zorg
salut. am facut o diagnoza pentru senzorii de abs si esp ca imi stau aprinsi cateodata si mi-au aparut urmatoarele erori;
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 2H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
Part No: 1J1959801C
Component: 2H T
1 - Probleme inchidere / deschidere hayon
2 - Defectiune senzori abs spate (stanga si dreapta) sau fire intrerupte
multumesc mult. sunt amandoi senzorii de pe spate. sau numai cel de pe dreapta. ca nu asa vrea sa ii schimb pe amandoi.
conform erorii afisate
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
35-10 - - - Intermittent
16-10 - Signal Outside Specifications - Intermittent
este vorba de cel de pe dreapta.
Exact / dreapta spate
Inainte sa il cumperi verifca-i mufa.
la cel existent pe masina .
Pentru un GIII daca se poate ce inseamna erorile de mai jos
VCDS Version: Release 908.0
Data version: 20090830
Sunday,20,June,2010,17:13:07:63170
Chassis Type: 1H - VW Golf/Vento III
Scan: 01 02 03 08 12 15 25 41 56
Address 01: Engine Labels: 028-906-021-AHU.lbl
Part No: 028 906 021 BF
Component: 1.9l R4 EDC 00SG 0804
Coding: 00002
Shop #: WSC 01077
2 Faults Found:
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 3A0-907-379.lbl
Part No: 3A0 907 379 A
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 00028
00285 - ABS Wheel Speed Sensor; Front Right (G45)
35-00 - -
Thanx
Verifica mufa de la MAF;
00575 - Intake Manifold Pressure: Control Difference
Possible Symptoms
Reduced Power
Possible Causes
Solenoid Valve for Boost Pressure Control (N75) defective
Hoses incorrect connected, disconnected, blocked or leaking
Possible Solutions
Check Solenoid Valve for Boost Pressure Control (N75)
Check Hoses
Verifica senzorul ABS fata dreapta:
00285 - ABS Wheel Speed Sensor Front Right (G45): Signal Outside Specifications
00285 - ABS Wheel Speed Sensor Front Right (G45): Electrical Fault in Circuit
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
ABS Wheel Speed Sensor Front Right (G45) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Check ABS Wheel Speed Sensor Front Right (G45)
00285 - ABS Wheel Speed Sensor Front Right (G45): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Front Right (G45) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Possible Solutions
Check ABS Wheel Speed Sensor Front Right (G45) Installation
Modificat de pronet
Am si eu o eroare :
Address 02: Auto Trans Labels: None
Control Module Part Number: 6N0 927 735 C
Component and/or Version: DS085 Getriebe 1070
Software Coding: 32767
Work Shop Code: WSC 50687
2 Faults Found:
00839 - Valve 4 for Gear Selection (N287)
35-00 - -
Am gasit in manualele de service care este Valve 4- N287, dar nu reusesc sa aflu codul piesei ca sa o pot comanda. Ma poate ajuta cineva ?
Modificat de Dan O
poate te ajuta asta http://www.volkspage.net/technik/ssp/ssp/SSP_221.pdf
Te sfatuiesc sa te duci la cineva care se pricepe pentru asa ceva, sa faca un basic settings cum zice in pdf , poate nu are ulei sau alte chestii nu te apuca de schimbat, de obicei cand are erori pe cutie cutia deja e terminata, rar se repara vreo cutie si merge bine.
Martorul DPF aprins.
Am profitat de amabilitatea colegului pronet si am facut scanarea cu VAG-COM.
Diagnoza rezultata:
009263 - Diesel Particulate Filter (Bank 1): Restricted/Clogged
P242F - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 1
Mileage: 155756 km
Time Indication: 0
Date: 2010.06.06
Time: 07:54:59
Am incercat regenerarea activa a filtrului de particule conform instructiunilor din manual. Rezultatul: nu se mai regenereaza.
Aveti cunostinta daca se poate trece la regenerarea fortata cu VAG-COM, in situatia in care filtrul este infundat 106%?
Care sunt riscurile in astfel de situatii? Contactati-ma si prin PM, va rog.
Mii de multumiri anticipate pentru sfaturi!
Acel senzor chiar este defect din pacate. Adaptarea cutiei nu se poate face decat dupa inlocuirea acestui senzor.
Am incercat la 2 magazine de piese auto si au spus ca nu gasesc codul pt aceasta piesa ca sa o poata comanda.
Atasez si o poza in care am marcat piesa defecta :
Aici se vede un cod pe piesa dar in ETKA nu o identifica
Stie cineva cum identific piesa ?
