zorg
Schimba siguranta SB23 de 10 A din cutia cu sigurante de langa baterie.
Salut!
Vă rog un pic de ajutor pentru următoarele erori apărute:
 Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 03G 906 018     HW: 03G 906 018
  Component and/or Version: R4 2.0l PPD1.1 G    9722
           Software Coding: 0050072
            Work Shop Code: WSC 10122 599 83379
3 Faults Found:
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
            P3101 - 009 - Open or Short to Ground - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 1
                    Fault Frequency: 10
                    Reset counter: 148
                    Mileage: 174593 km
                    Time Indication: 0
                    Date: 2016.08.14
                    Time: 15:29:05
             Freeze Frame:
                    RPM: 832 /min
                    Text:     24
                    Text: Nm
                    Text:
                    Voltage: 11.19 V
                    Text:   1016
                    Text: Nm
17075 - Fan 1 Control Circuit: Short to GND
            P0691 - 007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 10
                    Reset counter: 148
                    Mileage: 174593 km
                    Time Indication: 0
                    Date: 2016.08.14
                    Time: 15:29:13
             Freeze Frame:
                    Text:
                    Text:     24
                    Text: Nm
                    Text:
                    Voltage: 14.01 V
                    Load: 25.9 %
                    Temperature: 85.0°C
19558 - Motor for Intake Manifold Flap (V157): No Signal
            P3102 - 006 - Short to Plus - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100001
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 152
                    Mileage: 174607 km
                    Time Indication: 0
                    Date: 2016.08.16
                    Time: 16:29:26
             Freeze Frame:
                    RPM: 832 /min
                    Text:     40
                    Text: Nm
                    Text:
                    Voltage: 12.66 V
                    Text:    184
                    Text: Nm
Erorile au apărut cu trei zile în urmă la o pornire normală. În bord stă aprins permanent motorașul și intermitent spirala, ambele de culoare portocalie.
Azi am curățat EGR-ul dar nu au dispărut.
Mașina este ce-a din semnătură.
Mulțumesc anticipat.
Schimba clapeta de shut off. verifica siguranta aferenta ventilatoarelor si a clapetei.
Salutare! Va rog sa ma ajutati cu interpretarea unor coduri de eroare:
Address 01: Engine (J623-CRBC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 4943
   Revision: 83H22---
   Coding: 011D0032036405082000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002003
   ROD: EV_ECM20TDI01104L906021DT_VW37.rod
   VCID: 7AE3E543ACDFA05251A494D-802E
1 Fault Found:
5290 - Throttle Actuator Control Circuit
          P2100 00 [096] - Open Circuit
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 3613
   Revision: 05652103    Serial number: TFK01211091028
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1539D6FFA5816F2ADCB63F9-8040
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
             Freeze Frame:
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020104202100011105000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 367B3173D8478432F57C80D-8062
1 Fault Found:
327940 - Motor for Left Temperature Flap
          B108C 71 [008] - Actuator stuck
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 114
                    Mileage: 130778 km
                    Date: 2016.08.05
                    Time: 22:11:26
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5G0 920 870 A    HW: 5G0 920 870 A
   Component: KOMBI         336 0555
   Coding: 07A401086F94000800886A03040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   ROD: EV_DashBoardVDDMQBAB_AU37.rod
   VCID: 2745EC370FEDEDBA7EEA651-8072
2 Faults Found:
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 113
                    Mileage: 130693 km
                    Date: 2016.08.05
                    Time: 10:59:18
16777012 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 113
                    Mileage: 130693 km
                    Date: 2016.08.05
                    Time: 10:59:18
clapeta de acceleratie sau cablajul, sigurantele , etc
pe cutie ai o eroare legata de switch-ul care permite pornirea in functie de treapta in care e schimbatorul, posibil circuitul acestui switch.
pe clima, motorul care regleaza temperatura pe partea stanga este blocat
pe ceasurile de bord, s-a intrerupt comunicarea cu reteaua CAN si a aparut eroare.
Sterge-le si vezi daca mai apar, toate sunt intermitente.
