zorg
Salut. In urma unei scanari am descoperit urmatoarele erori de mai jo... de la ce provin? ms
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Sporadic communication error 1000
19-CAN Gateway -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021121
   Shop #: WSC 01392 785 00200
   VCID: 3A7D42AA7528F3CE959-806F
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 CS
   Component: Climatic PQ35   081 0404
   Shop #: WSC 00000 000 00000
   VCID: 77FB9B9E06BA2EA6AA7-8022
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000967732
   Coding: 008B8F0600041800001400001400000000
   VCID: 3F8B33BE6E0AD6E6A27-806A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 01 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0HVMFS
   Coding: 0012337
   Shop #: WSC 01371 785 00200
   VCID: 316F6586A85E3096243-8064
   Subsystem 1 - Serial number: 6332MSME1B7D4C03
   Subsystem 2 - Serial number: 6342MSME0D494704
   Subsystem 3 - Serial number: 6351HSME64032603
   Subsystem 4 - Serial number: 6361HSME46005803
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 500 0030
   Coding: 0000002
   VCID: EFEB23FEFEEAE666F27-80BA
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 851 B
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0004101
   Shop #: WSC 42307 141 86084
   VCID: 275B8BDE969A7E26FA7-8072
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 27001048130452
   Coding: 3D3F4B40070002
   VCID: 295F8DE6808E4856EC3-807C
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 75213 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:19:18
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0147
   Coding: 0000052
   VCID: 30696082A354399E2BD-8065
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.2       1401
   VCID: 2F6B63FEBE6A2666327-807A
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0201
   Coding: 10E802087F2D8404084F0100
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 K
   Component: Radio GR0           0014
   Revision: 0001002S    Serial number: VWZ2Z2D1006795
   Coding: 0020200
   VCID: 2E557EFAB9602F6E391-807B
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 69: Trailer        Labels: 8P0-907-383.lbl
   Part No SW: 8P0 907 383     HW: 8P0 907 383
   Component: ANHAENGERELEKTR H01 0010
   Coding: 0000001
   VCID: F6E5169A81B0D7AE311-80A3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D5779F6B466547600B-8078
End   ---------------------------------------------------------------------
Care erori ?
eroarea asta...
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 75213 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:19:18
si asta...
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC 0200SG  6176
   Revision: 12345678    Serial number: VWZ7Z0D0388652
   Coding: 0000071
   Shop #: WSC 66565 257 00032
   VCID: 65C7C1D6AC16AC3608B-8030
2 Faults Found:
16785 - EGR System
            P0401 - 000 - Insufficient Flow
             Freeze Frame:
                    RPM: 1764 /min
                    Torque: 46.0 Nm
                    Speed: 44.0 km/h
                    Load: 16.9 %
                    Duty Cycle: 14.7 %
                    Bin. Bits: 11000000
                    Mass Air / Rev.: 230.0 mg/str
                    Mass Air / Rev.: 600.0 mg/str
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 182.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.93 V
                    Bin. Bits: 00000100
                    Temperature: 0.9°C
                    Bin. Bits: 00110000
Readiness: 1 1 0 0 0
prima o poti ignora.
la motor probabil ai membrana sparta la capsula egr si o bujie arsa
Bujie cil 3 si flux scazut egr.
La tine dupa ce scrie la freeze frame data,e blocat pe inchis,adica intra numai aer pur in motor.
Posibile cauze:egr blocat pe inchis,conducta egr obturata,fire,conectori,parte electrica/pneumatica de actionare egr,etc.
Mai multe detalii aici:
wiki.ross-tech.com/wiki/index.php/16785/P0401/001025
Modificat de mario20vest
Salut
Am si eu o problema cu un check engine care apare din cand in cand la drum lung. EGR a fost desfacut anul trecut in vara cand a aparut prima data eroarea si era curat. Sa sters eroarea si dupa ce am schimbat furnizor motorina ma lasat in pace un an dar ieri a aparut din nou: Masina merge bine.
