zorg
Salutare, am gasit problema la Webasto, camera de ardere e plina cu cenusa sau calamina , mi-au spus ei de la service , acum nu stiu ce implica asta , pot sa o repar eu ? Se curata sau se schimba? Si la ce pret sa ma astept.
Multumesc ptr. vorbele voastre.
Se poate si curata dar nu garanteaza nimeni ca va merge ca una noua
De nou e in jur de 950 lei-ptr passat.
@nolimits: z35 defect-se refac lipiturile, semzor temp antigel dus, bujia 3 si 4. Sterge erorile si vezi ce mai ramane. Refaci setarile ptr geamuri. Ai ramas fara baterie de curand sau un nivel mic al acesteia.
Ok mersi mult, cred ca nou e cel mai bine.
Salutare, la o scanare cu VCDS am gasit 2 erori pe care nu prea le inteleg. :)
                Address 09: Cent. Elect.       Labels: 3C0-937-049-30-H.lbl
Control Module Part Number: 3C8 937 049 E    HW: 3C8 937 049 E
  Component and/or Version: Bordnetz-SG     H54 2602
           Software Coding: EF8A8F0700041A144F0000000F000000000B5D435C800120000000000000
            Work Shop Code: WSC 05124 123 12345
           Additional Info: 3C1955419A  Wischer 171008 004  0206   1K0955559AH RLS     080109 054  0402
                      VCID: 336F6E68522E776
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 53
                    Mileage: 232683 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.25 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
iar a doua eroare este legata de HVAC dar nu intleg ce inseamna ROD ????
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 3AD 907 044 C    HW: 3AD 907 044 C
   Component: Climatronic   H01 0102
   Revision: 00001001
   Coding: 0000014002
   Shop #: WSC 01973 973 01973
   ASAM Dataset: EV_ACClimaBHBVW411 A01001
   ROD: EV_ACClimaBHBVW411.rod
   VCID: 336F6E689A2E776
1 Fault Found:
13701424 - ROD - Unknown Error Code
          - 30 [009]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 233835 km
                    Date: 2077.14.23
                    Time: 18:46:55
Modelul de climatronic este cel de b7 cu 3 rotite.
Ceva pareri, opinii, idei ?
prima eroare = controlat contacte ,cablaj ,senzor .
a doua eroare = scaneaza cu o interfata originala
Ptr prima-sterge-o, daca ai activata functia de rain closing de acolo e. Stai linistit. Ptr a foua asa cum a spus si floro-nu ai fisierul rod-interfata ta fiind o clona versiune veche.
asa e am.activat rain closing. dar e vreo problema daca mai revine eroare sau se poate trai si cu eroare? am vazut ca eroare mai revine din cand de aceea întreb.
nu, nu are nicio treaba - e normal sa apara acea eroare - asa face toate..... :winter:
Apropo de discutia de mai sus am si eu eroarea de mai jos:
"Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000008874920
   Coding: E78F8F2700041500471400001400000000097F075C00010C000000000000
   Shop #: WSC 01357 011 00200
   VCID: 336F743952D0BCB9A29-8066
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     021008 054  0402
   Coding: 00479279
   Shop #: WSC 01357
1 Fault Found:
02382 - Sensor for Light Detection (G399)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 120620 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.60 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF"
Mentionez ca recent am dezactivat DRL Scandinavia, am activat Cornering cu proiectoarele si mai ales Rain Closing. Problema e ca dupa ce am dezactivat DRL si merg cu farurile pe Auto, acestea nu se sting ziua pe lumina decat din cand in cand (culmea e ca stau aprinse pe soare puternic si s-au stins pe vreme cu nori si burnita). Am incercat sa testez senzorul cu lanterna de la telefon si nu se stinge (cred ca lumina ar trebui sa fie suficienta).
Pana sa fac cele 3 chestii de mai sus nu am avut aceasta eroare si nici comportamentul senzorului - sesizam pe lumina ca se stinge bordul iar becul "Auto" de la comutator se facea verde.
Oare sa revin la setarile initiale? Mai ales ca acel rain closing e un moft din ce am constatat si as putea sa ma lipsesc de el.
Merci.
