zorg
Salutare!
Aveti vreo parere?
1 Fault Found:
590082 - Control Circuit for A/C Compressor
          B10A9 15 [009] - Open or Short to Plus
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 89
                    Mileage: 126655 km
                    Date: 2019.01.27
                    Time: 17:59:46
                    Outside air temperature: -1.0 °C
                    Engine speed: 0 /min
                    Compressor shut-off requirement: Outside air temperature too low
                    Compressor current: actual value: 0.020 A
                    Compressor current: specified value: 0.000 A
Verifca cablajul și conector
Am verificat sigurantele + cablaj cat am putut.Dupa mai multe stergeri succesive eroarea s a schimbat putin,apare temperatura corecta acum.
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 128757 km
                    Date: 2019.03.17
                    Time: 16:27:44
                    Outside air temperature: 21.0 °C
                    Engine speed: 700 /min
                    Compressor shut-off requirement: Compressor activation: malfunction in activation path
                    Compressor current: actual value: 0.115 A
                    Compressor current: specified value: 0.820 A
fire intrerupte sau electrovalva cu probleme.
Azi am pornit spre austria si la 3-4 km de casa nu a mai tras motorul de loc. Am oprit masina si am pornit din nou fara sa mai faca figuri pana in austria. Acum masina merge super, nu are probleme. Am pus testerul pe ea si am gasit aceste probleme. Ce poate avea? Codurie le-am sters si nu au mai aparut.
Adresa 01: Motor        Eticheta: ROJ\045-906-019-AMF.clb
   Numar VAG: 045 906 019 C
   Component:  1,4l R3 EDC G000SG  1479
   Codare: 00002
   Atelier: WSC 31414
   VCID: 152177556F8191E216-4B18
   WVWZZZ9NZ2D023757     VWZ7Z0A4441076
3  coduri de defecte:
17911 - Semnal de la alternator fir DF
            P1503 - 35-00 - neplauzibil
16485 - Debitmetru aer -G70- semnal neplauzibil
            P0101 - 35-10 -  - intermitent
17964 - Control de supra-încãrcare
            P1556 - 35-00 - deviaþie negativã
Gata de functie: 0 0 X X X
Va salut.
Incep prin a preciza ca deocamdata nu am pus testerul pe masina, abia marti o sa pot sa fac asta.
Azi, in timp ce veneam spre casa, in timpul mersului mi s-au aprins martorii de la esp, abs si presiunea in pneuri, toti odata.Am tras pe dreapta, am oprit motorul, l-am repornit, ramanand aprins doar abs-ul, care dupa aproximativ 100 m, s-a stins.Au mai urmat alte opriri/porniri, fara probleme.Nu se simte nicio modificare a mersului masinii.
O sa pun maine seara, sau marti cel tz testerul sa vad daca s-a stocat vreo eroare.
Pana atunci, "la prima vedere", aveti idee despre ce ar putea fi?Multumesc.
Modificat de Irinel9
în urmă cu 21 ore, Irinel9 a scris:
Va salut.
Am facut azi o scanare si am gasit urmatoarea eroare:
00287 - ABS Wheel Speed Sensor, Rear Right G44.
               003 - Mechanical Failure - Intermittent
Am sters-o si nu a mai reaparut la urmatoarea scanare.Inteleg ca este vb de senzorul ABS pe dreapta spate.De la ce ar fi putut sa apara?
Alte erori legate de ABS, ESP sau senzorii de presiune nu are.
Nu e senzorul de vina ci butucul cu inelul de citire care e ruginit,oxidat...
Multumesc, spido.
In curand o sa schimb placutele de frana si o sa-i spun mecanicului sa curete de rugina si oxidare tot ce este pe acolo.
NU are ce curata acolo, inelul este din cauciuc si are insertii magnetice. Se schimba impreuna cu rulmentul.
