zorg
DanuAL cred ca cel mai important e debitmetru, egr lasa sa treaca prea mult aer deci el nu se deschide, ori nu ii vine vacum ori e blocat, nu stiu in ce membrana ai umblat tu dar cred ca nu ai nimenit ce trebuia, egr este din metal cred ca ai umblat la alta supapa din ce mi-ai zis.
uite aici ai ceva pt eroari :
Possible Symptoms
Malfunction Indicator Light (MIL) active
Limp Mode active
Possible Causes
Wiring from/to Boost Pressure Sensor (G31) faulty
Ground Spots corroded
Possible Solutions
Check Wiring from/to Boost Pressure Sensor (G31)
Check Ground Spots for Corrosion
Check Boost Pressure Sensor (G31)
16786/P0402/001026 - Exhaust Gas Recirculation (EGR): Excessive Flow
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Reduced Exhaust Gas Recirculation (EGR)
Reduced Power Output/Engine running rough
Increased Emissions
Possible Causes
Exhaust Gas Recirculation (EGR) Valve stuck open/leaking/faulty
Exhaust Gas Recirculation (EGR) System leaking/faulty
Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
Possible Solutions
Check/Clean Exhaust Gas Recirculation (EGR) System
Check/Replace Exhaust Gas Recirculation (EGR) Valve
Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
16485/P0101/000257 - Mass Air Flow Sensor (G70): Implausible Signal
Possible Symptoms
Loss of Power
Erratic Idle
Possible Causes
Mass Air Flow Sensor (G70) faulty
Air Leak(s) after Mass Air Flow Sensor (G70)
Intake Air Filter dirty/faulty
Ground Spots corroded or Paint Residue
Wiring and/or Connections from/to Mass Air Flow Sensor (G70) faulty
Possible Solutions
Check Intake Air Filter
Check Mass Air Flow Sensor (G70)
Check Ground Spots
Check Wiring and/or Connections from/to Mass Air Flow Sensor (G70)
Deci sterge vezi ce apare si in ce conditii , curata egr vezi furtunase sa nu fie scoase pooate chiar din turbina sa sara cu toate ca are colier mic, cauta in mufa de la debitmetru sau map daca nu cumva e apa sau ceva corodat, sterge cauta cum se face un log in mers si vezi cum sta treaba.
Mecanicul ala care ti-a zis ca ai cutia cu valve sau ec ai zis acolo stia de erori sau a vorbit asa .
Cauta alta masina si incearca alt debitmetru...
Bafta!
Modificat de gabriel
Merci @Gabi! Am dat EGR-u jos si ii praf. Nu mai tine vaccum. 1400ron costa unul nou. Prima eroare cred ca se datoreaza pornirii motorului fara sa-i fi pus tubulatura de la/pana la filtru de aer (cea cu debitmetru).... Mecanicu stia de erori, insa nu era sigur daca e de la EGR sau de la cutia cu electrovalve. Cu debitmetru de aer, e o poveste veche, poate-ti amintesti si tu de discutie ..firul care alimenteaza MAF'ul, e tras din alta parte ... cu problema debitmetrului in fapta, masina mergea bine, acum parca's iesit la pensie, de cand cu EGR'u vietzzzi. Merci :cool:
Am si eu o eroare nou aparuta pe lista :
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0101
Coding: 0000012
Shop #: WSC 73430 790 00000
4 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Citind pe forumurile din grupul VAG e o problema cu contactul de pornire. A mai intalnit cineva situatia? Sfaturi?
Multumesc anticipat.
cine imi poate face si mie o diagnoza vag com in IASI? va rog mult
Am gasit astazi 2 coduri noi :
00096 - drivers door central locking (safe) motor (v161) 012 electrical fault in circuit.
si
00928 - locking module for central locking; front driver side (F220) 008 - implausible signal.
Oare vrea sa spuna ca este undeva un scurt pe circuit? Daca da cum se poate verifica unde este problema?
Multumesc frumos.
00096 - Drivers Door Central Locking (Safe) Motor (V161): Electrical Fault in Circuit
Possible Symptoms
Door Locks (Safe Function) not working properly
Possible Causes
Wiring/Connectors from/to Drivers Door Central Locking (Safe) Motor (V161) faulty
Voltage Supply for Drivers Door Central Locking (Safe) Motor (V161) faulty
Possible Solutions
Check Wiring/Connectors from/to Drivers Door Central Locking (Safe) Motor (V161)
Check Voltage Supply for Drivers Door Central Locking (Safe) Motor (V161)
Check Drivers Door Central Locking (Safe) Motor (V161)
Special Notes
Possibly stored in combination with 00928.
00928 - Locking Module for Central Locking; Front Driver Side (F220): Implausible Signal
Possible Symptoms
Door Locks not working properly
Possible Causes
Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220) faulty
Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220) faulty
Door Lock Mechanics are stiff/partially seized
Possible Solutions
Check Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220)
Check Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220)
Check Door Lock Mechanics/Operation
Check Locking Module for Central Locking; Front Driver Side (F220)
Multumesc frumos. Merg acum sa gresez mecanismul portierei, poate are ceva praf, desi in Romania de unde praf?Poate atunci cand am mers prin Germania cu masina sa fi prins ceva particule.Nemtii astia cu praful lor.
:Driver:
si
Multumesc frumos.
Desfa broasca si refa lipiturile si curata motorasul de la inchiderea de la usa soferului.
