zorg
Schimba urgent senzorul de presiune diferentiala
Modificat de EEXCALADE
Bereholschi
ce parere aveti trebuie schimbat doar injectorul numarul 3 ? sau ce ar fi mai bine sa fac?
log injectoare.CSV
vlahdacoroman
Supun atentiei cateva erori gasite la un passat b6 din 2008 cu 1.8 tsi.
Masina porneste greu si are mers neregulat cu intreruperi....Personal cred ca e vorba despre cablaj sau ecu.
Friday,25,May,2018,17:15:52:43508
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
                Address 01: Engine       Labels: None
Control Module Part Number: 06J 997 026 F    HW: 06J 906 026
  Component and/or Version: MED17.5             5704
           Software Coding: 0404000318070160
            Work Shop Code: WSC 28193 002 1048576
                      VCID: 37775A3546E470FA4D-8062
3 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 0
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 281264 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:13:30
             Freeze Frame:
                    RPM: 744 /min
                    Load: 15.3 %
                    Speed: 0.0 km/h
                    Temperature: 105.0°C
                    Temperature: 84.0°C
                    Absolute Pres.: 950.0 mbar
                    Voltage: 13.335 V
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 281264 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:07:02
             Freeze Frame:
                    RPM: 760 /min
                    Load: 36.5 %
                    Speed: 0.0 km/h
                    Temperature: 96.0°C
                    Temperature: 66.0°C
                    Voltage: 13.462 V
000289 - Throttle Position Sensor (G69)
               P0121 - 000 - Implausible Signal - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 281264 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:07:12
             Freeze Frame:
                    RPM: 905 /min
                    Load: 60.4 %
                    Speed: 0.0 km/h
                    Temperature: 96.0°C
                    Temperature: 58.0°C
                    Voltage: 13.589 V
Readiness: 0100 0101
Modificat de vlahdacoroman
Uzura la clapeta galeriei de admisie
Se monteaza limitator sau se schimba galeria cu clapeta cu tot.
vlahdacoroman
Pai este vorba de un motor 1.8 tsi...
Stiu ca la 2.0 tdi se rezolva cu limitator... insa nu am vazut si ptr 1.8 tsi.
Celelalte erori sunt adiacente... eu cred ca este vorba de ecu sau cablaj.
Da,acum am vazut ca e 1.8..
Problema pare aceeasi...curata clapeta,verifica cablaje...fa-i adaptare si vezi dupa.
Buna seara,
Am si io erorile astea si va rog sa ma ajutati cu o interpretare.
\multumwsc,
                Address 5F: Information Electr.       Labels: 5G0-035-MIB-STD2.clb
Control Module Part Number: 3Q0 035 864     HW: 3Q0 035 864
  Component and/or Version: MU-S-N-ER     H10 0138
           Software Coding: 02840101FF00000011110001000808001F01008401200100CD
            Work Shop Code: WSC 05311 115 00002
              ASAM Dataset: EV_MUStd4CTSAT 001018 (VW48)
                       ROD: EV_MUStd4CTSAT_VW27.rod
                      VCID: 6ED378BAB1970334FA-803A
2 Faults Found:
2562 - Navigation System
          B126C F0 [009] - Navigation Database Faulty
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 150
                    Mileage: 33612 km
                    Date: 2018.05.04
                    Time: 15:14:32
                    Voltage terminal 30: 12.3 V
7203 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 35149 km
                    Date: 2018.05.16
                    Time: 21:58:43
                    Voltage terminal 30: 14.1 V
                    BAP-BAP_Function_ID: 15
Address 5F: DTCs cleared
                Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 653 E    HW: 3Q0 980 653
  Component and/or Version: MQB_B_MFK     H07 0121
           Software Coding: 00040801000004010022134E8040A100980084300040
            Work Shop Code: WSC 53198 002 1048576
              ASAM Dataset: EV_MFKBoschMQBB 001001 (VW48)
                       ROD: EV_MFKBoschMQBB_VW27.rod
                      VCID: 387F9EE283538D84E0-806C
1 Fault Found:
1275 - Unknown Error Code
          B182E F0 [024] - Unknown Error Elaboration
          Intermittent - Confirmed - Not Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 32061 km
                    Date: 2018.04.26
                    Time: 11:51:24
                    Control Module temperature: 54 °C
                    Outside air temperature: 23.5 °C
                    Vehicle speed: 8.20 km/h
                    System run time: 1289.1 s
                    Voltage terminal 15: 13.4 V
                    mid: 01 62
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 2
                    Software_Info_2: 1
                    Software_Info_1: 0
Se pare ca este o problema cu hartile navigatiei,trebuie reinstalate.
Ptr eroarea A5 trebuie o interfata originala.
am inteles, multumesc
seara buna
Va salut,
Am intampinat astazi o problema, am fortat masina cam 2-3 ore prin Bucuresti, si accelerari mai mari, si condus mai brutal, la un moment dat mi-a intrat in limp mode, s-a aprins doar spirala, fara check engine, am oprit si am pornit, a mers perfect, am mai fortat-o inca o ora sa vad daca se mai manifesta dar nu a mai fost cazul.