Modificat de Al Bundy
Inelul separat nu se poate schimba?Presupun ca este vb despre acest inel:
Salutare! Am si eu o problema cu al meu passat b6, diesel din 2008, BMP, si am eroarea 005213 exhaust gas temperature sensor 3 P145D - 000 - short to plus intermittent . Nu se sterge deloc eroarea! Este permanenta. Va rog sa imi dati un sfat
Modificat de Vyorel08
In poza ai pus altceva..
Verifica/inlocuieste senzorul de temperatura de pe evacuare.
Scuze, era o poza de la o alta problema,rezolvata intre timp. Nu pot incarca poza corecta pentru ca este prea mare ca dimensiune. Voi inlocui acel senzor si apoi mai vedem ce va fi. Multumesc
Buna ziua.La o skoda octavia 3,  4x4, 150cp, motor 2000, mi s-a aprins martorul motor(galben), masina functioneaza fara probleme. La o scanare au aparut urmatoarele   erori( care au putut fi sterse).  Cum  trebuie sa fac?
Vineri,22,Martie,2019,14:48:22:00007
VCDS -- Emulator VAG/VAS bazat pe Windows. Ediþie în Românã Ruleazã pe Windows 7 x64
Versiune VCDS: ROJ 18.9.0.2
Versiune date: 20181004 DS296.0
www.vcds.ro
Numãr VIN: TMBLJ7NE9F0196729   Nr.înmatriculare: 1
rulaj: 204277km   Numãr foaie de lucru:
Tip caroserie: NE-SK37 (5Q0)
Adrese de scanat: 01 03 08 09 10 15 16 17 19 22 42 44 52 55 5F 6D A5
Numãr VIN: TMBLJ7NE9F0196729   rulaj: 204277km
01-Motor -- Status: Malfuncþie 0010
03-ABS frâne -- Status: OK 0000
08-Clima automatã -- Status: Malfuncþie 0010
09-Electr. centralã -- Status: OK 0000
10-Asist.direcþ./parc. -- Status: OK 0000
15-Airbaguri -- Status: OK 0000
16-Electronicã volan -- Status: OK 0000
17-Instrumente bord -- Status: OK 0000
19-Poarta CAN  -- Status: OK 0000
22-AWD  4x4 -- Status: OK 0000
42-Electr. uºa ºofer -- Status: OK 0000
44-Asistenþã direcþie -- Status: OK 0000
52-Electr. uºa pasag -- Status: OK 0000
55-Bãtaie far -- Status: OK 0000
5F-Electronicã info. -- Status: OK 0000
6D-Electronicã haion -- Status: OK 0000
A5-Frt Senz. Asistªof -- Status: OK 0000
Adresa 01: Motor (J623-CKFC)       Eticheta:. ROJ\04L-907-309-V1.clb
   Numãr VAG SW: 04L 906 021 EA    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 8126
   Revizie: 83H22---
   Codare: 11190012032601090000
   Atelier: WSC 55964 107 00000
   Pachet ASAM: EV_ECM20TDI01104L906021EA 002007
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 68DF0EA19373DC0A7D-803C
1 cod a gãsit:
19206 - Sistem recirculare gaze evacuare
          P0401 00 [237] - flux prea mic
          MIL aprins - Confirmat - Testat de la ºtergere de memorie
             împrejurãri cod:
                    Stare defect: 00000001
                    Prioritate defect: 2
                    Frecvenþa defect: 35
                    rulaj: 202694 km
                    Data: 2019.03.06
                    timp: 09:35:19
                    Turaþie motor: 2407.00 /min
                    Valoare de sarcinã normatã: 19.2 %
                    Viteza vehicul: 58 km/h
                    Temperatura antigel: 80 °C
                    Temperatura aer admisie: 74 °C
                    Presiune aer ambiental: 920 mbar
                    Tensiune terminal 30: 14.840 V
                    Numãrãtor procese de adaptare nereuºite conform OBD: 40
                    Sup.recirc.gaze arse 1 bloc 1: debit masic - val.prescrisã: 0.0 kg/h
                    Sup. recirc. gaze arse 1 bloc1: feedback poziþie - val. efect.: 0.00 %
