zorg
am scanat si eu masina azi dupa destul de mult timp si am gasit niste erori, ciudate, intrucat totul pare functional.. asadar unde ma uit sa de ce au aparut?
o fi simptome ca e bateria pe duca (e cea originala, are 6 ani deja, masina fiind 10.2011)...
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 FA    HW: 5K0 907 044 FA
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0004001803
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_VW36.rod
   VCID: 6FF4C2CFE79DF5FAF63A1D1-803A
1 Fault Found:
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 25
                    Reset counter: 193
                    Mileage: 198823 km
                    Date: 2017.09.05
                    Time: 19:10:41
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 E    HW: 3AA 937 087 E
   Component: BCM PQ47 H+   413 0455
   Revision: BC413001
   Coding: 000A00000000000000180080540029F423D50088626DA560E480C7240041
   Shop #: WSC 05311 000 00000
   VCID: 3C6E2583E66B5EE20338425-8068
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 06061  10  0603
   Coding: 00B795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 060711 05  54  0403
   Coding: 02302A
1 Fault Found:
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 4
                    Fault Frequency: 40
                    Reset counter: 181
                    Mileage: 197107 km
                    Time Indication: 0
                    Date: 2011.12.21
                    Time: 11:06:30
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.15 V
                        ON
                        ON
                        ON
                        OFF
                        ON
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 F    HW: 1T0 035 680 F
   Component: RNS-MID       H61 4120
   Revision: AB001001    Serial number: VWZ6Z7N3226020
   Coding: 04000402040000A00011
   Shop #: WSC 24511 133 86875
   VCID: 317004B73129A38AA08ECB9-8064
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V13  8350
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 194
                    Mileage: 193569 km
                    Time Indication: 0
                    Date: 2011.10.06
                    Time: 09:26:16
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 194
                    Mileage: 193569 km
                    Time Indication: 0
                    Date: 2011.10.06
                    Time: 09:26:16
Nu au legatura cu bateria.Senzor calitate aer defect,un bec ceata ars pe stinga,antena gps defecta.Sterge erorile,schimba becul si vezi daca mai apar celelalte 2 legate de senzor si antena.
Modificat de spido
Le-am șters și le monitorizez, dar cum sa stocheze eroare de bec ars când eu în bord nu l-am văzut aprinzi și farurile de ceata ard bine mersi? Iar GPS ul merge ceas, abia ce m-am întors de la Cracovia pe drumuri lăturalnice nu pe autostrada??
Erorile sunt ceva mai vechi.Sterge-le si vezi daca mai apar.Antena are o problema dar poate fi functionala in continuare.Mai apar erori din astea
...sunt specifice.
va salut,
de curand am schimbat si eu rcd310 cu rns315 , primul il avea masina in dotare cand am cumparat-o , al doi-lea l-am avut pe raposatul meu b6 .
azi m-am uitat putin prin calc. cu vcds-ul si am observat eroarea asta , care nu am avut-o dupa instalarea rns-lui.
                Address 37: Navigation       Labels: 1K0-035-27x-37.clb
Control Module Part Number: 3C8 035 279 R    HW: 3C8 035 279 R
  Component and/or Version: RNS315-EU   H80 0500
           Software Coding: 0400041102000B0000031102
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_RNS315EUV2UDS 001705 (VW46)
                       ROD: EV_RNS315EUV2UDS.rod
                      VCID: 3A7A0A74BD5F989684-806E
1 Fault Found:
1048647 - Cellular Antenna
          B1053 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 100
                    Mileage: 76567 km
                    Date: 2078.14.31
                    Time: 15:32:42
orice sugestie este binevenita, multumesc.
On 11.09.2013 at 11:06 AM, F l o r i n said:
masina porneste ?
verifica sa nu ai scurt intre liniile K si W de la imobilizator sau modulul imobilizatorului defect.
Am și eu eroarea ăsta 01202 la un lupo 3l.mă poți te rog îndruma la ce as putea face?
Unde sunt liniile ăsta K și W??
În caz de defect de imobilizator afectează și cheia.?
Mașină mea pornește  merge...Dar uneori moare motorul fără nici o explicație. Multumesc anticipat pt sfaturi.
