zorg
NU mai ai freon, pierde pe undeva.
 @Al Bundy, multumesc frumos
Buna ziua,
Detin un VW Passat din 2012, 2000 cmc ,140 cp cu codul de motor CFFB si de curand imi tot apar 2 erori (P0104 ,P0300).
Masina merge normal cu aceste erori, daca a mai avut cineva problema aceasta sa-mi spuna cum au remediat problema.
buna ziua,
ma poate ajuta cineva cu errorile astea 2, par sa provina din acelsi loc, J533
Skoda Rapid 2018.
Address 01: Engine (J623-CHZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 Q    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H26 3581
   Revision: W1H26---    CVN: 1086DC1E
   Coding: 01190032230411080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM10TFS01104C906026Q 002007
   ROD: EV_ECM10TFS01104C906026AH.rod
   VCID: 2F3B13A1D79EB2A2A69-807A
   VINID: 91D49588679819A1051C808708F57B9D1E
Center armrest control head 1:
1 Fault Found:
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [039] - -
          [Diagnostic interface for data busRead out DTC]
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 19523 km
                    Date: 2023.04.24
                    Time: 15:49:47
                    Engine RPM: 1304.50 /min
                    Normed load value: 22.4 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 15 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 13.853 V
                    Unlearning counter according OBD: 40
                    Outside temperature: 16 °C
                    Absolute intake pressure: 55 kPa abs
                    Engine torque: 27.3 Nm
                    Fuel level: 27.00 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Engine operating condition: Idle
                    Engine operating condition-Test_Program_Channel 87: 5
Readiness: 1110 0001
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0101
   Revision: --------    Serial number: 006728165468
   Coding: 030000042F0A570000000000000000010001050000000000000000000000
   Shop #: WSC 73430 790 00063
   GVL: 01443C0000000000400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 2615F685F864F3EA55F-8072
   Battery Monitoring Control Module:
1 Fault Found:
66567 - Local Databus
          U1030 00 [009] - Electrical Malfunction
          [LIN#1 (LIN-Energie) elektrischer Fehler]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 19523 km
                    Date: 2023.04.24
                    Time: 15:49:47
                    Terminal 30 power supply: 14.0 V
                    Terminal 15: On
multumesc
Modificat de wildserb
O problema pe linia de Lin. Ce manifestari are masina?
Nu porneste start/stop, in rest nimic, ma streseaza erorile....
Unde gasesc lin-ul :)
Verifica conectorii din spatele farului pe partea soferului. Pe acolo trece un Lin .
  On 25.04.2023 at 17:12, wildserb a scris:
Expand
Mufa mica de pe borna de minus, a bateriei, este conectata?
Bateria este in stare foarte buna?
Valorile nu sunt modificate, ca sa fie dezactivat start stop ul?
@Florin, mufa mica de pe borna - este conectata, am curatat-o si cu sprey contact.
S/S nu e dezactivat din meniu, pe multimedia la meniul S/S scrie: Necesarul de energie al vehiculului este mere.
Despre baterie nu stiu mare lucru, masina am cumparat-o in decemnbrie.
Exact acelasi mesaj (Necesarul de energie...) imi aparea cand bateria "era pe moarte". Poti sa testezi asta zi prin pornirea climei(AC) si sa vezi daca la scanare vezi o eorare intermitenta ca nu a avut suficient curent ca sa porneasca si compresorul AC (mie imi aparea - in special dimineata in timpul iernii).
Daca nu ai schimbat bateria as recomanda oricum sa o schimbi.
  On 26.04.2023 at 4:12, wildserb a scris:
Expand
scoate mufa de la modulul de pe cablul de minus si vezi ce eroare apare. daca nu se modifica baga mufa inapooi si scoate mufa de la alternator. Ai schimbat cumva al;ternatorul sau releul de incarcare ?
@Al Bundy am scos mufa mica de pe terminalul negativ de pe baterie a mai aparut o eroare, dupa reconctare am sters-o.
eu nu am umlat la alternator sau releu incarcare.
          U1030 00 [008] - Electrical Malfunction
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 117
                    Mileage: 19523 km
                    Date: 2023.04.24
                    Time: 15:49:47
                    Terminal 15: On
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 77
                    Mileage: 19558 km
                    Date: 2023.04.26
                    Time: 18:22:40
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
Vezi ce e cu alternatorul sau releul de incarcare.
Da, alternator poate sa fie,  de regula le inlocuiesc cu modele care nu sunt compatibile si de aici apare eroare si nu lucreaza start stop
multumesc, verific azi tipul si incarcarea alternatorului.
Salutare.Mi s a aprins check engine si am aceasta eroare.Aveti idee daca afecteaza regenerarile sau altceva,mai pot circula ceva timp?Acele pete de langa egr nu imi aduc aminte sa le fi avut o avea vreo legatura, e cablajul sau pompa? aveti idee care este codul ei? cod motor cbab passat b6.
