zorg
La bujii da eroare. Decat daca sunt moarte toate sa nu dea eroare.
am dat si eu de erorile astea la Polo dupa o prima scanare:
Address 01: Engine Labels: None
Part No: 03E 906 033
Component: 1,2l/4V SIMOS3 00HS4340
Coding: 00071
Shop #: WSC 00788
3 Faults Found:
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 35-10 - - - Intermittent
17811 - EGR System: Regulation Deviation
P1403 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
Readiness: 0000 0001
Address 03: ABS Brakes Labels: None
Part No: 6Q0 907 379 E
Component: ABS FRONT MK60 0103
Coding: 0001097
Shop #: WSC 00788
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 6Q0 820 045
Component: Klimaanlage X0840
7 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
41-10 - Blocked or No Voltage - Intermittent
55-00 - Adaptation Not Successful
Address 09: Cent. Elect. Labels: None
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 17420
Shop #: WSC 00788
4 Faults Found:
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 6Q0 909 605 S
Component: 03 AIRBAG VW5 01 0006
Coding: 12339
Shop #: WSC 00788
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
33-10 - Resistance too Low - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 00788
3 Faults Found:
Address 44: Steering Assist Labels: None
Part No: 6Q0 423 156 AA
Component: LenkhilfeKYO X757
Coding: 10140
Shop #: WSC 13765
2 Faults Found:
00816 - Power Steering Sensor (G250)
30-00 - Open or Short to Plus
27-00 - Implausible Signal
End --------------------------------------------------------------------------------------------------
dupa ce am sters erorile am mai dat un scan si am ramas cu astea:
Coding: 00071
Shop #: WSC 00788
WVWZZZ9NZ2Y019331 VWZ7Z0A4368951
No fault code found.
Readiness: 1110 0101
Coding: 0001097
Shop #: WSC 00788
1 Fault Found:
Coding: 17420
Shop #: WSC 00788
4 Faults Found:
Coding: 12339
Shop #: WSC 00788
Address 17: Instruments Labels: None
Part No: 6Q0 920 800 P
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 01131
Shop #: WSC 00042
Coding: 00014
Shop #: WSC 00788
3 Faults Found:
Coding: 10140
Shop #: WSC 13765
2 Faults Found:
martorul placutelor de frina este in continuare aprins (am citit ca asa face toate) iar cel de airbag a disparut
interesant de ce nu a mai aparut buba la bobina
(intre cele 2 scanari am mai pornit masina)
Tnx :Driver:
Care bobina? Te referi la erorile (initiale) de pe engine? Daca da, atunci eu iti zic parerea mea: de la EGR puteau rezulta si celelalte doua.
Mai ai (se pare) si probleme cu bateria sau, avand in vedere caracterul intermitent (prezentat si in cod) ceva contacte imperfecte - de aici mai pot rezulta cateva erori.
My opinion :lol:
Dupa curatare injectoare si inlocuit MAF s-a facut un alt log in mers. Multumesc lui aryes13.
In primul rand nu-mi place cum arata presiunea in turbo, dar cum nu sunt specialist in interpretare de loguri, va rog sa ma ajutati.
Log.xls
Modificat de AndyG
  AndyG a scris:
Nu este de sarit in apa, ai doar cateva spike-ri ... presiunea este controlata dar cu ceva intarziere.
presiunea este bunicica....ma deranjeaza debitmetru..
debitmetrul oscileaza datorita presiunii, deoarece cand presiunea este mare cantitatea de aer absorbit prin filtru este mai mare=> valoarea mare la debitmetru, valabil si pt reciproca de acolo vin acele diferente de valori
mai intai uitete....debitmetru arata mai putin :ceuameni:)
Multumesc foarte mult.
Imi este foarte clar acum de ce am valori putin marite/scazute ale debitmetrului din cauza spike-urilor.
Ce e de vina si ce e de facut sa intru in normal? Banuiesc doar, curatare turbina?