Am si eu o problema cu masina unui coleg:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DJ HW: 028 101 188 3
Component: R4 1,9L EDC 0000SG 6250
Revision: 12345678 Serial number: SKZ7Z0E3050737
Coding: 0000071
Shop #: WSC 73430 790 00000
16567 - Fuel Temp. Sensor A (G81): Open or Short to Plus
P0183 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Temperature: 26.1
NU se repara, doar se schimba si nu se face adaptare.
Hello
Ieri in timp ce urcam Feleacul s-a aprins senzorul de check engine, am cam turat-o deoarece aveam si bagaje cam multe (nu stiu daca are relevanta). Azi am reusit sa fac o diagnoza cu LAUNCH in Ocna Mures. Iata erorile:
16517 P0133 O2 Sensor sporadic: circuit, Bank 1-sensor 1: slow response
17584 P1176 Bank1 sporadic: lambda correction downstream of catalist: control limit attained
17978 P1570 Engine sporadic: control module disabled
Mecanicul spunea ca e sonda lambda ce nu a reusit sa furnizeze datele corecte catre computer si s-a dat peste cap. Voi ce parere aveti? E necesar schimb de senzor?
Ia uite aici ce zice:
17584/P1176/004470 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
Possible Causes
Intake Air System leaking
Oxygen Sensor(s) and/or Oxygen Sensor Control faulty
Possible Solutions
Check Intake Air System for Leaks (False Air)
Check Oxygen Sensor(s) and/or Oxygen Sensor Control (all of them!)
iar ultima eraore nu are treaba cu lipsa de putere:
17978/P1570/005488 - Engine Start Blocked by Immobilizer
Possible Symptoms
Engine starting but stalling immediately
Possible Causes
Key(s) not matched
Instrument Cluster not matched
Engine Control Unit (ECU) not matched
Engine Control Unit (ECU) Power Supply faulty
Possible Solutions
Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
Check Engine Control Unit (ECU) Power Supply (Relay)
Special Notes
In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related.
May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module.
If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, in rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery.
Modificat de pronet
Am urcat masina pe o rampa sa verific tubul flexibil de pe toba si la acceleratie mare simt cu sufla prin/langa el. Din eroare zice ca ar fi admisia de aer insa nu vad nimic ce ar bloca sau ar trage aer fals.
Acum ~6 luni a fost fisurat tubul flexibil, pierdea gaze pe acolo si la fel s-a aprins check engine. Din pacate atunci nu am reusit sa aflu codul de eroare. L-am schimbat si de atunci a fost OK. E posibil sa fie aceasi cauza? Merci.
S-ar putea. Respectivul senzor sa nu inregistreze corect. (sorry pentru ce scrisesem anterior)
Modificat de pronet
Va salut,
Am facut o scanare prietenului meu la un Seat Altea si iata ce erori am:
Data version: 20090911
Tuesday,06,July,2010,21:04:47:13314
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: VSSZZZ5PZ6R038863 Mileage: 88190km/54798miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
01296 - Sensor for Vent Temperature; Center (G191)
010 - Open or Short to Plus
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2335
Coding: 0000144
Shop #: WSC 06402 785 00200
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Spuneti-mi va rog ce probleme ar fi.
Schimba senzorul de temperatura de la climatronic.
Invata pozitia de maxim si minim la geamul pasagerului.
Poti sa-mi spui te rog unde este acest senzor? E cumva cel din centrul butonului de ventilatie?
Modificat de poe
rog sprijin pentru erorile care au aparut la masina din profil. pur si simplu a pierdut din putere . care ar fi solutiile. mersi mult.
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-10 - - - Intermittent
scuze daca am postat si in alta parte. sunt cam nou pe aici.
In mare daca supapa de pe turbo nu e sparta, furtun vacum iesit crapat sau spart....o sa ai nevoie de o curatare turbo pt ca se pare ca nu isi face cursa geometria variabila.
La cea de-a doua probabil ai scos mufa la debitmetru tu sau cine s-a uitat pe la masina sau e dus.
In cazul in care e dus si il pui nou se poate sa se duca ambele erori definitiv.
am verificat astazi debitmetru si nu avea ulei sau ceva suspect pe senzor. am pus mufa la loc. am rescanat si nimic. sunt curios sa vad maine in mers cum se comporta. totusi, am curatat turbina in iarna. a mers brici. chiar sa fie dusa?
Nu, verifica pe unde pierde vacum atunci, posibil daca ai supapa pe furtunul de caldura comandata de vacum sa piarda prin ea, am mai vazut cazuri.
Ia fiecare furtunas si vezi pe unde pierde si incearca sa vazi actuatorul de pe turbo daca tine vacumul.
  • Aerofan pinned this topic
