zorg
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
Possible causes:
* Wiring and connections
* Z35 defect
Possible solutions:
* Check Measuring Blocks
* Repair wiring and connections
* Replace Z35
Voi ce ziceti?
Address 01: Engine
Part No: 038 906 018 GA
Component: 1,9l R4 EDC 0000SG 2605
Coding: 00002
Shop #: WSC 00028
2 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
17969 - Quantity Adjuster (N146): Control Deviation
P1561 - 35-00 - -
Readiness: N/A
ma rod erorile astea
daca are cineva o parere ...
respect
Marius
Probabil ai bateria slaba sau nu incarca alternatorul
Pt a doua eroare... ai cumva Power Box pe masina? http://translate.google.ro/translate?js=y&...sl=nl&tl=en
Pt ceilalti cu erori, am gasit un site din olanda, dar merge cu google translate. Gasiti aici toate erorile, explicatiile si solutiile
http://www.gerritspeek.nl/vag-com_foutcodeslijst.html
Modificat de Clodius
Poate te ajuta cu ceva explicatiile astea:
Possible causes:
* Wiring / connections
* Fault code stored in control module
* Control Module not properly encoded
* Similar resistance in motor control module
Possible causes:
* Injection pump malfunction
* Wire breakage or short circuit
Is there some electronic modification (power box?) That runs the fuel quantity affected? If indeed there is a power box is probably because the contact a short time in succession, and again, and again switched. Then is the time delay in the power box is still in action in dispatching the QA at its final value. During power is because the 'mixing work tell "the ECU tested and driven vol. It then looks at which value comes back from the pump. If the power box is already enabled then you get this error.
Error reset, it is only a notification and has no effect.
sal,
e masina lui Finu`
o sa ma uit mai bine la ea deoarece powerbox e ilegal in Irlanda ... il omor
respect
Marius
Am cateva erori poate ma indrumati si pe mine macar sa inteleg despre ce este vorba. Multumesc.
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 A HW: 4F0 919 283 A
Component: Parkhilfe 8-Kan H12 0030
Revision: --.--.-- Serial number: 11820428200437
Coding: 0011006
Shop #: WSC 02325 785 00200
1 Fault Found
01625 - Front Parking Aid Warning Chime (H22)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 144343 km
Time Indication: 0
Date: 2010.02.22
Time: 21:46:02
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000085877
Shop #: WSC 20346 133 80621
Part No: 4F0 915 105 D
Component: von VA0 1503220134
Coding: 344630393135313035442056413031353033323230313334
Shop #: WSC 20346 133 86805
2 Faults Found
02479 - Partial Consumer Shut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Mileage: 144343 km
Time Indication: 0
Date: 2010.02.23
Time: 07:55:27
02254 - Interface to Generator
Freeze Frame:
Fault Status: 00110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 192
Mileage: 144343 km
Time Indication: 0
Date: 2010.02.23
Time: 07:55:34h
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004488
1 Fault Found
18265 - Load Signal: Error Message from ECU
P1857 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 233
Mileage: 144344 km
Time Indication: 0
Date: 2010.02.23
Time: 08:05:05
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4006
Hex Value: 0x12BF
Hex Value: 0x00B0
Hex Value: 0x00FF
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: --H01--- Serial number: 0045258
Coding: 0000001
1 Fault Found
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 144344 km
Time Indication: 0
Date: 2010.02.23
Time: 08:05:06
Freeze Frame:
RPM: 768 /min
RPM: 384 /min
RPM: 64 /min
(no units): 1.0
(no units): 27.0
Temperature: 28.0
salutare
am si eu o problema. am schimbat senzorul de abs ca se taiase cablul si acum imi apare eroarea de abs esp in bord si nu mai intra absul si espul. am inteles ca trebuie anulata pentru a-si reveni la normal. arae cineva in zona pantelimon-vergului un soft cu laptop la dispozitie sa ma ajute si pe mine cu problema asta?
multumesc anticipat
DA, ma gasesti pe mine in acea zona, stau langa XXL. Gasesti nr meu de telefon in profil.
@tipoval
difuzor pentru senzorii de parcare din fata defect.
Alternatorul nu furnizeaza semnal de incarcare, astfel ca centrala electrica taie din consimatori, iar semnalul nu ajunge nici la motor. Verifica conexiunile alternatorului.
@johnyr da, cand ai schimbat senzorul ai deconectat bateria?
daca nu gandeste'te ca tura viitoare poate fi mai grav
deconecteaza bateria pentru cateva minute, conecteazo inapoi si 80% sunt sigur ca va fi ok dupa aia
asteptam raspuns cu rezolvarea
respect,
Marius
014 - Defective
Possible causes:
* Z35 defect
Possible solutions:
* Replace Z35
Voi ce ziceti?
Mai in gluma mai in serios, sa faci excat ce scrie la "possible solution". In plus, verifica si siguranta F11 din cutia cu sigurante din compartimentul motor.
respect,
Marius
REzolvarea a fost introducerea senzorului de ABS pana la capat, adica in pozitia corecta de lucru. Eroarea era de semnal implauzibil.
Am si eu o eroare de care nu pot trece nici cu zece popi de trefla.
:icon_thumright:
Arata asa log-ul :
Adress 01 : Engine
Controller 03G 906 016 FS
Component R4 1,9L EDC 0000SG 6124
Coding 0000071
Shop WSC 01279
1 Fault Found
16502 Engine Coolant Temp. Sensor (G62) Signal too High
P0118-000- -- Intermittent
Amuzant este faptul ca nici unul din simptomele de mai jos nu sunt incidente in cauza, motorul porneste perfect, turometrul la relanti este nemiscat, acul nu scade niciodata in mers odata ce a ajuns la 90 grade, accelereaza la fel de bine si la rece si cald, atat ca porneste putin mai lung pe cheie cu motorul cald, dar acesta nu apare aici ca simptom si poate fi datorat electromotorului mai obosit.