Salut
Ajutor mare!!!
unde gasesc si eu la cineva ce inseamna eroarea asta aparuta la q7 pe mmi
"device error missing answer for nottification 0xc00'
si nu se mai aude nimic in boxe ...... nimic nimic, nici cd, radio, tv, tel ..... doar piuitu de la senzorii de parcare.
Mercic.
Scuze daca sunt OT
Ontopic sau nu, iti recomand repejor o vizita la un service autorizat Audi, cu siguranta masina este inca in garantie, prin urmare rezolvarea problemei se va face fara costuri.
Cheers.
mercic, am sa ma duc dar, vroiam sa ma informez despre ,buba' sa nu ma faca aia cum vor ei :lol:
va salut stimati colegi de forum
am facut o scanare vag si as vrea o interpretare din partea celor cunoscatori
va multumesc anticipat
Part No: 1K0 907 044 L
Component: ClimatronicPQ35 061 0201
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - - - Intermittent
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Coding: E68B8F0600041800001400001400000000
Shop #: WSC 00000
Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.2 1301
1 Fault Found:
000 - -
pai e simplu...ce scrie aia e
1. este din climatronic...motorasu care mofica amestecu aer cald cu aer rece...agata ocazinal
2.releul de la spalator faruri cred :huh:
3. senzorul de la volan care masoara unghiu.... (asta influenteaza ESP )
iti multumec mult
la 1 e clar ca se si aude un agatat
la 2:merg spalatoarele la faruri
si la 3 sa-r putea sa fie din cauza unei jante care e stramba(masina are 160 ed mii km) si esp-ul functioneaza....
La pct. 3, cam greu de crezut ca G85 sa "faca figuri" din cauza unei jante indoite. In cel mai rau caz, ar fi putut sa dea o eroare la senzorul de ABS dar, si asta ...f. greu.
La pct. 1, poti incerca un output test...poate isi revine.
va multumesc inca odata pentru raspun
in traducere ce reprezinta acest "g85" ce ar putea avea fizic masina??
trebuie sa-mi fac probleme ???
cand a nins "m-am jucat " si eu putin sa vad daca intra esp (jucat in sensul ca am accelerat in conditiile in care carosabilul era alunecos,asta pe dist scurte(
cand am luat masina am avut jate pe 17" si am luat o groapa cu dreapta fata si s-a zdruncinat bine , se paote sa fie de la chestia asta???
nu are nici o treaba... senzorul este pe volan.. un potentiometru
Modificat de aryes13
Am si eu in sfarsit o interfata si pentru prima data m-am uitat putin prin vag-com. Inainte am mai folosit altfel de testere, care sincer erau mult mai calumea ca functionalitate(asta doar asa in paranteza). Am avut un limpmode de ~2 saptamani si am aflat ulterior ca turbina baga presiune prea mare. Am facut acum seara ceva loguri cu vag-com si v-as ruga sa va uitati peste ele ca sincer nu ma stiu si nu stiu cum sa interpretez anumite chestii, oricum sunt acolo multe care nu corespund cu valoarea ceruta.
LOG_01_001_002_003xy.xls
Mai am o intrebare, la Engine Speed (relantiu) scrie 790-870, dar mie relantiul imi sta la 903. De ce?
Mersi anticipat si daca cumva nu-i bun log-ul sa-mi spuneti sa mai fac odata, sau cum sa fac.
p.s. acuma vad ca nu am facut calumea, trebuia 3 10 si 11.
Modificat de TitvsCaivs
deci fara presiune turbo nu prea e mult de zis.....e posibil sa fie mai mare...ca debitmetru a sarit de val normale.....
ma mai deranjeaza un lucru...temperatura apei este cam mica...sa nu fie senzorul decalibra
Cat tine de temperatura apei, pe bord imi era la mijloc acul, insa precizez ca de-abia ajunsese acolo cand am facut log-ul, deoarece nu mai aveam baterie la calc.(lucru cam stupid)
  • Administrator
  TitvsCaivs a scris:
La toate AXR / ATD turatia la ralanti este 903 . :)
Bun, dar chiar daca la AXR/ATD relantiul trebuie sa fie mai mare, programul nu ar trebui sa recunoasca acest lucru si sa furnizeze alte valori in care sa se incadreze cele actuale?