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CASA)       Labels: 059-907-401-CAS2.clb
   Part No SW: 7P0 907 401     HW: 7P0 907 401
   Component: 3.0TDI EDC17  H15 0007
   Revision: 51H15---
   Coding: 292A4012232601020000
   Shop #: WSC 10103 599 96538
   ASAM Dataset: EV_ECM30TDI0117P0907401 002009
   ROD: EV_ECM30TDI0117P0907311.rod
   VCID: ECDD5CF00775B67ED8B-80B9
4 Faults Found:
4807 - EGR System
          P0401 00 [232] - Insufficient Flow
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 25
                    Mileage: 62851 km
                    Date: 2015.06.01
                    Time: 20:15:21
10062 - Fuel Pump
          P3044 00 [101] - Short Circuit
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 58061 km
                    Date: 2014.12.28
                    Time: 11:54:15
5619 - Engine Off Timer Performance
          P150A 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
4629 - ECM Power Relay Load Circuit: (J271)
          P068A 00 [032] - De-Energized Performance Too Early
salut .
am si eu o problema cu niste erori mai exact :
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ASR.lbl
   Part No: 6Q0 907 379 D
   Component: ABS/ASR 5.7 FRONT   V00
   Coding: 00124
   Shop #: WSC 13765
   VCID: 3E73D87A3AD7B8EEA6F-517A
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            35-10 - - - Intermittent
si
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 C
   Component: 06 Komfortgerát     0003
   Coding: 00067
   Shop #: WSC 13765
   VCID: 3B75D16E29C5ADC6811-4B36
   Subsystem 1 - Part No: 6Q1959801
   Component: 2Q Tőrsteuer.FS TFK 0002
   Subsystem 2 - Part No: 6Q1959802
   Component: 06 Tőrsteuer.BF TFK 0002
1 Fault Found:
01044 - Control Module Incorrectly Coded
            35-00 - -
la a doua banuiesc switch portiera ce nu mi se aprind becurile cand deschid usa si nici avertizarea pozitia pornita.
Prima e un senzor de ABS si cealalta , daca ai fi trimis si autoscan, te-am fi ajutat.
salut .
   Coding: 00067
   Shop #: WSC 13765
1 Fault Found:
            35-00 - -
eroarea este de la o codare incorecta - cel putin asta vede - nu are legatura cu switch-ul yalei, care nu iti functioneaza
Salut am si eu problema cu egr dupa ce am dato jos pt curatare(inainte nu dadea eroare)
Mai sunt si ceva probleme pe cilindru1, s-a schimbat axa cu came, culbutori, s-a inversat injectorul 1 cu 2 dar eroarea ramane tot pe nr1.Am reglat avansul pe -2.5 si se aude un tacanit daca accelerez brusc.Cu avans pe -4.5 nu mai face
Control Module Part Number: 03G 906 021 SK    HW: 03G 906 021 AN
  Component and/or Version: R4 1,9L EDC G200SG  1444
           Software Coding: 0050071
            Work Shop Code: WSC 04941 785 00200
                      VCID: 7AFB146A357F54CEDA7-802F
2 Faults Found:
001025 - EGR System
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 143504 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:14:19
             Freeze Frame:
                    RPM: 1911 /min
                    Speed: 68.0 km/h
                    Load: 27.8 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 100.2 %
                    Mass Air / Rev.: 250.0 mg/str
                    Mass Air / Rev.: 585.0 mg/str
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 143579 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:18:27
             Freeze Frame:
                    RPM: 840 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.98 V
                    Inj. Quantity: 2.92 mg/str
                    Temperature: 87.3°C
                    (no units): 0.0
post-91962-0-21696800-1433575162_thumb.j
post-91962-0-54164800-1433575162_thumb.j
post-91962-0-83252200-1433575162_thumb.j
Modificat de sumi1
la Egr verifica cu un furtunel daca tine capsula vacuum, si pe urma furtunele dr vacuum pana la capsula.
la acel cilindru ai o problema, incearca sa faci un test de compresie
Modificat de andrei_221
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
Ma poate lumina si pe mine cineva cu acesta eroare? Care este cauza si cum o pot remedia?