Nu are legatura oprirea in mers cu imobilizatorul - acesta nu te-ar lasa sa pornesti. Dupa ce ai pornit, nu mai are treaba
salut, dupa o scanare am gasit urmatoarele erori:
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0134
   Revision: 00002001    Serial number: 0110411650
   Coding: 011B062200390480002001
   Shop #: WSC 06325 000 00000
   VCID: 3068CB8263B813C159-8064
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
3 Faults Found:
01134 - Alarm Horn (H12)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 142562 km
                    Time Indication: 0
                    Date: 2017.03.28
                    Time: 16:03:49
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 142562 km
                    Time Indication: 0
                    Date: 2017.03.28
                    Time: 16:03:49
02616 - Fuel Tank Cap; Unlock
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 142562 km
                    Time Indication: 0
                    Date: 2017.03.28
                    Time: 16:23:35
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 J    HW: 8T0 035 223
   Component: DSP STD       H07 0210
   Revision: S1700000
   Coding: 0203010102
   VCID: 3566FA969CDA36E90A-8060
1 Fault Found:
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 71
                    Reset counter: 246
                    Mileage: 142562 km
                    Time Indication: 0
                    Date: 2017.03.28
                    Time: 16:18:10
             Freeze Frame:
                    Voltage: 11.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000001
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000010445451
   Coding: 011002205E01410001
   Shop #: WSC 00045 210 175712
   VCID: 3E74E5BAA9ECF5B1DB-806A
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 245
                    Mileage: 142562 km
                    Time Indication: 0
                    Date: 2017.03.29
                    Time: 06:20:23
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000006981329
   Coding: 010002204001210001
   VCID: 40889B42D3188341A9-8014
1 Fault Found:
02115 - Locking Unit for Central Locking
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 107
                    Reset counter: 245
                    Mileage: 151219 km
                    Time Indication: 0
                    Date: 2017.08.06
                    Time: 18:01:30
-Cum verific alarma?
- Dupa ce incui masina, cand apas pe capacul de la alimentare, inca se deschide, nu imi dau seama de ce, ca ar trebui sa nu, daca masina e incuiata!
- intr-adevar boxa aia nu merge!
- cum verific daca merge incalzirea in oglinzile laterale? Ca in Uk deocamdata nu am temperaturi ca sa inghete geamurile / oglinzile;
- nu stiu ce e exact la usa stanga spate ca se incuie si descuie oke.
Ceva pareri? Multumesc!
audi a4 b8 2.7tdi 2008
Porneste  încălzirea la oglinzi  și apoi pui mana pe ele.Se incălește dacă merge încălzirea în oglinda.
Unde as putea gasi o lista cu ce functii pot activa la masina si cum se face? Cand imi dau seama ca dpf-ul isi face regenerare?
Andrews- goarna alarmei e defecta.se poate verifica cu vcds la output test.Ai motorasul de incuiere/descuiere rezervor blocat.Sterge eroarea de la usa...si vezi daca mai apare.Exista lista cu functii ce se pot activa pe forum.Un pic de search..
De fapt, motorasul defect - nu incuie/nu descuie - la rezervor.
Yala - sa o verifici din cand in cand... cand va face figuri, atunci trebuie desfacuta si reconditionata - sau schimbata la voi in UK...daca nu gasesti oameni care se pricep ca o repare
Am sters erorile insa tot apar dupa o scanare. As vrea sa verific injectoarele si turbina, se poate? Parametri, sa vad daca totul e oke! Multumesc pt toate informatiile.
Valorile injectoarelor se vad in blocurile de masura.Ptr turbina-faci un log in mers.Vezi ca e topic dedicat log in mers.
salutare din nou. Am incercat sa vad valorile la injectoare insa butonul pentru blocurile de masura e inactiv. am mai butonat pe acolo si am gasit undeva unde sa-mi dea valorile injectoarelor si grafica, insa valorile tot fluctuau nu erau stabile. Stie cineva de ce e inactiv acea optiune?  de asemeni o rezolvare la eroarea afisata in poza atasata? Multumesc!
no bun. o sa merg sa vad. Insa cu eroarea afisata in imagine ai vreo parere? Rezolvare? Alta treaba e ca dpf-ul si-a facut ultima regenerare acum 425km, e oke? Sau e prea mult. Si cum stiu ca isi face regenerare? Multumesc!
Modificat de andrews
Posteaza erorile..nu ajuta acea poza.
Regenerarea se face automat,fiind pornita de ECU.Creste turatia la 900 ture+martor in bord.
eroarea  nu e de la masina, ci de la soft. Acea eroare ca nu a putut gasi fisierele .rod
Da,acum am vazut...nu pot face zoom pe poza...sunt pe telefon.E cauzata de interfata clona pe care o folosesti.
stii cumva daca as lua alta interfata daca ar fi oke? Sau sa gasesc acele fisiere pe net si sa le pun unde e instalat programul, va merge oke?
Poti lua o interfata originala,fireste.
Discutia despre clone e interzisa.
Martorul NU se aprinde in cazul regenerarilor uzuale ale masinii.
Insa cat de des isi face? La mine are 425 km de la ultima regenerare, e mult? e putin? merci
In functie de gradul de incarcare a filtrului,stilul de condus,face mai des sau nu.Martorul din bord  il aprinde la regenerare fortata,in mers normal-nu.
Multumesc ptr corectie colegului.
  • Aerofan pinned this topic
    • Adria_n