009754 - Pompa lichid rãcire 2
               P261A - 000 - întrerupere - intermitent - MIL aprins
             împrejurãri cod:
                    Stare defect: 10100000
                    Prioritate defect: 2
                    Frecvenþa defect: 3
                    Resetare contor: 255
                    rulaj: 270026 km
                    Indicator de timp: 0
                    Data: 2023.05.10
                    timp: 07:26:09
             împrejurãri cod:
                    RPM: 920 /min
                    vitezã: 0.0 km/h
                    tensiune: 14.21 V
                    valori binare: 00000000
                    lambda: 95.5 %
                    temperaturã: 10.8*C
                    temperaturã: 12.6*C
Schimba pompa recirculare. Da,afecteaza buna functionare a motorului. Unele iau limp mode,altele nu fac regenerare.
5N0965561A - acesta este piesa?
Nu am acum acces la Etka dar la orice magazin de piese auto pot filtra dupa Vin si vor gasi codul piesei.
  On 06.03.2023 at 5:43, spido a scris:
De cate ori a reincercat Ecu sa faca readaptarea pozitiei clapetei Egr.  Se inlocuieste Egr in cazul tau.
Expand
Luni am înlocuit EGR (+ restul distracției) la reprezentanta din Craiova și totul pare să fie ok. Mâine sper să am timp să vă dau mai multe detalii (poze, factură, etc).
David Ioan Bogdan
Salutare oameni buni.
Am si eu eroarea asta pe OBD si cu check engine aprins in bord:
01. Engine control unit01. Engine control unit
DTCs: 1
28388 [0x006EE4]
P26F400: Coolant Pump "C" Control, Circuit/Open
Status bits: 1
Priority: 2
Frequency: 48
Unlearning index: 255
Odometer: 233423 km
Date, time: 2023.04.25 05:54:29
Engine RPM: 1941 rpm
Calculated engine load value: 56.08 %
Vehicle speed: 51 km/h
Engine coolant temperature: 44 ℃
Engine oil temperature: 51 ℃
Barometric pressure: 14.648811538707 psi
Klemme 30 voltage: 14
Paramteric values:  20 96 28 18 A7 25 07 16 25 0B 0F 13 BA 00 00 CD 6E
Status: Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
banuiesc ca e o pompa auxiliara dar care din ele?
Multumesc frumos!
FA o diagnoza cu vcds si aflii exact care e. sau cu odis. Si daca nici asa nu-ti dai seama, scoti mufa de la fiecare si vezi cand obtii aceeasi eroare.
identitate78
Mi s-au aprins in mers la aprox 80Kmph, in rampa si curba martorii din imagine. Am continuat drumul cu ei aprinsi(100km) pana la destinatie.
Ieri, la intoarcerea spre casa s-au stins in primi km si nu s-au mai aprins deloc pana acasa(300 Km).
Aveti idee care ar putea fi problema? Daca nu mai apare, mai pot merge asa aprox 1000 Km pana se implineste termenul sa schimb si lichidul de frana?
Erorile memorate sunt urmatoarele:
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
   Component: J104   C2 450M VD35 0024
   Revision: --H07---    Serial number: 00000005799422
   Coding: 0007612
   Shop #: WSC 05311 000 00000
   VCID: 77F63B62061C878640-8022
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00111000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 290624 km
                    Time Indication: 0
                    Date: 2017.10.16
                    Time: 17:15:07
             Freeze Frame:
                    Speed: 88.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.50 V
                    Bin. Bits: 00011111
                    Count: 35
                    Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 92
                    Mileage: 290624 km
                    Time Indication: 0
                    Date: 2017.10.16
                    Time: 17:15:17
             Freeze Frame:
                    Speed: 85.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148
   Component: J500__APA-BS KL.310 1101
   Revision: 1AH03735    Serial number: 00121360032201
   Coding: 0000258
   VCID: 3D7AE94A64A06DD65A-8068
1 Fault Found:
01316 - ABS Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 92
                    Mileage: 290624 km
                    Time Indication: 0
                    Date: 2017.10.16
                    Time: 17:15:08
             Freeze Frame:
                        Term 15 On
                    RPM: 1813 /min
                    Speed: 87.0 km/h
                    (no units): 7.0
                    Voltage: 13.20 V
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000000226985
   Coding: 0022167
   VCID: 3668F6664196BE8E9B-8062
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 92
                    Mileage: 290624 km
                    Time Indication: 0
                    Date: 2017.10.16
                    Time: 17:15:07
             Freeze Frame:
                    Voltage: 13.40 V
                    Count: 105
                    Speed: 86.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
Ai un senzor ABS cu probleme.