Salut baieti! Am o problema cu masina. Golf 5 1.9 TDI 90 HP. Acum 2 luni am avut aceleasi problema pe drum in austria, am fost la un service, a pus-o pe tester si a sters erorile(70E). 2 luni a tinut minunea, acum problemele au reaparut. Am fost azi la VW aici in localitate(austria) si m-au programat pe vineri. O sa atasez foaia de la tester de acum 2 luni, cred ca sunt aceleasi probleme avand in vedere ca masina se comporta la fel ca atunci. Probleme: cand este cald afara se aprinde becul galben(probleme la motor), motorul vibreaza ciudat si se aude ciudat, lipsa de putere. Dupa ce o opresc si o pornesc iar, merge bine o vreme....apoi rau din nou. Va rog sa imi spuneti macar daca e grav si cam la ce amenda(factura) sa ma astept. Va multumesc!!!
post-154146-0-97550800-1433940629_thumb.
Modificat de sebisoit
Fydo posteaza si modulul pe care a aparut respectiva eroare care te indeamna sa faci o scanare si pe Instrument Cluster.
Sebisoit intra pe link-ul asta si cauta dupa fiecare cod de eroare (ai acolo search in dreapta sus) si vei gasi posibilele cauze,ce sa verifici si cum sa remediezi problemele:
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Nu stiu la ce modul te referi, eu am facut o scanare generala si asta este singura care apare si nu se sterge.
Ai facut vreun retrofit gem schimbat ceasurile cu altele?mie imi apare asa deoarece am schimbat ceasuri immo 2 cu ceasuri immo 3 cu bc...
Nu le-am schimbat, nici macar nu le-am dat jos.
1 Fault Found:
CAre este eroarea de pe ceasuri ?
salutare.
 la o scanare de rutina am gasit urmatoarele:
01-Engine -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: OK 0000.
ERORILE AR FI:
                Address 19: CAN Gateway       Labels: 7N0-907-530-V2.clb
Control Module Part Number: 7N0 907 530 G    HW: 1K0 907 951
  Component and/or Version: J533  Gateway H41 1614
           Software Coding: 461006
            Work Shop Code: WSC 00028 028 00001
                      VCID: 34616A8B97B9BDBE40B-8061
1 Fault Found:
03927 - Function Restriction due to Driver Fatigue Recognition
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 119
                    Mileage: 139929 km
                    Time Indication: 0
                    Date: 2000.14.01
                    Time: 21:09:32
Address 42: Door Elect, Driver       Labels: 3C0-959-70X-GEN4.clb
Control Module Part Number: 3AA 959 701 A    HW: 3C0 959 793 C
  Component and/or Version: TUER-SG FT    002 0529
           Software Coding: 0210B7
            Work Shop Code: WSC 00028 028 00021
              ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001 (VW46)
                      VCID: 3567578F94C3A4B6775-8060
1 Fault Found:
66048 - Motor for Front Window Regulator
          B11EC 54 [008] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 139
Address 52: Door Elect, Pass.       Labels: 3C0-959-70X-GEN4.clb
Control Module Part Number: 3AA 959 702 A    HW: 3C0 959 792 C
  Component and/or Version: TUER-SG BT    002 0529
           Software Coding: 0210B6
              ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001 (VW46)
                      VCID: 3665508389C5AFAE7EF-8063
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 142
 despre ce este vorba, cat este de grav si daca se pot sterge efectiv folosind butonul CLEANER CODE.
pe bord, nu am nici un fel de eroare.
multumesc frumos.
Sterge=le linistit, si fa setarea de baza pentru motorasele de la geamuri.
multumesc.
imi poti spune te rog cum pot face setarea respectiva ?
Tii de buton geamuri in sus 3 sec dupa ce au ajuns la maxim, si la fel in jos.
multumesc frumos
Masina din semnatura imi face probleme .
Cand e cald afara si sta in soare, dupa aprox 5 minute de la pornire imi omoara clima, stergatoarele, claxon , semnalizare, faruri
Eroare pe 09 Central electric
Terminal 75x short to plus intermitent
Terminal 15 short to plus
Terminal 15 implausible signal
An schimbat releu ( cel cu 460)
Contact electric
Siguranta putere 80 amp.
Acelasi simptom aceleasi erori
Log complet pun mai tarziu vcds.
se poate masura cu vag-ul presiunea de ulei ??
  • Aerofan pinned this topic
    • Ady71
