zorg
Revin  asupra mesajului anterior
Am depistat problema care cauza cele patru erori si anume o siguranta arsa in tabloul de sigurante. Schimbat scanat sters erori    deplasare 15 km scanat din nou ..... OK masina functioneaza normal.
Modificat de dorumarcel
Este posibil ca erorile de mai jos sa fi aparut in mod normal in momentul in care am schimbat placute/discuri fata? Operatiunea s-a facut in reprezentanta si mecanicul nu a conectat diagnoza.
La acel moment s-a mai facut testul de frana si test rulmenti(pentru a avea informatia completa). Avand VCDS clona, pe baza Km si a orei din dreptul fiecarei erori sunt 99% ca in acea dimineata au aparut erorile.
Cu ajotorul vostru sper sa fiu 100% sigur. ?
Multumesc anticipat.
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
   Component: J104   C2 450M VD4A 0024
   Revision: --H07---    Serial number: 00000005799422
   Coding: 0007612
   Shop #: WSC 05311 000 00000
   VCID: 77F63B62061C878640-8023
3 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 201736 km
                    Time Indication: 0
                    Date: 2013.06.23
                    Time: 07:56:33
             Freeze Frame:
                    Speed: 203.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.50 V
                    Bin. Bits: 00011111
                    Count: 18
                    Hex Value: 0x0000
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 201736 km
                    Time Indication: 0
                    Date: 2013.06.23
                    Time: 07:56:33
             Freeze Frame:
                    Speed: 203.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.50 V
                    Bin. Bits: 00011111
                    Count: 19
                    Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 201736 km
                    Time Indication: 0
                    Date: 2013.06.23
                    Time: 09:07:52
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Voltage: 14.50 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 1101
   Revision: 1AH03735    Serial number: 00121360032201
   Coding: 0000258
   VCID: 3D7AE94A64A06DD65A-8069
1 Fault Found:
01316 - ABS Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 86
                    Mileage: 201736 km
                    Time Indication: 0
                    Date: 2013.06.23
                    Time: 07:56:33
             Freeze Frame:
                        Term 15 On
                    RPM: 2005 /min
                    Speed: 195.0 km/h
                    (no units): 7.0
                    Voltage: 14.80 V
L.E. Merci mult @F l o r i n. Mi-ai dat si acel 1% care sa ma linisteasca complet.
Modificat de identitate78
este de la testul de frana efectuat. nu-i nicio panica, sterge erorile si atat
Salutare.
Pentru cele de mai jos ma poate ajuta cineva cu o explicatie mai detaliata ?
Mentionez si ca nu pot accesa deloc modulul Central Conv. Imi poate spune cineva de ce ? Am inteles ca se mai blocheaza cateodata si ca ar trebui resetat scotand borna de la baterie. Sa incerc si eu varianta asta ?
Masina este cea din semnatura.
                Address 01: Engine       Labels: 03G-906-016-BKC.lbl
Control Module Part Number: 03G 906 021 SC    HW: 03G 906 021 AN
  Component and/or Version: R4 1,9L EDC G000SG  1438
           Software Coding: 0050071
            Work Shop Code: WSC 06402 785 00200
                      VCID: 72EC018A6D3461D1EF-8026
1 Fault Found:
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 126118 km
                    Time Indication: 0
                    Date: 2035.14.06
                    Time: 02:04:15
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.93 V
                    Bin. Bits: 00101100
                    Temperature: 9.9°C
                    Bin. Bits: 00110000
Readiness: 0 0 0 0 0
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 086     HW: 5K0 937 086
  Component and/or Version: BCM PQ35 M    008 0019
           Software Coding: 46180A3C982508C00280008095008104057100A8427D81605C8040000000
            Work Shop Code: WSC 04941 000 00000
                      VCID: 71EE0E86A8325AC916-8024
2 Faults Found:
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 70
                    Mileage: 126275 km
                    Time Indication: 0
                    Date: 2035.14.08
                    Time: 05:50:28
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.50 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00893 - Switch for Trunk Handle (E234)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 70
                    Mileage: 126275 km
                    Time Indication: 0
                    Date: 2035.14.08
                    Time: 05:50:28
Modificat de Johnny
1. nu ai 46...ai doar 09-bcm
2. schimba bujia de pe cil 4. De fapt, recomand pe toate 4.
3. verificati switch-ul de la portbagaj - daca iti face probleme......
Salut Florin. Si cea cu Terminal 15 Relay de la ce este sau ce pot sa ii fac ?
Salut...ma poate ajuta cineva...trebuie schimbat egr ul ? Mentionez ca la pornire se aprindea bujia incadescenta apoi disparea...ulterior si martorul de motor...ms!
erori : 14355 -P 242 A
             9852 -P 242 B vw golf 6 1.6 tdi 105 cp
Modificat de Mariusneagaa
Mentionare auto
ce probleme are ?
Pai nu are nici o problema grava zic eu. Nu ramane nimic in bord aprins sau altceva. Dar totusi apare aceasta eroare si nu ma pricep de la ce este.
ai sters-o si tot apare?
salut. revin cu problema mea care se pare ca se repeta si anume mi se arde siguranta nr 14 din tablou cea responsabila de motor. Atasez log si foto cu pozitia sigurantei din tablou. Care sa fie motivul pentru care aceiasi siguranta se arde la interval de trei zile????
log 08.03.2019.txt
ce masina. ce an, ce cod motor?
