zorg
012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 006 - short to plus- Intermittent
Short to plus inseamna circuit deschis, deci pe undeva pe traseul ECU-clapeta sau chiar in clapeta e un circuit intrerupt,
Salut am problema cu codarea noului modul de la usa sofer este vb de primul din cele 4 Address 46: Central Conv. Labels: 1J0-959-799.lbl
LA g4 NU se codeaza calc de usa.
ms mult. sa inteleg ca alta solutie nu ar mai fi...
La un vw golf din 2000, 1,9 motor ALH, am o eroare motor si nu stiu ce sa fac!!! De ceva timp sta pompita galbena aprinsa si nu reusesc sa o sting cu vag-ul. Nici motorul nu merge cum trebuie..mai mult de 120 km/h nu se mai duce deloc..Ma poate ajuta cineva cu un sfat privind ce defecte ar putea fi?
La scanare imi da urmatorul lucru:
VAG-COM Version: Release 704.1
Data version: 20070422
Sunday,09,January,2011,09:47:02:59303
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 5657 75
76
Mileage:231920km/144108miles
Address 01: Engine Labels: 038-906-012.LBL
Part No: 038 906012 M
Component: 1,9l R4 EDC 0000SG 2813
Coding: 00002
Shop #: WSC 01317
3 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 -35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 -35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 -35-10 - - - Intermittent
Readiness: N/A
Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
Part No: 3B1 907044 C
Component:CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 01317
37-10 -Faulty - Intermittent
Address 17: Instruments Labels: 1J0-920-xxx-17.LBL
Part No: 1J0 920822 B
Component:KOMBI+WEGFAHRS. BOO V55
Coding: 01142
Shop #: WSC 72834
Part No: Ident
Component: Nr.WEGFAHRS.:VWZ6Z0X1092962
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1092962
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-10 -Open or Short to Plus - Intermittent
00534 - Engine Oil Temperature Sensor (G8)
30-00 -Open or Short to Plus
Address 36: Seat Mem. Drvr Labels: None
Part No: 1J0 035152 B
Component: Radio 0002
Coding: 00001
Shop #: WSC 31414
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00- -
00856 - Radio Antenna
36-00 -Open Circuit
Address 56: Radio Labels: 1J0-035-15x-56.LBL
Coding: 00001
Shop #: WSC 31414
2 Faults Found:
00-00- -
36-00 -Open Circuit
La scanarea in mers mi-a dat urmatorul log:
LOG-01-003-010-011.txt
Actuator sau geametrie variabila blocata sau valva de comanda actuataor sau lipsa vacuum.
Salutare baieti. Am si eu o problema, astazi am scanat un Vw Touareg, an 2006, 2.5 TDI, caruia ii ramasesera pernele de aer blocate jos masina fiind foarte rigida.
In urma diagnozei au aparut urmatoarele coduri:
VCDS Version: Release 10.6.1
Data version: 20100831
Sunday,09,January,2011,07:28:17:20398
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ6D049778 Mileage: 96810km/60154miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 BL HW: 028 101 185 9
Component: R5 2,5L EDC G001AG 7001
Revision: 12345678 Serial number: VWZ3Z0E1443646
Coding: 0011175
Shop #: WSC 66565 257 00032
VCID: 5BBE9081E357
No fault code found.
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 DQ
Component: AL 750 6A 0780
Coding: 0004200
Shop #: WSC 31414 000 00000
VCID: 800407EDAA71
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0006402
VCID: 3D7A3E191D03
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 HW: 5WK 484 94
Component: Kessy 6700
Revision: 67005915 Serial number: VWZ3Z0E1443646
Coding: 0000232
VCID: E6C83175A815
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 040 L
Component: CLIMAtronic R/L 4017
Coding: 0000030
VCID: 39722A09092B
Address 09: Cent. Elect. Labels: 7L6-937-049.lbl
Part No: 7L6 937 049 M
Component: 3001
Coding: 0103676
VCID: 468851F548D5
2 Faults Found:
00907 - Intervention load Management
000 - -
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0V Airbag 8.4E+ H10 0951
Coding: 0012374
VCID: 254AF6799593
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 H
Component: Lenks
Bogdan ,verifica si siguranta f24 ,la mine asta a fost,si se afla in cutia de sigurante de langa motor.eu am schimbat clapeta aia si n-a disparut eroarea din bord pana n-am schimbat si siguranta f24 care era si puscata de altfel.am mai citit pe net ca ei zic de siguranta f8 dar la bkd-ul meu a fost 24.bafta
Modificat de mejdelicious
De aici si eroarea in bord legata de ulei?
Multumesc mult..
Si care e eroarea? Clapeta se inchide la oprirea motorului? In general intra uei la partea electrica si nu mai ai ce sa-i faci.