Am facut o scanare si a ramas eroarea:
P0087 Fuel Rail/System Pressure - Too Low.
Am sanse sa nu o mai vad, sa fi fost o lipsa de motorina pe moment, sau sa ma pregatesc pentru investitii?
Masina are stage 1, de la 140 la 184 cp, revizia (inclusiv filtrul de motorina) a fost facuta cu 1000km in urma...
Multumesc anticipat pt raspuns!
O problema la sistemul de alimentare ,eroarea o sa revina
O scanare cu VCDS m-ar putea ajuta sa gasesc sursa problemei?
O sa schimb si filtrul de motorina, sa vad daca este mizerie in el...
Necesita investigatii amanuntite
Sincer, nu m-au ajutat prea mult raspunsurile tale, ca este o problema la sistemul de alimentare am tradus si eu, si ca necesita investigatii amanuntite stiam, dar iti multumesc pentru raspunsuri, o sa vad ce o sa fac... :)
DAca nu  te-au multumit raspunsurile, chiar era cazul sa comentezi  ?
Nu poate ghici nimeni.
In eroare sunt implicate urmatoarele componente :
Pompa din rezervor,pompa de medii,pompa de inalte,valva metering,senzor presiune rampa,regulator presiune rampa ,injectoare,valva retur injectoare....
Ca sa nu schimbi piese degeaba trebuie sa duci masina la cineva specializat in motoare vag .
Am inteles, multumesc frumos, o recomandare in Bucuresti?
Salutare tuturor
Ieri am facut o scanare si am gasit ceva erori. Masaina este un Passat, CBAB, 2.0 TDI, 140CP. Ma poatre lamuri cineva cu ,,magariile'' astea?
Address: 0001 System name: Diesel direct fuel injection with DPF Protocol variant: KWP2000/TP20 (Ereignisse: 4)
-Identification:
Hardware part number:
03L907309
Part number:
03L906022BL
Hardware version number:
H01
Software version number:
9977
Production date:
16.04.2008
Code:
72
Flash capability:
flashable
System designation:
R4 2.0l TDI 0001SG
-Event memory entries:
Entry in fault memory
Number:
P0299:  Turbo/Super Charger Underboost
Fault type 2:
static
+Standard ambient conditions:
+Extended ambient conditions:
Number:
P0102:  Mass or Volume Air Flow Sensor "A" Circuit Low
Fault type 2:
Intermittent
Number:
P2564:  Turbocharger Boost Control Position Sensor Circuit Low
Fault type 2:
Intermittent
Number:
P2563:  Turbocharger Boost Control Position Sensor Circuit Range/Performance
Fault type 2:
Intermittent
Address: 0053 System name: Parking brake (electrical) Protocol variant: KWP2000/TP20 (Ereignisse: 2)
-Identification:
3C0907801J
Part number:
3C0907801J
008
0009
Production date:
12.04.2008
Code:
56
Flash capability:
flashable
System designation:
J540 EPB3 VW-09393
Number:
VAG02442:  Function lamp in operating unit
Fault type 1:
Open circuit/short circuit to ground
Fault type 2:
Intermittent
Number:
VAG03200:  Electro-mechanical parking brake button
Fault type 1:
Electrical error in circuit
Fault type 2:
Intermittent
-Identification:
3C0907801J
Part number:
3C0907801J
008
0009
Production date:
12.04.2008
Code:
56
Flash capability:
flashable
System designation:
J540 EPB3 VW-09393
Number:
Fault type 1:
Fault type 2:
Intermittent
Number:
Fault type 1:
Fault type 2:
Intermittent
Address: 0056 System name: Radio RCD300 mp3 Protocol variant: KWP2000/TP20 (Ereignisse: 2)
-Identification:
Part number:
1K0035186AD
034
0033
Production date:
21.04.2008
Code:
20200
Flash capability:
not flashable
System designation:
Radio GR0 034
Number:
VAG00872:  Left rear bass speaker
Fault type 1:
Open circuit
Fault type 2:
static
Number:
VAG00873:  Right rear bass speaker
Fault type 1:
Open circuit
Fault type 2:
static
Multumesc pentru intelegere si scuze pentru deranjul facut, prieteni.
O diagnoza cu VCDS nu ai ?
Salut colegii,
Imi poate spune si mie cineva, ce reprezinta " Reset counter" din descrierea erorii din poza de mai jos ?
Modificat de passat19tdi
Va salut.In urma aprinderii martorului "check engine" in bord am facut o scanare din care a reiesit 4 erori la motor.Masina merge si porneste normal momentan dar nu stiu unde trebuie sa actionez si cum.Sa schimb releele la care mi-a dat eroare?!
Log-154930km-96269mi.txt
Cred ca ai o siguranta arsa.
  • Aerofan pinned this topic
    • opleistul32