8 minute în urmă, Al Bundy a scris:
Polo 9n an 2003 1.4 tdi  55kw/75 cp cod motor BAY
Va rog sa ma ajutati pentru a putea remedia erorile de mai jos.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 0F: Digital Radio
Cannot be reached
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C055100163
Coding: 7DFD3C44C71002
Shop #: WSC 05311 123 12345
VCID: 2149030FF83C3116BBD-8074
1 Fault Found:
02649 - Digital Radio Tuner
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 243061 km
Time Indication: 0
Date: 2019.03.13
Time: 20:29:58
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 DX
Component: Radio 0030
Coding: 0010400
Shop #: WSC 72320 143 04009
VCID: 7EF318732902AEEEE6F-802B
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 E HW: 3C0 035 729 C
Component: Telefon 6009
Revision: 00008000 Serial number: 0000000628044
Coding: 0016143
VCID: 2541171FEC14DD36C75-8070
2 Faults Found:
02791 - Telephone baseplate (R126)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 243061 km
Time Indication: 0
Date: 2019.03.13
Time: 20:29:56
01524 - Antenna for Telephone
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 243061 km
Time Indication: 0
Date: 2019.03.13
Time: 20:29:56
Ce va pot spune, si ce cred eu ca are legatura cu o parte din erorile de mai sus, este ca acum pe masina este montat un MFD2, dar stiu ca vechiul proprietar a avut montat si un RNS 510 (sper sa nu gresesc modelul)
Din ce am reusit eu sa mai citesc pe aici, e posibil sa fi efectuat ceva codari pe acolo pentru RNS.
Daca va mai sunt necesare si alte informatii va rog sa imi spuneti.
debifeaza 0F din can gateway.
Modificat de Al Bundy
Multumesc pentru raspunsul prompt, inca nu stiu cum se face asta ?, e prima mea masina din grupul VW, si ieri a a fost prima utilizare a unui VCDS, dar o sa mai sap eu legat de asta.
Totusi, inteleg ca asta rezolva si erorile legate de telefon?
Modificat de lupo_bv
quote postare anterioara
Te duci pe 19 cam gateway, install list, debifezi, salvezi și gata
saluatare... am si eu astea:
trebuie inlocuit ceva? am avut ceva pocnituri in bord, cred ca atunci cand am luat erorile astea .... acum nu mai pocneste nimic,
erorile le am sters cu succes (pentyru moment), sa ma pregatesc de ceva piese de inlocuit?
multumesc.
Address 08: Auto HVAC       Labels: 5G0-907-044.clb
Control Module Part Number: 5G1 907 044     HW: 5G1 907 044
  Component and/or Version: Climatronic   H03 1001
           Software Coding: 11020104202100012115500C00101002
            Work Shop Code: WSC 00015 115 00001
              ASAM Dataset: EV_ACClimaBHBVW37X 003018 (VW48)
                       ROD: EV_ACClimaBHBVW37X_003_VW48.rod
                      VCID: 65CBC07D64C8326A2F-8030
2 Faults Found:
328198 - Position Sensor for Right Temperature Flap Motor
          B1095 11 [008] - Short to Ground
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 123
                    Mileage: 47298 km
                    Date: 2019.03.13
                    Time: 18:31:24
                    Voltage terminal 30: 14.5 V
                    Outside air temperature: 9.0 °C
                    Interior temperature: 20.8 °C
                    Right temperature flap: actual value: 226
                    Right temperature flap: actual value: 98.5 %
                    Right temperature flap: specified value: 226
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 46962 km
                    Date: 2019.02.27
                    Time: 07:40:23
                    Voltage terminal 30: 14.0 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.value: 3
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
Motoras reglare temperatura dreapta.
Multumesc, Cristi.
Zici ca ar fi de schimbat? Sau sa astept sa vad daca mai face?
Doar daca nu lucreaza corespunzator, inlocuiesti.
multumesc Florin.
si am mai avut si erorile astea... le am sters dar nu stiu de ce apar.
multumesc
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 026 ET    HW: 04L 907 309 R
  Component and/or Version: R4 2.0l TDI   H21 1990
           Software Coding: 011D0012036405083000
            Work Shop Code: WSC 43231 183 00000
              ASAM Dataset: EV_ECM20TDI01104L906026ET 002002 (VW48)
                       ROD: EV_ECM20TDI01104L906026ET_002.rod
                      VCID: 0005F1E99BAAF742BC-8054
2 Faults Found:
5244 - Fuel Pressure Sensor (G247)
          P0193 00 [032] - Short to Plus
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 47311 km
                    Date: 2019.03.13
                    Time: 22:58:05
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 53 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 12.600 V
                    Unlearning counter according OBD: 38
                    Engine status: COENG_FINISH
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [032] - Signal too High
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 47311 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Coolant temperature: 74 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 12.520 V
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 4131.2 hPa
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
ai umblat pe la mufe, ceva ?
  • Aerofan pinned this topic
    • orca
    • LoliSor
