zorg
Daca ai interfata fa un log in mers si vezi cum lucreaza debitmetrul si turbo, basta.
Am facut o scanare cu VAG COM-ul si pe un passat b5, 1.9 TDI, motor AHU, si iata ce am obtinut:
Address 01: Engine Labels: 028-906-021-AHU.lbl
Part No: 028 906 021 GK
Component: 1,9l R4 EDC 00AG 1445
Coding: 00001
Shop #: WSC 05319
2 Faults Found
01268 - Quantity Adjuster (N146)
35-10 - - - Intermittent
65535 - Internal Control Module Memory Error
37-10 - Faulty - Intermittent
Readiness: N/A
Address 08: Auto HVAC Labels: 1J1-907-044.lbl
Part No: 1J1 907 044
Component: CLIMATRONIC S 5.0
Coding: 02000
Shop #: WSC 05319
1 Fault Found
00792 - A/C Pressure Switch (F129)
35-00 - -
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 8L0 959 655 A
Component: Airbag VW 3-S V02
Coding: 00065
Shop #: WSC 05311
3 Faults Found
01221 - Crash Sensor Side Airbag; Driver Side (G179)
36-10 - Open Circuit - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance too High - Intermittent
44-10 - Short Circuit - Intermittent
Address 46: Central Conv. Labels: 3B0-959-79x-46.lbl
Part No: 3B0 959 798 G
Component: Zentral-SG Komfort V43
Coding: 00257
Shop #: WSC 05311
7 Faults Found
01329 - Convenience System Data Bus in Emergency Mode
00931 - Locking Module for Central Locking; Rear Right (F223)
27-00 - Implausible Signal
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Ma poate ajuta cineva cu interpretarea lor?
Possible Symptoms
A/C System not working
Possible Causes
A/C System Malfunctions
Over or insufficiently charged
Refrigerant System blockage
Insufficient Air Flow to Condensor and/or Engine Radiator
Wiring to/from A/C Pressure Switch (F129) faulty
Possible Solutions
Check A/C System for Malfunctions
Check Wiring to/from A/C Pressure Switch (F129)
Check A/C Pressure Switch (F129)
01221 - Crash Sensor Side Airbag; Driver Side (G179): Open Circuit / Short to Plus
Possible Symptoms
Airbag Warning Light ON
Possible Causes
Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) faulty
Airbag Control Module (J234) faulty
Possible Solutions
01218 - Side Airbag Igniter; Front Passenger Side (N200): Resistance too High
Possible Symptoms
Malfunction Indicator Lamp (MIL) active
Possible Causes
Wiring/Connectors from/to Side Airbag Igniter, Front Passenger Side (N200) faulty
Possible Solutions
Check Wiring/Connectors from/to Side Airbag Igniter, Front Passenger Side (N200)
Check Side Airbag Igniter, Front Passenger Side (N200) faulty
Check Measuring Value Blocks (MVB)
Special Notes
When found in the NAR '05 -> '07 Jetta, Rabbit, Eos and Passat, Please See TSB 69-08-02 / 2011271.
Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179)
Replace Crash Sensor Side Airbag; Driver Side (G179)
Replace Airbag Control Module (J234)
Possible Causes
Control Module housing leaky > Control Module wet
Wiring from/to Control Module faulty
Possible Solutions
Check/Clean Wiring from/to Control Module
Replace Control Module
Special Notes
This fault is NOT to be ignored when found in a major and/or critical system (Airbag, ABS etc.).
When stored in other unimportant systems (Radio etc.) the general suggestion is to ignore it unless you notice functional limitations. Within the warranty period dealers are usually required to replace such control modules, but there have been a couple of cases with similar codes where these are getting ignored due to flaws in the control module software. If in doubt please refer to technical bulletins and similar documents provided by the vehicle manufacturer.
Audi Airbag 6 & 7
Problem: A fault of the acceleration sensor may result in the above fault.
Solution: Replace Airbag control module and both acceleration sensors.
Audi Airbag 8
Problem: Due to under voltage the control module does not complete it's self test successfully.
Solution: Replace Airbag control module and install a under voltage protection relay for it.
Certain older TDI ECUs which have a vacuum line going to them
Problem: Vacuum line broken, either before ECU or inside ECU.
Solution: Inspect and repair vacuum lines to ECU and inside ECU.