                    Sup.recirc.gaze arse 2 bloc 1: debit masic - val.prescrisã: 98.0 kg/h
                    Sup. recirc. gaze arse 2 bloc1: feedback poziþie - val. efect.: 99.46 %
                    El. exec. clap.gaze arse 1 bl1: feedback poziþie - val. efect.: 75.34 %
                    Cantitate aer pe debitmetrul 1.: 125.0 kg/h
                    Sondã lambda 1 bloc 1 în fa?a Oxi-Kat: valoare brutã: 2.5679
Gata de funcþie: 1 1 0 0 0
Adresa 03: ABS frâne (J104)       Eticheta: 5Q0-907-379-ESP-V1.clb
   Numãr VAG SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revizie: 00000000    Numãr serial: 60505000000752
   Codare: 1C07629124290972007E070241CC293846249000E08294F200630070C009
   Atelier: WSC 73430 031 00063
   Pachet ASAM: EV_Brake1UDSContiMK100ESP 034033
   ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
   VCID: 479DED1DFEADF37254-8012
Nu a gãsit coduri.
Adresa 08: Clima automatã (J255)       Eticheta:| ROJ\5G0-907-044.clb
   Numãr VAG SW: 5E0 907 044 L    HW: 5E0 907 044 L
   Component: Climatronic   H03 0907
   Revizie: 00001K06
   Codare: 02010104002100011005000000101000
   Pachet ASAM: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 2E53B8B97117423A77-807A
   Unitate de comandã ventilator de climatizare (faþã):
   Senzor presiune ºi temperaturã agent frigorific:
   Senzor pentru calitatea aerului:
328196 - Motor reglaj clapetã temperaturã dreapta
          B108D 71 [008] - actuator blocat
          intermitent - Confirmat - Testat de la ºtergere de memorie
             împrejurãri cod:
                    Frecvenþa defect: 1
                    Resetare contor: 33
                    rulaj: 203928 km
                    Data: 2019.03.19
                    timp: 13:21:37
                    Tensiune terminal 30: 12.4 V
                    Temperatura exterioarã: 17.5 °C
                    Temperatura interioarã: 30.9 °C
                    Clapã temperaturã dreapta- valoare mãsuratã: 40
                    Clapã temperaturã dreapta- valoare mãsuratã: 6.5 %
                    Clapã temperaturã dreapta- valoare calculatã: 21
1048834 - Limitare de funcþionare; prin management de energie
          B10CD 00 [008] - -
          [Proprietate nouã! Date extinse coduri UDS sunt suportate numai de gener. nouã de interfeþe]
             împrejurãri cod:
                    Prioritate defect: 7
                    Frecvenþa defect: 2
                    Resetare contor: 5
                    rulaj: 202494 km
                    Data: 2019.02.27
                    timp: 21:32:21
                    Tensiune terminal 30: 11.2 V
                    Încãlzire suplimentarã a aerului: în trepte-Permisiune regim încãlzire auxiliarã: nu este permis
                    Încãlzire suplimentarã a aerului: în trepte-Valoare efectivã: 1
                    Încãlzire suplimentarã a aerului: în trepte-Valoare specificatã: 3
                    Încãlzire suplimentarã a aerului: în trepte-Valoare prescrisã reglare: 3
1048835 - Limitare de funcþionare din modul comandã motor
          P1719 00 [008] - -
             împrejurãri cod:
                    Prioritate defect: 6
                    Frecvenþa defect: 10
                    Resetare contor: 24
                    rulaj: 202502 km
                    Data: 2019.02.27
