zorg
Vezi daca ai tensiune pe sig Sb 33,32 si 45 din cutia compartiment motor.Daca nu, verifica releul 167 tot de acolo.
Pe Sb? Nu-mi dai seama care sunt.
Modificat de Silviu18
E scris numarul sigurantei linga fiecare. Vezi F32,F33..
Modificat de spido
Pai pe F32,F33 si F45 nu am sigurante.?
Lasa-mi datele masinii pe PM si caut mai tarziu.An/cod motor/marca.
salutare,
am si eu2erori care nu se sterg, pe 6D tTrunk, rezultate in urma unui retrofit la portbagaj ectric
si inca una pe faruri.
masina este passat  B8 sedan
apreciez orice recomandare,  multumesc.
      Address 6D: Trunk Elect.       Labels: 5Q0-959-107.clb
Control Module Part Number: 5Q0 959 107 D    HW: 5Q0 959 107 D
  Component and/or Version: HDSG-Modul    H12 0233
           Software Coding: 0168
            Work Shop Code: WSC 00015 115 00001
              ASAM Dataset: EV_DeckLidCONTIAU736 001009 (VW48)
                       ROD: EV_DeckLidCONTIAU736_VW27.rod
                      VCID: 39799BE6B859948C1F-806C
Fault Codes have been Erased
2 Faults Found:
0006 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 64
                    Mileage: 66288 km
                    Date: 2020.02.02
                    Time: 15:41:13
0017 - Switch for Locking of Read Lid
          B1545 29 [009] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 64
                    Mileage: 66288 km
                    Date: 2020.02.02
                    Time: 15:41:13
si:
  Address 55: Headlight Range       Labels: 7P6-907-357.clb
Control Module Part Number: 7P6 907 357 C    HW: 7P6 907 357 B
  Component and/or Version: AFS-ECU       H01 0110
           Software Coding: 039A00004F200200
            Work Shop Code: WSC 33291 001 1048576
              ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001 (VW48)
                       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
                      VCID: 3F8DF5FEA67DBABC21-806A
1 Fault Found:
13705995 - Databus
          U1123 00 [009] - Received Error Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 64
                    Mileage: 66288 km
                    Date: 2020.02.02
                    Time: 16:00:36
Acum, daca iti vede la diagnoza portbagajul electric, vezi de ce nu vede switch ul respectiv si ce probleme ai la codare.
dar despre care switch este vorba,  cel de la incuiatoare? sau cel de la buton?
cum sa vad ce probleme s la codare, sa intru pe Lon Coding in 6D ?
multumesc
Modificat de cascadoru
Da, de la.butonul de inchidere care l-ai montat
Da, pe.6d
Cand mai scanezi scoate Aggressive mode la autoscan ca-ti mai da erori ciudate gen
13705995 - Databus
Nu cred ca ai nimic la Xenoane, si mie-mi mai apare eroarea dar de cand debifez agressive mode nu mai apare.
Legat de eroare de switch poate ca trebuie sa-i faci basic settings, uite aici, poate ca scapi si de cealalta dupa basic settings:
http://wiki.ross-tech.com/wiki/index.php/VW_Touareg_(7P)_Trunk_Electronics
am scos agresive mod si tot ramane eroarea pe faruri, in fine, o sa vad eu cu asta
la ^D nu ma lasa sa fac  Basic Setings
Revin cu update la erorile postate de mine Duminica.Se pare ca de vina pt seria de erori  a fost releul 167.Schimat releu, sters erori si momentan nu-mi mai  apare EPC in bord.Mii de multumiri Mr.Spido pt info si suport.
Am si eu urmatoarele erori. Ce ma sfatuiti sa fac?