Address 42: Door Elect, Driver
Control Module Part Number: 1K0 959 701 P
Component and/or Version: J386 TUER-SG FT 1133
Software Coding: 0000180
Work Shop Code: WSC 00066
00109 - Left Mirror Turn Signal Lamp (L131)
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 13
Reset counter: 177
Mileage: 27702 km
Time Indication: 0
Am aceasta eroare care tot reapare pe ambele usi , sofer si pasager, de cand am montat alarma Viper5002 cu CANMAX400 pe CAN-ul masinii, ce mi se pare suspect este faptul ca are acelasi numar de aparitii pe ambele usi, la aceeasi numar de kilometrii si aceeasi frecventa de aparitii. Mentionez faptul ca, cand inchid din alarma mi se aprinde casetofonul si climatornicul pentru o scurta perioada de timp, iar uneori semnalizarile papaie la inchidere ca si cum ar fi un scurt undeva. Alte erori nu am, am facut teste cu VAG-ul pe portierele respective si nu sunt probleme. Daca aveti idei ce pot face.... sau de la ce poate fi.... Multumesc Anticipat.
Meseriasul care ti-a montato ce zice?
Am montat alarma la SANDRA Iasi iar nenea ala care a montat-o nu prea le are cu configurarile, setarile canmax-ului pe care le-am facut eu singur, inclusiv programarea. De cand am alarama am observat mai multe anomalii, de exemplu farurile parca palpaie si ele in intensitate , stopul de pe hayon la fel..... cred ca weekendul asta imi fac timp si scot ala de pe canul masinii...
Si eu am montat tot Viper 5002 dar cu modul CAN1 tot de la Directed. Nu au fost probleme de compatibilitate, deoarece modulul este produs de aceeasi firma ca si alarma Viper. Ulterior am facut si restul de legaturi intre alarma si modul, deoarece montatorii nu le-au legat. Nu am avut nici pana acum vreo eroare generata de alarma, modul sau montajul acesteia. Probabil la tine nu este compatibil modulul cu can-ul masinii sau cu alarma, sau nu au fost legate cum trebuie. Vezi pe topicul cu Viper 5002, ca gasesti acolo si persoane care se pricep sa le monteze, si poti primi si sfaturi ...
salutare ,
imi poate traduce si mie eroarea cineva care se pricepe?
apare tot timpul si daca o sterg !
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0002
Coding: 17000
Shop #: WSC 05311
multumesc anticipat !
Senzor de presiune de pe instalatia de clima , posibil sa fie defec senzorul sau sa nu ai destula presiune in instalatia de clima sau vreun contac oxidac, clima iti merge??
Sigur ca nu ii merge ...
Mergi la cineva , cum zice si colegul liviuplaton, sa iti verifice presiunea din instalatie ... iar daca e Ok - fugi si schimba switch .
Altfel - e rau cu caldura asta nu ? :))
Succes!
multumesc ca mi ai raspuns asa repede :)
clima nu merge daca masina sta pe loc si ventilatorul de clima nu porneste decat daca aplic lovitura cu coada ciocanului dar si atunci tot slab merge ventilatorul de abia se invarte :))
in rest daca masina e in miscare e ok , baga aer rece !
Intr-o parte zici ca nu baga rece / aici , in topicul de mai sus zici ca baga ....
Decide-te
De vreo saptamana ma tot sacaie o eroare de genu' "Emissions! Garage!" pe masina din semnatura...
La o verificare scurta cu VAG-ul, am dat peste urmatoarea eroare:
Control Module Part Number: 03G 906 021 DP
Component and/or Version: R4 1,9L EDC 000SG 7870
Software Coding: 0000071
Work Shop Code: WSC 00028
001025 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 85457 km
Time Indication: 0
Date: 2000.00.00
Time: 20:03:29
Freeze Frame:
RPM: 2016 /min
Speed: 48.0 km/h
Load: 29.8 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 245.0 mg/str
Mass Air / Rev.: 545.0 mg/str
Readiness: 1 1 0 0 0
Problema e ca degeaba am sterso, ca peste 2 zile iar mi-a aparut :(
Mai nou, ma sacaie zi de zi, indiferent daca merg prin oras sau extraurban...