Posibil sa fii nevoit sa inlocuiesti componenta.
Alta solutie??:) ms.
Multumesc mult..
Nu are legatura
Modificat de Al Bundy
Salutare! La masina din profil, de aproximativ doua saptamani intampin o problema asemanatoare cu cea a lui Cyp88.
La fiecare punere a contactului dupa o noapte de ninsoare/inghet, martorii ABS si ESP raman aprinsi iar cele 2 sisteme evident inceteaza sa mai functioneze odata cu pornirea motorului.
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 01317 785 00200
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit
Poate sa-mi spuna cineva daca pozitia senzorului ABS pt stanga fata la Bora este cea de sus, fix langa etrier, precum in poza de mai jos? Am observat ca mai exista o mufa si un senzor aproape identic pe partea dreapta a discului, chiar in spate langa scutul de praf.
De pe mufa din dreapta lipseste o bucata destul de mare de plastic si a trebuit sa improvizez o izolatie dupa ce am curatat-o de noroi si alte reziduuri. Cred ca trebuia sa ma concentrez mai mult pe mufa din poza de mai jos si nu pe cea din dreapta.
Desi le-am curatat pe amandoua si am izolat-o pe cea din dreapta, ABS-ul a dat din nou eroare; dupa vreo 10-15 km de condus, ABS-ul si ESP-ul functioneaza fara nicio problema.
Baterie slaba sau mufa/senzor/cablaje defecte? :vaidecapulmeu:
Multumesc colegului dbk pt ajutor!:icon_thumright:
Modificat de robert03
mufa din poza de langa etrier este mufa pt senzorul de uzura placute.... deci e mufa din parte dreapta a discului si intra in fuzeta
Multumesc mult..
Ai fir intrerupt sau sonda defecta
Mersi pentru confirmare, Swat Cat! Ai o bere fara alcool din partea mea daca ne intalnim vreodata.
Pe cea care intra in fuzeta am izolat-o; sau cel putin asa sper ca am reusit sa fac. N-am apucat sa verific daca am rezolvat problema sau nu dar mai e in plan si un alt test referitor la baterie slaba sau senzor defect.
am facut un alt log , puteti arunca o privire la el
astept parerile voastre
De ce postezi aceleasi loguri in doua topic-uri diferite? Se considera spam de catre regulament. Citeste-l, inainte sa folosesti acest forum.
Salut,am o intrebare la voi cei mai priceputi in asa ceva am facut o scanare la un prieten cu un passat tdi b5 si au iesit urmatoarele erori
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ2P118163 Mileage: 139140km/86457miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 EM
Component: 1,9l R4 EDC 0000SG 1368
Coding: 00005
Shop #: WSC 00028
WVWZZZ3BZ2P118163 VWZ7Z0A3923111
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D10
Shop #: BB 24548
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0006
Coding: 17000
Shop #: WSC 00028
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 02
Coding: 12353
Shop #: WSC 00028
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 826 A
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05115
Shop #: WSC 00186
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 00028
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 15 Komfortger
Stie cineva ce ar putea fi la vitezometru , nu indica viteza, atunci cand aprind pozitiile functioneaza
VW Golf 4 - 1.6 - 2002
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17962 - Throttle Actuator (J338): Conditions for Basic Settings not Met
P1554 - 35-10 - - - Intermittent
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
17912 - Intake Air System: Leak Detected
P1504 - 35-10 - - - Intermittent
Ma intereseaza 17961 daca ma poate ajuta cineva..
Multumesc anticipat.
o scanare cu VAG-COM unde se poate face in brasov?Sau colegi care au cablu soft etc?GASIM PLS?MERCI
Nimeni ,nici o sugestie pentru ce am postat mai sus la postu 3140?
Pentru eroare asta:
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Control Module Part Number: 1Z0 907 044 H
Component and/or Version: ClimatronicPQ35 084 0305
Software Coding:
Work Shop Code: WSC 00000 000 00000
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
Am fost cu prietenul meu care a problema de mai sus la cineva care repara compresoare si a verificat electrovalva. Respectivul zice ca de la aia ar fi. Am masurat si eu cu el la alte compresoare pe care le reparase si rezistenta electrovalvelor (functionale) era undela intre 10.3 si 11 ohmi.
Va intreb(pe cei care se pricep): eroarea de mai sus poate fi data de o electrovalva defecta(rezistenta ei intrerupta)?
Si rezolvarea? sau doar postezi ca sa te afli in treaba?
In alta ordine de idei: am verificat sigurantele, am alimentat direct(cu fir de la baterie) electrovalva, dar nu cupla.
Eu intreb sa fie eroare de short to plus de la electrovalva defecta?
  • Aerofan pinned this topic
    • jangabrieldrind