2. La ultima coloana, la EGR Duty Cicle de ce sunt valorile atat de mici, este normal?
p.s. mai editez si eu.
Dupa postul lui aryes13,>celalte valori cerute sunt corecte sau exista si acolo abateri ca si la relantiu? Ce mai este, la care tre' sa fiu atent, si nu corespunde niciodata cu valoarea ceruta?
  • Administrator
Probabil ca nu au stat cei de la Ross Tech sa isi bata capul si cu problema turatiei pe fiecare tip de motor in parte . :(
PS : Ti-am editat eu postul anterior . ;)
Salutare tuturor. Acesta e primul meu post aici, pe forum. De 2-3 saptamani am luat un Golf 4. Masina a fost adusa din Germania cu putin inainte sa o cumpar eu. Merge foarte bine, dar am o problema cu pornirea la rece.
Tin pe bujii, se sting toate cele din bord si actionez electromotorul. Dupa 2-3 secunde are tendinta sa porneasca si, sunt tentat, in mod normal sa dau drumul la cheie. Culmea e ca motorul balbaie, nu stiu cum sa zic, ca un Diesel mai vechi, fara compresie buna la toti cilindrii. Adica, merge in 2-3 pistoane. Partea proasta e ca, de cateva ori dupa acest scurt balbait, s-a oprit. Si am incercat sa mai pornesc o data. Tin pe bujii, se sting, dau iar si aici e partea interesanta, nu mai vrea sa porneasca deloc. Am incercat 5-6 tentative si apoi m-am lasat pagubas, mi-a fost mila de baterie. Insa, de fiecare data, in aceste tentative, nu a mai dat vreun semn ca ar mai vrea sa o ia, nici macar o mica aprindere macar la un cilindru. Dau pe electromotor ca si cum nu are motorina, dau degeaba. Daca o las mult timp (5-6 ore - 1 zi) poare reusesc sa o pornesc, sau cel putin, se repeta povestea, macar vrea sa o ia.
Alteori, pentru ca acum m-am mai invatat, tin cuplat electromotorul inca 1-2 secunde in timp ce motorul se aude ca ar fi pornit. Si uneori merge treaba, balbaie ca de obicei, dar in final o ia. Acest balbait tine cam 2 secunde, dupa aceea merge frumos, rotund, 900 rot/min. Cand e cald motorul, porneste foarte bine, in sensul ca merge din prima rotund, nici o problema in acest caz. Doar dimineata, la prima cheie, cand e motorul rece.
Motorul este TDI, AXR, 101 cai putere si are in bord 140 000 km. Astazi mi-a sosit cablul si tin sa-i multumesc lui Saboteur Czech pentru promtitudine si seriozitate. Am facut o scanare si asta e tot ce a iesit.
Intrebarea mea este si v-as fi recunoscator daca mi-ati spune, are legatura acest senzor de turatie cu aceasta problema de pornire? Stiu ca la benzinare are legatura, dar nu am idee la Diesel, la TDI. Si eroarea cu ABS/ESP-ul, de la ce ar putea fi? Multumesc frumos!
Thursday,20,December,2007,16:10:50:50594
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Address 01: Engine Labels: 038-906-019-100.LBL
Part No: 038 906 019 AT
Component: 1,9l R4 EDC 0000SG 1513
Coding: 00002
Shop #: WSC 01317
WVWZZZ1JZ2W548323 VWZ6Z0A3894158
1 Fault Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.LBL
Part No: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019458
Shop #: WSC 01317
Address 56: Radio Labels: 1J0-035-15x-56.LBL
Part No: 1J0 035 152 E
Component: Radio PHO 0003
Coding: 00001
Shop #: WSC 01317
Modificat de ionut.bratu
  • Aerofan pinned this topic