1. Verificat firul de comanda pana la compresor
2. Nimic. Prea scump senzorul, pt nimic rezultat
Ma puteti ajuta cu un sfat indrumare cu privire la erorile de mai jos ? Masina in cauza este un Audi A3 2004, Benzina ,2.0, 150CP, AXW si din pacate nu este in tara :( :
Numar VIN: WAUZZZ8P34A176279   rulaj: 206540km
Adresa 01: Motor        Eticheta: ROJ\06F-906-056-AXW.clb
   Numar VAG SW: 06F 906 056 CP    HW: Hardware No
   Component: MED9.5.10        00 5787
   Revizie: 00000000    Numar serial: AUX7Z0D4FN40MP
   Codare: 0000072
   Atelier: WSC 06435 000 00000
   VCID: 79F95BE530D9558292-802C
   Subsistem 1 - Numar VAG: 06F 907 807 F
   Component: NOX  1509290025 004 0409
   06F907807F  NOX  1509290025 004 0409
2  coduri de defecte:
18057 - Bus de date tren rulare lipsã semnal de la
            P1649 - 008 - modul ABS - MIL aprins
18354 - Modul comandã 1 pentru ventilatot
            P1946 - 004 - defect
Gata de functie: 1010 0101
Adresa 03: ABS frâne
Nu poate fi accesat
Adresa 09: Electr. centrala        Eticheta:. ROJ\8P0-907-279-23-H.clb
   Numar VAG SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H30 0501
   Revizie: 00030000    Numar serial: 00000000763918
   Codare: 098ECF0080141000000000000000000000
   Atelier: WSC 00000 000 00000
   VCID: 3B7581ED7A65A792C0-806E
   Subsistem 1 - Numar VAG: 8P1 955 119 C  Eticheta: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Codare: 16711696
   Atelier: WSC 00000
1 cod a gasit:
00924 - Releu pentru sistem spãlare faruri -J39-
            009 - întrerupt/scurt la masã
Adresa 17: Instrumente bord        Eticheta: ROJ\8P0-920-xxx-17-MY7.clb
   Numar VAG SW: 8P0 920 930 G    HW: 8P0 920 930 G
   Component: KOMBIINSTR. VDO H25 0150
   Revizie: D10         Numar serial: 2244DD10031745
   Codare: 0004103
   Atelier: WSC 80093 222 69422
   VCID: 366390D941477AFA3F-8062
00562 - Senzor nivel/temperatura ulei -G266-
            008 - semnal neplauzibil
             împrejurari cod:
                    Stare defect: 00000011
                    Prioritate defect: 6
                    Frecventa defect: 2
                    Resetare contor: 150
                    rulaj: 206544 km
                    Indicator de timp: 0
                    Data: 2019.12.13
                    timp: 01:59:11
            010 - întrerupt/scurt la plus
             împrejurari cod:
                    Frecventa defect: 1
                    rulaj: 206544 km
                    Data: 2019.12.13
                    timp: 01:59:11
Adresa 19: Poarta CAN         Eticheta:. ROJ\1K0-907-530-V1.clb
   Numar VAG SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revizie: 08          Numar serial: 25001044210377
   Codare: 3D0F0342070100
   VCID: 285F4EA19BF31C0ABD-807C
1 cod a gasit:
01316 - Modul comandã frâne
            004 - lipsã semnal/nu comunicã
             împrejurari cod:
                    Stare defect: 01100100
                    Prioritate defect: 2
                    Frecventa defect: 1
                    rulaj: 206544 km
                    Data: 2019.12.13
                    timp: 02:08:25
Adresa 44: Asistenta directie        Eticheta: 1Kx-909-144-G2V2.clb
   Numar VAG: 1K1 909 144 F
   Component: EPS_ZFLS Kl.9       1301
   VCID: 2E53B8B9B917423A77-807A
00625 - Semnal vitezã vehicul
            004 - lipsã semnal/nu comunicã - MIL aprins
             împrejurari cod:
                    rulaj: 6520 km
                    temperatura: 26.0*C
                    tensiune: 14.20 V
                    tensiune: 14.00 V
00778 - Senzor unghi volan -G85-
            000 - -
             împrejurari cod:
Adresa 46: Confort        Eticheta: ROJ\8P0-959-433.clb
   Numar VAG: 8P0 959 433 B
   Component:    KSG          H02 0040
   Codare: 008800186D288505484A016000
   Subsistem 1 - Component:   Sounder n.mounted
   Subsistem 2 - Component:       NGS n.mounted
   Subsistem 3 - Component:      IRUE n.mounted
1 cod a gasit:
01312 - Bus date tren de rulare
            013 - Citiþi vã rog memoria de defecte
Sfârsit------------------------(Timp scurs: 01:29)-------------------------
Multumesc anticipat!
E posibil sa fie vorba si de o masa proasta? Si daca ma poti ajuta si la restul :)
Modificat de gogota69
E posibil chiar si o  masa.
Mai are un senzor temp ulei defect sau cablaj deteriorat(e pe baia ulei) si o siguranta arsa/releu spalatoare faruri.Restul sunt legate de Abs.
On 8/3/2019 at 12:49 PM, zebrocksky said:
Salutare tuturor.Postez o scanare la un Passat B8 2015 1.6d la care au cedat senzorii de parcare,pilotul automat,start-stopul si distronicul.Camera marsarier fctioneaza,la fel ca si celelalte.Multumesc anticipat.
sper ca nu e cu intarziere....am rezolvat cu inlocuirea senzorului luat nou,pe original....celalate variante din dezemembrari nu au fctionat
Atasez un Log cu erorile de la masina mea. Toate se sterg si nu apar la rescan,dar apar dupa un drum cu masina..
Fuel flap actuator l-am schimbat cu unul sh,a mers o buna perioada, dar a aparut iar.
Log-TMBAJ7NE9E0105707-138861km-86284mi.txt
Schimba actuatorul cu unul nou.S-ar putea sa existe revizie imbunatatita. Ptr celelalte erori-ai cumva un incarcator de telefon,tableta...mp3 player in locas bricheta? Scoate-l,sterge erorile si vezi daca mai apar.
Da. Am o tripla, dar are un buton de oprit... O sa-l scot cand o las oprita...
Dar eroarea pe Auto HVAC ce reprezinta?
Modificat de bogdan_vw_11
Am verificat toate sigurantele, Am verificat masa si am schimbat pompa de ABS :). Acum imi functioneaza vitezometrul dar m am procopsit cu alte erorii si imi stau aprins martori de ABS, ESP si Frana (!).
  • Aerofan pinned this topic
    • LoliSor