La o mica cautare pe http://wiki.ross-tech.com, observ:
Exhaust Gas Recirculation (EGR) Flow restricted/clogged
Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty
Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
Exhaust Gas Recirculation (EGR) System faulty
Oare o curatare mai este eficace sau trebuie sa ma gandesc serios sa bag 500-600 RON (ca nici nu stiu cat costa) intr-un EGR nou ? :huh:
Astept cu nerabdare un raspuns din partea voastra.
:( safe
Modificat de Riddler
MAi intai incearca o curatare.
am si eu niste erori...ma poate ajuta cineva?
multumesc:
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 018 N
Component: 1,9l R4 EDC 00SG 1615
Coding: 00002
Shop #: WSC 05314
4 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
01262 - Solenoid Valve for Boost Pressure Control (N75)
31-00 - Open or Short to Ground
00553 - Mass Air Flow Sensor (G70)
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 15 -------------------------------------------------------
Controller: 1J0 909 607 A
Component: AIRBAG VW3 S V03
Coding: 00065
Shop #: WSC 05311
01221 - Crash Sensor Side Airbag: Driver Side (G179)
29-00 - Short to Ground
Address 17 -------------------------------------------------------
Controller: 3B0 919 861 J
Component: KOMBI+WEGFAHRS. MM4 V11
Coding: 04140
Shop #: WSC 00000
Ident.-Nr. Wegfahrs.:VWZ5Z0V9072030
00667 - Ambient Temperature Signal
30-00 - Open or Short to B+
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 F
Component: 0A Zentral-SG Komf.0001
Coding: 00257
Shop #: WSC 05311
5 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
00930 - Locking Module for Central Locking: Rear Left (F222)
00931 - Locking Module for Central Locking: Rear Right (F223)
01030 - Central Locking Key Switch: Driver Side: Lock
00928 - Locking Module for Central Locking: Front Driver Side (F220)
End -------------------------------------------------------
Incerca sa le stergi si sa vezi care mai apar, in mare imobilizatorul nu-ti recunoaste cheia ,probleme cu electrovalva N75 care comanda geometria variabila, debitmetru dus, sezorul de temperatura interioara , incerca un log in mers sa vezi cu lucreaza debitmetrul si N75, intai curata contactele cu sprei de contac, bafta.
Am gasit la masina mea, urmatoarea eroare:
17656 - Injection Start Regulation: Control Deviation
P1248 - 35-10 - - - Intermittent
Explicatiile gasite pe ross-tech:
Possible Symptoms
* Loss of Power at high Engine Speeds
* Engine difficult to Start
Possible Causes
* Start of Injection Timing Regulation not OK
* Injection Pump Control Range blocked/dirty (e.g. by Metal Particles)
* Engine has stalled / ran out of Fuel recently
* Wiring/Connectors from/to Injection Valve (N108) faulty
Possible Solutions
* Check/Adjust Injection Start
* Check Fuel Supply
* Check/Replace Fuse(s)
* Check/Repair Wiring/Connectors from/to Injection Valve (N108)
Singurele interventii asupra masinii care ar fi putut cauza eroarea sunt: schimbarea filtrului de combustibil si reglarea avansului injectiei (la reprezentanta mi l-au gasit ca fiind "retarded"). Am intrat cu vag-com-ul la TDI Timing iar pentru motorul meu (ALH) am gasit doua variante: "... >4.99" si "... 4.99>". Nu stiu insa care dintre variante e corecta. Atasez ambele variante rezultate, oricum nu par sa fie probleme (ba chiar daca varianta corecta e 4.99> atunci mecanicul a nimerit la perfectie avansul). Ce altceva ar fi putut genera aceasta eroare?
multumesc mult...ai putea sa ma ajuti cu niste imagini si mai multe sfaturi?
Am o problema la EGR, l-am curatat si tot apare aceasta eroare, poate aveti ceva sugestii?
Diagnoza:
Modificat de Radek
mai bine incearca sa-l schimbi.... verifica cu un furtunel si cu gura daca tine vacum
Ma duc sa verific.
Trebuie schimbata partea mecanica sau partea electrica (clapeta?) . Sau tot ansamblul?
Dupa ce l-ai curatat ai facut si readaptarea lui?
N-am facut readaptare, astia de la reprezentanta nu stiu de asa ceva . Parca la diesel-uri nu era necesara adaptarea, parca asa citisem.
Apropo, n-am probleme cu vid-ul general, il tine .
Nu stiu care sa fie problema. Eroarea asta n-am mai vazut-o nicaieri.
  • Aerofan pinned this topic
    • mfm71