Au aparut si la mine cite erori dupa schimbul injectoarelor ce parere aveti
Address 91: LT3 Engine        Labels: 074-906-032.clb
   Part No SW: 074 906 032 BA    HW:
   Component: R5 2,5L EDC 0400SG  5176
   Revision: --H02---    Serial number: VWZDZ0F1005229
   Coding: 0003072
   Shop #: WSC 80093 222 71269
   VCID: 52A16208CD11808E727-8007
2 Faults Found:
005213 - Exhaust Gas Temperature Sensor 3
               P145D - 000 - Short to Plus
             Freeze Frame:
                    RPM: 714 /min
                    Torque: 63.4 Nm
                    Speed: 0.0 km/h
                    Voltage: 14.29 V
                    Temperature: 1.8°C
                    Temperature: 96.0°C
                    Temperature: 72.0°C
                    Temperature: 324.0°C
008194 - Particulate Trap Bank 1
               P2002 - 000 - Efficiency Below Threshold - MIL ON
             Freeze Frame:
                    RPM: 714 /min
                    Torque: 63.4 Nm
                    Speed: 0.0 km/h
                    (no units): 4.0
                    Duty Cycle: 14.6 %
                    (no units): 15.30
                    Temperature: 1.8°C
                    Time: 0.0 s
nu mai vrea sa faca nici o regenerare nimic
Address 91: LT3 Engine  (074 906 032 BA)
11:58:28
  216.0°C   Temperatur in Particle Filter
  15.30   Press. Difference Particle Filter
  -2.55   Press. Difference Offset
  15.0 %   Particle Filter Load Coefficient
  144.0   Particle Filter Carbon Mass
  0.0 %   Carbon Mass Learned Value
  4.0   Failed Regenerations
  0.0   Successful Regenerations
  114.0°C   Temperature bef. Turbo Charger
  102.0°C   Temperature bef. Particle Filter
vw Crafter 2.5 BJL
verifica cablajul la senzor - daca este ok, inlocuieste senzorul
Merci.
E cea mai simpla solutie, sa revii la setarile initiale.
CAblaj defect la senzorii de temperatura inca nu am gasit, schimba senzorul. Nu pune SH.
am gasit cablaj rontait in schimb.... hat-hat.... inainte de inlocuire, cel mai sigur e sa verifice.
Va salut, as vrea sa va expun si eu problema mea: de acum vreo 2 luni, intr-a 4-a si a 5-a nu mai trage, in bord se aprindea citeodata simbolul de motor iar azi a aprarut ENGINE WORKSHOP si clipeste simbolul de bujie. Am scanat si mi-au aparut niste erori. Ma puteti ajuta cu descifarea lor? Mai merg cu ea sau o trag pe dreapta ?
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ4W182403   Mileage: 212090km/131786miles
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0001025
   Shop #: WSC 01266 785 00200
   VCID: 336E9A3A2B5D
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01266
   VCID: 2142607281A1
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
            37-00 - Faulty
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 01266
   VCID: 22406F7E84A7
No fault code found.
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 826 C
   Component: KOMBI+WEGFAHRSP VDO V21
   Coding: 01112
   Shop #: WSC 00000
   VCID: 29527852F991
   WVWZZZ1JZ4W182403     VWZ7Z0D9401129
3 Faults Found:
01128 - Immobilizer Pickup Coil (D2)
            35-10 -  -  - Intermittent
01176 - Key
            07-10 - Signal too Low - Intermittent
01336 - Data Bus for Comfort System
            80-10 - Single-Wire Operation - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01266
   VCID: F0E4D5369ACB
1 Fault Found:
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799
   Component: 1F Komfortgerát HLO 0002
   Coding: 00259
   Shop #: WSC 01266
   VCID: F4ECD926EED3
   Part No: 1C1959801A
   Component: 1F Tõrsteuer.FS KLO 0202
   Part No: 1C1959802A
   Component: 1F Tõrsteuer.BF KLO 0202
   Part No: 1C0959811A
   Component: 1F Tõrsteuer.HL KLO 0202
   Part No: 1C0959812A
   Component: 1F Tõrsteuer.HR KLO 0202
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-10 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
            29-10 - Short to Ground - Intermittent
Address 56: Radio        Labels: 1J0-035-15x-56.lbl
   Part No: 1J0 035 153
   Component:  Radio BNO         0007
   Coding: 00001
   Shop #: WSC 00001
   VCID: DCBC91866643
End   ---------------------------------------------------------------------
Tocmai pe motor nu ai scanat, si nu ai erorile.