                    timp: 22:38:13
                    Tensiune terminal 30: 13.9 V
                    Încãlzire suplimentarã a aerului: în trepte-Permisiune regim încãlzire auxiliarã: Autorizare treapta 3
                    Încãlzire suplimentarã a aerului: în trepte-Valoare specificatã: 1
                    Încãlzire suplimentarã a aerului: în trepte-Valoare prescrisã reglare: 1
Adresa 09: Electr. centralã (J519)       Eticheta:| ROJ\5Q0-937-08X-HV1.clb
   Numãr VAG SW: 5Q0 937 086 AE    HW: 5Q0 937 086 AE
   Component: BCM PQ37BOSCH 028 0145
   Revizie: --------    Numãr serial: 86581902151543
   Codare: 0C000B46424722FB4FE44004001C17080000000000000000000000000000
   Atelier: WSC 73430 790 00000
   Pachet ASAM: EV_BodyContrModul1UDSBosc 014004
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DF14FF5ECF169A2BE-8028
   Unitate de comandã motor ºtergãtoare:
   Subsistem 1 - Numãr VAG SW: 5E1 955 119     HW: 5E1 955 119   Eticheta: ROJ\5QX-955-119-V1.CLB
   Component: WWS371 150212  041 0570
   Numãr serial:         150215235045
   Codare: 065DDD
   Senzor ploaie/luminã:
   Subsistem 2 - Numãr VAG SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Eticheta: ROJ\5Q0-955-547.CLB
   Component: RLHS  037 0059
   Numãr serial: S4Y15M02D26H17M30S13
   Codare: 028877
   Senzor umiditate relativã_internã:
Nu a gãsit coduri.
Adresa 10: Asist.direcþ./parc. (J791)       Eticheta:| ROJ\5Q0-919-283.clb
   Numãr VAG SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revizie: --------    Numãr serial: 39291505000331
   Codare: 0001050001
   Pachet ASAM: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_002_VW37.rod
   VCID: 3A7B84E9BD5F9E9ADB-806E
Nu a gãsit coduri.
Adresa 15: Airbaguri (J234)       Eticheta:| 5Q0-959-655.clb
   Numãr VAG SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revizie: --------    Numãr serial: 003P4P3SGXJR
   Codare: 98CCC000000000005C5400CC000800000065
   Pachet ASAM: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0DB5FDE6FD7BB2AC-802A
   Senzor impact airbag DF:
   Subsistem 1 - Numãr VAG SW: -----------    HW: 454 000 802 15
   Component: SideSensor_Df  008 0887
   Numãr serial: 3576U000000CA3842318
   Codare: 2D2D2D
   Senzor impact airbag  lateral DF:
   Subsistem 2 - Numãr VAG SW: -----------    HW: 454 000 802 15
   Component: SideSensor_Pf  008 0887
   Numãr serial: 3586U00000043C842313
   Codare: 2D2D2D
   Senzor impact airbag lateral SS:
   Subsistem 3 - Numãr VAG SW: -----------    HW: 454 801 102 15
   Component: SideSensor_Dr  111 0148
   Numãr serial: 3516R2DCFD505000000L
   Codare: 2D2D2D
   Senzor impact airbag  lateral DS:
   Subsistem 4 - Numãr VAG SW: -----------    HW: 454 801 702 15
   Component: SideSensor_Pr  111 0148
   Numãr serial: 3526R1FC3DA05000000G
   Codare: 2D2D2D
   Senzor impact airbag SF:
   Subsistem 5 - Numãr VAG SW: -----------    HW: 454 801 302 15
   Component: FrontSensor_D  114 0149
   Numãr serial: 3556V67D6D705000000L
   Codare: 2D2D2D
Nu a gãsit coduri.
Adresa 16: Electronicã volan (J527)       Eticheta:| ROJ\5Q0-953-549.clb
   Numãr VAG SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revizie: --------    Numãr serial: 19021504400483
   Codare: 1400
   Pachet ASAM: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 77FD5DDDCECD43F2E4-8022
Nu a gãsit coduri.