Mulțumesc @Al Bundy, problema a fost siguranța SB23 de 10 A din cutia cu siguranțe din compartimentul motor. În manualul meu 3.3 nici nu există siguranța SB23.
Cu placere.
Salut!
@Al Bundy, am schimbat siguranta SB23 - 10A, si am refacut testul actuatori si aceeasi problema prezentata. Ce mai pot face?
Siguranta era arsa? Dupa ce ai schimbat-o s-a ars din nou ?
Nu, nu era arsa.
Si de ce ai schimbat-o?
Avea tensiune pe ea  ?
@Al Bundy, tu mi-ai zis să o schimb??
Esti sigur ca ai schimbat siguranta care trebuie?
Pune o poza cu locatia ei.
Am schimbat cele două siguranțe roșii, F23,F24
Modificat de wvirgil
@Al Bundy, sau altcineva, pareri?
toate cele 3 electrovalve sunt localizate in blocul de valve , situat langa baterie - piesa neagra cu multe furtunele in ea. Verifica mufa si firele pana la ECU. Cauta schema electrica si vezi ce fire si sigurante ai de verificat.
Modificat de andrei_221
Am si eu rugamintea de a ma ajuta cu interpretarea unor coduri de eroare. Mai exact la spalatorul de faruri este siguranta sau releul ars? Si unde este aceasta situata?
Friday,26,August,2016,17:14:15:13314
VCDS Version: Release 908.0
Data version: 20141103
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 7D
VIN: WVWZZZ1KZ5B084167   Mileage: 198910km/123596miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC G010SG  6176
   Revision: 12345678    Serial number: VWZ7Z0D1099391
   Coding: 0000071
   Shop #: WSC 12345 412 06402
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021121
   Shop #: WSC 00046 412 32768
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001352698
   Coding: 448B8F0600041800001400001400000000097B075C
   Shop #: WSC 00046 412 13598
   Part No: 1K1 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00046
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00046
2 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 07 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD023PS8
   Coding: 0012343
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 521 0050
   Coding: 0000042
   Shop #: WSC 00046 412 1540096
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 861 B
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0007103
   Shop #: WSC 59804 001 1048576
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104B120C4A
   Coding: 3D3F0B00070002
   Shop #: WSC 00046 412 15564
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VDD 0814
   Shop #: WSC 71340 136 81527
1 Fault Found:
01176 - Key
            008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0153
   Coding: 0000052
   Shop #: WSC 00046 412 1359872
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.2       1502
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 98C802087F2D8404084F01E010
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
End   ---------------------------------------------------------------------
Address 09:1K0 937 049 M recoded (Long Coding) from 448B8F0600041800001400001400000000097B075C to 408B8F0600041800001400001400000000097B075C
Address 09: DTCs cleared
Doar siguranta arsa.
Ai masurat daca ai tensiune pe sigurante ?
Victor77
este arsa siguranta spalatorului de fat, cutia cu sigurante in stanga bordului
Multumesc, o sa cumpar maine o siguranta sa o schimb! Cealalta eroare de la imobilizator nu poate fi stearsa
BUNA SEARA.La masina din semnatura ,golf 4 variant, 1.9. tdi atd, 74 kw, 4 motion, am facut o scanare si mi-au iesit urmatoarele erori. Mentionez ca acum  3 saptamani am schimbat distributia, , am completat cu freon( am avut ceva probleme cu siguranta de pe baterie-cea de 30 A , cred ca nu facea contact bine  penrtu ca la un moment dat nu mai baga aer rece si am schimbat-o pt ca era putin deformata), am schimbat flanse + rulmenti  amorizor fata , burduf planetara. Am sters codurile de eroare si am mers  aprox 1 km, codurile nu au aparut .   Astazi in mers la turatie  de aprox 2800-3000  se intampla ceva .......cam ca la batrana Dacie cand se infunda  jiglerul.Mentionezca pe bord nu s-a aprins nimic.
