Ca de dus cu zaharelul e usor. Pedala e DBW, adiva la ea sunt doar fire electrice care duc la ECU.
HELP !!!!!
ma ajuta si pe mine cineva cu asta va rog ?
nu reusesc sa gasesc codurile astea .
poate ma scoate cineva din necaz .
ajutati va rog un om in necaz .
am postat alaturat rezultatul scanarii . Multumesc anticipat .
Thursday,27,January,2011,18:18:38:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 4F0
Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62
72
VIN: Mileage: 253590km/157573miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300084250
Coding: 0000001
Shop #: WSC 78646 150 80799
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H36 0040
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 1
Mileage: 252825 km
Time Indication: 0
Date: 2010.12.30
Time: 07:43:19
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000071784
Part No: 4F0 915 105 B
Component: von MLA 0410250433
Coding: 34463039313531303542204D4C4130343130323530343333
Shop #: WSC 00000 384 00290
4 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Time Indication: 0
Date: 2010.12.15
Time: 08:11:00
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 253516 km
Time Indication: 0
Date: 2011.01.24
Time: 08:13:14
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 253516 km
Time Indication: 0
Date: 2011.01.24
Time: 08:13:24
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 253516 km
Time Indication: 0
Date: 2011.01.24
Time: 08:13:34
BAte3rie slaba sau masina nu incarca.
@ cristian7481
Erorile respective (0227x - Quiescent Current Stage x) sunt generate de calculatorul de management al bateriei - iti taie unii dintre consumatori pentru a mentine un nivel de incarcare al bateriei - verifica bateria (daca mai e buna sau nu), verifica sa nu ai scurgeri de curent. Daca ai schimbat bateria, vezi ca cea noua trebuie adaptata pe masina - calculatorul de management o vede tot pe cea veche.
Modificat de pronet
va rog sa ma ajuta ti si pe mine ca e prima oara cand scriu pe acest forum pana acum doar am citit pareri.am achizitionat de curand o interfata vag si am dat un auto scan la jetta mea 1.9 TDI si am gasit o erroare pe care nu o sterge vreau si yo niste pareri
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Part No SW: 1K0 920 873 B HW: 1K0 920 873 B
Component: IMMO 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4484711
Shop #: WSC 00000 000 00000
VCID: 2B5E05F2B55F2644
1 Fault Found
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Mileage: 73123 km
Time Indication: 0
Date: 2000.00.00
Time: 14:22:50
  • Aerofan pinned this topic
    • samiii