Adresa 17: Instrumente bord (J285)       Eticheta:| ROJ\5G0-920-XXX-17.clb-SRI3
   Numãr VAG SW: 5E0 920 751     HW: 5E0 920 751
   Component: KOMBI         304 4270
   Codare: 07A40800E984000801086A021000000000000000
   Atelier: WSC 73430 031 00000
   Pachet ASAM: EV_DashBoardVDDMQBAB 009037
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 62CB1C89754FB65AA3-8036
Nu a gãsit coduri.
Adresa 19: Poarta CAN  (J533)       Eticheta:| ROJ\5Q0-907-530-V1.clb
   Numãr VAG SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revizie: --------    Numãr serial: 0003173868
   Codare: 030100040F087300EF00024A080F00010001050000000000000000000000
   Pachet ASAM: EV_GatewLear 011020
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 72EB6CC9A5AF26DAD3-8026
   Alternator:
   Volan multifuncþional:
   Subsistem 2 - Numãr VAG SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H05 0130
   Numãr serial: 000000000C1072300115
   Modul de comandã pentru control baterie:
   Subsistem 3 - Numãr VAG SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Component: J367-BDM  H08 0223
   Numãr serial: 52026B54334291415827
Nu a gãsit coduri.
Adresa 22: AWD  4x4 (J492)       Eticheta:* 0CQ-907-554.clb
   Numãr VAG SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Numãr serial: HA1-00014.01.15
   Codare: 0001
   Pachet ASAM: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X.rod
   VCID: 4683E019F9A7EA7AAF-8012
Nu a gãsit coduri.
Adresa 42: Electr. uºa ºofer (J386)       Eticheta:| ROJ\5QX-959-X93-42.clb
   Numãr VAG SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Numãr serial: 0000138505104
   Codare: 00110920D000040000001100
   Pachet ASAM: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 4581E715C4A1E162A6-8010
   Drivers Door Rear Control Module:
   Subsistem 1 - Numãr VAG SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Eticheta: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Numãr serial: 00000000000005165990
   Codare: 010200
Nu a gãsit coduri.
Adresa 44: Asistenþã direcþie (J500)       Eticheta:| ROJ\5Q0-909-144.clb
   Numãr VAG SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1061
   Codare: 1103
   Pachet ASAM: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB_012_VW37.rod
   VCID: 4385F90DCA95DF5288-8016
Nu a gãsit coduri.
Adresa 52: Electr. uºa pasag (J387)       Eticheta:| ROJ\5QX-959-X92-52.clb
   Numãr VAG SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Numãr serial: 0000138527923
   Codare: 00110120D000040000001100
   Pachet ASAM: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 4487FA11CF9BD86AB1-8010
   Passengers Rear Door Control Module:
   Subsistem 1 - Numãr VAG SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Eticheta: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Numãr serial: 00000000000005289467
   Codare: 190200
Nu a gãsit coduri.
Adresa 55: Bãtaie far (J745)       Eticheta:| ROJ\7P6-907-357.clb
   Numãr VAG SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revizie: --------    Numãr serial: --------------
   Codare: 03EA00003F010000
   Atelier: WSC 73430 790 00063
   Pachet ASAM: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 408FF601DB83C44A95-8014
   Unitate de putere far stânga:
   Subsistem 1 - Numãr VAG SW: 1T0 941 329 B    HW: 1T0 941 329 B  Eticheta: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Codare: 3E0000
   Unitate de putere far dreapta:
   Subsistem 2 - Numãr VAG SW: 1T0 941 329 B    HW: 1T0 941 329 B  Eticheta: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Codare: 3E0000
Nu a gãsit coduri.