Log-DEEA-WVWZZZ1JZ2D096934-341350km.txt
Log-DEEA3-WVWZZZ1JZ2D096934-341350km.txt
Adresa 17: Instrumente bord        Eticheta: ROJ\1J0-920-xx5-17.clb
   Număr VAG: 1J5 920 846 C
   Componenta comandată: KOMBI+WEGFAHRSP VDO V05
   Codare: 21114
   Atelier: WSC 00000
   VCID: 30657B35F0C6FE9891C
   WVWZZZ1JZ2D096934     VWZ7Z0A3788938
8  coduri de defecte:
00771 - Senzor nivel combustibil -G-
            30-10 - Circ.deschis sau scurt la plus - intermitent
00779 - Senzor pentru temperatura exterioara -G17-
01128 - Bobina cititoare cheie -D2-
            35-10 - - - intermitent
01176 - Cheie
            07-10 - Semnal prea mic - intermitent
01314 - Modul de comanda motor
            49-10 - Nu este comunicare - intermitent
01316 - Modul de control ABS
01321 - Modul pentru comanda airbaguri -J234-
01336 - Bus de date pentru confort
Adresa 19: Poarta CAN         Eticheta: ROJ\6N0-909-901-19.clb
   Număr VAG: 6N0 909 901
   Componenta comandată: Gateway K<->CAN    0001
   Codare: 00006
   Atelier: WSC 31414
   VCID: F0E53B35B0463E9851C
6  coduri de defecte:
00778 - Traductor unghi volan -G85-
01324 - Modul pentru comanda 4x4 -J492-
Modificat de cornel75
Am urmatoarele doua erori la care am incercat sa gasesc un raspuns, dar dupa ce am citit vreo 20 de pagini din 130, nu prea am inteles mare lucru.
Am un Passat B5.5 cred, din 2005, cod motor BGW, 2.0, detin un cablu VAG908 si VCDS 9.08 deoarece ultima versiune nu detecteaza masina.
ce am facut (la service) pana acum pentru rezolvarea erorilor:
eroare1: schimbare bujie deoarece aveam inainte eroarea: 17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault P0671 , verificare cablaj
eroare2: schimbare coolant sensor (dadea si el eroare si nu stiu daca are legatura cu problema - 16502 - Engine Coolant Temp. Sensor (G62): Signal too High), schimbare electrovana turbo care ramanea blocata si ramanea blocata si "clapeta" din cate imi aduc aminte ca a zis mecanicul, curatare EGR si alte furtune
manifestari:
eroare1: nimic sesizabil
eroare2: cand ies pe autostrada intra in limp mode, apare mesajul workshop engine si emissions workshop, iar ultima data se aprindea si becul de bujii
eroare1:
17054 - Glow Plug Module 1; Glow Plug Circuit: Electrical Malfunction
            P0670 - 000 -  -
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.01 V
                    Bin. Bits: 00001100
                    Temperature: 23.4°C
                    Bin. Bits: 00110000
eroare2:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
            P0234 - 000 -  -
             Freeze Frame:
                    RPM: 2961 /min
                    Torque: 296.0 Nm
                    Speed: 97.0 km/h
                    Load: 40.0 %
                    Voltage: 13.68 V
                    Bin. Bits: 00001000
                    Absolute Pres.: 2111.4 mbar
                    Absolute Pres.: 2590.8 mbar
Modificat de laurentiun
-vag-ul tau e interzis pe acest forum
-reparatiile facute nu au legatura cu eroarea 16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)-aici ai geometria care se  blocheaza,necesita curatare/inlocuire
-17054 - Glow Plug Module 1 -aici verifica cablaj si releu
de ce este interzis pe forum? l-am regasit pe site-ul ross tech deci este original
 Boost Pressure Regulation - asa o sa fac, multumesc.
17054 - Glow Plug Module 1 - cablajul a fost verificat, ramane sa schimb releul. se poate verifica releul ca sa nu il schimb degeaba?
Fa actualizare la 16.8.0 si o sa detecteze si masina ta
  • Aerofan pinned this topic