Schimba partea electrica a contactului.
Multumesc frumos. Am pierdut de ceva vreme garnitura de cauciuc care este montata pe prag si unde intra o bucata mica din partea de jos a portierei. Am vazut ca la G6 s-a schimbat sistemul si pragul nu mai este gaurit, fiind montat in partea de jos a portierei un distantier de cauciuc. Am comandat garnitura respectiva, si daca nici dupa montarea acesteia nu se schimba nimic va urma desfacerea, verificarea si curatarea.
Cred ca si micile erori mai vechi ale inchiderii centralizate din interior tot de aici sunt, deoarece dupa blocarea usilor din interior la deblocare portiera stanga ramanea blocata, insa deschiderea acesteia aprindea luminile de interior si martorul din bord pentru usa deschisa.
Acum functioneaza perfect sistemul lock/unlock, insa nu mai vede ECU portiera stanga deschisa.
Mii de multumiri, zi faina sa aveti.
buna seara!
am si eu cateva coduri de eroare, pe care nu stiu sa le interpretez....
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 M
Component: 1,9l R4 EDC 0000AG 2813
Coding: 00001
Shop #: WSC 65535
3 Faults Found:
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-00 - -
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 01317 785 00200
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
01315 - Transmission Control Module
004 - No Signal/Communication
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 27 AIRBAG VW5 01 0006
Coding: 12855
Shop #: WSC 01317
9 Faults Found:
00595 - Crash Data Stored
35-00 - -
01214 - Crash Data for Belt Tensioner Stored
35-00 - -
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
32-00 - Resistance too High
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
29-10 - Short to Ground - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 805 E
Component: KOMBI+WEGFAHRS. BOO V12
Coding: 01112
Shop #: WSC 00000
Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0A3345334
Ident.-Nr. WEGFAHRS.:VWZ6Z0A3345334
No fault code found.
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 2H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
Part No: 1J1959801C
Component: 2H T
Turbo - face suprapresiune, senzor temperatura , senzor abs dreapta spate, airbag - storat crash data ,,, , incalzire oglinda sofer si inchidere pasager.
dupa ce ai sters care au ramas ?
Pe masina unui amic, un Audi A4 B7 din 2006 cu motor 2.0 TDI BLB am gasit la o scanare urmatoarea eroare:
17056- (Cylinder 2 Glow plug circuit (Q11))
Problema e ca din pacate masina nu mai poate fii pornita, deloc :)
Any ideas ?! :)
Mihai, verifica cablajul/ bujia de pe cil. 2:
17056/P0672/001650 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug Wiring faulty
Glow Plug faulty
Possible Solutions
Check Glow Plug Wiring
Check Glow Plug
sau
http://forums.tdiclub.com/showthread.php?t=79819
Verifica si siguranta din compartimentul motor.
Modificat de pronet
Nu are treaba pornirea ta cu eroarea aparuta .
Vezi si alimentarea cu combustibil.
Problema e ca din pacate masina nu mai poate fii pornita, deloc :D
Any ideas ?! :unsure:
Spira se aprinde cand pui contactul ?
Cred ca se aprinde - vad ca i-a acceptat diagnoza pe motor: 17056- (Cylinder 2 Glow plug circuit (Q11)
salutare. cine imi da si mie un manual/lista cu erori depistate de vag com 908.?
are cineva manual de utilizare in limba romana pt. vag com 908?
mersi mult.
Salutare!
Am un Golf 4 si ceva este in neregula cu inchiderea centralizata, nu deschid toate usile din cheie, numai usa dinspre sofer (nu am telecomanda). Dupa ce pun contactul si apas pe butonul de descuiere pr maner, se deschid toate usile. Masina a fost scanat cu vag-com si a dat urmatoarea cod de eroare:
1 cod a găsit
01031 - Contact cheie sofer : descuiat
29-00 - scurt la masă
Puteti sa-mi ajutati cu niste sfaturi?
Lipituri "reci" in broasca !
salut
Am si eu 2 erori aparute si nu stiu sa le interpretez,ma puteti ajuta ?
Address 01: Engine
Control Module Part Number: 028 906 021 CK
Component and/or Version: 1.9l R4 EDC G00SG 0802
Software Coding: 00002
Work Shop Code: WSC 05311
2 Faults Found
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
01237 - Fuel Shut-Off Valve (N109)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
00575 - Intake Manifold Pressure: Control Difference
Possible Symptoms
* Reduced Power
Possible Causes
* Solenoid Valve for Boost Pressure Control (N75) defective
* Hoses incorrect connected, disconnected, blocked or leaking
Possible Solutions
* Check Solenoid Valve for Boost Pressure Control (N75)
* Check Hoses
01237 - Fuel Shut-off Valve (N109)
Possible Symptoms
* Limp mode
* MIL
Possible Causes
* Wiring and/or connections faulty
* N109 faulty
Possible Solutions
* Check wiring and connections
* Check/replace N109
Cum se poate vedea consumul de benzina la un golf 1,4 cu vag-comul?
DPF-ul e imediat dupa iesirea de evacuare al motorului. Arata ca o toba de esapament. G450 e sub rezervolrul de lichid de racire... deci e posibil ca senzorul sau conectorul lui sa se fi contaminat cu lichid. Trebuie curatat/inlocuit.
O poza se poate cu pozitionarea senzorului G450 ? Multumesc anticipat!
LA ce masina si ce motor ?
  • Aerofan pinned this topic