Possible Symptoms
Difficulties with starting a cold engine.
Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
RPM at idle is irregular.
With all engine temperatures idle rpm will often vary between 900 - 1000 rpm.
With engine warm (90
Va salut pe toti!
Am tot cautat pe forum de cateva zile dar inca n-am gasit raspuns la problema mea.
Pe scurt, am 5 erori "la pachet" care se insotesc de pierderi de putere (practic raman fara turbina in mod cu totul aleator) - cand merge brici, cand merge ca moartea in vacanta
5 faults found
17932 - Fuel Pump Relay (J17): Open or Short to Ground
P1524-35-00 - -
17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
P1549-35-00 - -
17903 - Switch Over Valve for EGR Cooler (N345): Open or Short to Ground
P1495-35-00 - -
17849 - EGR valve (N18): Open Circuit or Short to Ground
P1441-35-10 - - - Intermittent
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101-35-10 - - - Intermittent
La primele 3 erori cateodata da intermitent.
Mentionez ca am schimbat releul pompei de carburant, N75 si valva EGR ca atare (nu N18), toate piesele fiind noi. Am spray-at contacte, mufe, panou de sigurante si tot ce mi-a fost pe la indemana. Urmeaza sa-i dau foc :icon_thumright:
Dati-mi macar o idee, in afara de a schimba toate cablurile sau de resoftare
Modificat de rostov105
Toate erorile indica un scurt undeva, verifica firele, bafta.
Multumesc pentru raspuns Liviu!
Am ajuns si eu la ideea ca e o problema electrica. Daca era un scurt pe undeva, ma gandesc ca trebuia sa-mi sara vreo siguranta, nu? Pe de alta parte, am mai rasfoit pe tdiclub.com despre erori de tip open or short to ground si am gasit ceva despre releul 109, e releul din care se alimenteaza toti senzorii plus ECU. Ma gandesc sa-l comand si pe ala si sa-l inlocuiesc...
Nu ai vreun amic de la care sal inprumuti sa nu te trezesti ca nui vorba de releu109?
Modificat de liviuplaton
Ma poate ajuta careva sa imi zica unde pot gasi senzorul de temperatura B1 S3? sau macar ce cod are G....
Va rog mult de tot, am cautat peste tot si nu gasesc deloc.
ar fi ceva de genul bancul 1 sonda 3 cred ca este ceva de la esapament
de unde ai aceste date mai da-ne un indiciu
Va supun atentiei erorile identificate dupa scanarea unui VW Bora. Daca are cineva idee ce reprezinta, in special prima, va rog sa-mi spuneti. Va multumesc!
17958 - Charge Pressure: Control Deviation
P1550 - 08-10 - Control Limit Surpassed - Intermittent
Readiness: N/A
00953 - Interior Light Time limit
25-00 - Unknown Switch Condition
00912 - Window Regulator Switch: Front Left (E40)
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
Modificat de TheBoogieMan
Overboost adica presiune prea mare, geometrie sau actuator blocat.
Nu are legatura cu 109.
Modificat de Al Bundy
AM scanat recent passatul tdi al unui bun prieten si mia aparut urmatoarele coduri de eroare..adress08 climatronic,cood 00787,ceva cu temperatursenzor 89,adress 15 airbagcood eroare00532,suply voltajeB+,acum la motor,cood eroare 16955ceva in legatura cu schwitul la pedala de frina,apoi cood eroare17664engine temp senzor g62,,cod eroare17965,premisse control pozitive deviation...apoi cod eroare01039,colant temperature senzor.....a schimbat decurind schwitul la pedala de frina si tot i se aprinde martorul de bujii adica spirala aia la bord,iar cind apasa tare pedala de frina,apoi o elibereaza,si o ridica in sens invers cu virful piciorului eroarea se stinge....probabil nu a fost montat corect...as fi mai mult decit recunascator daca as vedea cum se demonteaza un schwit la pedala de frina la un pssat tdi ...inca odata scuze moderatorilor daca am fost oftopic
c,cood 00787,ceva cu temperatursenzor 89,adress 15 airbagcood eroare00532,suply voltajeB+,acum la motor,cood eroare 16955ceva in legatura cu schwitul la pedala de frina,apoi cood eroare17664engine temp senzor g62,,cod eroare17965,premisse control pozitive deviation...apoi cod eroare01039,colant temperature senzor.....a schimbat decurind schwitul la pedala de frina si tot i se aprinde martorul de bujii adica spirala aia la bord,iar cind apasa tare pedala de frina,apoi o elibereaza,si o ridica in sens invers cu virful piciorului eroarea se stinge....probabil nu a fost montat corect...as fi mai mult decit recunascator daca as vedea cum se demonteaza un schwit la pedala de frina la un pssat tdi ...scuze pentru greseli,sper sa se inteleaga(ma refer aici la cei cu experienta}
cod de eroare climatronic 02176,ce reprezinta?
Din cate stiu eu : motor reglaj lombar fata - la scaunului pasagerului-V126
Pai din eroare:
009259 - Exhaust Gas Temperature Sensor; B1 S3: Range/Performance
P242B - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 1
005213 - Exhaust Gas Temperature Sensor 3: Short to Plus
P145D - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.01 V
  • Aerofan pinned this topic