Adresa 5F: Electronicã info. (J794)       Eticheta:| 5E0-035-MIB-HGH1.clb
   Numãr VAG SW: 5E0 035 020 D    HW: 5E0 035 020 C
   Component: MU-H-ND-EU    H44 0370
   Numãr serial: A313B0F7546493
   Codare: 03730201FF0000001111120100A800002F0000C401000100F6
   Pachet ASAM: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_SK37.rod
   VCID: 183F7E61E393AC8A0D-804C
   Unitate de operare ºi afiºare 1 pt bloc electronic de informare:
   Subsistem 1 - Numãr VAG SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H60 0030
   Numãr serial: SKZ8Z9PT600LAA
   Suport de date:
   Subsistem 2 - Numãr VAG SW: V03 959 800 MD    HW: -----------
   Component: ECE 2015  --- 0098
   Numãr serial: --------------------
Nu a gãsit coduri.
Adresa 6D: Electronicã haion (----)       Eticheta:| ROJ\7N0-959-107.clb
   Numãr VAG SW: 5E0 959 107 A    HW: 5E0 959 107
   Component: HDSG-Modul    H01 0746
   Revizie: 42001001    Numãr serial: 040500884
   Codare: 1233074002
   Pachet ASAM: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 2A5BB4A94DFF2E1AAB-807E
Nu a gãsit coduri.
Adresa A5: Frt Senz. Asistªof (R242)       Eticheta:| ROJ\5Q0-980-653.clb
   Numãr VAG SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Numãr serial: 10000303559
   Codare: 0101010001030303000400000000000100
   Pachet ASAM: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B7581EDB265A792C0-806E
Nu a gãsit coduri.
Sfârºit------------------------(Timp scurs: 04:24)-------------------------
Log-1-TMBLJ7NE9F0196729-204277km.txt
Verifica/ curata EGR.Incearca sa postezi doar erorile ca sa poata fi mai usor de urmarit.
Salutare, am si eu o problema la auto hold, imi da eroare in mers si dupa ce repornesc motorul dispare.La motor e dusa sonda lambda? Merci!
OBDeleven istoricul masinii
Jurnal: 2019-03-25 17:41
    VIN: WVWZZZAUZFP528478
    Masina: Volkswagen Golf GTD
    An: 2015
    Body type: Variant
    Motor: CRBC 110 kW (150 HP) 2.0 l
    Mile: 190671 KM
Fault
    Unitate de comanda: 13 Adaptive Cruise Control
    Active faults: 0
    Inactive faults: 2
    descriere sistem: ACC Bosch MQB
    Număr software: 5Q0907572D
    versiune software: 0304
    număr hardware: 5Q0907572D
    versiune hardware: H05
    număr serial: 23071403210980
    ODX nume: EV_ACCMRRBoschVW372
    ODX versiune: 001015
    Erori:
        U112300 - Databus error value received
            Intermittent
            Intermittent
    Mile: 190671 km
    Jurnal: 2019-03-25 17:20
    Unitate de comanda: 03 Brakes
    Active faults: 0
    Inactive faults: 1
    descriere sistem: ESC
    Număr software: 5Q0907379M
    versiune software: 0571
    număr hardware: 5Q0907379H
    versiune hardware: H31
    număr serial: 61984000000573
    ODX nume: EV_Brake1UDSContiMK100IPB
    ODX versiune: 033001
    Erori:
        C100E13 - Right parking brake motor voltage supply Open circuit
            Intermittent
    Mile: 190671 km
Fault
    Unitate de comanda: 08 Air Conditioning
    Active faults: 1
    Inactive faults: 0
    descriere sistem: Climatronic
    Număr software: 5G0907044AN
    versiune software: 0907
    număr hardware: 5G0907044AN
    versiune hardware: H03
    ODX nume: EV_ACClimaBHBVW37X
    ODX versiune: 003018
    Erori:
        P171900 - Function restriction by engine control module
            static
    Mile: 190639 km
    Jurnal: 2019-03-20 17:41
Fault
    Unitate de comanda: 01 Engine
    Active faults: 0
    Inactive faults: 1
    descriere sistem: R4 2,0L EDC
    Număr software: 04L906021DT
    versiune software: 7545
    număr hardware: 04L907309D
    versiune hardware: X22
    ODX nume: EV_ECM20TDI01104L906021DT
    ODX versiune: 002007
    Erori:
        P223700 - O2 Sensor Positive Current Control Circuit Bank 1 Sensor 1 Open
            Intermittent
    Mile: 190500 km
    Jurnal: 2019-03-08 16:06
Modificat de Zabin
Ai o problema pe alimentarea sondei..acum poate fi conector cu pini oxidati,cablaj deteriorat,chiar  si sonda defecta. La AH- verifica motoras frina dreapta spate.