In urma montarii unui RCN210 in locul RCD300, m-am ales cu cateva erori si nu stiu daca asa e ok, sau am mai facut eu vreo minune pe acolo. Am folosit conector Y cu care am legat noua unitate la CAN-ul de la climatronic (firele portocaliu-verde si portocaliu-maro). Ideea e ca am pus si contactul cat timp am lucrat pt a folosi  lumina din plafoniera. Unele erori le-am sters, dar sunt cateva care reapar si nu inteleg de ce. Ma refer mai mult la
00470 - Combination comfort Databus in Single Wire
            011 - Open Circuit
sau
Aceasta este prima scanare, fara a sterge vreo eroare
Tuesday,01,October,2013,22:29:41:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ1KZ5W073600   License Plate:
Mileage: 191610km-119060mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC G000SG  6176
   Revision: 12345678    Serial number: VWZ7Z0D0537022
   Coding: 0000071
   Shop #: WSC 01279 785 00200
   VCID: 65C15716ACC1CB36075-8030
1 Fault Found:
18104 - Powertrain Data Bus
            P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.62 V
                    Bin. Bits: 00101100
                    Bin. Bits: 11000000
                    (no units): 3.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021121
   VCID: 3A7BD46A75FF94CE9A7-806F
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67DD5D1E56CDD926359-8032
2 Faults Found:
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000937308
   Coding: E4890F0600041800001400001400000000
   VCID: 3F8DA57E6EDDB1E6AD9-806A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00000
2 Faults Found:
01320 - Control Module for Climatronic (J255)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 01 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0JF53S
   Coding: 0012337
   Shop #: WSC 01268 785 00200
   VCID: 3169F346A88957962BD-8064
   Subsystem 1 - Serial number: 6332MSME4C751204
   Subsystem 2 - Serial number: 6342MSME460F2F05
   Subsystem 3 - Serial number: 6351HSME54486202
   Subsystem 4 - Serial number: 6361HSME5E0B6903
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000022
   VCID: 306FF642A3835E9E243-8065
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 851 B
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003103
   Shop #: WSC 62031 133 88909
   VCID: 275D1D1E964D1926F59-8072
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 27001048180552
   Coding: 3D3F0B40070002
   VCID: 29591B2680592F56E3D-807C
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 104
                    Mileage: 191572 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:59:24
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 101
                    Reset counter: 65
                    Mileage: 191572 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:26:08
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 191572 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:35:39
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 96
                    Reset counter: 65
                    Mileage: 191572 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:38:22
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 96
                    Reset counter: 65
                    Mileage: 191572 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:38:24
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0147
   Coding: 0000052
1 Fault Found:
            011 - Open Circuit
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.2       1401
   VCID: 2F6DF53EBEBD41663D9-807A
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0201
   Coding: 18E802087F2D8404084F0100
2 Faults Found:
            011 - Open Circuit
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
1 Fault Found:
            011 - Open Circuit
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
1 Fault Found:
            011 - Open Circuit
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
1 Fault Found:
            011 - Open Circuit
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D51EF36B4B133760F5-8078
Modificat de Mak17
pare ca ceva nu e ok - nu ai inversat cumva firele in mufa climatronicului sau in adaptor ?
sigurele erori care raman, sunt de comunicatie cu radio - avand in vedere ca el nu este conectat pe can infotainment.
Sa zicem ca le-am inversat, desi nu pot sa spun sigur...ar mai trebui sa functioneze ok si climatronicul si unitatea rcn? Pentru ca la mine functioneaza ok ambele.
cel mai bine - sterge toate erorile - intra pe fiecare modul unde ai erori - sterge - dupa care da-i autoscan sa vedem ce erori au ramas.
vad ca ai erori de circuit deschis si defective - pe liniile de can - ceea ce nu e normal - daca se conecta totul cum trebuie, nu trebuia sa existe aceste erori - deci, verifica bine conexiunile realizate, sterge erorile si vedem ce raman
vw sharan 2001 ,1,9 tdi,116 cp unde are modulul de confort?
este in stanga jos, sub bord. Acolo ai centrala electrica
nu ai modul separat - 46 - ca la alte modele - e pe 09 la tine.
Sharan 2001,1,9 tdi,116cp,auy.
Telecomanda are doar 2 butoane(inchis si jos deschis)
Am vazut ca se poate opta pentru inchiderea la o viteza de peste 15km/h,urca geamurile dupa inchidere,etc
Din 46 toate canalele sunt N/A.
Se poate face din 09?
Modificat de georgemarcu53
sharan 2001,1,9 tdi,116 cp,auy.
telecomanda are 2 butoane(inchis - deschis)
am incercat din 46 sa fac sa se blocheze usile la o deplasare cu peste 15km./h si nu am reusit.
imi spune ca nu comunica cu controlerul.
sa incerc pe all modul ?
@Florin,
Am rezolvat problema erorilor. Am verificat conexiunile si intr-adevar pusesem un cablu de la CAN in alt pin...bine ca nu s-au intamplat si alte minuni.
eu ti-am zis.... ma bucur ca s-a rezolvat.
nu ai 46-convenienta - ti-am scris mai sus.
la tine ai totul pe 09.
Salutare . Te pot ajuta eu cu o scanare .
  • Aerofan pinned this topic
    • CristianH
