zorg
Al Bundy
CE alte verificari s-au facut ? Dupa diagnoza.
Absolut nicio verificare, eu am făcut scanarea cu ce am și atata tot.
F l o r i n
Verifica cablajul motor, in zona de trecere spre lonjeron caroserie sofer
Salut Florin, am sa ma uit să văd atat cât ma pricep.🤦‍♂️ Mulțumesc!
Bine am revenit in lumea VAG dupa 7 ani de japoneza, m-a convins, nu mai vreau...
De o saptamana am achizitionat masina din profil, cod motor DTSB.
Am scotocit internet-ul cat m-am priceput, nu prea am gasit ceva concret, drept urmare am zis sa cer ajutorul.
La o prima scanare mi-au aparut anumite erori, le-am sters si am mers aproximativ 200 km, erorile care mi-au reaparut sunt urmatoarele (am sa postez doar erorile sa nu consum jumatate de pagina cu tot log-ul):
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 320 B    HW: 3G0 920 320 B
   Component: KOMBI         502 5176
   Coding: 04A438186F8C00080180620B1001000880700103
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_DashBoardVDDMQBA0 001045
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 1C61D46DB628393A732-8048
2 Faults Found:
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 137
                    Mileage: 134284 km
                    Date: 2025.05.11
                    Time: 19:10:11
16777056 - Function Restricted due to Interrupted Communications
          [BAP_SDS_0x46 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 137
                    Mileage: 134284 km
                    Date: 2025.05.11
                    Time: 19:10:09
Address 4B: Multifunc. Module (J745)       Labels:* None
   Part No SW: 3Q0 907 338 F    HW: 3Q0 907 338 F
   Component: FCM MQB High  004 0370
   Serial number: 30102011600049 Dataset Number: V03935337Y  0001
   Coding: 000000070B0004CA01106F04020300000000000000000000000000000000
   Shop #: WSC 05311 115 00085
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 382928FD22D0751A77A-806C
   Antenna for short-range communication:
   Subsystem 1 - Part No SW: 3V0 959 121 A    HW: 3V0 959 121 A
   Component: R350 NFCTGS  401 0109
   Serial number: 0000000000B54F300081
   Antenna 2 for short-range communication:
   Subsystem 2 - Part No SW: 3G0 980 611     HW: 3G0 980 611
   Component: J524 NFCMIKO  H09 0060
   Serial number: 32000000000002549935
1 Fault Found:
65851 - Control Module for Near-Field Communication in Center Console
          B16E6 04 [00001000] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 134264 km
                    Date: 2025.05.11
                    Time: 17:00:28
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 284 E    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0141
   Serial number: 0000000009VIJH7 Dataset Number: V03935447RE 0001
   Coding: 024830001968AC209005460161102607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 48C9583D5230059A07A-801C
1 Fault Found:
1644017 - Online Services
          B1915 F1 [00001001] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 40
                    Mileage: 134285 km
                    Date: 2025.05.11
                    Time: 19:20:56
                    Voltage terminal 30: 12.4 V
                    Remaining long term energy budget: 3562 mAh
                    Remaining short term energy budget: 1 mAh
                    Wake up cycles counter: 7268
Multumesc mult pentru raspunsuri.
Log-REERROR-WVWZZZ3HZME504083-134315km-83459mi.txt
F l o r i n
Bateria emergency o sa trebuiască inlocuita
Da. Si ceva probleme cu NFC ul din consola centrala.
Multumesc mult @F l o r i n si @spido !
Cel mai mult incercam sa interpretez eroarea de pe IC, sa aibe legatura cu emergency battery sau cu nfc-ul ?
Cu niciuna. Are legatura cu sistemul infotainment,adresa 5F. Vezi daca exista vreo actualizare ptr Mib.
On 10/31/2016 at 9:38 PM, phenom said:
Salut, am facut o diagnoza cu autocom si a dat "eroarea" asta:
65535 - System OK (If fault still evident, check control unit and associated wiring)
Stie cineva ce inseamna?
Mersi.
Nu gasesc unde ai scris cum ai rezolvat.
andrei_221
aia nu este eroare.
Salut. Ieri cand ma intorceam pe autostrada de la Ploiesti m-am trezit cu spirala aprinsa in bord (intermitent). Nu am sesizat vreo problema in practica asa ca am mai mers vreo 30 de km pana la intrarea in Bucuresti, unde am conectat diagnoza sa vad ce s-a intamplat. Am dat peste ce apare mai jos, care presupun ca ar insemna ca e necesara schimbarea senzorului G235.
              Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 AH    HW: 03L 906 022 G
  Component and/or Version: R4 2,0L EDC G000AG  6170
           Software Coding: 0000078
            Work Shop Code: WSC 74565 000 00000
                      VCID: 6BD572AB4A85F9CB0E-803E
1 Fault Found:
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
               P0544 - 000 - Circuit Malfunction
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 200842 km
                    Time Indication: 0
                    Date: 2063.14.31
                    Time: 14:00:36
             Freeze Frame:
                    RPM: 2622 /min
                    Speed: 132.0 km/h
                    Temperature: 81.0 C
                    Temperature: 23.4 C
                    Inj. Quantity: 23.1 mg/str
                    Temperature: 420.0 C
                    Temperature: 18.0 C
Sau ar putea fi vorba de o alta problema?
Intreb deoarece temperaturile pe care le vad acolo par ok, in timp ce in alte postari de pe aici am vazut 930 - 1000 grade, ceea ce aparent insemna ca senzorul era defect.
Modificat de Jeffy86able
Dan Adrian 1975
Buna ziua,ma poate ajuta cineva cu o diagnoza turbo/admisie... masina nu trage cum trebuie,are lag mare dupa ce se incalzeste.nu are erori stocate.Am schimbat turbina dar are acelasi comportament ca inainte .Am tot incercat sa verific,am facut si un log asa cum m am priceput dar nu i dau de cap ,multumesc !
skoda octavia3 1.6 TDI 110cp euro6
presiunea diferentiala esteb6,8mb dupa regenerare,deci nu vad sa fie problema de acolo!
Verifica valva N75/electrovalva turbo si capsula vacuumatica de pe turbina.
On 30.04.2025 at 10:55, SelesanD a scris:
Ceau ,
Am eroarea urmatoare , electrovalva N249 are membrana OK. In 1000 Km de 2 ori am eroarea .
Ce poate fi ?
Am fost la electrician , verificat cablajele ...dar mi-a gasit joc serios la axul turbinei.Poate fi cauza pierderilor si oscilatiilor de putere + erori pe senzor G31 semnal implauzibil  ?
Dan Adrian 1975
în urmă cu 8 ore, spido a scris:
Nu ar avea o eroare stocata ? Masina nu are erori!
Nu cred ca a verificat ceva,sigur era "electrician"?!