Despre ce deviație e vorba? Se poate regla sau e doar semn de uzură la ceva?
Address 01: Engine        Labels: 038-906-019-AJM.lbl
   Part No: 038 906 019 J
   Component: 11,9l R4 EDC  0000SG  1087
   Coding: 00002
   Shop #: WSC 00020
   VCID: 1E3368799AB7D2BAC7-4B18
1 Fault Found:
17965 - Charge Pressure Control
            P1557 - 35-10 - Positive Deviation - Intermittent
Readiness: 0 0 X X X
Inseamna presoune prea mare facuta de turbina. Verifica geometria turbinei...e blocata.
Mulțumesc. Într-adevăr, turbina e blocată de o vreme încoace.
Va salut. Am revenit cu doua erori care nu-mi dau pace. La o skoda octavia 3 , tdi,2.0 , 110 kw mi se aprinde martorul galben (motor), dupa o perioada se stinge singur.Atasez erorile . Ce ar trebui sa fac? Va multumesc.
                Adresa 01: Motor       Eticheta: ROJ\04L-907-309-V1.clb
    Numãr piesã modul comandã: 04L 906 021 EA    HW: 04L 907 309 D
    Component ºi/sau versiune: R4 2,0L EDC   H22 8126
                  Codare soft: 11190012032601090000
                Numãr atelier: WSC 55964 107 00000
              Pachet ASAM: EV_ECM20TDI01104L906021EA 002007 (SK37)
1 cod a gãsit:
          P0401 00 [109] - flux prea mic
             împrejurãri cod:
                    Frecvenþa defect: 9
                    rulaj: 204573 km
                    Data: 2019.03.27
                    timp: 14:13:04
                    Turaþie motor: 2293.50 /min
                    Valoare de sarcinã normatã: 63.9 %
                    Viteza vehicul: 101 km/h
                    Temperatura antigel: 89 °C
                    Temperatura aer admisie: 98 °C
                    Presiune aer ambiental: 1010 mbar
                    Tensiune terminal 30: 13.400 V
                    Sup.recirc.gaze arse 2 bloc 1: debit masic - val.prescrisã: 93.1 kg/h
                    Sup. recirc. gaze arse 2 bloc1: feedback poziþie - val. efect.: 93.79 %
                    El. exec. clap.gaze arse 1 bl1: feedback poziþie - val. efect.: 64.26 %
                    Cantitate aer pe debitmetrul 1.: 180.4 kg/h
                    Sondã lambda 1 bloc 1 în fa?a Oxi-Kat: valoare brutã: 1.7878
Gata de funcþie: 0 1 0 0 0
   Revizie: 00001K06
1 cod a gãsit:
          P1719 00 [008] - -
             împrejurãri cod:
                    Frecvenþa defect: 1
                    Resetare contor: 42
                    rulaj: 204763 km
                    Data: 2019.03.30
                    timp: 06:58:30
                    Tensiune terminal 30: 13.3 V
                    Încãlzire suplimentarã a aerului: în trepte-Valoare efectivã: 2
Posibil EGR blocat sau pierderi/fisuri pe circuitul EGR.
  • Aerofan pinned this topic
    • costivio91
